  • natester
  • natester
20 Oct 2024 01:37
Replied by natester on topic wait_complete()
wait_complete()
Did you ever figure this out? I also found this bug in probe screen v2.8: github.com/verser-git/probe_screen_v2.8/...probe_screen.py#L341
Increasing the timeout makes no difference as wait_complete always returns immediately. I'm also on linuxcnc 2.8.4
20 Oct 2024 01:10
Replied by tommylight on topic Mesact 2 Setup
Mesact 2 Setup
Category: Configuration Tools
That does not seem right at all, i get this on Mint22
cnc@256NVME:~$ apt search python3-distro
i   python3-distro        - Linux OS platform information API
p   python3-distro-info        - information about distributions' releases (Python 3 module)
I am pretty sure it is an issue with repositories, probably from using and older ISO that had such issues, so Rod should have some info on how to fix that.
In the meantime, open "software sources" from the menu and try enabling other repositories (there are 3, something with romeo, unstable, source code, or similar).
You can do the same thing from the "synaptics package manager" if the above is missing.
Do and update first, then try apt search or apt install again.
20 Oct 2024 01:01
Replied by tommylight on topic Open Configuration tool issue
Just went back and checked the messages here and there as i thought someone already answered, but no answer was there.
No worries, i will transfer my reply there and delete this after you get to read it so we keep both topics clean.
Thank you.
  • tray
  • tray
20 Oct 2024 00:55
Replied by tray on topic Mesact 2 Setup
Mesact 2 Setup
In the terminal I enter the following:
The response is:
Sorting... Done
Full Text Search... Done
  • tray
  • tray
20 Oct 2024 00:54
Replied by tray on topic Open Configuration tool issue
Apologies I was prompting if it was the same issue.
20 Oct 2024 00:51 - 20 Oct 2024 01:02
Mesact 2 Setup
What does this in a terminal return:
  • tray
  • tray
20 Oct 2024 00:41
RLA,
Did you execute the following?
sudo apt install python3-distro
When I run I get the following error message.
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package python3-distro is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python3-distro' has no installation candidate
20 Oct 2024 00:37
Replied by tommylight on topic rp1lib - user space driver for the RP1 chip
People may have been wondering why I have been a little quiet on the forum of late ...
I know i have.
-Pinned to find easily.
Thank you for everything.
P.S.
Why rp1lib? Why not rp5lib?
Just wondering, as i am not into RPI for quite a while.
  • scotta
  • scotta's Avatar
19 Oct 2024 23:59
People may have been wondering why I have been a little quiet on the forum of late and that pull requests to Remora have been slow to be merged. Well, I've been working away on getting SPI on the Raspberry Pi 5 working so that we can support the SPI version of Remora. I'm now happy to share where things are up to.
github.com/scottalford75/rp1lib
The BCM2835 library was the inspiration, a library that gave access to all the chip peripherals. Hopefully the rp1lib can become the start of something similar.
Rather than reinventing the wheel, the library utilises the gpiochip_rp1 library for GPIO and I've adapted the kernel Designware driver for user space.
Next step is to update the Remora component, which is not too far off as I've got the RPi version detection working already.
  • PCW
  • PCW's Avatar
19 Oct 2024 23:21
Replied by PCW on topic 7I33TA Just plug it in?
Category: Driver Boards
You need 5I24-25 firmware for a 7I52S_7I33+7I44:
File Name: 5i24_25_7i...7i44.zip
File Size:166 KB
  • phillc54
  • phillc54's Avatar
19 Oct 2024 22:51
Replied by phillc54 on topic Update failure
Update failure
Category: Plasmac
Hmm, that is the useless package that is on Bookworm.
I am afraid that I am out of ideas. Maybe post in the installing linuxcnc  section.
  • bkt
  • bkt's Avatar
19 Oct 2024 21:25
Replied by bkt on topic c++ compiling error
c++ compiling error
@grotius .....   ... I see now your linuxcnc-trajectory-planner ...... you are strong boy .....
  • Deckerjwd
  • Deckerjwd's Avatar
19 Oct 2024 20:44
Replied by Deckerjwd on topic 7I33TA Just plug it in?
ok how do i write a driver for 5i24-25 with 7i52s, 7i33ta, 7i44.
i kinda want to know how that works. its an fpga right
  • Lcvette
  • Lcvette's Avatar
19 Oct 2024 20:05
Replied by Lcvette on topic Tool length sensor direction change
Category: QtPyVCP
no worries, hope you get it sorted out!
  • Lcvette
  • Lcvette's Avatar
19 Oct 2024 20:04
ProbeBasic Spindle connection (No Speed indicated, no control possible)
Category: QtPyVCP
the hal pin for the load insicator is spindle-load-indicator, just connect in hal as with any other connection, you will need to feed it the analog and give it a scale. the indicator scale in the ui is 0-150%
Displaying 22381 - 22395 out of 22868 results.
Time to create page: 1.330 seconds
