  • andrax
  • andrax's Avatar
29 May 2026 18:30
TTL to differential converter (STEP / DIR / ENABLE)
Also ich hab mal geschaut.
Standartmäßig gibt es meistens max 3 Kanal für die typischen ABZ Encoder.
Gegenfrage: was hast du vor, evtl. gibt es eine andere Lösung?
  • spumco
  • spumco
29 May 2026 17:50
Replied by spumco on topic Reset Custom M-codes on Machine Disable?
According to the docs, shutdown.ngc only gets run when exiting normally.  Machine-off state does not trigger it, and neither does a PC crash.
I think on-abort.ngc should work without explicitly remapping.  A quick test could confirm:
  • Create a test abort.ngc file with something in it to test (i.e. halcmd to set a pin value)
  • Add the file to you INI
  • Create user M-code (M1xx) which creates some sort of call to the abort.
    • All of my M66 checks in the various tool-change (or similar) sequences have something like:
    • [*]M66 P9 L3 Q2                                        ; Check ATC door open sensor
      O100 if [#5399 LT 0]
            M65 P8                                          ; Turn off ATC door open solenoid
          (abort, ATC door not open)                      ; Abort if the sensor does not activate in 2 seconds
        O100 endif
You could make the abort.ngc be the bash script, or you could create another M1xx bash script and use abort.ngc to call that M-code.
Once you've got everything set up, open halshow and add the hal pin you want to twiddle using abort.ngc.  Call the M-code which will abort and see if the hal pin changes state.
  • PCW
  • PCW's Avatar
29 May 2026 17:39 - 29 May 2026 21:02
The conversion interface parts depend on the signal levels needed.
For RS-422 (going into a line receiver on the drive ) where 3V signals into a load are OK,
any RS422 driver will work (say 26LS31 equivalent for 4 channels/chip)
If you wish to drive optocoupled drive inputs that expect 5V signals, you would need
a driver with 5V outputs. AFAIK the only 4 channel RS-422 drivers that do this are
the ISL32174,ISL34172 and MAX3042 (The MAX parts are expensive)
Another option for 5V signals is to use a combination of ACT driver chips with inverting
and non-inverting  outputs, say a 74ACT540 and a 74ACT541.
  • PedPEx
  • PedPEx
29 May 2026 17:20
Retrofitting an old industrial CNC mill with EtherCAT components - MAHO MH400E
Category: EtherCAT
Hello guys,
Here is a little update. Since my last post, I had a detailed look at my picture gallery, specifically at the pictures of an EL5021 terminal I bought and disassembled back in early 2025. The original plan back then was to add an axial resistor in order to get it to read 11µA encoder signals. I quickly realized that wouldn't work, took some pictures, reassembled it, and returned it to the seller.
Last weekend, I took another detailed look at the PCB of the EL5021 and recognized the interpolator IC Beckhoff is using: an iC-Haus iC-NQI. For my own interpolator solution, I had actually copied the typical application circuit straight from that datasheet. That's why I immediately reordered an EL5021 terminal off eBay, opened it up, and properly reverse-engineered it today.
Beckhoff is actually following this required application circuit almost exactly ( Datasheet iC-NQI, Page 24, Figure 30 ). They are also using 4.7k Ohm resistors for RS1 and RS2. Those have to be swapped for 50k Ohm ones (I will test if these are too big; possibly 43k or 47k are better suited), and lastly the 120 Ohm resistors need to be removed. This way, the EL5021 terminal should be able to read 11µA sensors. By adding a 120 Ohm axial resistor across each input channel (A & /A, B & /B, and C & /C), the EL5021 can again be used for 1V signals. In theory, it would also support TTL signals, but that is outside the scope of this test.
Other than that, I vibe-coded a CiA402 dashboard tab for LinuxCNC to be able to see any problems with the Danfoss VFD directly in one place, without needing to decode the status word or the command word. The Danfoss VFD is now also able to read the frequency of an inductive sensor, internally calculates the motor speed, and reports that speed back via a PDO as feedback speed.
Additionally, the decision was made not to keep the original relay-based DC gearmotor solution, but to switch to two Beckhoff EL7332 terminals. Details about that coming soon™.
I'll test the functionality of the modified EL5021 terminal and keep you posted :) Wishing you all a great weekend!
  • Todd Zuercher
  • Todd Zuercher's Avatar
29 May 2026 16:53
Replied by Todd Zuercher on topic Reset Custom M-codes on Machine Disable?
Does a shutdown hal file only run on exiting out of Linuxcnc, or would it run when ever the machine is disabled to the machine off (F2) state? That sounds like the simplest way if it the shutdown hal is exicuted when ever the machine is put to the off state.
Will the on_abort.ngc work without remap? I'm assuming that the file should not have any motion causing codes in it. Are there any restrictions as to what commands can be executed in it? If I can execute some custom M-codes in it, that should be good enough for my purposes.
  • PCW
  • PCW's Avatar
29 May 2026 16:41
Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
Category: Plasmac
It sounds like the maybe Ethernet on the host has power management or enabled or something similar
what does:
ethtool --show-eee [ethernet device name]
report?
[ethernet device name] is the name of the Ethernet device connected to the 7I76E,
something like eth0 or eno1. You can get the device name from a the results of
the command
ip a
  • RMJ fabrication
  • RMJ fabrication
29 May 2026 15:57
Category: Plasmac
This problem has always been there, it is a new build I just completed last week and I have gotten this error from the start.
  • PCW
  • PCW's Avatar
29 May 2026 14:08
Category: Plasmac
OK, the /INIT LED is illuminated on the 7I76E which means this is not a 7I76E power issue
but either a host or 7I76E network issue. (The /INIT LED indicates a watchdog bite)
Is this a new problems or has it always been there?
  • Asymmetrisch
  • Asymmetrisch
29 May 2026 13:35
Replied by Asymmetrisch on topic TTL to differential converter (STEP / DIR / ENABLE)
Gibt es so eine Lösung evtl. auch gleich mit mehreren Kanälen?
Da kommen ja doch einige Module zusammen bei 3 oder 4 Achsen...
  • andrax
  • andrax's Avatar
29 May 2026 12:39
Jupp,
txd = transmid Data
rxd = receive data
du willst ja nur Senden, also txd
Board ist eigentlich egal, z.b. das hier:
Amazon
  • Asymmetrisch
  • Asymmetrisch
29 May 2026 12:25
Ah ok, vielen lieben Dank!
Das sind dann die Konverter mit dem MAX490, und hier dann nur TXD, Y und Z (Senden) anschließen, richtig?
  • spumco
  • spumco
29 May 2026 12:23
Carousel component with CIA402 controlled Ethercat closed loop stepper
Just checking back here - any progress or example of using an Ethercat drive with carousel.comp?
  • low79fx
  • low79fx
29 May 2026 11:56 - 06 Jun 2026 11:36
Replied by low79fx on topic Installing ethercat repositories
Category: EtherCAT
  • spumco
  • spumco
29 May 2026 11:40
Stepperonline A6 Ethercat - Digital IO [SOLVED]
Category: EtherCAT
Great you worked it out. But normally, there will also be settings to tell the type of input. eg, GPIO, Max Limit, Min Limit, Estop (disable drive),
Did you work that out too? eg If you want to use as GPIO, you need to set the type to be GPIO for a specific pin for internnalhoming, you need to set homing.
Yes, I worked that out, too.  I'd already set the DIO appropriately before starting this thread.
Unlike the missing output information, the manual is explicit on DIO function configuration:
  • Via parameters:
    • DI - C04.00-C04.12
    • DO - C04.30-C04.35
  • Via Ethercat:
    • 2004, sub-index 01 through 36
As I stated in my first post, this was a only basic bench test to explore the drive's IO with some buttons and LED's.
  • Henk
  • Henk
29 May 2026 11:27
Bosch Servodyn-D DSS configuration software
HI all
Does anyone have a copy of the above software?
Used to configure Bosch Servodyn-D  servo drives
Henk
Displaying 3421 - 3435 out of 12542 results.
Time to create page: 0.263 seconds
