  • RPdeebee
  • RPdeebee
31 Dec 2024 11:30
Replied by RPdeebee on topic Need help implementing EtherCAT spindle driver
Category: EtherCAT
Hi, just wondering if you ever made progress on this? Also looking at EtherCAT drives from that manufacturer.
  • kimkar
  • kimkar
31 Dec 2024 10:47
Replied by kimkar on topic Power Supply and Line driver encoders
Category: Driver Boards
Are the QA, QB, IDX pins on the 7i85 equivalent to the A, B, Z signal in line driver encoders?
  • __Tom
  • __Tom
31 Dec 2024 10:27
Replied by __Tom on topic THC
THC
Category: Plasma & Laser
Hello Tommylight, yes this advices fixed my problem the THC is now working how it should.
Thanks once more and Happy new year!
  • __Tom
  • __Tom
31 Dec 2024 08:43
THC
Hello Tommylight thanks for your quick reply. Need to check it out, let you know. BR
  • elovalvo
  • elovalvo
31 Dec 2024 07:21 - 31 Dec 2024 07:29
Newbie looking for a hardware configuration based on Raspberry Pi
This is the download link
drive.google.com/file/d/1pmV587gXFEvznQB...00x/view?usp=sharing
Something has changed on linuxcnc between then and now, but not much.
In particular, the function for using GPIOs which was previously hal_pi_gpio and is now hal_gpio
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html
forum.linuxcnc.org/24-hal-components/504...-with-raspberry-pi-4
The image of RaspiOS with Linuxcnc is available in this link
forum.linuxcnc.org/9-installing-linuxcnc...pi-5?start=40#303752
Let me know if you need further guidance
  • cmorley
  • cmorley
31 Dec 2024 06:48
Replied by cmorley on topic Threading Index Varies With Speed
I would think (in general) encoder resolution, axis acceleration and trajectory servo update rate all have potential to improve the tracking.
but changing the speed significantly is not going to track in the same place with the current code. I wouldn't think it would be hard to code absolute position tracking, but I bet it has some corner cases.
  • rodw
  • rodw's Avatar
31 Dec 2024 06:29
Python4Lazarus Undefined symbol: PyExc_ValueError
For your homing issue, set a home_offset to move the axis off the switch when homing otherwise the home/limit switch will be homed when homing of that axis is completed
  • rodw
  • rodw's Avatar
31 Dec 2024 04:40
Replied by rodw on topic Chasing Threads and Re-Threading
Metric threads are pretty simple. My guess it would be a metric fine thread 17mm x 1.5mm pitch
So if you don't have a thread gauge, measure 10 threads and see if it is 15mm long.
Then you just need  to buy a 17x1.5mm tap.
to size the drill for a metric tap, just deduct the pitch from the diameter. In this case, 17-1.5 = 15.5mm
  • Jdolecki
  • Jdolecki
31 Dec 2024 02:36
Replied by Jdolecki on topic Pi image to pi 4
Pi image to pi 4
Category: Installing LinuxCNC
So my laptop running win 11 won’t do it correctly
My laptop running win 10 was totally different acting when downloading the file.
I already had etcher installed.
Worked flawleslly .
B
31 Dec 2024 01:53
Replied by tommylight on topic THC
THC
Height Per Volt?
Leave at default 0.1 or whatever the default is, i never had to change that.
VAD at 65% or 70% should be fine, 90% is to much
THC delay i usually have at 0.1-0.2, only for slow cutting speeds use more if needed
And disable "use auto volts" until you get the machine working properly.
From your pictures, i would venture a guess at Z axis acceleration being way to low, or scaling being way off from reality.
If all of the above is set and verified to be OK, then set the P value to 8 or 7 or even lower, but if you end up any lower than 5, something is terribly wrong.
30 Dec 2024 23:27
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
They require a lot of rework to get inputs. Swapping out chips, add jumpers, messing with power supply voltages, can be done but fiddly.
Best starting with one of the more common boards discussed on this thread.
Just keep this is mind that it may end up costing close to the cost of original Mesa board (less postage if you are outside the locality of a local supplier). Most of these projects turn out that way.
BTW Linuxcnc-RIO is a great project, well supported and actively developed.
  • PCW
  • PCW's Avatar
30 Dec 2024 23:25
Replied by PCW on topic Threading Index Varies With Speed
Could you plot the encoder position and velocity to see if the error is from the encoder side or LinuxCNC?
The jagginess may be from encoder wheel inaccuracies and inherent velocity quantization
errors from the 1 ms time stamp of the software encoder (this would be improved by using the hardware encoder)
  • MarkoPolo
  • MarkoPolo
30 Dec 2024 23:13
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
The coloring of the movements works very well, that's what I wanted, thanks for another good job.
In my simulation, the "myhud" panel would be more to my liking in the upper right corner. How can I set this up?
  • Grotius
  • Grotius's Avatar
30 Dec 2024 23:05
Replied by Grotius on topic PathPilot V2 source code
Category: PathPilot
The planner at work.
tapping.
30 Dec 2024 22:56
Replied by Cant do this anymore bye all on topic EOI in getting SPI going on the RPi5 solved read First post for updated info
Ok this thread was primarily for the development of a Linuxcnc spi driver for the RPi5.
This as been done, but you will need to build either 2.9 or master from source.
There is a more recent thread discussing this.
Apart from the new driver everything that applies to RPi 4 and either the 7c81 or 7c80 is relevant.
There is a quite large thread on the 7c81 that you may want to read, the 7c80 manual should have information on using mesa flash.
Setup and mesa flash was not the point of this thread . Now that a driver has been developed this thread is pretty much moot.
Displaying 20881 - 20895 out of 21849 results.
Time to create page: 0.399 seconds
