  • myankov
  • myankov
17 Oct 2024 14:38 - 17 Oct 2024 14:39
Replied by myankov on topic RF 45 homing issue
RF 45 homing issue
Category: Basic Configuration
It go up fast click returns slow click and goes above the switch.
17 Oct 2024 14:21
Replied by tommylight on topic Welche Tasten haben die Achsen?
Category: Deutsch
Caps_Lock muss aus sein.
17 Oct 2024 14:19
  • Muecke
  • Muecke's Avatar
17 Oct 2024 14:17
Replied by Muecke on topic Welche Tasten haben die Achsen?
Category: Deutsch
Meinst du diese?
17 Oct 2024 14:14
Category: Deutsch
U mit zwei punkte unde die mit + - geschrieben unten aber im gleiche horizontal linie.
17 Oct 2024 14:13
Replied by tommylight on topic RF 45 homing issue
RF 45 homing issue
What does it do now?
  • Muecke
  • Muecke's Avatar
17 Oct 2024 14:12
Unterstützung bei der Automatisierung einer Simulation
Category: Deutsch
Ok, dann muss ich jetzt den neuen Code herunterladen?
17 Oct 2024 14:11
Replied by tommylight on topic Fast Hole EDM from Hacked Parts
BAXEDM sells a very nice power supply, with all bells and whistles included for interfacing with LinuxCNC, as that is what he uses for his machines.
No idea about the price, but from what i have seen on youtube, he is very reasonable and supportive.
His channel has the same name on youtube.
  • Muecke
  • Muecke's Avatar
17 Oct 2024 14:11
Category: Deutsch
Kann man die Tasten auch selbst belegen?
@ tommylight
Welche genau?
17 Oct 2024 14:07
Category: Deutsch
Usually last two buttons before ENTER, upper row.
17 Oct 2024 14:00
Replied by tommylight on topic Linux is an RTOS NOW
Category: Installing LinuxCNC
6.11 shows SMP PREEMPT_DYNAMIC out of the box, did not test LinuxCNC yet.
  • Phorced
  • Phorced
17 Oct 2024 13:46
Replied by Phorced on topic Linuxcnc for CNC-STEP HIGH Z 400
I know that it is now over a year ago but i am currently setting up exactly the same machine and am not getting any movement just sounds like the steppers are being provided a locking current and that is it would you be willing to provide your configuration file that i can test on my side cause i have tried all the configuration changes mentioned in this forum with no resolve.
  • myankov
  • myankov
17 Oct 2024 13:46
RF 45 homing issue was created by myankov
RF 45 homing issue
Hello
It is my first time converting a mill and I am having a problem with homing sequence. I short I can't make it work.
I read this linuxcnc.org/docs/html/config/ini-homing.html  and some similar  topics  here in the forum, and after all I am more confused :).
I use same input for home and limit switch  on all axes .
You see in the where are the switches:
What I want to do is when lets say homing Z - goes to the switch trips it, returns slowly trips it again and then moves 10mm down. Ini file is attached check it and tell me what I am doing wrong.
Thank you.
  • unromeo21
  • unromeo21
17 Oct 2024 13:36
LitexCNC: firmware and driver for 5A-75B and 5A-75E
Category: Driver Boards
Any updates on the new version with shit register support ? It was anounced for 1st of March.
  • timo
  • timo
17 Oct 2024 13:12 - 17 Oct 2024 13:13
Replied by timo on topic Fast Hole EDM from Hacked Parts
"I am in desperate need of drilling some very small (.5-.8mm) holes in inconel of high aspect ratio."
Sounds like an examination question to a "make or buy" decision.
holeflix or spotdrillfy?
Displaying 22591 - 22605 out of 22868 results.
Time to create page: 0.813 seconds
