  • HansU
  • HansU's Avatar
13 Jan 2025 22:01 - 13 Jan 2025 22:04
Replied by HansU on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Seems to work on axis (2.10):
This file gives me this. Still an emtpy tool list:
G-code properties: {'name': 'gmoccapy_2_tools_with_cutter_radius_compensation.ngc', 'size': '1234 bytes\n93 gcode lines', 'g0': '58.000 mm', 'g1': '327.121 mm', 'run': '25 Seconds', 'toollist': [], 'x': '31.000 to 69.000 = 38.000 mm', 'x_zero_rxy': '31.000 to 69.000 = 38.000 mm', 'y': '31.000 to 69.000 = 38.000 mm', 'y_zero_rxy': '31.000 to 69.000 = 38.000 mm', 'z': '-252.287 to -221.287 = 31.000 mm', 'z_zero_rxy': '-252.287 to -221.287 = 31.000 mm', 'machine_unit_sys': 'Metric', 'gcode_units': 'mm'}
Also a bit weird that it has the tools 0, 3, 1 in the list in Axis, but there is only T3 and T1 in that file.
I prefer the progress bar under the g-code.
Me too :)
About the Icon it's just a matter of taste IMHO, I do not like the black and white icon, but I also see the need to reorder the button to reduce mouse movement.
We can also have this icon in yellow, no problem ;-)
About the File Chooser widget, I was thinking for long time about a Widget designed like the Midnight Commander but unfortunately I have not even started to write the first line of code .
You mean that one that looks like the Norton Commander, so text based only?
  • lukin1156
  • lukin1156
13 Jan 2025 21:42
Replied by lukin1156 on topic Carousel with analog servo drive
I tried using the speed mode, but it didn't work. So I went back to the original control. By manually rotating the carousel, I determined the number of pulses between the individual pockets. The automatic tool change works quite well, sometimes there is just a problem with homing the carousel. If the carousel goes to the same side at the home position, it is fine. However, if the carousel goes to the other side after homing, there is a small error in the position. I tried using rotation in only one direction, but there is another problem that the error in the number of pulses between the individual pockets adds up over time.
Here is short video from tool change.
youtube.com/shorts/BAgzHO6OKA0?si=I7e9RTFSHqlaFPUl
 #  --- automatic tool change ---
loadrt carousel pockets=6 encoding=index dir=2
addf carousel.0        servo-thread
setp carousel.0.scale 1666
setp carousel.0.home-offset -70
net spindlenot <= halui.spindle.0.is-on => not.0.in
net spindlenotout <= not.0.out => and2.2.in0
net toolunlock <= motion.digital-out-00 => or2.1.in0
net toolunlockkey <= hm2_5i25.0.7i84.0.2.input-07 => or2.1.in1
net toolunlockout <= or2.1.out => and2.2.in1
net toolunlockout1 <= and2.2.out => hm2_5i25.0.7i77.0.0.output-00
net carouselup <= motion.digital-out-01 => hm2_5i25.0.7i77.0.0.output-01
net spindleair <= motion.digital-out-02 => hm2_5i25.0.7i77.0.0.output-02
net orient1   <= motion.digital-out-03 => hm2_5i25.0.7i77.0.0.output-12
net orient2     <= motion.digital-out-04 => hm2_5i25.0.7i77.0.0.output-13
net toolisunlock   <= motion.digital-in-00  => hm2_5i25.0.7i77.0.0.input-04
net toolislock        <= motion.digital-in-01  => hm2_5i25.0.7i77.0.0.input-05
net carouselisup     <= motion.digital-in-02  => hm2_5i25.0.7i77.0.0.input-06
net carouselisdown  <= motion.digital-in-03  => hm2_5i25.0.7i77.0.0.input-07
net spindleinposition <= motion.digital-in-04 => hm2_5i25.0.7i77.0.0.input-24
net carousel-index carousel.0.sense-0 hm2_5i25.0.7i77.0.0.input-03-not
net carousel-pulse carousel.0.sense-1 hm2_5i25.0.7i77.0.0.input-02-not
net carousel-enable <= motion.digital-out-05 => carousel.0.enable
net carousel-pocket <= motion.analog-out-00 => conv-float-s32.0.in
net carousel-pocket-out <= carousel.0.pocket-number => conv-float-s32.0.out
net carousel-finish <= motion.digital-in-08  <= carousel.0.ready
# PID carousel
setp   pid.c.Pgain     [SPINDLE_2]P
setp   pid.c.Igain     [SPINDLE_2]I
setp   pid.c.Dgain     [SPINDLE_2]D
setp   pid.c.bias      [SPINDLE_2]BIAS
setp   pid.c.FF0       [SPINDLE_2]FF0
setp   pid.c.FF1       [SPINDLE_2]FF1
setp   pid.c.FF2       [SPINDLE_2]FF2
setp   pid.c.deadband  [SPINDLE_2]DEADBAND
setp   pid.c.maxoutput [SPINDLE_2]MAX_OUTPUT
setp   pid.c.error-previous-target true
net c-index-enable  =>  pid.c.index-enable
net machine-is-enabled    =>  pid.c.enable
net c-vel-cmd       =>  pid.c.command
net c-pos-fb       =>  pid.c.feedback
net c-output        <=  pid.c.output
# ---PWM Generator signals/setup---
setp   hm2_5i25.0.7i77.0.1.analogout3-scalemax  [SPINDLE_2]OUTPUT_SCALE
setp   hm2_5i25.0.7i77.0.1.analogout3-minlim    [SPINDLE_2]OUTPUT_MIN_LIMIT
setp   hm2_5i25.0.7i77.0.1.analogout3-maxlim    [SPINDLE_2]OUTPUT_MAX_LIMIT
net c-output     => hm2_5i25.0.7i77.0.1.analogout3
net c-vel-cmd    <= carousel.0.counts-target
setp    hm2_5i25.0.encoder.03.counter-mode 0
setp    hm2_5i25.0.encoder.03.filter 1
setp    hm2_5i25.0.encoder.03.index-invert 0
setp    hm2_5i25.0.encoder.03.index-mask 0
setp    hm2_5i25.0.encoder.03.index-mask-invert 0
setp    hm2_5i25.0.encoder.03.scale  [SPINDLE_2]ENCODER_SCALE
net c-pos-fb               <=  hm2_5i25.0.encoder.03.position
net c-vel-fb               <=  hm2_5i25.0.encoder.03.velocity
net c-pos-fb               =>  conv-float-s32.1.in
net c-pos-fb-out             => conv-float-s32.1.out => carousel.0.counts
net tool-changed    <= iocontrol.0.tool-change  => iocontrol.0.tool-changed
  • TomAlborough
  • TomAlborough's Avatar
13 Jan 2025 21:42
RPi 5 with 6.12 PREEMPT_RT = Using POSIX non-realtime
Category: Installing LinuxCNC
Hello @cornholio:
I do understand some of the things you are saying.
I'm not a LinuxCNC'er so please bear with me.
A start might be to enumerate types of users as I see them:
Gold users just want to get something done (say make parts for a space station). Their CNC machines are already supported by LinuxCNC. They would appreciate a working version of LinuxCNC. Once they get it they probably will not change it over time unless they need to support new devices or new features.
The key here is that installing and getting LinuxCNC running should be as easy as it is to get Raspberry Pi 5 or Ubuntu up in the first place. (I'm not sure if my experience getting RPi5 up is similar to getting RPi4 up but more on that later).
If a newcomer can not get a version going enough to run say a "Maslow" machine (please Google "maslow cnc kit") then work still needs to be done.
Silver users/developers know and contribute to the LinuxCNC GitHub repo. The users have absolute control of the repo and the CNC, sysgen and testing features merged into it.
Bronze users/developers know and contribute to the Linux GitHub repo. The users have absolute control of the repo and the OS, sysgen and testing features merged into it.
The question comes: How to manage the need for support between Gold, Silver and Bronze users. I'm not sure of a solution here but I believe some solution will arise.
Tests should exist that (all) developers can run and get understandable results from. The only issue should be coverage at a given point in time. Hopefully the more tests you develop and manage the better off everyone should be.
I realize some of the above exists. It just needs to be pulled together.
An observation about configuration files: I think they may have gotten a bit out of hand.
I believe plain text files are easier for users to work with than XML but, a coherent "system build, installation and configuration" facility may be easier to develop and maintain if the configuration is rationally represented by some data handling facility (not a DBMS).
Please let me know your thoughts up to this point.
Many thanks,
Tom
  • MWalz
  • MWalz
13 Jan 2025 21:26
Replied by MWalz on topic StepperOnline A6 Servo
Category: EtherCAT
Thanks a lot, I can confirm your configuration works.
These are my first steps using ethercat. My mistake was that I added sdoConfig commands in the ethercat.xml to configure the PDO mapping like described in the servos manual.
Seems like it's sufficient to just add the pdoEntry's for the desired PDO mapping group and somehow it's configured automatically. By linuxcnc or the ethercat subsystem?
Maybe someone can comment/confirm this to avoid others making the same mistake.
  • RotarySMP
  • RotarySMP's Avatar
13 Jan 2025 21:20
Replied by RotarySMP on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Thanks for adding the progress bar Norbert. I often wonder roughly how much longer a program will take.
  • chrischan
  • chrischan
13 Jan 2025 21:19
Replied by chrischan on topic Maus funktioniert nicht bei Spindel Start
Category: Deutsch
I'm using this one:
www.fif.com.pl/pl/przekazniki-elektromag..._query=Pk%202p%2012v
Can't find any information about a diode in it. So I try it tomorrow.
13 Jan 2025 21:11
Replied by tommylight on topic Maus funktioniert nicht bei Spindel Start
Category: Deutsch
Yes.
Do check if the ralay has one already, some do but mostly do not have it.
  • PCW
  • PCW's Avatar
13 Jan 2025 21:11 - 14 Jan 2025 00:47
7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
Category: Driver Boards
freeby.mesanet.com/95tinit.tgz
Not sure about the executables (might be too old a libc version),
but you can get by by just programming the FPGA via JTAG
and running the two mesaflash commands.
Here is the FTDI4232 --> 10 pin header connection:
freeby.mesanet.com/pdf/parallel/4232efin.pdf
  • chrischan
  • chrischan
13 Jan 2025 20:48 - 13 Jan 2025 20:49
Category: Deutsch
That way, correct?
  • dschultz
  • dschultz
13 Jan 2025 18:28
Replied by dschultz on topic StepperOnline A6 Servo
Category: EtherCAT
These are basic with just the X axis.
  • Aciera
  • Aciera's Avatar
13 Jan 2025 17:52
Replied by Aciera on topic LinuxCNC with OKUMA OSP MX-55VA
Category: Basic Configuration
First thing you want to find out is what kind of signal interface the axes and spindle drives use (ie analog +-10V, step/direction, serial interface) that will then largely dictate the options to go forward.
  • Lcvette
  • Lcvette's Avatar
13 Jan 2025 17:23
Replied by Lcvette on topic Installation links failing
Category: QtPyVCP
links are now fixed!
  • zz912
  • zz912's Avatar
13 Jan 2025 16:57
Replied by zz912 on topic LCNC 2.10 - Ask for AUTOMATIC_G43
Category: Gmoccapy
"Should I move this thread over to the Gmoccapy section?"
Yes
  • PCW
  • PCW's Avatar
13 Jan 2025 16:32
Replied by PCW on topic 7I96S setup issue
7I96S setup issue
Category: PnCConf Wizard
I think that's a locale bug on pncconf:
forum.linuxcnc.org/27-driver-boards/5145...ettings-issue#291810
Displaying 19936 - 19950 out of 21712 results.
Time to create page: 0.405 seconds
