14 Dec 2024 08:59
Replied by Cant do this anymore bye all on topic Selecting Between Multiple LCNC Versions
Build each version as a Run In Place (RIP) setup.
Check the docs if you don't know what that means.
14 Dec 2024 08:55
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
Perl complains if LC_ALL or LANGUAGE isn't set.
  • electrosteam
  • electrosteam
14 Dec 2024 08:38
Selecting Between Multiple LCNC Versions was created by electrosteam
I recently commented on the absence of MDI queuing and Run-From-Here in the AXIS 2.9.1 release on my RPi4 B mill.
I tried going back to 2.8.4, but that seemed a retrograde step.
So I made a new 2.9.1 Gmoccapy adjacent to the AXIS on the same SD card for testing.
The queuing is there, not sure yet of the Run-From-Here.
Both AXIS and Gmoccapy seem to operate independently quite OK.
But, during stress testing of the queuing, I got an occasional Following-Error which prompted me to start reviewing HALShow and HALScope for assistance.
It was then that I realized that Gmoccapy uses names for the various files identical to that of AXIS.
Is it wise to re-name all the Gmoccapy files so that they are different to the AXIS names ?
What is the best way to arrange two or more LCNC versions so that any one can be selected ?
Keep well,
John.
  • fully_defined
  • fully_defined's Avatar
14 Dec 2024 07:38
Replied by fully_defined on topic Teknic Clearpath SDSK wiring to 7i96s
The enable outputs and input common are still not right
The drive enables could be wired in parallel as there is typically
no reason to drive them separately
Parallel Drive enable wiring could be:
+5V --> OUT0+
OUT0- --> all Drive ENA+
GND --> all Drive ENA-
I think you're saying I can (and should) run all enable+ in parallel from output 0 and all enable- in parallel to GND for drive 0? Teknic previously advised me that I can tie enable-, step- & direction- together, but you said I should not do that on the 7i96s so I figured I would just give each input and output its own wire since I'm connecting all of this with a 64-conductor DSUB cable and I don't need to save on conductors. Obviously I am going to do it whatever the right way is, and I just need to figure out what the right way is, because there is no guide.
I don't fully understand what you mean in the first and second lines: +5v --> OUT0+, and: OUT0- --> all Drive ENA+. If I did not get it right above, can you elaborate what you meant?
  • rodw
  • rodw's Avatar
14 Dec 2024 06:35
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
The default  settings come from userdata.txt github.com/rodw-au/rpi-img-builder-lcnc/...9.3/userdata.txt#L40
I.m not sure LANGUAGE  needs to be set for the locale if its en_US.UTF-8 as we use for the default config
On my chrome book,  locale reports
rod@penguin:~$ locale
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
On my Debian PC in my office, I get
rod@debian:~$ locale
LANG=en_AU.UTF-8
LANGUAGE=en_AU:en
LC_CTYPE="en_AU.UTF-8"
LC_NUMERIC="en_AU.UTF-8"
LC_TIME="en_AU.UTF-8"
LC_COLLATE="en_AU.UTF-8"
LC_MONETARY="en_AU.UTF-8"
LC_MESSAGES="en_AU.UTF-8"
LC_PAPER="en_AU.UTF-8"
LC_NAME="en_AU.UTF-8"
LC_ADDRESS="en_AU.UTF-8"
LC_TELEPHONE="en_AU.UTF-8"
LC_MEASUREMENT="en_AU.UTF-8"
LC_IDENTIFICATION="en_AU.UTF-8"
LC_ALL=
  • kjlty
  • kjlty
14 Dec 2024 06:16
Turn Preview Off was created by kjlty
Turn Preview Off
Category: Other User Interfaces
Hello expert, can you optimize the problem of large capacity G-CODE occupying more memory?(Turn preview on and disable preview)
14 Dec 2024 06:10
Doesn't have an option for setting LANGUAGE.
Had to use
sudo update-locale LANGUAGE="en_AU:en"
Then log out and login for it to take effect.
  • rodw
  • rodw's Avatar
14 Dec 2024 05:11
Thanks, that image was prepared by James Walker (Joco) one of the qtpyvcp developers.
All of these features can be set using sudo menu-config which brings up this menu.
14 Dec 2024 04:56
Just checked out your new image that you linked a couple of posts ago. Video works ok when using min hdmi to DVI adapter.
Just for those of us that are a bit silly what is the correct procedure & values to setup
1: LANGAUGE (currently unset)
2: LC_ALL (currently unset)
LANG = "en_AU.UTF-8" is fine.
Currently starting to test the new hm2_spix driver
  • P.J.B.C
  • P.J.B.C
14 Dec 2024 04:21
Replied by P.J.B.C on topic Same settings, different result
Category: Basic Configuration
Oh, yeah. so i was wondering if my assumption is correct, in that i am having trouble because of the ethernet controller...
Do you know of any reason that the intel nics would be an issue?
  • jyeomans
  • jyeomans
14 Dec 2024 04:08
qtdragon additonal buttons was created by jyeomans
Category: Qtvcp
Hello
i have been using qt dragon HD and like it.
i would like to add some buttons to my screen and was looking for the directions or a resourct to help me.
i have three things i want to add.
i have a work light
a spindle light
and a relay that switches between my prob in put and my tool setter.  both the tool setter and probe are normaly closed. seamed like the best way to do it.
i could put them on a tab or in utilitys.  but still a littel unclear on how to do that.
thanks for the help.
  • scotta
  • scotta's Avatar
14 Dec 2024 02:01
Hi, there is no cpp source code for the NVMPG. I decompiled the extracted firmware and managed to find the serial transmission section. The communication protocol was derived from that. The attached spreadsheet simulates the protocol. You should be able to use that for your purpose or alternatively look at the code of the NVMPG LinuxCNC component.
github.com/scottalford75/Remora-NVEM/blo.../MPG%20protocol.xlsx
Hi Scott,
thanks for your time and dedication.
I've owned a NVEM 2 since 2018, but buried it long time ago since I was not able to make it work reliably.
www.cnczone.com/forums/controller-cards/...084.html#post2154084
At that point in time, and till now, I've been using Mach3 (yeah... no LinuxCNC... i know...)
2019, after migrating to an UC300ETH controller, I tried to make the MPG work with Mach3 without using the NVEM.
I didn't want to waste such a nice MPG.
At that time, I did some reverse engineering... not as professional as you did... mine was mostly trial and error and listening to the serial communication between the MPG and the NVEM after opening it and finding a MAX232. I captured hundreds of packages, and tried to find the similarities on what was displayed on the MPG and what was within the payload. I almost got the payload down to your level.
I was too dumb to know about headers and such -_-
I also tried to create an Arduino program for having the MPG communicate with a PC using MODBUS.
But again, I was too dumb to find a smart solution, like having the Button-presses being reflected as Output-Pin changes on the Arduino, and hook those up to my motion-controller. Or using the Arduino Pro-Micro as a HID. Instead I tried to make the communication work with MODBUS and Mach3 "Brain", which resulted in a complex, and unreliable solution.
So I buried that solution almost 4 years ago as well.
That being said... I'm surprised about the NVEM still being a topic after stumbling about this thread by accident.
Would you mind if I would revive my idea of a NVMPG to PC connection, utilizing some of the "wisdom" you've gathered throughout the years?
Don't get me wrong... I'm an "enthusiast", far away from being an "achiever", my programming days are more than 20 years in the past now... but it's been bugging me a lot looking at this "unfinished project" (a lot of them exist though -_-)
Kind regards,
David
Hi David,
No problem from my side. This is exactly why I love open source projects. One builds from another.
  • gbestwick
  • gbestwick
14 Dec 2024 00:37
Replied by gbestwick on topic Issue with halcmd show pin not showing pins.
Category: EtherCAT
I found my problem!
It wasn't configuration at all, it was a very basic error where I hadn't started lcec!
halcmd loadrt lcec
That was it!
Thank you everyone for your time.
  • behai
  • behai
14 Dec 2024 00:07
Replied by behai on topic Mesa firmware versions and updating
Category: Driver Boards
Hi Behai. I purchased a couple of these cards from the US. I built a CNC around this card and a raspberry pi five. If you want to chat about it, I’m at the top of the South Island.
Hi @RNZ,
Thank you very much for the offer. I appreciate that... I know nothing about CNC. I am learning at the moment.
I am learning HAL :) I have been a run-of-a-mill computer programmer, conceptually I have no problem understanding HAL, but I am not yet familiar with all the stuff in HAL yet. For example, I have learned that there is a motion module. But I don't yet understand what it is about, and its properties etc... I have much to learn till I can questions which hopefully make sense :)
Have a good weekend...
Best regards,
...behai.
Displaying 21706 - 21720 out of 22100 results.
Time to create page: 0.665 seconds
