  • mkudlacek
  • mkudlacek
22 Aug 2024 16:44
Replied by mkudlacek on topic Optimum Optimill MH50V CNC conversion
Category: Milling Machines
Hello, I would like to thank you for the E-Stop routine HAL. It saved me good couple of hours of head scratching:) Your build looks amazing! M.
  • greg23_78
  • greg23_78
22 Aug 2024 16:29 - 22 Aug 2024 16:33
Replied by greg23_78 on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
Category: Driver Boards
So I tried to adjust my drivers,
I started to set zero offset, I didn't feed the analog and I set the motor to slip as little as possible.
I powered the analog at 10V, set reference input at 10V and set tacho input at 1600 rpm. so 10V-1600 rpm.
as for the de I and epsilon settings, I have leave as it was either set to full.
as for speed stability, nothing happened when I moved it, except when I started to set it to full, a buzz appeared but nothing visible on the motor rotation.
  • garthnoakes
  • garthnoakes
22 Aug 2024 16:19
Logitech F310 shows in lsusb but HAL config does not show it - still strange
I found that in the hal file that uses loadusr -W hal_input -KRAL <identifier>, I had overwritten this with the wrong value when reinstalling LinuxCNC and copying the hal files from backup
I changed the identifier to F310.
When I run halrun from the command line and input the above (loadusr -W hal_input -KRAL F310) and <show pin>, I now see the input pins correctly. So hal is now working
But when I run LinuxCNC itself, I still don't see the pins (using HAL config or monitor).
  • greg23_78
  • greg23_78
22 Aug 2024 15:47
Driver NUM GEC MK2S
yes, the tachometer is connected to the motor.
i wanted to talk about a laser tachometer to measure speed because my encoder is no longer connected to the motor.
I've just put 10V into the analog input and the motor is running correctly.
  • spumco
  • spumco
22 Aug 2024 15:30
Replied by spumco on topic Which Mesa Card Should I Buy?
@JackRay,
Nice machine!
I'm sorry, but I've never used a Pi with Mesa or LCNC.  I think your best bet is to do some searching in the "Computers" sub-forum, and post a new thread in there (or "Driver Boards") specifically seeking recommendations for Pi + Mesa combinations.
I suspect there isn't any difference in Mesa selection if you plan to use an ethernet cable (rather than the RPi-specific 7C80 or 7C81), but someone else should be able to provide more guidance.
  • PCW
  • PCW's Avatar
22 Aug 2024 15:29
Replied by PCW on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
Is there a tachometer from the motor connected to the drive?
  • greg23_78
  • greg23_78
22 Aug 2024 15:09 - 22 Aug 2024 15:10
Driver NUM GEC MK2S
it's not news, but I prefer to control it.
if i understand correctly, i have just mechanically disconnected my motor from my Z axis.
i put 10V on the drive and control the speed with a tachometer ?
but how adjusting the drives velocity loop  gain as high as possible while remaining stable ?
which button should I modify ?
-Zero offset
-Speed stability
-current limit
-Reference input
  • schuetzbuilds
  • schuetzbuilds
22 Aug 2024 15:04 - 22 Aug 2024 15:06
Replied by schuetzbuilds on topic Retrofitting a MAHO MH600T
So after the crucial tip from pcw I got the outputs working and configured the lube system. As for the hydraulic draw bar I repurposed the former cycle start button from our very simple hand held. After looking at the code for the central lubrication, I modified it a bit to fit the drawbar application and loaded it as drawbar component, which will only release the drawbar, if the spindle is not running.
It connects via Hal similar to the central lubrication component (wiki.linuxcnc.org/cgi-bin/wiki.pl?CentralizedLubricator).
# drawbar
loadusr -W /home/maho/linuxcnc/configs/maho_mh600t/drawbar.py
net drawbar-open drawbar.open => hm2_5i25.0.7i84.0.2.output-03
net machine-is-enabled drawbar.machine_status <= motion.motion-enabled
net spindle-enable drawbar.spindle_status
net drawbar-sw drawbar.open_sw <= hm2_5i25.0.7i77.0.0.input-00
  • PCW
  • PCW's Avatar
22 Aug 2024 14:50
Driver NUM GEC MK2S
1. If you have new drives, the drives themselves likely need
to be tuned first. This includes scaling the tachometer feedback
so you get full speed at 10V. It also means adjusting the drives
velocity loop  gain as high as possible while remaining stable.
2. Since these are velocity drives, you should use a velocity mode
tuning guide. Note that for properly tuned velocity mode drives,
the most important LinuxCNC PID term is FF1.
3. As far as output scaling goes, setting the output scale to the machine
units per second of axis velocity at 10V, means that now all PID terms
are normalized to engineering units, and FF1 == 1.0. This also makes
it easier to compare setups.
  • Todd Zuercher
  • Todd Zuercher's Avatar
22 Aug 2024 14:49
Replied by Todd Zuercher on topic Re-enable drives after a fault
As to your question about the position continuing to increase with the effector against a stop, could be explained by multiple reasons. It could be a physical issue such as flex in the machine or a coupling slipping, It could be an electrical issue such as noise causing miss reading of your encoder. It could be a Linuxcnc setting, such as the display set to show commanded position instead of actual. It could even be something is wrong with your kinematics model.
  • zmrdko
  • zmrdko's Avatar
22 Aug 2024 14:29 - 22 Aug 2024 14:29
Replied by zmrdko on topic is there some basic list to build the net ?
Category: EtherCAT
also you can get some inspiration in my config: github.com/zmrdko/3dworks_ethercat_lcec
not finished, but basics work.
  • Todd Zuercher
22 Aug 2024 14:26 - 22 Aug 2024 14:36
What do you have set for your MIN_FERROR and FERROR settings in your ini file? Perhaps you need to loosen those tolerances so that you only set a following error alarm when there truly is a significant problem?
Also those two settings work together and should not necessarily be the same. The MIN_FERROR setting sets the following error limit when the joint is stopped or moving extremely slowly, and can be set to a relatively small amount (maybe the machine unit equivalent to 50-100 encoder counts). The other setting FERROR sets the following error limit for that joint at it's fastest possible movement (programed max velocity limit). Generally this should be set to something significantly larger than the MIN_FERROR. What that should be will depend on the nature of the machine. For a fast linear joint that might need to be something like 10-20mm or several degrees for a rotary one.
Edit add
Linuxcnc calculates the actual following error limit linearly between the two MIN_FERROR and FERROR settings dependent on the speed of the joint.
  • greg23_78
  • greg23_78
22 Aug 2024 13:59
Driver NUM GEC MK2S
I changed the output-scale sign and now it works.
I've tried tuning my motor but I can't get it to work properly.
I find it strange that my motor remains stable when I activate my drivers with a P of 0.1. Above that, when I activate the motor, it races and oscillates.
After several searches, I find the same behavior as H bridge drives running PM DC motors.
I actually have a PM DC motor
I came across your procedure
Blatantly copied and pasted from a post made by PCW regarding H bridge drives:
Bare H-bridge drives running PM DC motors behave somewhat like velocity mode servos
(with quite low velocity feedback gain) So they end up being somewhere between velocity
and torque mode.
That is, you are setting the average motor drive voltage with the PWM value. This sets the
approximate motor velocity because the motor will accelerate to a velocity where the generated
back EMF is close to the supplied voltage. If the motor impedance was zero, you would have close
to a perfect velocity mode servo, but the impedance is substantial which leads to the low
inherent feedback gain.
Normally for Hbridges, I would start with a low P value and tune the D term as high as
possible without excessive buzzyness, then set FF1 so that the actual position does
not lead or lag the commanded position at full speed, then I would tune FF2 so that
the actual position does not lead or lag the commanded position during acceleration
Then I would tune P as high as possible without oscillation, overshoot and then when
everything else is close, add as much I term as possible without instability.
Thank you, PCW.
Please feel free to voice your advice, critique, additional info etc.
and that of IRAK
forum.linuxcnc.org/10-advanced-configura...ge-tuning-servo-loop
What procedure should I follow for my driver and motor?
In the IRAK procedure, it says “Set P to low value - about 1/4 any possible oscillation.” oscillation when enable the drive or i jog? because when I set P to 0.9 sometimes the axis oscillates and sometimes it remains stable (I'm not talking about jog because in all cases it oscillates even before P=0.2).
then as I understand it I need to “Set OUTPUT_SCALE to encoder.N.velocity” to know maximum speed the table (I presume I need to look at the speed through the encoder).
How do you do “Set OUTPUT_SCALE to encoder.N.velocity”?
  • Aciera
  • Aciera's Avatar
22 Aug 2024 13:41
Replied by Aciera on topic Re-enable drives after a fault
The end effector position reported by linuxcnc kept increasing but the arm wasn't moving.
Sounds like something is wrong with your setup.
Could you post your hal and ini files?
  • vick.trinity
  • vick.trinity's Avatar
22 Aug 2024 13:23
Replied by vick.trinity on topic Re-enable drives after a fault
Todd, thanks for your response.  You are correct, the right way to do this would be to add some sort of brake to the motor shaft.  However, due to the nature and budget of this project, that is not an option.
One of the responses that I got from the linuxcnc facebook group for this same question might be an option: Is it possible to:
"Create a component that is called by the Ferror pin which sets the joints to zero speed and re-enables the drives sounds like the right way to do it. "?
I am also curious about your statement: "The precise position was already lost due to the following error".  I think I noticed this after I increased the Ferror settings in the INI file and then drove the arm against an object.  The end effector position reported by linuxcnc kept increasing but the arm wasn't moving.  I didn't know linuxcnc worked like this - I thought It only reported the actual position from the encoders and the "desired" position was some other value.  I haven't had to worry about this on my mill because the desired and actual position are essentially the same.
Displaying 23611 - 23625 out of 24280 results.
Time to create page: 0.434 seconds
