  • ts
  • ts
25 Mar 2026 07:15
Ext hard buttons duplicate Power_PB and Reset
Category: Flex GUI
Hi, JT!
i didnt understand how to add functionallity, to doplicate fleglxgui buttons like a PowerPB and Reset (included functions, and there are not in Hal components) to the external hard electrical contacf buttons (ext btn already in hal, but where the pin signals to connect it)?
Thanks in advace!
TS
  • bladekel
  • bladekel
25 Mar 2026 07:01
I tried it as you said but nothing changed.
Again receving "USRMOT: ERROR: command timeout" errors and couldnt control the LEDs.
    "rpi5": "true",
    "rpi5": true,
Thats the trick, thank you.
Its working now...
  • rock861261
  • rock861261
25 Mar 2026 04:11
Replied by rock861261 on topic El5101 Config
El5101 Config
Category: EtherCAT
Seems to all be working correctly open to any additional inputs
  • rock861261
  • rock861261
25 Mar 2026 04:00
El5101 Config
Category: EtherCAT
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
loadrt ddt names=spindle-v
loadrt mult2 names=rpm-calc
loadrt near names=spindle-at-speed
loadrt lowpass names=spindle-filter
addf rpm-calc servo-thread
addf spindle-at-speed servo-thread
addf spindle-v servo-thread
addf spindle-filter servo-thread
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
setp lcec.0.El5101.enc-pos-scale 2000
net spindle-pos-fb lcec.0.El5101.enc-pos => spindle-v.in => spindle.0.revs
setp rpm-calc.in1 60
net spindle-rps spindle-v.out => rpm-calc.in0
setp spindle-filter.gain 0.1
net spindle-rpm-raw rpm-calc.out => spindle-filter.in
net spindle-rpm-fb spindle-filter.out => spindle.0.speed-in
setp spindle-at-speed.scale 1.1
setp spindle-at-speed.difference 10
net spindle-vel-cmd spindle.0.speed-out => spindle-at-speed.in1
net spindle-rpm-fb => spindle-at-speed.in2
net spindle-at-speed-sig spindle-at-speed.out => spindle.0.at-speed
net spindle-index-enable lcec.0.El5101.enc-index-c-enable => spindle.0.index-enable
net spindle-rpm-fb => pyvcp.spindle-speed
  • grandixximo
  • grandixximo's Avatar
25 Mar 2026 02:36
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I will try to replicate, thank you!
  • Lcvette
  • Lcvette's Avatar
25 Mar 2026 00:52
Replied by Lcvette on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
If you want to contribute to the pyside6 branch you can use the new Trixie installer in my GitHub, but this is for development use only, not for machine use yet.
  • Lcvette
  • Lcvette's Avatar
25 Mar 2026 00:50
Category: QtPyVCP
It's still work in progress, not ready for official release yet. Once it is it will be available for normal install with updated docs. The latest vtk edits are still in a testing branch and have not even been merged into the pyside6 branch.
  • Lcvette
  • Lcvette's Avatar
25 Mar 2026 00:46
30 Second timeout before opening and E-Stop button not clicking...
Category: QtPyVCP
How about the SIM, does the SIM start and work as expected? If so it's almost certainly a config setting issue.
This sounds like maybe an estop conflict. Or perhaps a post gui hal file issue.
  • PCW
  • PCW's Avatar
24 Mar 2026 22:06
Replied by PCW on topic What's the opposite of skipping steps?
Category: Driver Boards
Needs to be done with physical wiring
  • frankomatic
  • frankomatic
24 Mar 2026 22:01
Replied by frankomatic on topic What's the opposite of skipping steps?
Thanks, that sounds like exactly what I need. Do I need to connect it electrically or can it all happen in hal?
  • AntonioT
  • AntonioT
24 Mar 2026 21:01
THC not getting active even when "all seemingly needed" requirements are met
Category: Plasmac
Hello Tommy thanks for your response, yesterday in follow up to your suggestion I set the parameters as I will show in the pictures below and I have some updates:For the first time THC stayed enabled during the cut, this happened around once every 5-8 tries, dint have the chance to validate it worked properly but that is some progress.*Something that i was not doing before is to set same speed in material table as well as in the G1 command of the G code idk yet if that has something to do with it, please see the next items.*Normal behaviour in my setup is that screen always went black for a second or two right after the pierce, it was so consistent that thought it was a feature of the GUI, yesterday noticed only a few runs where the screen did not go black, some of those matched the times where THC remained enabled. I checked and seems that the black screen is rather an issue caused potentially by EMI?*Changed plasma source settings to increase pilot arc and I could see the screen going black more violently. i.e. with flickering before going black.I am making some improvements to grounding to see if this helps, do you have any recommendations to make the arc ok, feature more resilient? in case that it is emi or do you have any other idea thanks.
  • PCW
  • PCW's Avatar
24 Mar 2026 20:27
If you want to, you can loop back a step/dir channel to the 7I96S's encoder
Step to A and DIR to B  with the encoder set to UP/DOWN  =  counter mode
This is how the hardware Step generator was originally tested
  • fletch
  • fletch's Avatar
24 Mar 2026 20:11
A Teensy -> Python Interface Manualmatic MPG/pendant
just found this manual matic pendant, but teensy 4.1 is too expensive ower price board, can i use teensy 2.0 this ? lot lot cheapen, and what need dong encoder or other library, ?not understand english good, need change arduino ide encoder library to new and were have ? i come old teensy 2.0 USB pendant all time only errorrs whit encoder.h
no declare scope etc. i not know what this all mean. not need diplay , only encoder and rotary SW change acis and scale. can move XYZ remote controll. were i found code teensy 2.0 can use. this.
Hi - the project is based around the Teensy 4.1 to ensure responsiveness from both inputs and the display. Technically you could use a Teensy 4.0 on the PCB (ir I created a common footprint) but I have not tested this and you would not be able to use the 5 physical buttons below the display.
If you don't need the display, this is probably not the right hardware to base your project off but the Manualmatic Python Component and pendant code is all open source so should help point you in the right direction. A Teensy 2.0 would no doubt be more than enough to run an MPG and an encoder button or two.
The Encoder (`encoder.h`) library is designed/written by PJRC for the Teensy range and is extremely reliable, so not sure why you are getting errors. You could use my InputEvents library (in Arduino IDE  and PlatformoIO library managers) to make it easier to use the base Encoder library.
HTH
  • frankomatic
  • frankomatic
24 Mar 2026 20:05
I thought about that, so I marked the position of the pulley on the motor and ballscrew, but they didn't move and the belt didn't skip. Also the ballnut mounting and the bearings on the fixed side of ballscrew have no backlash.
I think the primary problem is the 455 steps/mm. The microstepping is set to 3200, the motor pulley is 20 teeth, the ballscrew pulley has 30 teeth and the ballscrew pitch is 10mm. That should be 480 steps/mm, but if I set it to that it moves about 5% farther than it should. I should somehow count the pulses coming out of the 7i96s, but I haven't been able to convince my oscilloscope to count reliably. Is there something in halscope that would show that?
  • Todd Zuercher
  • Todd Zuercher's Avatar
24 Mar 2026 19:44 - 24 Mar 2026 19:46
Replied by Todd Zuercher on topic Updating Old GladeVCP Files?
Category: GladeVCP
With further testing, I'm seeing one weird quirk that I can't quite figure out.
I would like the two sets of clamping radio buttons to also indicate the state of the clamps. Because the clamps can also be activated/deactivated by custom M-codes in g-code, or by set of physical buttons on a user panel on the other side of the machine, I added some hal pins in the call back file to set each radio button active. The real buttons and M-codes all work as expected as I want them to. But when I press the unclamp button in the GladeVCP the clamps, unclamp then reclamp, then unclamp again. (And I have not even connected or used any of the hal pins I've added yet.) The GladeVCP clamp buttons seem to be working correctly.
Any ideas?
Displaying 5371 - 5385 out of 12543 results.
Time to create page: 0.308 seconds
