  • Muecke
  • Muecke's Avatar
02 Mar 2026 18:49
Replied by Muecke on topic Forum Fehler, ... :-(
Category: Deutsch
Can you post from a phone or a tablet?
Das Problem besteht gerade wieder. Auf Tablet, Smartphone und PC bekomme ich die gleiche Meldung. :(
Liegt das an meinem Gerät? Kann ich etwas tun, um diesen Fehler zu umgehen?
  • hitchhiker
  • hitchhiker
02 Mar 2026 18:38
EMCO Compact 5 cnc Turret with dc motor and no feedback
Hi guys
does someone done a retrofit of the compact 5 cnc with turret with dc motor and NO feedback?
my way would be:
add a pyvcp menu to make move from tool position to tool position.
if i reach tool 1 i set with a button that its now tool1.
every move from tool to tool would lock first back and then drive forward to next position...
turret can rotate forward free. Backward would lock it.
after locking backward reducing power is needed.
i have here a l298n modul and a mesa 7i92 with bitfile adjusted to have pwm and 2 gpios for setting direction.
i cant find a custom library for it. But is this the correct way to do it or i am complete lost? Its not the issue to set tool 1 manual over buttons.
Forward u would use pwm 100%
Backward pwm 60%
and holding against the pawl about pwm 30%
any ideas or help?
thanks
  • Q-Man0815
  • Q-Man0815
02 Mar 2026 18:20 - 02 Mar 2026 18:41
Handrad XHC-WHB04b-6 braucht 9b für LEAD Funktion
Category: Deutsch
Signals utilized for operating spindle and feed override. The feed rotary button can serve in
  • Continuous move x% from max velocity
  • Step move x mm
  • MPG override feed/spindle
  • The special position Lead.
    Continuous: In this mode jogging is performed at the selected feed rate. As long the jogwheel turns, the selected axis moves.
    Step: In this mode the machine moves steps  wheel_counts at the currently selected step size and the current set feed rate in machine units. If the commanded position is not reached the machine keeps moving even the jogwheel is not turning.
    Lead: Manipulates the spindle override.
    MPG: Manipulates the feedrate override.
    See here  xhc-whb04b-6
    Signale, die zum Betätigen von Spindel und Vorschubübersteuerung verwendet werden. Der Vorschub-Drehknopf kann dienen als
  • Countinou: Bewegung x% von der maximalen Geschwindigkeit
  • Steps x mm
  • MPG-Vorschubübersteuerung
  • Die Sonderstellung Lead
         Continous: In diesem Modus wird das Joggen mit der gewählten Vorschubgeschwindigkeit durchgeführt. Wenn man                        das Jogwheel dreht, bewegt sich die ausgewählte Achse.
          Step: In diesem Modus bewegt die Maschine mit den Schritten  wheel_counts bei der aktuell ausgewählten Schrittgröße                  und der aktuellen Soll Vorschubrate in Maschineneinheiten. Die Maschine bewegt sich so lange bis die Anzahl der Schritte                abgearbeitet ist, selbst dann wenn das Handrad nicht gedreht wird.
         Lead: Manipuliert die Spindelübersteuerung
         MPG: Manipuliert die Vorschubübersteuerung
              Siehe auch   xhc-whb04b-6
  • papagno-source
  • papagno-source
02 Mar 2026 18:01
Post process Fusion 360 lathe was created by papagno-source
Category: Fusion 360
Hi.
Existe the postprocess for Fusion 360 fo lathe machine , with use the g7x cycle ?
  • andrax
  • andrax's Avatar
02 Mar 2026 17:57
  • IKEmaster
  • IKEmaster
02 Mar 2026 16:29
Replied by IKEmaster on topic DynexHobby impulse 2 for sale
Category: User Exchange
I need 1 card, 1 rpm sensor, 1 accelerometer + cable.
  • Smitherman
  • Smitherman
02 Mar 2026 15:27
Cumark Closed-Loop VFD with EtherCAT (non-CiA402) Configuration
Category: EtherCAT
I can but, i dont really know how to copy the Config to the PC right now. I need to check that
  • Hakan
  • Hakan
02 Mar 2026 14:35
Replied by Hakan on topic XHC WHB04B development?
Exactly the same log message.
I also tested to unplug + plug back the dongle. Exactly the same log message.
Both ended up in the debug message in libusb.
It can of course be my hardware. It isn't to difficult to test with another test computer I have.
  • Eisbaeeer
  • Eisbaeeer
02 Mar 2026 13:34 - 02 Mar 2026 13:38
Replied by Eisbaeeer on topic Dual axis Lichuan driver configuration problem
Category: EtherCAT
Hi David
Did you get running the 2A?
Im own the version with 4 axis and trying to get the right ethercat config.
The name of driver is CL57E-4A.
I will try to expand your example to 4 axis.
Perhaps you can told me, if you get it running?
Greets Lars
I have a second driver from Lichuan called OLC-E57H. I will also try to get it running. I think this should work all in same structure (hopefully).
  • amanker
  • amanker
02 Mar 2026 13:30
Replied by amanker on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
  Thanks for giving such a detailed guide, I tried to solve it by looking at code, but I couldnt. How ever I managed to solve it, But its really not a solution.
  • Hakan
  • Hakan
02 Mar 2026 13:24
I use the built-in :) libusb-1.0 in debian bookworm (12.13)
It says
#define LIBUSB_API_VERSION 0x01000109
in the include file.
I was able to install libusb 1.28, compile xhc component with it and at least it starts.
I have a minimal milling job this afternoon. I'll see how it reacts.
  • RotarySMP
  • RotarySMP's Avatar
02 Mar 2026 13:17
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Good input, I have used names before, but had forgotten it.
Cheers,
Mark
  • Red_D85
  • Red_D85
02 Mar 2026 12:57
Replied by Red_D85 on topic Maho MH-400 Retofit
Maho MH-400 Retofit
Category: Deutsch
Hattest du die originalen Glasmasstäbe für die Positionierung angezapft? Ich Spiele mit dem Gedanken die Position einzufrieren wenn die Achsbewegung abgeschlossen ist um ein Nachregulieren zu verhindern und würde statt den Massstäben den Encoder vom Servo anzapfen. (ich weis das es zur lasten Genauigkeit gehen kann)
  • Finngineering
  • Finngineering
02 Mar 2026 11:43
Replied by Finngineering on topic Schaublin 125-CNC retrofit.
Category: Turning
Nice video and good work! It's interesting to see the internals of the tool changer. And it will be interesting to see how it works once you have it all back together.
By the way, regarding the earlier video. Are you aware that you can use named parameters in g-code?
linuxcnc.org/docs/stable/html/gcode/over...ode:named-parameters
I think it improves readability quite much if you use variable names like #<partnum> instead of something like #50. Especially if you have many parameters, and might still need to understand the code the following day
  • roland
  • roland's Avatar
02 Mar 2026 11:35
400V Servo (51 Nm) mit EtherCAT / CiA402 in LinuxCNC – bezahlbarer Drive gesucht
Category: Deutsch
Der Motor hat ja über 20 kW...
Hinter dem 140:1 Getriebe hätte der ein Haltemoment von 7000 Nm. Krass
Displaying 6286 - 6300 out of 12554 results.
Time to create page: 0.455 seconds
