29 Apr 2024 18:52
Replied by tommylight on topic Is there a way to touch-off purely in HAL?
Category: HAL
My condolences.
  • JohnBr00ker
  • JohnBr00ker's Avatar
29 Apr 2024 18:52 - 29 Apr 2024 18:54
Replied by JohnBr00ker on topic 'Test this axis'
'Test this axis'
Category: StepConf Wizard
I've just had a brain wave - checked the parport mode in the bios, and discovered the default setting for this pc is PS/2.
Now faced with decision - EPP or ECP ?
EPP gives 2 addresses - 378h or 278h ?
ECP gives 3 addresses - 378h, 278h and 3BCh.
In addition, ECP then offers a DMA channel setting - OFF, DMA1 or DMA3
Feel I've opened a can of worms, but may be on the right track !
EDIT I've tried EPP with both addresses, but in both case I get the 'Error - broken pipe' pop up.
29 Apr 2024 18:51
Replied by tommylight on topic Resources for C++ User Space Component Authoring?
I think Rod mentioned a while back some google video about it, had a look at it, it was good so i saved it somewhere... no idea where, i'll have a look later and post back if i can find it.
Not sure if it was C++ but those are quite similar.
  • KlausB
  • KlausB
29 Apr 2024 18:22
Replied by KlausB on topic z_level_compensation
Category: Qtvcp
Hello Chris,
As announced, I tested the modified module today. The Z-axis is now moving. So far, I haven’t noticed any incompatibilities that might be due to a version conflict. Will you coordinate with Bill regarding the change? Will the modifications will be incorporated into a future update?
Thank you very much for your support and the work on this fantastic project.
Klaus
  • vedatech
  • vedatech
29 Apr 2024 17:26
Replied by vedatech on topic PREEMPT_RT no longer needed in Ubuntu?
I'm using ubuntu 22.04.4 with the initrd.img-5.15.0-1061-realtime kernel (PREEMPT_RT)
and a Mesa 6i25 pci card.
I get very good jitter so I'll stick with that for now.
I'm running a RIP install of 2.9.0~pre and want to upgrade to 2.9.2 but don't want to loose the edits I've done in the RIP directory.
Any suggestions?
29 Apr 2024 17:00
Replied by tommylight on topic Mesa 5i25 and 7i77 and Geckodrive G340's for sale
Category: User Exchange
All good.
Might be good to have a price estimate, though.
  • chowderhead
  • chowderhead
29 Apr 2024 17:00
Replied by chowderhead on topic Is there a way to touch-off purely in HAL?
Category: HAL
Sorry for the very late reply. Death in the family put all sideline projects on hold.
INTERP_IDLE has proven to be a mixed bag with other US components of mine. I'm looking at switching to C++ and getting a little lower level. If I have the chops.
  • chowderhead
  • chowderhead
29 Apr 2024 16:54
I've been writing US components in Python, and want to test the C++ waters. Are there any resources to get me going? My C++ skills are middling...
  • chimike
  • chimike
29 Apr 2024 16:44 - 30 Apr 2024 16:52
I have an unused Mesa 5i25 / 7I77 setup for sale in the UK that has only been bench tested , but never fitted to a machine.
Also, 4 off Geckodrive G340's ,early ones, again, run on bench, but not on a machine.
Not sure of the protocol on this Forum, please advise.
  • DK8DE
  • DK8DE's Avatar
29 Apr 2024 16:34 - 29 Apr 2024 16:36
Replied by DK8DE on topic mesaCT, 7i95t and SPINx
Category: Basic Configuration
Hello,All my issues are resolved. The spindle is running, and the end stops and stepper motors are also functioning. For those looking for an example, I have attached the files.
File Name: io.hal
File Size:1 KB
File Name: custom.hal
File Size:0 KB
File Name: handrad.hal
File Size:10 KB
File Name: spindel_alt_neu.hal
File Size:6 KB
File Name: spindel_alt_neu.ini
File Size:7 KB
  • Thayloreing
  • Thayloreing
29 Apr 2024 16:31
Replied by Thayloreing on topic Linuxcnc keeps the port connected when exiting
Good afternoon, I came to ask for help once again, a while ago in this post I asked a question and they told me the charge pump, I have some doubts, I saw in the video that they put the link that the charge pump activates a relay, so that Would this relay be exactly? I saw the video, but I don't speak English, I translate everything, then I didn't understand much because I couldn't translate
  • PCW
  • PCW's Avatar
29 Apr 2024 15:57 - 29 Apr 2024 20:29
Encoder connection for threading on lathe
1 PPR threading should be OK with a servo spindle (its no good if the spindle speed varies)
But there is no direct support for this with Mesa encoders so its probably easiest to use A/B/I
Theoretically you could connect the drives index to the encoder A and I inputs and use interpolated position
but this has not been tried AFAIK.
Edit, I just tried this and it does seem to work:
1. Connect 1 PPR signal to Mesa encoder A and I.
2. Set encoder scale to 1 and count mode true.
3. Use encoders interpolated position (this may be in LinuxCNC 2.10 only)
  • LearningLinuxCNC
  • LearningLinuxCNC's Avatar
29 Apr 2024 15:40
Replied by LearningLinuxCNC on topic Questions about moving install from one system to another
So I moved the hard drive to another motherboard and now all is well with the setup. Must have an incompatibility or a problem on the one motherboard.
  • EddySPalm
  • EddySPalm's Avatar
29 Apr 2024 14:29
Hello,
I was hijacking another guy's similar thread about roughly the same subject, but I should really stop cluttering his thread now and make my own.
I have now bought some of the very common Chinese AC servos on aliexpress (Lichuan with A5 drives), and will be using them as both axis and spindle motors.
The spindle motor will drive the spindle with a 1:1 ratio, so the plan was to just use the encoder output from the servo drive as-is, directly into the encoder input on the 7i96s.
I have understood that an index pulse will be enough to do threading on the lathe (both single point and rigid?), but will it be beneficial to feed the A+, A-, B+ and B- pulses also? or will it just complicate things?
  • PCW
  • PCW's Avatar
29 Apr 2024 14:23
Replied by PCW on topic SERVO_PERIOD
SERVO_PERIOD
The trajectory period can be set though it defaults to the servo thread period.
man motion
Displaying 26131 - 26145 out of 26688 results.
Time to create page: 0.408 seconds
