  • PCW
  • PCW's Avatar
13 Feb 2026 21:46 - 13 Feb 2026 21:47
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Category: Driver Boards
It should be possible with hm2_modbus,
(as long as the devices sharing a link have the same baud rate)
mesa-modbus only supports one device (per host UART)
  • PCW
  • PCW's Avatar
13 Feb 2026 21:44
Retrofit 7 ton HOMAG with Rexroth motors and drives - mesa 7i97t
No, if you set all PID values to 0 in the .ini file, run linuxcnc
and set LinuxCNC into the machine-on state, all PWM values will be 0
and the PWM enables should all be true (at least for the joints enabled in the hal file)
  • Nkbhvid
  • Nkbhvid
13 Feb 2026 21:35
“Also insure the all PWM enables are true, and all PWM values are 0”
Should I define this in HAL?
  • freemoore
  • freemoore
13 Feb 2026 21:31
Great, that's got the sserial and pktuart ports appearing and working, thank you for the quick response.
We have 3x identical modbus cards to communicate with. Using mb2hal it was possible to address each one but I can't see how to do that using mesa_modbus - is there a way to talk to different addresses over a single pktuart port? This may be a question for Andy Pugh...
Is this possible in hm2-modbus?
  • PCW
  • PCW's Avatar
13 Feb 2026 20:45
OK that looks good.
The next test is to set all PID pins to 0 (P,I,D,FF0,FF1,FF2) in the ini file
and start LinuxCNC, then enable motion, at this point, PWM should be enabled on all axis
but the PWM value should be 0 on all axis. Again measure all the Analog outputs.
 (test done with nothing connected to the 7I97T except 5V power and Ethernet)
  • Hakan
  • Hakan
13 Feb 2026 20:19
IndraDrive + LinuxCNC – PDO configuration problems
Category: EtherCAT
Have a look in syslog "sudo dmesg" and if you find the word EoE that is a problem.
Typically that interferes with the linuxcnc lcec component, which can not handle EoE.
There is a way to read out the eeprom content from the drive, flip a bit and write the eeprom content back.
However, it is much better to compile the ethercat master yourself with eoe disabled.
It has been recommended before in the forum, please search (I don't have it readily available).
See how far that takes you.
  • Nkbhvid
  • Nkbhvid
13 Feb 2026 20:11
Axis0 11mv
Axis1 9mv
Axis2 10mv
Axis3 9mv
Axis4 10mv
Axis5 9mv
13 Feb 2026 20:06
Replied by tommylight on topic QtPyVCP Mill Touch Screen
Category: QtPyVCP
@Kell,
Do not send reports asking for help, you will be banned for doing that again.
From your error report:
Can't execute DISPLAY program qtpyvcp
So did you install QtPyVCP as per the howto on their github?
13 Feb 2026 20:03
Replied by tommylight on topic Joint following error all axis
You are welcomed, always.
13 Feb 2026 19:58
  • Nkbhvid
  • Nkbhvid
  • PCW
  • PCW's Avatar
13 Feb 2026 19:31 - 13 Feb 2026 19:34
Failed communication connections are a software issue.
If you power the 7I97T (and not run LinuxCNC), do you read
near 0V on all analog outputs? (that is, less than 15 mV)
  • TAKUYA
  • TAKUYA
13 Feb 2026 19:17
Replied by TAKUYA on topic StepperOnline A6 Servo
Category: EtherCAT
Moin,
mich würde interessieren wie du deine A6 getuned hast.
Ich hab noch immer leichtes fiepen an manchen Stellen und kriegs einfach nicht weg.
  • Sparky3
  • Sparky3
13 Feb 2026 19:02
Replied by Sparky3 on topic QTPlasmaC Remove Z axis for Tube Cutter
Category: Plasma & Laser
vikingj
Can you post your INI and hal files.
Displaying 7036 - 7050 out of 12581 results.
Time to create page: 0.568 seconds
