26 Jan 2026 15:41
Question about using Deadband in calibration when switching from Position to Spe
Category: Basic Configuration
From LinuxCNC documentation:
Still does not explain setting deadband causing a joint error.
26 Jan 2026 15:39
A nice tutorial on using Path workbench included in FreeCAD
Category: CAD CAM
I do not think so, and i never tried.
I use strictly Inkscape for plasma machines, it is easy to use and works perfectly fine, except for nesting that requires dividing cuts into layers and groups, so a bit more fiddly and i do not bother with it, it is easier for me to just edit the resulting gcode and move stuff around.
  • Jerry69
  • Jerry69
26 Jan 2026 15:37
Kuhlmann engraving machine upgrade was created by Jerry69
Hello I am new to this forum, but I have a Kuhlmann Engraver and a board died. I am looking for anyone who has information about converting it with new software and controllers.
  • Aciera
  • Aciera's Avatar
26 Jan 2026 15:34 - 26 Jan 2026 16:21
Replied by Aciera on topic LinuxCNC S-Curve Accelerations
Sounds all sensible to me but I really don't feel competent to comment on the proposed path.
I certainly like the structured approach of your initiative, that is something that has been sorely lacking in other attempts.
I think/hope that Rob will be able to give an educated opinion on it and help shape it into a concrete roadmap.
Note that Mitsubishi SSCNET requires a servo cycle <= 222us
forum.linuxcnc.org/9-installing-linuxcnc...cnet?start=70#256576
  • grandixximo
  • grandixximo's Avatar
26 Jan 2026 14:57
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Ruckig, I think we just need the math based on the math paper I think. Don't actually need to build the thing inside linuxcnc.
I proposed a minimum of 250us because that's what other users here expressed, otherwise you could run ruckig in the servo, but I thought better keep it out, even if advertised as 50us, some calculations seems known to exceed this advertisement. The handoff was my concept idea. Inspired by how CPU have predictive branching
  • meister
  • meister
26 Jan 2026 14:40
my calculation of the DEADBAND value:
pid_setup["DEADBAND"] = round(1 / abs(joint_config["SCALE_OUT"]) * 2, 4)
works for me :)
  • sataran
  • sataran
26 Jan 2026 14:35
Bitfile or help – Mesa 6i25 + 7i74 (BiSS-C) + 8i20 + 7i70/7i87
Category: Driver Boards
Ok so before i am breaking everything do i need something else apart for the hostmot2-firmware/tree/master from the git in order to compile a framework?
In the first file that you send to me PCW you added 4biss chanel insted of 3 and "IOPortTag & x"03" & BISSTag & BISSClkEnPin, -- I/O 16 PIN 13"
i was curious about this line?
I was going for a conf like that for 7i76_7i74biss3d depending on that this line does.
use work.IDROMConst.all;
package PIN_7I76_7I74BISS3D_34 is
constant ModuleID : ModuleIDType :=(
(HM2DPLLTag, x"00", ClockLowTag, x"01", HM2DPLLBaseRateAddr&PadT, HM2DPLLNumRegs, x"00", HM2DPLLMPBitMask),
(WatchDogTag, x"00", ClockLowTag, x"01", WatchDogTimeAddr&PadT, WatchDogNumRegs, x"00", WatchDogMPBitMask),
(IOPortTag, x"00", ClockLowTag, x"02", PortAddr&PadT, IOPortNumRegs, x"00", IOPortMPBitMask),
(BISSTag, x"00", ClockHighTag, x"03", BISSDataAddr&PadT, BISSNumRegs, x"00", BISSMPBitMask),
(QcountTag, x"02", ClockLowTag, x"01", QcounterAddr&PadT, QCounterNumRegs, x"00", QCounterMPBitMask),
(SSerialTag, x"00", ClockLowTag, x"01", SSerialCommandAddr&PadT, SSerialNumRegs, x"10", SSerialMPBitMask),
(StepGenTag, x"02", ClockLowTag, x"05", StepGenRateAddr&PadT, StepGenNumRegs, x"00", StepGenMPBitMask),
(LEDTag, x"00", ClockLowTag, x"01", LEDAddr&PadT, LEDNumRegs, x"00", LEDMPBitMask),
(NullTag, x"00", NullTag, x"00", NullAddr&PadT, x"00", x"00", x"00000000"),
constant PinDesc : PinDescType :=(
-- Base func sec unit sec func sec pin -- external DB25
IOPortTag & x"00" & StepGenTag & StepGenDirPin, -- I/O 00 PIN 1
IOPortTag & x"00" & StepGenTag & StepGenStepPin, -- I/O 01 PIN 14
IOPortTag & x"01" & StepGenTag & StepGenDirPin, -- I/O 02 PIN 2
IOPortTag & x"01" & StepGenTag & StepGenStepPin, -- I/O 03 PIN 15
IOPortTag & x"02" & StepGenTag & StepGenDirPin, -- I/O 04 PIN 3
IOPortTag & x"02" & StepGenTag & StepGenStepPin, -- I/O 05 PIN 16
IOPortTag & x"03" & StepGenTag & StepGenDirPin, -- I/O 06 PIN 4
IOPortTag & x"03" & StepGenTag & StepGenStepPin, -- I/O 07 PIN 17
IOPortTag & x"04" & StepGenTag & StepGenDirPin, -- I/O 08 PIN 5
IOPortTag & x"04" & StepGenTag & StepGenStepPin, -- I/O 09 PIN 6
IOPortTag & x"00" & SSerialTag & SSerialTX0Pin, -- I/O 10 PIN 7
IOPortTag & x"00" & SSerialTag & SSerialRX0Pin, -- I/O 11 PIN 8
IOPortTag & x"00" & SSerialTag & SSerialTX1Pin, -- I/O 12 PIN 9
IOPortTag & x"00" & SSerialTag & SSerialRX1Pin, -- I/O 13 PIN 10
IOPortTag & x"00" & QCountTag & x"03", -- I/O 14 PIN 11
IOPortTag & x"00" & QCountTag & x"02", -- I/O 15 PIN 12
IOPortTag & x"00" & QCountTag & x"01", -- I/O 16 PIN 13
-- 26 HDR -- IDC DB25
IOPortTag & x"00" & BISSTag & BISSDataPin, -- I/O 17 PIN 1
IOPortTag & x"01" & BISSTag & BISSDataPin, -- I/O 18 PIN 14
IOPortTag & x"02" & BISSTag & BISSDataPin, -- I/O 19 PIN 2
IOPortTag & x"01" & SSerialTag & SSerialRX3Pin, -- I/O 03 PIN 15
IOPortTag & x"00" & BISSTag & BISSClkPin, -- I/O 21 PIN 3
IOPortTag & x"01" & BISSTag & BISSClkPin, -- I/O 22 PIN 16
IOPortTag & x"02" & BISSTag & BISSClkPin, -- I/O 23 PIN 4
IOPortTag & x"01" & SSerialTag & SSerialTX3Pin, -- I/O 07 PIN 17
IOPortTag & x"01" & SSerialTag & SSerialRX4Pin, -- I/O 08 PIN 5
IOPortTag & x"01" & SSerialTag & SSerialRX5Pin, -- I/O 09 PIN 6
IOPortTag & x"01" & SSerialTag & SSerialRX6Pin, -- I/O 10 PIN 7
IOPortTag & x"01" & SSerialTag & SSerialRX7Pin, -- I/O 11 PIN 8
IOPortTag & x"01" & SSerialTag & SSerialTX4Pin, -- I/O 12 PIN 9
IOPortTag & x"01" & SSerialTag & SSerialTX5Pin, -- I/O 13 PIN 10
IOPortTag & x"01" & SSerialTag & SSerialTX6Pin, -- I/O 14 PIN 11
IOPortTag & x"01" & SSerialTag & SSerialTX7Pin, -- I/O 15 PIN 12
IOPortTag & x"01" & SSerialTag & SSerialTXEn7Pin, -- I/O 16 PIN 13
  • Ekholm
  • Ekholm
26 Jan 2026 14:34
Category: CAD CAM
Do you know of Freecad works for plasma cutting with freecad and linuxcnc?
  • Aciera
  • Aciera's Avatar
26 Jan 2026 14:15
I'm a bit weary of anything that comes out of AI.
Could you give a bit more background information as to how you came up with these outlines? In other words: Are these the result of conscious deliberation or is that a product of AI?
### Architecture Principles
**RT thread (250µs capable):** Only evaluates pre-computed polynomials. No planning, no Ruckig, no kinematics. Just `position = evaluate_polynomial(t)` and send to drives.
**Userspace:** All heavy computation. Ruckig, backward velocity pass, kinematics, blending. Not tied to servo cycle.
**Predictive Handoff:** When replanning is needed (feed override, etc), userspace plans from a predicted future state, not current state. RT continues executing until the handoff time, then seamlessly transitions. This decouples userspace latency from RT determinism.
**Buffer Management:** Track buffer in TIME, not segment count. Short segments and long segments treated appropriately.
  • Aciera
  • Aciera's Avatar
26 Jan 2026 13:58 - 26 Jan 2026 14:45
I notice that you mention the use of 'ruckig', is this a decision you made or is that something AI suggested?
According to this statement (which I have not verified )the 'ruckig' library is not free for more advanced uses. (Not that this must necessarily be a deal breaker):
forum.linuxcnc.org/38-general-linuxcnc-q...nner?start=70#320906
[edit]
there seems to be a ''community" and a "pro" version of ruckig:
docs.ruckig.com/md_pages_2__intermediate__waypoints.html
There seems to be little information about the 'pro' version:
github.com/pantor/ruckig/issues/78
26 Jan 2026 13:38
Again, something is not OK if you can change values of FFx and get no change in response, so are the drives set in "velocity" or "torque" mode?
  • Mark Kraus
  • Mark Kraus
26 Jan 2026 13:28
Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Category: StepConf Wizard
The encoder came in and would like to ask what is the best ppr setting to select? I will have max 3600 rpm and i want to do rigid tapping.
rotational speed (at each
resolution)
192, 384, 400, 500, 800, 1000, 1024, 2048 7500 RPM
48, 96, 100, 125, 200, 250, 256, 512 15000 RPM
26 Jan 2026 13:24
Replied by tommylight on topic Mini PC for LinuxCNC/CPU Realtime Performance
However I’m a bit limited by the low ram (8GB), low disk space and etc.
8GB should be fine, and how low is "low disk space"? Linux starts complaining only when you get under 1GB of free space, so anything above is fine.
I realize newer models are risky, therefore some of the models I am looking at are far from new generation CPUs (like the Ryzen5 7535U)..
7535U is not "far from new", it is new and still in production, Zen3 with 15W TDP, so it is a laptop CPU and this may be bad for latency, although not always.
Or is CPU not the only potential issue, but also things like the motherboard etc?
CPU's are mostly fine as they can change states and do stuff, mainboards are usually the latency killers depending on quality, BIOS implementation, power saving options, etc, etc, way to many to list here, but mostly bad/weak CPU power stage set to work at the edge and throttling the CPU to save itself from going up in smoke.
As a general rule, i would stay away from those small PC's, they are cute and stuff, but way to limited thermally, the xxxxU versions are fine, but a 13900 ... oh hell no, it will be limited thermally to something like a good 4 core CPU when under load, and they fail but being limited will prolong their life a lot so...
There were some NUC's that were OK for LinuxCNC way back.
After all this, there is no way to know for sure if any of those will be OK, short of buying and testing.
  • Aciera
  • Aciera's Avatar
26 Jan 2026 13:20
I'll try to have a look at the '9D' branch later. Thanks.
which I got not much feedback..
Just as a word of caution from my own experience:
You mustn't expect to much from a forum thread like this. Few people will even read a post that long, fewer still look at the code and hardly anybody will even try to understand it. I know of at least one long time contributor, since retired, who got quite bitter about trying to get sustained and involved feedback here. Even from the very people asking for the specific feature.
  • Hakan
  • Hakan
26 Jan 2026 13:17
Many of us run systems with much lower spec CPUs, like Celeron J1900, i3-6100, N100, N150 with good result. 8GB should be plenty.
What does your latency-plot look like?
Displaying 7936 - 7950 out of 12652 results.
Time to create page: 1.408 seconds
