26 Aug 2024 03:21
Replied by Cant do this anymore bye all on topic Is software Estop allowed
Category: HAL
Gatekeeper ?
Full of good solid advice would be the better description.
Man you are so out of line with that comment.
Up til then it's been a decent discussion.
I'm just hoping there was a bit of confusion into the term "e-stop latch".
Just a little aside.
I've worked a lot of casual labour hire, disposable workers is what we really are, I was at a recycling plant, pulling steel that was missed during separation and wasn't supposed to go into the crusher. The plant wasn't the best safety wise. Anyways they had this dodgy estop setup, was like 2 step away from where you had to work. So after being there for a bit I realised the issue, spoke to the guy on site, no reaction, spoke to my contact at the labour hire mob, all they hid was ring the plant up and were assured yes there is an estop on the machine, tho access wasn't never discussed. So I said "Fuck it" and walked out. Got a call from from the labour hire mob, told them never to call again as their "safety officer was useless". Yeah and they are a major player in concrete recycling in Sydney.
So yeah machine safety is fucking important.
I fully agree a software estop is not the ideal way to go. Ah fuck I've lost my train of thought.
  • CFE
  • CFE
26 Aug 2024 03:19
Replied by CFE on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
Just to add to the previous : when I use conversational to generate the same contour the sudden feedrate change at the last straight line doesn't occur. But when I add "#<holes> = 3" to the conversational program the velocity is simply 60% of the feedrate all around the contour. Got me stumped.
  • phillc54
  • phillc54's Avatar
26 Aug 2024 03:16
Replied by phillc54 on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
The file seems to run fine on a sim.
My first thought was that it may have been due to the seemingly slow MAX_ACCELERATION values in your ini file so I changed the values in the sim to reflect yours and it still seems to work fine.
  • CFE
  • CFE
26 Aug 2024 02:33
Category: Plasmac
Hi all,
We are seeing some unexpected behaviour on our plasma cutter. I have attached the config settings file and a G-code program which behaves strangely. (We do see similar behaviour with other programs as well, but it a bit unpredictable.)
Let me try to explain what happens : When the first 2 slots are cut the torch moves to the first outside contour. During cutting that contour the velocity doesn't exceed 1700mm/min, which is 60% of the material feedrate (2815mm/min). But when it rounds the 4th (last corner) and enters the straight line all the sudden the velocity is at 100%, 2815mm/min. It does this on all 4 outside contours.
My best guess is that it has something to do with the M67 commands which QtPlasmaC adds, but why it is not consistent is beyond my expertise or comprehension. Anybody with thoughts ?
Cheers, Peter
  • Benb
  • Benb's Avatar
26 Aug 2024 02:27
Replied by Benb on topic Is software Estop allowed
Category: HAL
Tommy what you saying in your rant is wrong “software estop is not allowed “.   So, do yourself a favor and add an external estop to your 50 kg bench drill press and your 16-ton machine.I also hope you don’t let anyone else uses your software estop equipped machines, they are unsafe and you will not forgive yourself if someone else using them gets hurt.
And yes, no one asked me for advice but since Linuxcnc documentation does not address this subject I felt obligated to make hobbits and new Linuxcnc users aware of the use of Estop.
Tommy as Linuxcnc gate keeper do us (Linuxcnc users) favor and add a warning in the Linuxcnc documentation “software estop is not allowed.  here is no substitute for an external standalone Estop/reset”.
  • SamCoffee
  • SamCoffee's Avatar
26 Aug 2024 02:22
Replied by SamCoffee on topic Computer Shutdown
Computer Shutdown
Hello,
I use gmoccapy. When I turn on the machine, the computer starts first, then gmoccapy. How can I shut down Linuxcnc first and then the computer when I press an external key?
Can I do this with a button on the machine?
Hello,
I think you could script the HAL file to configure the external button to shut down LinuxCNC first, then the computer, and link the button to both functions in that order.
  • spacestate1
  • spacestate1
26 Aug 2024 00:41
Replied by spacestate1 on topic MCG Server Controller for 4th axis
Category: Driver Boards
Thanks for they reply. I bought this controller on ebay(picture). it was cheap, not totally sure it will work, but it was $25. I think right now the biggest problem is going to be figuring out the wiring on the motor, because it's not labeled or anything. I'll look into those controllers as well.
Also do you think 60v sounds right ? that seem high to me.
  • rodw
  • rodw's Avatar
25 Aug 2024 23:33
Replied by rodw on topic Is software Estop allowed
Category: HAL
Not really good enough. Everything needs dual redundancy.
Note that the estop button has two redunant circuits
The main contactor needs both K1 & K2 to be triggered
K3 & K4 are seperate force guided relays. Linuxcnc is not updated with a sucessful power on unless both K3 & K4 are triggered.
Force guided relays have a non conductive pin forced between the contacts to ensure contacts cannot be welded together.
Additional safety switches eg. door switches, guards etc are placed in the S33/S34 loop with the reset button.
With such a wiring layout, it is permissable to use  linuxcnc's software power button as a reset latch. In this case, use iocontrol.0.user-request-enable as it receives a pulse to repliciate the external reset button.
BUt the safety relay cost me $250 AUD and another $100 or so for the force guided relays.
25 Aug 2024 23:19
Replied by tommylight on topic Is software Estop allowed
Category: HAL
F117 has 9 computers with a single purpose of keeping it from falling like a brick!
Yes, it is a plane, and it is stealth.
No one asked for this info.....
Benb is trying to explain, with examples, how e-stop functions and how it should be implemented and why it is very important, so help him.
Thank you Benb.
Mentioning related stuff and the multitude of options might add to it, but it is not helping much without actual examples and corresponding info.
Another rant:
I have never used e-stop latch, although it does have it's uses for sure, but i have used the normal e-stop in and out even on 16 ton machines, as Aciera so eloquently put it "the implementation of proper machine safety standards is first and foremost the responsibility of the machine integrator" so the e-stop from LinuxCNC is just integrated into the machine e-stop system.
My point being, stop telling people to use e-stop latch unless they actually need it, they wind up wasting days trying to set it up and get frustrated, while the machines using it can be mostly stopped with a single hand and not much effort.
net e-stop-in <=== whatever-input-pin-01
net e-stop-out ===> whatever-output-pin-22
  • Benb
  • Benb's Avatar
25 Aug 2024 22:47
Category: HAL
Let me be clear ,I am only trying to raise awareness that screen estops are not allowed.
This discussion is not about machine safety relays, devices, … etc. So, let’s not mix-up things and muddy the discussion.
This awareness message is strictly about machine estop/reset only, which require very simple relay circuit. If you cannot read electrical diagrams just google start/stop circuit and you will find several examples showing realistic picture and wiring diagram for non electrical inclined.
To build an estop/reset circuit you need: red mushroom shaped push button, a push button and a relay wired as follows:
  • wm56
  • wm56
25 Aug 2024 22:23
Servo HCFA Y7 was created by wm56
Servo HCFA Y7
Category: EtherCAT
 Hi .
I recently purchased HCFA HN-Y7FB040A-S servos. Linuxcnc installation with Ethercat went well, but I don't know what to do next. How to configure it all. I've been working on it for a long time and nothing comes to mind. I'm mainly interested in the .xml file, how to go about it.
I received a configuration file from the manufacturer, but what to do with it next?
I'm new to ethercat. If I don't have a problem configuring mesa or lpt cards, I don't know how to deal with ethercat.
I have a project to complete to build my own machine and I would like to use these servos in it.
Please help. I'll be happy to return the favor.
File Name: HCFA_Y7_Se...1.24.xml
File Size:270 KB
  • besriworld
  • besriworld
25 Aug 2024 20:39
Replied by besriworld on topic Spindle Step/Dir and as C axis one the same Servo
Category: Basic Configuration
The setting of the Pid regulator seems not good
  • PCW
  • PCW's Avatar
25 Aug 2024 20:26
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
7c81 configuration with 7I77 on P1, MX4660 on P2 and just GPIO on P7:
File Name: 7c81_7i77x...0x1d.zip
File Size:107 KB
  • _skinner
  • _skinner
25 Aug 2024 19:29 - 25 Aug 2024 19:38
Replied by _skinner on topic Raspberry Pi 4 with Mesa 7c81
Currently I'm using that:
freeby.mesanet.com/7c81_mx4660x2d.zip
Can I ask You to make it in way:
P1 = 7i77
P2 = MX4660
P7 = GPIO
if it's not plenty of work?
I'm asking because that will help me with arrange space in cabinet.
Thank You in advance
and in connection with photos above
I manually added config for pncconf for 7c81 and 7i77 and mx4660 but something is wrong in comparision to 5i25 + 7i77:
  i cant find where is mistake, everything looks ok, maybe You know?
  • PCW
  • PCW's Avatar
25 Aug 2024 19:09
I'm not sure what you are suggesting
What firmware are you using currently?
I would probably make firmware something like
P1 = MX4660
P2 = 7I77
P7 = GPIO
Displaying 23416 - 23430 out of 24297 results.
Time to create page: 0.505 seconds
