  • Yaroslav
  • Yaroslav
14 Jan 2025 02:51
Replied by Yaroslav on topic M6 Remap Lathe (Remap T & ignore M6)
I created two configurations for 7i96s. One on the carousel component, the other on the ladder. The ladder works fine with Remap T and Ignore m6, just like when changing tools manually. When working with the carousel component, Remap T throws an error "M6: no tool prepared". Remap M6 = Ignore M6 - does not work at all, since Remap M6 is already used. In the configuration, these functions are disabled in the ini file.
14 Jan 2025 02:32
Replied by Cant do this anymore bye all on topic RPi 5 with 6.12 PREEMPT_RT = Using POSIX non-realtime
Category: Installing LinuxCNC
Hello @cornholio,
You are right - I need to move on to LinuxCNC. I noticed a new CNC machine. It's called "Maslow". Google it as "Maslow CNC".
I want to use it for cutting out frame members for wooden boats.
Does LinuxCNC support it or does something need to be done?
T
From reading their blurb it seems to use a GRBL type controller, not compatible with Linuxcnc's model. Just for future reference anything that connects via USB (as of this current time) or uses a GRBL type controller is not compatible with Linuxcnc.
I always thought kinematics related to the motion of a machine, very math intensive, I wasn't aware speed would negate it.
I have concerns with the machine, the main one being what stops the cutter platform from raising if it hits a knot or other harder section of plywood. I really didn't read too much about it. It may be a reasonable design but not something I'd spend any money on.
A Lowrider would be another option. docs.v1e.com/lowrider/
Tho with the amount of plastic involved meh.
  • PopBang
  • PopBang
14 Jan 2025 02:24
Thanks, much appreciated!
Yeah, the board was a pretty attractive option when I bought about 6 years ago.
  • cajbr
  • cajbr
14 Jan 2025 02:22
Where to buy inexpensive, reliable stepper drivers in Canada.
Category: Driver Boards
Automationdirect (dot com) ships to Canada. Excellent selection of drives, etc. and other supplies.
BR
  • claytoncramer
  • claytoncramer
14 Jan 2025 02:14
Replied by claytoncramer on topic G2
G2
was the only useful one for me. This is the bash scrip that I wrote to produce a hole centered in a box specified by four points. There are two files that this script uses.
#!/bin/bash
# Cut an interior circle starting at xStartBB yStartBB xEndBB yEndBB zStart zStep zEnd feedRate holeDiameter endMillDiameter
# BB is short for BoundingBox
if [ "$#" -eq 0 ];
then echo "$0 xBB yBB xEndBB yEndBB zStart stepZ endZ feedRate holeDiameter endMillDiameter"
else
xStartBB=$1
yStartBB=$2
xEndBB=$3
yEndBB=$4
startZ=$5
stepZ=$6
endZ=$7
feedRate=$8
holeDiameter=$9
endMillDiameter=${10}
millRadius=`echo "$endMillDiameter/2"|bc -l`
# Calculate starting cut points
echo $xEndBB $xStartBB $holeDiameter
center=`echo "(($xEndBB-$xStartBB)/2)"|bc -l`
offset=`echo "((($xEndBB-$xStartBB)-($holeDiameter))/2)"|bc -l`
startXCut=`echo "$xStartBB+$offset+$millRadius"|bc -l`
startYCut=`echo "($yEndBB-$yStartBB)/2"|bc -l`
endYCut=$startYCut
endXCut=`echo "$yEndBB - $offset - $millRadius"|bc -l`
# calculate radius for i
i=`echo "($center-$startXCut)"|bc -l`
cat prolog.nc >rotate.nc
echo "g1 z1.0 f$feedRate" >>rotate.nc
echo "g1 x$startXCut y$startYCut f$feedRate" >>rotate.nc
echo "g1 z$startZ y$startYCut f$feedRate" >>rotate.nc
newstartZ=`echo "$startZ+$stepZ"|bc -l`
for curZ in `seq $newstartZ $stepZ $endZ`
do
echo "g1 z$curZ f$feedRate" >>rotate.nc
echo "g2 x$endXCut y$endYCut i$i j0 f$feedRate" >>rotate.nc
echo "x$startXCut y$startYCut j0 i-$i" >>rotate.nc
done
cat epilog.nc >>rotate.nc
fi
The two external files are prolog.nc
g17 g20 g54
and epilog.nc
m2
  • cakeslob
  • cakeslob
14 Jan 2025 02:13
just use the one here github.com/scottalford75/Remora-NVEM/tree/main/Firmware
use only the files in that repo for linuxcnc installation as well, the remora-nv one
everything in the videos about this stm board will still be relevant im sure
these stm ethernet boards have more users than i would have guessed
  • WonderOwl
  • WonderOwl
14 Jan 2025 02:05
find_rt_cpu_number() Error in uspace_rtapi_app.cc on PREEMPT_RT
Hi, I am new to LinuxCNC and have some questions about how LinuxCNC find the RT CPU (isolate CPU core) on PREEMPT_RT.
It seems the find_rt_cpu_number() function in uspace_rtapi_app.cc either choose the environment variable RTAPI_CPU_NUMBER (which is NULL if not set manually) or choose the last CPU core regardless of whether there is an isolated core.
e.g. The isolate core on my Preempt_RT is core 1, but find_rt_cpu_number() returns 3 and the RT thread is running on core3 in the attached images.
My test version is LINUXCNC - 2.10.0~pre0. Thx for your time :-D
  • claytoncramer
  • claytoncramer
  • rodw
  • rodw's Avatar
14 Jan 2025 01:30
G3 command ignores and resets M67 feedrate?
Category: Plasmac
There are some variables to enable hole mode etc in the top of the plasmac post processor in sheetcam. They may help
  • rodw
  • rodw's Avatar
14 Jan 2025 01:14
Replied by rodw on topic bookworm/master-uspace/binary-amd64
Is there another way to upgrade to version 2.10?
This is a bit tricky if you are using the 2.9 download. the official Linuxcnc repo does not contain 2.10
You would need to edit linuxcnc-uspace.list in one of the /etc/apt folders to use the buildbot2 settings described here
buildbot2.highlab.com/
Otherwise download a deb file from there and install it.
  • rodw
  • rodw's Avatar
14 Jan 2025 01:02
Replied by rodw on topic 7I96S setup issue
7I96S setup issue
Category: PnCConf Wizard
Assuming you are using the linuxcnc rpi 4 image, on the command line, try typing menu-config and selecting the correct locale for your part of the world
  • arauchfuss
  • arauchfuss
14 Jan 2025 00:56
Replied by arauchfuss on topic Tree Journeyman 325 (Dynapath)
Category: Milling Machines
First attempt at physically fitting everything together.
Need to work on the 24V and 5V power supply mounting.
  • phillc54
  • phillc54's Avatar
14 Jan 2025 00:42
Replied by phillc54 on topic Axis Modifications
Axis Modifications
Category: AXIS
I really didn't like the last one so I tried something different and this is the result.
You don't need user_live_update, just use the below in bigfileopen.tcl.
# bigfileopen.tcl
if {[info proc tkgof] == ""} {rename tk_getOpenFile tkgof}
proc tk_getOpenFile {args} {
    # get width and height for max screen size:
    variable width  [lindex [wm maxsize .] 0]
    variable height [lindex [wm maxsize .] 1]
    # alternately, just set width and height explicitly:
    variable width  800
    variable height 600
    # location on screen:
    variable xoffset 0
    variable yoffset 0
    # padding to enlarge buttons:
    variable padx 10
    variable pady 20
    # set the window size and the button sizes
    after 0 {wm geometry .__tk_filedialog ${width}x${height}+${xoffset}+${yoffset};
             .__tk_filedialog.contents.f2.ok configure -padding [list $padx $pady $padx $pady];
             .__tk_filedialog.contents.f2.cancel configure -padding [list $padx $pady $padx $pady]}
    return [eval ::tkgof $args]
  • PopBang
  • PopBang
  • cakeslob
  • cakeslob
14 Jan 2025 00:19
Displaying 19906 - 19920 out of 21711 results.
Time to create page: 0.669 seconds
