  • scotta
  • scotta's Avatar
12 Aug 2024 20:38 - 12 Aug 2024 20:38
Replied by scotta on topic Remora for RP2040
Remora for RP2040
I don't want to seem intrusive. But does anyone have an idea and could help?
Hi, maybe this thread could help
Lathe Spindle control with step/dir - LinuxCNC
  • Mecanix
  • Mecanix
12 Aug 2024 20:34 - 12 Aug 2024 20:35
if you still have io-pins free on the FPGA, put them on test-pads if you can, you can always use them
Ok, I'll delay the pcb fab a day and see what I can do with those lonely 15 GPIOs. I'll have them all via and TP on the back side of the PCB.
Fine if I just leave them at their 3V3 logic level? Test pins assuming, [USE WITH CARE, pirate skull logo near lol]
  • meister
  • meister
12 Aug 2024 20:22
  • Limo
  • Limo
12 Aug 2024 20:18
Replied by Limo on topic Remora for RP2040
Remora for RP2040
  • AlessandroEmm
  • AlessandroEmm
12 Aug 2024 20:11
Replied by AlessandroEmm on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
thanks! I actually just come from further testing. I must have done something wrong. Because the states of the pins do actually change. Apologies.
How is it mapped now anyway, implicitly?
because on the top of the example-hal file it mentions that limit switches are configured. but i cant find them explicitly:
➜ remora-rt1052-basic cat remora-ec500.hal
# Basic HAL config file for NVEM controller board running Remora firmware
# Configured for 3 joints (A, Y, Z axes) with home and limit switches
Thanks!
Alessandro
  • Lcvette
  • Lcvette's Avatar
12 Aug 2024 20:09
Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
@Patrick,
for the vtk error, check the latest sim configs for changes there are many including the var file, Ini File, custom_config.yml, subroutines just about all of them, and the ui has received some pretty serious updates. that is one of the issues of trying to do customizations without using the user tabs. if you decide to make edits i strongly recommend using only the user tabs to do so which are not changed on updated and are loaded from your config folder.
Chris
  • SilverRain
  • SilverRain
12 Aug 2024 19:58
Replied by SilverRain on topic Question: Gmoccapy 3.4.2 and touchscreen
Category: Gmoccapy
I haven't been able to get 2.9.3 to work for over a month now. more and more new problems... on another machine 2.8.4 there are already 4 goals - everything is fine. I have no more strength. Tomorrow I will roll back to 2.8.4
  • Mecanix
  • Mecanix
12 Aug 2024 19:35 - 12 Aug 2024 19:36
Replied by Mecanix on topic Computer crashing
Computer crashing
Category: Installing LinuxCNC
Have a look into /var/log/syslog and see if you can find anything time-relevant to your issue(s).
  • Lpkkk
  • Lpkkk
12 Aug 2024 19:20 - 12 Aug 2024 19:22
Hi pin outputs you can find in the attachment.
Estop has 2 pins, same for probe. Other inputs have one common and one negative for each input.
  • Mecanix
  • Mecanix
12 Aug 2024 19:18
Replied by Mecanix on topic Y axis configuration
#*** AXIS_Y *******************************
[AXIS_Y]
MIN_LIMIT = 0
MAX_LIMIT = 144
MIN_LIMIT = -144
MAX_LIMIT = 0
[JOINT_1]
MIN_LIMIT = 0
MAX_LIMIT = 144
MIN_LIMIT = -144
MAX_LIMIT = 0
Rename attachement keybingdings.py.txt to keybingdings.py
Place into your /config/ folder.
Hope this helps.
  • scda
  • scda's Avatar
12 Aug 2024 18:47
Mesa7i96s + 7i85 + pktv2 firmware for Huanyang VFD
Category: Driver Boards
Hi PCW. Ok thanks for the reply. This was my backup plan, so I will probably go this route then and leave the modbus stuff for another project.
Cheers,
David
  • swepeter
  • swepeter
12 Aug 2024 18:43 - 12 Aug 2024 18:45
Pi4b and Pi5 users - What should go in a 2.9.3 image
how do i use a img.xz.sha256 file?
I believe that is the wrong file
  • Ismacr63
  • Ismacr63
12 Aug 2024 18:37
Y axis configuration was created by Ismacr63
Hi, I've been trying to configure my Y axis on a bf20 type milling machine for a few days now.
I've read a lot on the forum, but I'm not able to configure it the way I'd like.
I understand that the Y axis, when the spindle moves away from me (or the table moves towards me) should be positive. That's what my Y axis does
I have an inductive sensor installed as a switch for both limits and home. When I search for home it goes to the negative side and I want it to go to the positive side.
I've tried HOME_SEARCH_VEL = 10.000000 and it goes to the positive side, but after home it always hits the hard limits when I get close.
Another issue is that I'd like to change the direction I move the table on the Y axis with the keys. When I press the up arrow I'd like the table to move away from me.
  • PCW
  • PCW's Avatar
12 Aug 2024 18:36
I would think it would be simpler to use a 0-->10V analog spindle speed control
Also, I'm not sure if the Mesa MODBUS interface would work with the Huantyang
  • AndyDM01
  • AndyDM01
12 Aug 2024 18:27
I have serious questions about some stuff I didn't find an answer for
Category: EtherCAT
I am just overloaded with other jobs at work right now, didn't even get the one I am retrofitting from mach3 (dead Bob... again!) to linuxcnc to move yet... already working overtime just trying to get the normal repairs done in a normal schedule..
Displaying 24031 - 24045 out of 24438 results.
Time to create page: 0.955 seconds
