  • NWE
  • NWE's Avatar
03 Mar 2026 18:13
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
If someone with LCEC + CiA402 hardware would be willing to test the modular stack on real drives, I can prepare:
- Clean HAL example configuration
- Minimal README
- Reproducible test steps
- Fault and homing test scenarios
I currently have a Lichuan model OL57E-4A 4-axis drive and a Stepperonline model A6-750EC 750 watt servo drive set up on the workbench for testing, I can connect homing and limit switches without too much trouble.
Both are LCEC + CiA402.
The Lichuan manual is available here:  git.gitcoding.net/nwe/lcec_4x_stepper/src/branch/main/manual
The Stepperonline manual is  here .
I'd be willing to test drive your config. It might be a couple days till I find time.
  • PCW
  • PCW's Avatar
03 Mar 2026 18:01
Replied by PCW on topic Trying to set up position control mode
Category: HAL
I would agree with Tom here, that there's something basic wrong with the hal  or ini files.
(my guess would be no position feedback connection from the steppgens)
  • meister
  • meister
03 Mar 2026 17:57
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
I think I need to apologise, I'm currently testing a working serial/USB setup.
Not simple IO, 1kHz loop 3-axis stepper real-time control.
But I can't quite believe it yet, still have a lot to test.
I actually wanted to try building something for the RPI serial port, small and cheap, but for development I have it on the PC with USB/serial, and the bloody thing works.
  • depronman
  • depronman
03 Mar 2026 17:53 - 03 Mar 2026 17:54
signal tool change complete with physical panel button
Category: Gmoccapy
Norbert,
Was the HAL pin for 'manual tool change confirmation dialog' ever implemented ?
I'm in the process of changing from par ports to mesa 7i92 and moving the PC out of the machine cabinet, as such my keyboard hack for a physical button on the control panel to press the 'Enter' key is no longer practical and with the larger amounts of i/p pins on the mesa card I would like to hook the physical button to a mesa gpio i/p pin and use that to clear the gmoccapy tool change dialog popup
now using 2.9.8 latest build
  • hitchhiker
  • hitchhiker
03 Mar 2026 17:52
EMCO Compact 5 cnc Turret with dc motor and no feedback
No because i have no feedback! Its only a dc motor and a disc that rotats in one direction and if you drive backward it looks against a pawl.
Here the mechanism
The dc motor drives a planetary gear.. the gear drives a wormgear.. the wormgear rotate the disc where the tools are mounted.
do you have a better solution without any feedback?
its not a issue to drive it to tool one and set it as tool 1.
i had years before mounted a stepper and done it with O Codes.. but the dc motor which was original used is bettee because it hold against the pawl. With stepper there is small small movement on the tool because its not holded against the pawl like the dc motor it does.
  • andrax
  • andrax's Avatar
03 Mar 2026 17:32 - 03 Mar 2026 17:40
Replied by andrax on topic CiA 402 Folder Missing
Category: EtherCAT
dmesg_new looks better.
However, your vid and pid are incorrect.
They are from Stepperonline A6.
You must enter those from your servos.
vid according to manufacturer xml: 00000eff
pid: 0d3e0001 (not sure)
Note:
please use: dmesg | grep ethercat as root
sudo su
password
that's conspicuous
EtherCAT ERROR 0-3: AL status message 0x001A: "Synchronization error".
03 Mar 2026 17:30
Are you using the "carousel" component, or any other, or python remap for the tool changer?
03 Mar 2026 17:29
Replied by tommylight on topic Forum Fehler, ... :-(
Category: Deutsch
Today morning still did not work for me, now evening and it works with Dark Reader active, so try again and let us know if it works.
The forum server is being backed up and upgraded, but for now there are no issues i can see.
03 Mar 2026 17:26
Replied by tommylight on topic 7i92T and mx3660 request for help
Category: PnCConf Wizard
set the HOME_search/latch/final velocities to something really, really slow, that way you can see what part of the sequence is causing the issue while homing.
03 Mar 2026 17:24
Replied by tommylight on topic Trying to set up position control mode
Category: HAL
upload the hal and ini files here so we can have a look.
  • T_D
  • T_D
03 Mar 2026 16:37
Replied by T_D on topic Probleme mit NativeCam
Category: NativeCAM
i have found the problem , the problem was the sentence in the RS274NGC part :
[RS274NGC]
RS274NGC_STARTUP_CODE = G17 G21 G40 G43H0 G54 G64P0.005 G80 G90 G94 G97 M5 M9
# required NativeCAM item : PARAMETER_FILE = linuxcnc.var   <=HERE WAS THE FAULT I HAD WRITTEN THIS BUT THERE SHULD BE THE PLACE WHERE THE DATA SHULD BE => /Usr/linuxcnc/MY_CONFIG/........
SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities
  • billykid
  • billykid's Avatar
03 Mar 2026 16:18
5I20 replacement was created by billykid
5I20 replacement
Ten years ago I mounted a 5i20 on a friend's lathe. I remember we used all four ports because he wanted to use the original switches for feedrate and other things. Now he'd like a spare board in case of failure. What can I use with four ports?
  • Finngineering
  • Finngineering
03 Mar 2026 15:27
Replied by Finngineering on topic XHC WHB04B development?
I flashed back the original firmware to my dongle for testing. When commenting out the assert and adding a debug print there instead if r != 0, I get the following output during jogging in auto:
in    0x04 10 00 00 10 11 00 10 delta 16 => | 04 | 10 |                 |                 |     1( 30%) |     X(    ) |   0 | 10
pndnt wheel  event 604
pndnt wheel total counts {counts=604 activeCounter=0 isLeadActive=0}
in    0x04 10 00 00 10 11 06 10 delta 16 => | 04 | 10 |                 |                 |     1( 30%) |     X(    ) |   6 | 10
pndnt wheel  event 610
Can't switch mode while mode is AUTO and interpreter is not IDLE
hal   failed to wait for requested mode. waited 300ms
pndnt wheel total counts {counts=610 activeCounter=0 isLeadActive=0}
Usb::setupAsyncTransfer() libusb_submit_transfer failed with code -4
transmission failed, try to reconnect ...
connection lost, cleaning up
init  pausing 3s, waiting for device to be gone ....... done
init  usb context ... ok
init  not waiting for device XHC-WHB04B-6 vendorId=0x10ce productId=0xeb93, will continue in 0s .... ok
init  XHC-WHB04B-6 device found
init  detaching active kernel driver ... ok
init  claiming interface ... ok
init  enabling reception ... ok
task: main loop took 0.036080 seconds
I tried more than 10 times in a row, and every time the pendant successfully reconnected. In other words, I cannot reproduce your issue. And unfortunately that also means I cannot be of much help to you.
It is a bit surprising that you get the same issue on two different machines, and I don't. Or are the two machines you tested on fairly similar? Could still be e.g. kernel version difference, I suppose. In case they have fixed some usb bugs related to this. It's a bit of a long shot, but I don't have anything better at the moment.
  • T_D
  • T_D
03 Mar 2026 14:24
Category: NativeCAM
i have opened the file as an . ngc file but the same error accurs with seeking o word in line 92 what i am making wrong? please help  is there something i could try to find out what the problem is ?
Displaying 6226 - 6240 out of 12554 results.
Time to create page: 0.905 seconds
