  • Odiug
  • Odiug
14 Jul 2026 19:49
qtDragon: Auto Return to Manual Mode After an MDI Command so MPG works
Category: Qtvcp
Hi Chris,
thanks for looking into it.
I am currently just running the normal 2.9.10 LinuxCNC. I guess it came with a version of QtDragon? I have to figure out first what's the best way to run the Master branch.
Can I check it out and use it parallel to the 2.9.10 version and be able to switch back and forth?
Guido
  • tuxcnc
  • tuxcnc
14 Jul 2026 18:37
Replied by tuxcnc on topic arcs in 4 axis mode
arcs in 4 axis mode
I have build foam cutter a few years ago and not remember details, but I think it was as follows:
There are two possibily configurations:
1. XY with master-slave axes - no cones, but you can use G2/G3.
2. XYUV independent axes - can cut cones, but can't use G2/G3.
When you use XYUV you must convert circles to strings of short lines in your CAD/CAM.
  • Todd Zuercher
  • Todd Zuercher's Avatar
14 Jul 2026 16:26 - 14 Jul 2026 16:26
Replied by Todd Zuercher on topic arcs in 4 axis mode
arcs in 4 axis mode
I've never worked with a wire foam cutter, but I have made some Linuxcnc configurations that can use some custom M-code commands that will temporarily slave two axis together such that one will move with the commands of the other. The machines I was using this on were routers with two spindles each mounted on their own axis and configured XYZW. I had ran these for years just using XYZW g-code, but when the multi-line look ahead planer was first introduced in Linuxcnc, it only supported XYZ moves, any moves with a W command reverted to the old single line tool planner, and significantly slowed the wood carving we did with these. So I built my config with an M-code that slaved the W axis to the Z at their current positions when the command was issued. The W would then follow the Z until I issued the M-code command that released the W. (This had to be done when Z and W were commanded to be at the same positions relative to the position they were slaved at, or the W would give a following error.) Maybe this technique could be useful for you? Here is a copy of one of my configurations.
File Name: TwinCNC.zip
File Size:93 KB
  • cmorley
  • cmorley
14 Jul 2026 15:38
  • tuxcnc
  • tuxcnc
14 Jul 2026 14:57
Replied by tuxcnc on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
The first problem is Python.
Python is powerfull, but permanently developed, so python scripts are version sensitive.
LinuxCNC depends on Python...
Debian is conservative, Ubuntu is progressive, so there must be version mismatches.
Sometimes old programs not works with new OS, but worst is when works, but not properly, become unstable or some functionality gone....
Believe me, experiments like LinuxCNC+Ubuntu are not worth wasted time.
  • GeckoWorks
  • GeckoWorks
14 Jul 2026 14:42 - 14 Jul 2026 15:42
Replied by GeckoWorks on topic Control panel
Control panel
Category: Show Your Stuff
Mass - thanks so, so much!:)
This is sweet. I will dive deeper into it in the days to come and the project you linked to. But I am almost sure I will buy a (used) SK4/6 panel. I wouldn't be surprised if they all come with the PS/2 + matrix combo. (Some will possibly be USB+matrix but that would just be a win). I know, no guarentees - also in terms of pinout and such, but the main foundation is certainly there as you have shown. And most important, nothing locked behind a proprietary serial protocol either, it seems.
But any chance you could share the code, too?
Having looked at the github for the Arduino-LCNC project a bit, I now realize that the matrix never gets turned into USB-HID or gamepad protocol, at all. Interesting. Maybe a better more direct approach.
Not that I really know what I will be looking at but with the help of Gemini, I managed to make a nice custom version of the NanoELS FW (an open source electronic leadscrew project) for my little lathe. Had to get DRO scales implemented and add some other features - and I actually managed to do so on code level. So, hopefully the robots can help me on this project, too.
Various Panels
As for SK4/6 I actually think they share the same layout 100%. I think I have even seen some SK6s with SK4 printed on the PCBs - but I could be wrong as I have looked at sooo many pics lately.
But there's also an SK5 which does have a slightly different layout. (Attaching pics of SK4/5/6).
Most often SK4 has membrane buttons whereas the SK6 often has tactile ones. I am leaning towards the latter.
But looking at SK PCBs get confusing very fast as there are so many different itirations of the SK4/5 plus a bunch of clones.
Encoder Overrides?
BTW, it looks like you swapped out the clicky rotary switches for pots or encoders? So, no hardstops at each end but possibly better "sync" between screen and knob, is that it?
I think I will try to stay with the rotaries and see how they feel.
14 Jul 2026 13:53
Replied by tommylight on topic linking U axis to X
linking U axis to X
We (this forum) do not close or retire topics as some forums do, i have no clue why they do that as the only thing that does is cause chaos and makes the forum unusable with many instances of the same Q&A that mostly never conclude or solve anything.
14 Jul 2026 13:50
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
See what Tuxedo OS uses for touch, i am sure it worked on Mint also as i tested on a Lenovo X1 Yoga a while back, but do not recall what the package name was.
  • foam man
  • foam man
14 Jul 2026 13:29
Replied by foam man on topic linking U axis to X
linking U axis to X
sorry, I posted on that one, but when nobody replied, I figured the post was too old and wasn't active anymore
  • Mr. Mass
  • Mr. Mass's Avatar
14 Jul 2026 12:58
Replied by Mr. Mass on topic Control panel
Control panel
Ha, that's spot on—I really did feel like a detective sometimes
The top part is a standard PS/2 keyboard; I connected it to the computer using a PS/2-USB adapter. I remapped the keys, mainly to access lowercase characters (Remap the Shift + button, just like in the original system).
The lower part is connected via an Arduino and an ArduinoConnector (forum.linuxcnc.org/show-your-stuff/48630-arduino-io-expansion).
On this keyboard, the pinout is rotated 90 degrees relative to the visual orientation, and not all pins are used. I added a pinout; I hope this helps.
P.S. The SK6 keyboard has a visually different circuit board; I haven't checked it, so all of this applies only to the SK4.
  • RoberCNC
  • RoberCNC
14 Jul 2026 09:18
Replied by RoberCNC on topic Problem with PROBE tab after running a program
Category: Qtvcp
Hi Chris.
Here you have the file.
  • Ismacr63
  • Ismacr63
14 Jul 2026 07:51
Replied by Ismacr63 on topic Probe Basic widgets missing
Category: QtPyVCP
Now it has let me set it to 5 + Jog, and it displays correctly.
  • Ismacr63
  • Ismacr63
14 Jul 2026 07:47
Replied by Ismacr63 on topic calling all probe basic lathe users!
Category: QtPyVCP
Sweet are you in the probe basic Facebook group?
Yes, I'm in the Facebook group.
  • BlownCorona
  • BlownCorona
14 Jul 2026 07:27
Replied by BlownCorona on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Heh.. the very next search i did after replying lead me to the info that the displaylink driver doesn't handle touch, Linux kernals hud-multitouch does.
always something new to learn eh.. though its pretty obveous in hindsight
  • BlownCorona
  • BlownCorona
14 Jul 2026 07:18 - 14 Jul 2026 07:23
To be fair to Tommy, I've used this ISO successfully for a while now, this is the first issue I've come across and its not anything to do with linuxcnc, and sounds like I can resolve it.
In fact the synaptics displaylink drivers are only officially offered for ubuntu, while there is a community Debian option available, and the second computer I have that I set up a Debian build on is struggling to get the screen to show anything, where as this Mint ISO already allows the screen to display and operate with single point touch only, which would actually be sufficient for a cnc mill, but less refined than the screen could be.
This goes to show that there are pros and cons to all options and its not at all accurate to claim we must stick with Debian.
With that said, i am wanting to try Probe Basic, and being that this was developed for Debian may be the way i go, hence the aforementioned debian unit.
To all that replied with useful information, greatly appreciated. Ill report back with results.
Displaying 2461 - 2475 out of 12540 results.
Time to create page: 0.322 seconds
