  • Lcvette
  • Lcvette's Avatar
27 Jan 2026 02:17 - 27 Jan 2026 02:18
Replied by Lcvette on topic Probe Basic Stable error
Category: QtPyVCP
.3 pretty small unless you have it real close to the corner when you start. Do you have the probe tip diameter set in the tool table?
Do the other corners behave the same?
  • ncf250sd
  • ncf250sd
27 Jan 2026 02:05 - 27 Jan 2026 02:13
Replied by ncf250sd on topic Probe Basic Stable error
Category: QtPyVCP
pretty sure i have all the setting correct as that was my first suspicion. I have already calibrated the probe and used it to find the center and z height of the stock.. I don't think that would have been possible with bad values? Or am i wrong? I will check again tomorrow. I used the original PB for several years so I am pretty familiar.  Also, the pictures are confusing; the second pic the probe had already completed the x measurement and moved into position for the Y.  the probe did step off the correct .3" in the x direction.
  • NWE
  • NWE's Avatar
27 Jan 2026 01:48
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
I'm interested in trying this out. Where can I get the Arduino source code?
  • Lcvette
  • Lcvette's Avatar
27 Jan 2026 01:37
Category: QtPyVCP
Step off width.
Read the probe help on the probing page for explanations on how probing settings works.
  • ncf250sd
  • ncf250sd
27 Jan 2026 01:31
Category: QtPyVCP
Thank you I got it working. Today I attempted to probe a top left outside corner and noticed that when the routine went to probe the "Y" side the probe does not move over enough to the positive X to probe the material.  It does like it should when it probes the X.  It does the same on all outside corners.  It probes the center position just fine.  I attached a pic of the probe start position and where it fails to move over enough. Any ides on what to look for?
  • grandixximo
  • grandixximo's Avatar
27 Jan 2026 00:07
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I'll try to have a look at the '9D' branch later. Thanks.
which I got not much feedback..
Just as a word of caution from my own experience:
You mustn't expect to much from a forum thread like this. Few people will even read a post that long, fewer still look at the code and hardly anybody will even try to understand it. I know of at least one long time contributor, since retired, who got quite bitter about trying to get sustained and involved feedback here. Even from the very people asking for the specific feature.
I will do it because I want to, don't need cheering up much, although it is nice, it is more about doing something that I can share with everyone, and we are all roughly on the same page, as to what has to be done, but I will do it regardless, and then it can stay in a fork, or merged, we will see...
  • unknown
  • unknown
26 Jan 2026 23:42
Replied by unknown on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
Does mesaflash see the card ?
Usually in these situations it is help to attach your ini & hal files and the error reports from when Linuxcnc fails.
  • Nkbhvid
  • Nkbhvid
26 Jan 2026 23:28
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
I am not sure I understand your question?
This is my last attempt to make it work after having spend days trying to figure out how to configure Linuxcnc to work with my Mesa 7i97T.
So far it has been a nightmare -expensive in time and money.
  • Mark Kraus
  • Mark Kraus
26 Jan 2026 22:08
  • Mark Kraus
  • Mark Kraus
26 Jan 2026 21:40
Having Trouble getting encoder to work. Amt102-v 5 wire
Category: Basic Configuration
I was wondering if someone could take a look at my hal and ini files and tell me why i have not encoder count on my halshow but the at speed light is green.  All of this worked in uccnc before i switched over.  I set the encoder to 1024 ppr.  I have 5volts going to encoder.
# Generated by PNCconf at Mon Jan 26 15:37:21 2026
# Using LinuxCNC version:  Master (2.9)
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=1 num_stepgens=5 sserial_port_0=0xxxxxxx"
setp    hm2_7i96s.0.pwmgen.pwm_frequency 5000
setp    hm2_7i96s.0.pwmgen.pdm_frequency 6000000
setp    hm2_7i96s.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt near
addf hm2_7i96s.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf near.0                   servo-thread
addf hm2_7i96s.0.write         servo-thread
setp hm2_7i96s.0.dpll.01.timer-us -50
setp hm2_7i96s.0.stepgen.timer-number 1
# external output signals
# --- SPINDLE-BRAKE ---
net spindle-brake  =>     hm2_7i96s.0.ssr.00.out-00
# --- COOLANT-MIST ---
net coolant-mist  =>     hm2_7i96s.0.ssr.00.out-01
# --- SPINDLE-CW ---
net spindle-cw  =>     hm2_7i96s.0.outm.00.out-04
# --- SPINDLE-CCW ---
net spindle-ccw  =>     hm2_7i96s.0.outm.00.out-05
# external input signals
# --- ESTOP-EXT ---
net estop-ext     <=  hm2_7i96s.0.inm.00.input-00
# --- ALL-LIMIT ---
net all-limit     <=  hm2_7i96s.0.inm.00.input-01
#  AXIS X JOINT 0
setp   pid.x.Pgain     [JOINT_0]P
setp   pid.x.Igain     [JOINT_0]I
setp   pid.x.Dgain     [JOINT_0]D
setp   pid.x.bias      [JOINT_0]BIAS
setp   pid.x.FF0       [JOINT_0]FF0
setp   pid.x.FF1       [JOINT_0]FF1
setp   pid.x.FF2       [JOINT_0]FF2
setp   pid.x.deadband  [JOINT_0]DEADBAND
setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp   pid.x.maxerror 0.000500
net x-index-enable  =>  pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-pos-fb        =>  pid.x.feedback
net x-output        <=  pid.x.output
# Step Gen signals/setup
setp   hm2_7i96s.0.stepgen.00.dirsetup        [JOINT_0]DIRSETUP
setp   hm2_7i96s.0.stepgen.00.dirhold         [JOINT_0]DIRHOLD
setp   hm2_7i96s.0.stepgen.00.steplen         [JOINT_0]STEPLEN
setp   hm2_7i96s.0.stepgen.00.stepspace       [JOINT_0]STEPSPACE
setp   hm2_7i96s.0.stepgen.00.position-scale  [JOINT_0]STEP_SCALE
setp   hm2_7i96s.0.stepgen.00.step_type        0
setp   hm2_7i96s.0.stepgen.00.control-type     1
setp   hm2_7i96s.0.stepgen.00.maxaccel         [JOINT_0]STEPGEN_MAXACCEL
setp   hm2_7i96s.0.stepgen.00.maxvel           [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= joint.0.motor-pos-cmd
net x-vel-cmd    <= joint.0.vel-cmd
net x-output     => hm2_7i96s.0.stepgen.00.velocity-cmd
net x-pos-fb     <= hm2_7i96s.0.stepgen.00.position-fb
net x-pos-fb     => joint.0.motor-pos-fb
net x-enable     <= joint.0.amp-enable-out
net x-enable     => hm2_7i96s.0.stepgen.00.enable
# ---setup home / limit switch signals---
net x-home-sw     =>  joint.0.home-sw-in
net all-limit     =>  joint.0.neg-lim-sw-in
net all-limit     =>  joint.0.pos-lim-sw-in
#  AXIS Y JOINT 1
setp   pid.y.Pgain     [JOINT_1]P
setp   pid.y.Igain     [JOINT_1]I
setp   pid.y.Dgain     [JOINT_1]D
setp   pid.y.bias      [JOINT_1]BIAS
setp   pid.y.FF0       [JOINT_1]FF0
setp   pid.y.FF1       [JOINT_1]FF1
setp   pid.y.FF2       [JOINT_1]FF2
setp   pid.y.deadband  [JOINT_1]DEADBAND
setp   pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror 0.000500
net y-index-enable  =>  pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-pos-fb        =>  pid.y.feedback
net y-output        <=  pid.y.output
setp   hm2_7i96s.0.stepgen.01.dirsetup        [JOINT_1]DIRSETUP
setp   hm2_7i96s.0.stepgen.01.dirhold         [JOINT_1]DIRHOLD
setp   hm2_7i96s.0.stepgen.01.steplen         [JOINT_1]STEPLEN
setp   hm2_7i96s.0.stepgen.01.stepspace       [JOINT_1]STEPSPACE
setp   hm2_7i96s.0.stepgen.01.position-scale  [JOINT_1]STEP_SCALE
setp   hm2_7i96s.0.stepgen.01.step_type        0
setp   hm2_7i96s.0.stepgen.01.control-type     1
setp   hm2_7i96s.0.stepgen.01.maxaccel         [JOINT_1]STEPGEN_MAXACCEL
setp   hm2_7i96s.0.stepgen.01.maxvel           [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd    <= joint.1.motor-pos-cmd
net y-vel-cmd    <= joint.1.vel-cmd
net y-output     => hm2_7i96s.0.stepgen.01.velocity-cmd
net y-pos-fb     <= hm2_7i96s.0.stepgen.01.position-fb
net y-pos-fb     => joint.1.motor-pos-fb
net y-enable     <= joint.1.amp-enable-out
net y-enable     => hm2_7i96s.0.stepgen.01.enable
net y-home-sw     =>  joint.1.home-sw-in
net all-limit     =>  joint.1.neg-lim-sw-in
net all-limit     =>  joint.1.pos-lim-sw-in
#  AXIS Z JOINT 2
setp   pid.z.Pgain     [JOINT_2]P
setp   pid.z.Igain     [JOINT_2]I
setp   pid.z.Dgain     [JOINT_2]D
setp   pid.z.bias      [JOINT_2]BIAS
setp   pid.z.FF0       [JOINT_2]FF0
setp   pid.z.FF1       [JOINT_2]FF1
setp   pid.z.FF2       [JOINT_2]FF2
setp   pid.z.deadband  [JOINT_2]DEADBAND
setp   pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror 0.000500
net z-index-enable  =>  pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-pos-fb        =>  pid.z.feedback
net z-output        <=  pid.z.output
setp   hm2_7i96s.0.stepgen.02.dirsetup        [JOINT_2]DIRSETUP
setp   hm2_7i96s.0.stepgen.02.dirhold         [JOINT_2]DIRHOLD
setp   hm2_7i96s.0.stepgen.02.steplen         [JOINT_2]STEPLEN
setp   hm2_7i96s.0.stepgen.02.stepspace       [JOINT_2]STEPSPACE
setp   hm2_7i96s.0.stepgen.02.position-scale  [JOINT_2]STEP_SCALE
setp   hm2_7i96s.0.stepgen.02.step_type        0
setp   hm2_7i96s.0.stepgen.02.control-type     1
setp   hm2_7i96s.0.stepgen.02.maxaccel         [JOINT_2]STEPGEN_MAXACCEL
setp   hm2_7i96s.0.stepgen.02.maxvel           [JOINT_2]STEPGEN_MAXVEL
net z-pos-cmd    <= joint.2.motor-pos-cmd
net z-vel-cmd    <= joint.2.vel-cmd
net z-output     => hm2_7i96s.0.stepgen.02.velocity-cmd
net z-pos-fb     <= hm2_7i96s.0.stepgen.02.position-fb
net z-pos-fb     => joint.2.motor-pos-fb
net z-enable     <= joint.2.amp-enable-out
net z-enable     => hm2_7i96s.0.stepgen.02.enable
net z-home-sw     =>  joint.2.home-sw-in
net all-limit     =>  joint.2.neg-lim-sw-in
net all-limit     =>  joint.2.pos-lim-sw-in
#  SPINDLE
setp   pid.s.Pgain     [SPINDLE_0]P
setp   pid.s.Igain     [SPINDLE_0]I
setp   pid.s.Dgain     [SPINDLE_0]D
setp   pid.s.bias      [SPINDLE_0]BIAS
setp   pid.s.FF0       [SPINDLE_0]FF0
setp   pid.s.FF1       [SPINDLE_0]FF1
setp   pid.s.FF2       [SPINDLE_0]FF2
setp   pid.s.deadband  [SPINDLE_0]DEADBAND
setp   pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  =>  pid.s.index-enable
net spindle-enable        =>  pid.s.enable
net spindle-vel-cmd-rpm     => pid.s.command
net spindle-vel-fb-rpm      => pid.s.feedback
net spindle-output        <=  pid.s.output
# ---PWM Generator signals/setup---
setp   hm2_7i96s.0.pwmgen.00.output-type 1
setp   hm2_7i96s.0.pwmgen.00.scale  [SPINDLE_0]OUTPUT_SCALE
net spindle-output      => hm2_7i96s.0.pwmgen.00.value
net spindle-enable      => hm2_7i96s.0.pwmgen.00.enable
setp    hm2_7i96s.0.encoder.00.counter-mode 0
setp    hm2_7i96s.0.encoder.00.filter 1
setp    hm2_7i96s.0.encoder.00.index-invert 0
setp    hm2_7i96s.0.encoder.00.index-mask 0
setp    hm2_7i96s.0.encoder.00.index-mask-invert 0
setp    hm2_7i96s.0.encoder.00.scale  [SPINDLE_0]ENCODER_SCALE
net spindle-revs             <=   hm2_7i96s.0.encoder.00.position
net spindle-vel-fb-rps       <=   hm2_7i96s.0.encoder.00.velocity
net spindle-vel-fb-rpm       <=   hm2_7i96s.0.encoder.00.velocity-rpm
net spindle-index-enable     <=>  hm2_7i96s.0.encoder.00.index-enable
net spindle-vel-cmd-rps        <=  spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs    <=  spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  spindle.0.speed-out
net spindle-vel-cmd-rpm-abs    <=  spindle.0.speed-out-abs
net spindle-enable             <=  spindle.0.on
net spindle-cw                 <=  spindle.0.forward
net spindle-ccw                <=  spindle.0.reverse
net spindle-brake              <=  spindle.0.brake
net spindle-revs               =>  spindle.0.revs
net spindle-at-speed           =>  spindle.0.at-speed
net spindle-vel-fb-rps         =>  spindle.0.speed-in
net spindle-index-enable      <=>  spindle.0.index-enable
net spindle-vel-cmd-rps    =>  near.0.in1
net spindle-vel-fb-rps         =>  near.0.in2
net spindle-at-speed       <=  near.0.out
setp near.0.scale 1.000000
setp near.0.difference 1.666667
# connect miscellaneous signals
#  ---HALUI signals---
net axis-select-x  halui.axis.x.select
net jog-x-pos      halui.axis.x.plus
net jog-x-neg      halui.axis.x.minus
net jog-x-analog   halui.axis.x.analog
net x-is-homed     halui.joint.0.is-homed
net axis-select-y  halui.axis.y.select
net jog-y-pos      halui.axis.y.plus
net jog-y-neg      halui.axis.y.minus
net jog-y-analog   halui.axis.y.analog
net y-is-homed     halui.joint.1.is-homed
net axis-select-z  halui.axis.z.select
net jog-z-pos      halui.axis.z.plus
net jog-z-neg      halui.axis.z.minus
net jog-z-analog   halui.axis.z.analog
net z-is-homed     halui.joint.2.is-homed
net jog-selected-pos      halui.axis.selected.plus
net jog-selected-neg      halui.axis.selected.minus
net spindle-manual-cw     halui.spindle.0.forward
net spindle-manual-ccw    halui.spindle.0.reverse
net spindle-manual-stop   halui.spindle.0.stop
net machine-is-on         halui.machine.is-on
net jog-speed             halui.axis.jog-speed
net MDI-mode              halui.mode.is-mdi
#  ---coolant signals---
net coolant-mist      <=  iocontrol.0.coolant-mist
net coolant-flood     <=  iocontrol.0.coolant-flood
#  ---probe signal---
net probe-in     =>  motion.probe-input
#  ---motion control signals---
net in-position               <=  motion.in-position
net machine-is-enabled        <=  motion.motion-enabled
#  ---digital in / out signals---
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-ext     =>  iocontrol.0.emc-enable-in
#  ---manual tool change signals---
net tool-change-request    <= iocontrol.0.tool-change
net tool-change-confirmed  => iocontrol.0.tool-changed
net tool-number            <= iocontrol.0.tool-prep-number
#  ---ignore tool prepare requests---
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
[EMC]
MACHINE = Bridgeportsimple2
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = qtvcp qtdragon
PREFERENCE_FILE_PATH = WORKINGFOLDER/qtdragon.pref
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_0_OVERRIDE = 2.000000
MIN_SPINDLE_0_OVERRIDE = 0.500000
DEFAULT_SPINDLE_0_SPEED = 500
MIN_SPINDLE_0_SPEED = 100
MAX_SPINDLE_0_SPEED = 2500
INTRO_TIME = 5
PROGRAM_PREFIX = /home/debian/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
CYCLE_TIME = 100
[MDI_COMMAND_LIST]
MDI_COMMAND = G0 Z0;X0 Y0
MDI_COMMAND = G53 G0 Z0;G53 G0 X0 Y0
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G20 G40 G90 G94 G97 G64 P0.001
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1200000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i96s.0
[HAL]
HALUI = halui
HALFILE = Bridgeportsimple2.hal
HALFILE = custom.hal
POSTGUI_HALFILE = qtvcp_postgui.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[TRAJ]
COORDINATES =  XYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 0.15
MAX_LINEAR_VELOCITY = 1.48
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 1.1666666666666667
MAX_ACCELERATION = 10.0
MIN_LIMIT = -7.0
MAX_LIMIT = 8.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
STEPGEN_MAXVEL = 2.33
STEPGEN_MAXACCEL = 20.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 5000
DIRHOLD    = 5000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 4000.0
BACKLASH = 0.001
MIN_LIMIT = -7.0
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 1.0
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
STEPGEN_MAXVEL = 2.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 5000
DIRHOLD    = 5000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = -16000.0
BACKLASH = 0.001
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
[AXIS_Z]
MAX_VELOCITY = 1.4833333333333334
MIN_LIMIT = -3.0
MAX_LIMIT = 5.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
STEPGEN_MAXVEL = 2.97
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 2000
DIRHOLD    = 2000
STEPLEN    = 2000
STEPSPACE  = 2000
STEP_SCALE = -65000.0
BACKLASH = 0.001
MIN_LIMIT = -3.0
MAX_LIMIT = 5.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
ENCODER_SCALE = 4096.0
OUTPUT_SCALE = 2000
OUTPUT_MIN_LIMIT = -2000
OUTPUT_MAX_LIMIT = 2000
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
# Custom spindle analog PWM setup for 7i96S TB2 (pot replacement mode)
setp hm2_7i96s.0.pwmgen.00.scale 3500     # Max RPM = full ~10V output
# Let pncconf's existing connection handle the value signal
# (it usually connects pwmgen.00.value to spindle-output or similar)
# Enable the PWMgen when spindle is on
#net spindle-on spindle.0.on => hm2_7i96s.0.pwmgen.00.enable
# Optional: Digital FWD enable on TB3 (OUT4 for example)
# net spindle-on hm2_7i96s.0.ssr.00.out-04   # Adjust out-04 to match your assignment
# Spindle Encoder RPM Display Fix (Ultimate Final - No Encoder Pin Nets)
# Only setp for encoder config + single bridge net on display side
# Zero duplicate warnings, pncconf-safe
# Encoder configuration (setp only - completely safe)
setp hm2_7i96s.0.encoder.00.counter-mode   0      # Quadrature A/B/Z
setp hm2_7i96s.0.encoder.00.filter         1      # Filter noise/blips
# Scale - CHANGE THIS to your actual PPR × 4
# Test: Spin shaft 1 full turn by hand → count change / 4 = PPR
# Common AMT102-V settings: 400 CPR → 1600, 1000 → 4000, 1024 → 4096
setp hm2_7i96s.0.encoder.00.scale          4096   # ← EDIT THIS LINE !!!
# Optional: Invert A/B if direction is reversed (counts decrease on forward spin)
# setp hm2_7i96s.0.encoder.00.phase-a-invert 1
# setp hm2_7i96s.0.encoder.00.phase-b-invert 1
# Route pncconf's existing velocity signal to QtDragon RPM display pin
# This is the only net - it never touches encoder pins
# net spindle-vel-fb-rpm => spindle.0.speed-in-rpm
# Optional: Extra smoothing to eliminate random blips when stopped
# Uncomment if blips persist after scale fix
# loadrt lowpass
# addf lowpass.0 servo-thread
# setp lowpass.0.gain 0.05   # Lower = smoother (0.01–0.1 range)
# net spindle-velocity-filtered lowpass.0.out => spindle.0.speed-in-rpm
  • ihavenofish
  • ihavenofish
26 Jan 2026 21:37
Replied by ihavenofish on topic LinuxCNC S-Curve Accelerations
Sounds all sensible to me but I really don't feel competent to comment on the proposed path.
I certainly like the structured approach of your initiative, that is something that has been sorely lacking in other attempts.
I think/hope that Rob will be able to give an educated opinion on it and shape it into a concrete roadmap.
Note that Mitsubishi SSCNET requires a servo cycle <= 222us
forum.linuxcnc.org/9-installing-linuxcnc...cnet?start=70#256576
defenetly is great to have something faster then 1ms .. ethercat can run at 50us with 16axis but this complex calculations are far slower for now
I think 250us is very pretty goal (common industrial standard) at any hardware and then reduce it based at used hardware
Note than many ethercat drives are also limited to 1khz in position mode. lichuan is, stepperonline/jss i think is and Im pretty sure the delta b3 is. My omrons I think are restricted to 2khz in csp mode.
For 4khz or 8khz usually you are restricted to other modes. At least in the drives I have. There definitely are (much) faster ones, but they are more specialised gear vs generic milling cnc applications.
Point being, 250us sounds great, but I don't know it needs to be any sort of priority cause only few people could use it. But then maybe those few people are important (like the people I know wanting to nanometer scale optical things and MUST have the higher "loop" speed so can't entertain linuxcnc right now)
  • bobwolf
  • bobwolf
26 Jan 2026 21:20 - 26 Jan 2026 21:23
Hi everyone,
As promised in my last update, I’ve just released the v1.0-eval package, including the driver, the Arduino firmware, and full documentation.
I’ve set up a dedicated project page to host the quick-start guide and the wiring diagrams to make the setup as easy as possible.
What’s included in this release:
HAL Driver: The core engine to interface your USB panel with LinuxCNC.
Evaluation Firmware: Ready to be flashed on your Arduino Uno.
Technical Docs: Wiring schemes and HAL configuration examples.
You can find everything here: Project Home & Documentation: bobwolfrst.github.io/io_decoder-linuxCNC/demo_mode.en
Quick Links:
Direct Download (.zip):
github.com/bobwolfrst/io_decoder-linuxCN..._decoder_eval-v1.zip
Technical Demo: Evaluation Mode & HAL Test Video (showing the real-time response of the physical buttons and MPG in HAL).
I’ve also recorded a short technical demo showing the driver in action: you can see the real-time response of the physical buttons and MPG selector mirrored instantly in the HAL pins.
I’m really interested in your feedback regarding the setup process and the latency you experience on your machines. Let’s break the "USB dogma" together!
ciao
Roberto
  • Hakan
  • Hakan
26 Jan 2026 20:36
Replied by Hakan on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
From what I can see, different modes can live side by side in the cia402 component without problem.
They already do today. Different pins, yes. For example PV needs two accelerations and a speed pin.
Homing, probing etc their own set of pins. And possibly some small piece of logic, like "at-speed" indication.
And then handle the switching of modes with the position feedback, a bit optimistic this can be done in a general way.
  • rodw
  • rodw's Avatar
26 Jan 2026 19:57
Mini PC for LinuxCNC/CPU Realtime Performance
Thanks for the reply! I’ve done all that so I believe my G2 is optimized for LinuxCNC.
However I’m a bit limited by the low ram (8GB), low disk space and etc.
This is nonsense! 4 gb RAM is fine for LinuxCNC but it will tolerate 8gb without ill affect. Linux is more memory efficient than Windows.....
  • PCW
  • PCW's Avatar
26 Jan 2026 19:38
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
What program does not recognize the card?
Displaying 7906 - 7920 out of 12651 results.
Time to create page: 0.571 seconds
