08 Feb 2026 01:35
Replied by tommylight on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
I hope I'm not hijacking your thread here, maybe I should start a separate thread in hardware or builds related category when I start building this 3d printer.
This would be the right place for it:
forum.linuxcnc.org/additive-manufacturing
08 Feb 2026 01:23
Lenovo T14 Gen2 AMD - CRAZY High Latency - Am I screwed?
Probably...
But, do download and test from USB the 2.8.4 version of LinuxCNC in a live session, report back how that looks.
And from experience with many, many laptops, they either work or they do not, so tweaking might just improve things a bit, but going from 3 million to 25-50K is never going to happen.
Also, disable TPM or whatever Lenovo is calling the Trusted Platform and anything related to virtualisation.
Some ideas here:
forum.linuxcnc.org/18-computer/54369-use...mesa-ethernet-boards
  • MaHa
  • MaHa
08 Feb 2026 01:17
Adding Feed Rate (IPM or IPR) to the lathe screen
Category: AXIS
With 2.7 i have used this pin. It needs multiply by 60 for feed per minute
motion.current-vel
current velocity in user units per second
example HAL:
setp   mult2.0.in0   60
net velcalc   mult2.0.in1   motion.current-vel
net cur-vel   mult2.0.out   pyvcp.feed
actual linuxcnc stable has pin
motion.feed-inches-per-minute
  • NWE
  • NWE's Avatar
08 Feb 2026 01:00
Replied by NWE on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
37 m/min! Wow! I was starting to worry these motors will look tiny on such a big printer maybe I should look at bigger motors haha.
I will plan on using these motors with 2:1 reduction and 60mm dia. drum. 3 axis plus I can use the 4th output from this Lichuan driver for the small extruder motor.
My Elegoo Neptune 3 Max has a max rated speed of 6.4 m/min and they recommend printing at 3.6 m/min. The guy running the fast little FLSUN printer will probably share with me what the slicer settings look like for such high speed printing. The FLSUN S1 does 72 m/min. but I'm not interested in trying to match that any time soon. That printer has even less build volume than my elegoo.
The extruder - I will probably start with the spare head I think I got for my other printer, but I read recently about a new printer model, can't recall what it was called. It used high frequency induction heat to heat the nozzle, allowing the heater in the print head to heat up and cool off in seconds because the mass of the heater was reduced to pretty much just the nozzle. I might try that later.
  • ihavenofish
  • ihavenofish
08 Feb 2026 01:00
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Neeeed that jerk controllll.....
haha. :)
  • NT4Boy
  • NT4Boy
08 Feb 2026 00:23
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Thanks Andy. In fact I amusing Open Loop control fo this spindle. its a 2hp three phase device and seems pretty stable as is. Tried the improive it with pid tuning but only made things worse.
Still not got the orient to work. Swiching pids ok, but somewhere the orient count, angle and units screwed up and not reseting on the index.
might take a while longer.
  • Looby
  • Looby
08 Feb 2026 00:11
Hello All,
Im a first timer trying to setup linuxcnc and fairly new to linux in general.  Im hoping there is something im overlooking and my purchase wasn’t a waste but not optimistic…
I was originally going to get a Pi5 but price went from $80 to $130 locally just for the board that would have needed cost of case and screen on top of that.  Picked up the laptop below for $200 so it seemed like a sweet upgrade and saw what appeared to be success from other users on what seemed like similar hardware.  I understand that laptops are not ideal due to power saving settings built into them but I will be running a Mesa 7i96s so figured I could get away with it.  I wanted something with a bit more power as in a perfect world I WOULD like to be able to run fusion 360 on it (I know its not directly compatible) if I need to make simple tweaks to a program.  This would just save me carting around two computers.
Computer:
Lenovo T14 Gen 2 AMD
Ryzen 7 Pro 5850u (8c/16t 1.9ghz)
Radeon Integrated Graphics
16gb DDR4 3200
512gb SSD
Realtek RTL8111H-CG Ethernet
Installed LinuxCNC 2.9.8 Debian 13 Trixie PREEMPT-RT without major issue except it not finding network drivers itself.  Everything seemed to work ok but I installed r8168-dkms to hopefully prevent issues.  Get into the system and run the latency test.  Not getting any consistent results but from the latest run I got the following.
Latency Histogram Results with nobase – 2450 microseconds running 10 glxgears and a couple videos
Latency Test Results – Servo thread jitter 3,370,408ns
Latency from laptop to Mesa card through a 3 ft cable is 0.857/0.891/0.937/0.014ms
Results seem crazy based on what I have read so I started following various peoples advice on tweaks.
Going through the BIOS its completely LOCKED down unfortunately.  There are basically no options other than security and boot options.  I went through and did everything I could but no ability to disable SMT or anything else that everyone recommended as first steps.
Walked through several videos on youtube from MrRodW on system and kernel tweaks and none of the tweaks seem to have a significant impact unfortunately.  I could get a little better but still miles off what people say is acceptable.
Changes made
Isolcpus – tried several combinations of multiple and single cpus
nohz_full – matched above changes
rcu_nocbs – matched above changes
intel_ideal.max.cstate=0
processor.max.cstate=1
idle=poll
cpupower frequency-set --governor performance
Checks:
uname -a = Linuxcnc 6.12.63+deb13-rt-amd64
latency-histogram – Note: Using POSIX realtime
So give it to me straight….  Am I screwed?
Thanks,
Looby
  • PCW
  • PCW's Avatar
07 Feb 2026 19:32
  • suraj9735
  • suraj9735's Avatar
07 Feb 2026 19:18
How to do wiring to generate quadrature encoder signal in Mesa 7i95 board
Category: Driver Boards
Could you suggest any Mesa board that can connect to my Mesa 7i95 and provide analog input support?This is urgent for my project, and I need to finish it as soon as possible. I cannot wait for the 7i87 to come back in stock.Thanks.
  • PCW
  • PCW's Avatar
07 Feb 2026 19:15
Configure Mesa 7i96s and pktuart with Omron MX2 (wj200)
<data value="0"/>
Is register initialization data for the init section of the mbccs file
(since the data is initialization data, not data from hal like the command
section)
What does the last error show? (theres a modbus pin for the last reported error)
This is a really strange error since it seems like CRC checked communication
is happening but no data is being transferred.
  • djdock99
  • djdock99
07 Feb 2026 19:03
Replied by djdock99 on topic Maho mh800w retrofit
thanks tommy for the reply. regarding pushing the contactors, i hade to prove that the machines electronics are working properly and that the push button 3sh1 which powers 6a1 safety relays temporarily until 19k1 is latched was working correctly. all the safety systems of the machine are not be touched. similar to Rotarysmp's mh400 retrofit.
Linear scales are reading correctly on the dro and as you can see from the ini file posted above i have accurately populated the scales values.
regarding the indramat drive signals i bet your right and i know i have something wrong here but im having trouble figuring out what. +10 and -10 wires are connected to the 7i97ts and i have left the original drive enable circuit untouched as this is handle by a contactor called 7k1 whose coil is pulled when 19k1 relay has been latched leaving mahos estop and error indictor logic untouched. can this work?
linuxcnc does not show joint.n.following-error but it did before i added an extra ground from +10-10 cable sheathing cables sheathing.
contactors fire and back to estop errors. i know im doing something wrong but writing this and try to explain whats going on might help. thanks for your help
  • Stephan@work
  • Stephan@work
07 Feb 2026 18:23
Hey Guys,
bad luck. The communication seems to run between mesa and Vfd.
Now i measured (in parallel) the connected Mesaoutput with Vfd Input. (mesa_modbus.png)
Compare to the connected USB-Dongle output and Vdf Input (USB_Modbus.png)
Signal Quality looks pretty good. (pktuart seems to work)
I figured out by using the USB-Dongle, that i have to set some Frequency to get this RUN-LED flashing on my OmronMX2 Vdf.
So I implemented all the other necessary Hal Pins to .hal file to check this with the Mesa <--> Vdf communication.
Know, if i click the CW AXIS GUI Button, Iḿ getting the same Error at my Vdf ( E12.1 like a few days ago).
From my point of view, there must be something wrong with the run, reverse or cmd-freq command.
Or still some wrong configuration somewhere.
Iḿ still getting no Vdf temperature out of the Vdf.
so write or read is not Working,
my current .mbccs:
<mesamodbus baudrate="9600" parity="N" interval="1000" stopbits="1" duplex="half">
  <devices>
    <device name="omronmx2" address="0x01"/>
  </devices>
  <initlist>
    <command device="omronmx2" address="0x0001" function="W_COIL">
      <description>Zero Operation</description>
      <data value="0"/>
    </command>
    <command device="omronmx2" address="0x0002" function="W_COIL">
      <description>Reverse Operation</description>
      <data value="0"/>
    </command>
    <command device="omronmx2" address="0x0001" function="W_REGISTERS">
      <description>Frequency</description>
      <data value="0"/>
    </command>
  </initlist>
  <commands>
      <command device="omronmx2" address="0x0001" function="W_COIL"       name="run"/>
      <command device="omronmx2" address="0x0002" function="W_COIL"       name="reverse"/>
      <command device="omronmx2" address="0x0001" function="W_REGISTERS"  name="cmd-freq"       haltype="HAL_FLOAT" modbustype="U_AB" count="1"/>
      <command device="omronmx2" address="0x0014" function="R_COILS"      name="is-at-speed"    count="1"/>
      <command device="omronmx2" address="0x0018" function="R_COILS"      name="watchdog-out"   count="1"/>
      <command device="omronmx2" address="0x0013" function="R_COILS"      name="is-running"     count="1"/>
      <command device="omronmx2" address="0x1003" function="R_REGISTERS"  name="motor-current"  haltype="HAL_FLOAT" modbustype="U_AB" count="1"/>
      <command device="omronmx2" address="0x1019" function="R_REGISTERS"  name="heatsink-temp"  haltype="HAL_FLOAT" modbustype="U_AB" count="1"/>
  </commands>
</mesamodbus>
Can someone explain these
<data value="0"/>
Once, i had one PDU Error. But i guess it was only a wrong configuration.
Iḿ loosing my motivation, i wasted 3 weeks now 3h a day :(
  • Finngineering
  • Finngineering
07 Feb 2026 18:03
Replied by Finngineering on topic XHC WHB04B development?
Hopefully have a completely stable firmware and some type of watchdog to keep track of the communication. By the way, with firmware I speak about the USB dongle and with driver I mean the computer/LinuxCNC component.
I'm not completely happy with how the LinuxCNC xhc-whb04b-6 component works either. And at least for me, the amount of abstraction layers in that code makes it difficult to understand/change.
07 Feb 2026 17:54
Replied by tommylight on topic Maho mh800w retrofit
.... i can manually latch relay 19k1 by holding on the contactor with a screw driver.
Never smart to do that to machines.
.... but the x and z servos are rotating slowly but smoothly.
This means that LinuxCNC has no control over the servo drives, usually incorrect or missing wiring, like are the encoders wired to Mesa and do they work correctly counting up/down on the LinuxCNC DRO ?
Then when i update the hal file to electronically latch 19k1 with f2 it will not hold and drops relays straight away.
What error does LinuxCNC show when that happens?
I would bet it shows "joint.n.following-error" as noted on my second reply.
You are working on a complicated machine, so it is imperative to follow instructions strictly and as listed in priority.
See this for wiring and testing:
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
And for network and WiFi to work at the same time, see here
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
Displaying 7306 - 7320 out of 12619 results.
Time to create page: 0.566 seconds
