  • juliankoenig87
  • juliankoenig87
07 Feb 2025 20:57
Replied by juliankoenig87 on topic scurve trajectory planner
Hi.
So, I tested the scurve with my loop machine for over 18 hourse. No crashes. And I really try to torture it with extreme values. I would call it a sucess and really good coding by Grotius. Well done.
I will go on and do some tests and thinking of backlash compensation this weekend. Have some thoughts but have to figure it out first.
  • notJamesLee
  • notJamesLee
07 Feb 2025 20:47
Replied by notJamesLee on topic Z Homing
Z Homing
Category: Basic Configuration
I've tried a bunch of more things.
I noticed it could possibly be a wiring issue but that just flipped the directions so you'll notice that the scale now has a different sign. I thought maybe i was getting confused by the min/max and it largely operating in the negative domain so I just changed it to operate from 0 ->4 and the max is 4.
I also messed around with the 'home offset' alot. trying 0, 0.1, -0.1, 3.9, -3.9 and no dice, so its now at 0.The last thing i changed was 'home' in the section above as a last ditch effort. I changed it to 4. The logic is when it hits the switch it considers max that it should do its final approach thing, back off then consider that home and set the DRO to 4. This isn't what happens.
 I noticed that when Z is homing, as soon as it hits the switch the DRO changes to zero and not 4. This is the opposite of what we'd expect but clear I've fat fingered something. Attached is the latest .hal and .ini .
side note: these motors give a lot of vibration and noise at slow speeds but it seems really nice and smooth at higher speeds (over 28 in/min) I'm not homing at these speeds but i don't know if this is just resonance and rattling as i still haven't anchored the machine yet or maybe settings i could look into.
  • NT4Boy
  • NT4Boy
07 Feb 2025 19:22
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Aha, no they weren't.
But they are now.
Can now toggle them all to change state, but oddly y-min is inverted, and cannot quite see what I have done wrong there.
Thanks again.
  • andreabonuc
  • andreabonuc
07 Feb 2025 18:56
Replied by andreabonuc on topic 7i73 input 0-7 i cant'use
sorry but I'm not very expert, what do you mean by added externally? Can you explain it to me practically? Thank you
  • jairobbo
  • jairobbo
07 Feb 2025 18:42 - 07 Feb 2025 18:43
Replied by jairobbo on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
Hi KrisJ,
I can at least confirm a pi 5 that is able to find WiFi networks. In my case nmtui did work I chose something I remember was called ‘activate network’ and it would show a bunch (and prompt for password).
With kind regards,
Jairo
edit: this is on the latest linuxcnc image 2.9.4 by rodw
  • PCW
  • PCW's Avatar
07 Feb 2025 18:26
Replied by PCW on topic HURCO KMB-1 Control Update
Are the encoder inputs for the limit switches jumpered for single ended use?
  • PCW
  • PCW's Avatar
07 Feb 2025 18:23 - 07 Feb 2025 18:24
Replied by PCW on topic 7i73 input 0-7 i cant'use
Inputs 0..7 on the 7I73 have no pullups/pulldowns
so these must be added externally if used with
single throw switches.
  • KrisJ
  • KrisJ
07 Feb 2025 17:57
Replied by KrisJ on topic LinuxCNC on Raspberry Pi 5
OK, So I think I managed to configure some GPIOs (more or less) successfully using official Rpi5 img, (Thanks for the guidance, unkonwn)
Now my problem is that I can't manage to get the WiFi working and I sorely need it for development. I'm pretty sure I ran some older release that had it working (with network-manager) out of the box but network-manager does not seem to be installed by default in this version.
What I tried is apt-get install network-manager and after that I reboot and launch the terminal based GUI with 'nmtui'. In here (in previous versions) I used to see a list of SSIDs to connect to but now the list is empty. I'm guessing that there might be an issue with some driver or similar and that no WiFi chip is recognized but I don't have the knowledge to check. Has anyone else got their WiFi up and running on the latest Rpi5 image?
  • NT4Boy
  • NT4Boy
07 Feb 2025 17:48
The 5v limits switches, (connected to the 7i77 spare encoder terminals QA3,QB3,IDX3 etc), are registering in linuxcnc randomly. Even though the machine is parked mid stroke, the Y axis min is always true, and I can trigger the X max with a wrench from false to true, but it stays that way with the wrench removed.
Looking at the original control there is a 470ohm resistor to 5v holding the signal to the MUX chip high, and when the limit is triggered, this gets grounded.
Do I need to do something else electrically to gets this working?
  • andreabonuc
  • andreabonuc
07 Feb 2025 17:26
7i73 input 0-7 i cant'use was created by andreabonuc
Hi everyone, I have a 7i96s and a 7i73, until now I have used the 3 analog inputs of the 7i73 (in 0,1,2,3- pin 3,4,5,6) to use them with 3 potentiometers but they are not stable and I have not continued to use them. I would like to understand if they can be used as standard inputs because I have to move 4 external buttons to recover the 6 encoder inputs for the potentiometers. My problem is that I see them as inputs in halshow but I can't use them, I can use from in8 up. I certainly wrote something in the HAL to enable the analog inputs but I haven't solved anything for 2 days to get them working as standard inputs again. It's been more than 1 year since I changed the hal file and being a beginner I don't remember... Can anyone help me? Thanks.
  • Aciera
  • Aciera's Avatar
07 Feb 2025 17:16 - 07 Feb 2025 17:17
Replied by Aciera on topic Coordinate system and touch off
Try (note the difference in the L-word)
g10 l20 p1 x0 y0 z0.
L2 sets the offset values themself to 0
L20 sets the offset values so the current coordinate is 0
  • zz912
  • zz912's Avatar
07 Feb 2025 17:16
Replied by zz912 on topic Macros. File not open
Category: Gmoccapy
Sub has not same name at start and end.
  • ihavenofish
  • ihavenofish
07 Feb 2025 17:05
Replied by ihavenofish on topic scurve trajectory planner
Beef has done his Master Degree in the mean time.
Beef mostly just mutters in the corner these days about everyone being jerks...
*tries to start some forum beef*
:P
  • PCW
  • PCW's Avatar
07 Feb 2025 16:48
Replied by PCW on topic 7i96s Replacement Needed
Yes, spindle control is the typical use of the 7I96S analog output.
  • PCW
  • PCW's Avatar
07 Feb 2025 16:43
Replied by PCW on topic Index homing Mesa 7i96s
Category: PnCConf Wizard
If by daughtercard you mean the 7I84U, any firmware with a sserial port will do.
(basically and 7I96S firmware that does not use the serial expansion for modbus etc)
Displaying 19231 - 19245 out of 19540 results.
Time to create page: 0.507 seconds
