  • cmorley
  • cmorley
15 Jan 2026 07:04
Replied by cmorley on topic GTK little probe screen
Category: Gmoccapy
Readme files are not part of the official documentation and AFAIK one can't link to it.
One can link pages of docs to other pages of docs.
this is a pretty good refrence for docs:
docs.asciidoctor.org/asciidoc/latest/syntax-quick-reference/
What should be on the page is what you think users will need to know to use it. keep in mind most users using docs will not be seasoned users so don't assume too much of what they know.
Critical is just to make sure it is always shown. so yes ok.
  • rodw
  • rodw's Avatar
15 Jan 2026 07:03
Replied by rodw on topic For a full-fledged Press Brake GUI
Category: Other User Interfaces
Fold order: top, ,bottom, left tab, left, right tab, right.
  • rodw
  • rodw's Avatar
15 Jan 2026 06:59
 I don't know much either. Here is a part I folded a lot in batches of 20.
The press brake had the knife and lower V block defined in the commercial control. First I numbered each bend on the paper drawing (6 in total) in the order I wanted to do them
Where a flange had already been folded, I would manually deduct the width of the material (2 mm) for the back gauge
Then I built the bend list as you say bend number, angle, length
From memory, there was a calibration screen that set the angle and it was set to under bend just a little but so we had some adjustment on the first part.
Ideally, the operator would not need to know the axis positions and instead you would calculate that from known maths.
Over time, I tweaked the  dimensions and bends to get as perfect as I could and the job was saved in the control for next time.  Good luck
  • cmorley
  • cmorley
15 Jan 2026 06:53
Replied by cmorley on topic I got a medal!
I got a medal!
Nice!
  • cmorley
  • cmorley
15 Jan 2026 06:52
Replied by cmorley on topic For a full-fledged Press Brake GUI
FYI, flexGUI is not part of linuxcnc so a GUI based on it will not be package-able with linuxcnc.
But if you made something in flexGUI, it's probably not that hard to re-imagine it in Gladevcp or Qtvcp afterwards.
I like the idea of a quick drawing for reference.
  • 3404gerber
  • 3404gerber
15 Jan 2026 06:13
Happy to hear you solved your problem! In case you need some extra SPI cable length, you could balance the signal. I did a test and was able to transmit a 4MHz SPI signal to a driver over several meters of cable. I think it could get way faster than 4MHz, but I did try it so far as it is the max frequency of my driver.
  • NWE
  • NWE's Avatar
15 Jan 2026 05:14 - 15 Jan 2026 05:46
How to set current machine position manually?
Not sure if I caught on, am I correct:
1. You're jogging the machine by turning handwheels attached to each axis while the motors are powered off,
2. You want the resulting position to be your starting point.
Which GUI are you using? I experimented in Axis, I can do touch-off and enter a value instead of 0 to tell it where it is starting. You will need to know how far from home you jogged it, and enter that value in touch off for each axis.
EDIT:
Sorry, I was wrong. That will not work. Entering an offset moves the part away from the tool. I think my brain needs sleep soon.
Lacking any other options to reliably jog it, you might use MDI commands to send it to the touchoff point. If it is in incremental mode 'jogging' might be less complicated compared to absolute mode depending how quick you are with math.
Surely switching the jog increments from 'continous' to a specific value would suffice, and be easier than MDI commands. It should then only move the specified distance each time you press a key, if it continues anyway, I would suspect a problem with the keyboard auto-repeat on your system.
  • NWE
  • NWE's Avatar
15 Jan 2026 03:40 - 15 Jan 2026 06:05
I'm working on a press brake retrofit and need a GUI for it. This is going to be a full fledged GUI hopefully somewhat universal in hopes of making future press brake retrofits much easier. My goal is to come up with a couple example configs that could be packaged with LinuxCNC. I think I will create it using FlexGUI. My big problem is, I have little experience actually operating press brakes and will need some guideance on what features are required and which ones will just waste screen space.
Any offers to help with the coding will also be appreciated, however, I am willing to jump in myself and see what I can do with it.
I assume it will need at least:
0. Touchscreen freindly.
1. A "status" ribbon across the top displaying current operational status, including color-coding; like red for errors, yellow for warnings, green or blue otherwise.
2. DRO displaying position of movable beam (the die). How about also displaying positions of all axis? I performed service work on a 12 axis press brake a year or two ago, it had Y1, Y2 (left and right side of upper beam). The backstop consisted of two independant 3-axis stops: R1, R2, X1, X2, Z1, Z2. Crowning was 9th axis. Variable width bottom die was 10th axis. Sheet lifter in front of press had height and angle (axis 11-12)...
3. Program bends table. The program will need to contain various parameters for each 'bend' in the part. The table on the 'Run' screen hardly needs to display every fine detail. I'm thinking maybe 4 columns: 'Bend Number', 'Length', 'Angle', 'Notes'.
4. Tonnage control: how visible does this want/need to be for the operator? Least visible = just set it in the programming screen, or more visible, say a big guage displaying tonnage live?
5. Editting the 'part program' should probably be done on a separate tab or screen.
5.a My first version of the editor will be basic: enter the go-to positions for each axis to configure that specific bend.
5.b My goal for a 'real' editor is one where you can select dies, enter tab lengths and bend angles, and it produces the parameters for the bending program. This editor should have a 2D display of dies and plate and can possibly be a separate app.
What am I overlooking?
I will start drawing the ui...
15 Jan 2026 03:28
Replied by tommylight on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
Base period is in the .ini file inside your configuration folder, usually
/home/cnc/linuxcnc/configs/sim.axis
instead of cnc you will have your user name
As for latency screenshots, see those colorful vertical lines on both sides of the graph? Those mean there are latency excursions outside the visible area, so add --show at the end of latency-histogram line and test again.
  • rodw
  • rodw's Avatar
15 Jan 2026 03:12
Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Category: StepConf Wizard
So I stopped trusting Chat gtp and started to think more for myself
great! pncconf will calculate out the step calibration but there is a shortcut if you dare!
You can review you mach3/uccnc and look for what Mach3 calls steps-per (steps per inch or steps per mm)
This directly equates to what linuxcnc calls STEP_SCALE in the ini file. so just edit your ini file to use your known values. But at this point you will be doing stuff manually in a text editor from here on. Which is not a bad thing in my book! Also try using geany for text editing. Our ISO's install it but otherwise type sudo apt install geany. Its very similar to notepad++ in Windows.
I often use pncconf to create a basic config and edit it by hand to correctly scale the axes and set velocities and acceleration.
slowing down in a cut is done by the motion controller. It knows from your ini file what the velocities and accelerations are and will adjust them accordingly. G64 is probably new to you but it sets the closest distance away from a corner you want to allow and should be in every gcode file (and set in the ini file). Without it, the motion will stay at your maximum velocity which cause you to cut corners significantly. Read up on it.
Yes, buttons to allow you to override limits should appear if you violate them.
This forum is far better than any AI as its where the AI's come to get their info. I prefer Elon Musk's Grok as it lies less even though it has quoted info I wrote here back to me a week later
  • lukechan
  • lukechan
15 Jan 2026 03:01 - 15 Jan 2026 07:05
MESA 6i24 + 7i36 was created by lukechan
MESA 6i24 + 7i36
Category: PnCConf Wizard
This browser does not support PDFs. Please download the PDF to view it: Download PDF
File Name: HAL_INI.zip
File Size:4 KB
I am from Taiwan and want to modify a decommissioned laser etching machine into a CNC router. I purchased MESA 6i24 and 7i36 cards from EuSurplus. my old PC can now detect the 6i24 (5i24_16_sv8_7i36x2d.bit), and I've started configuring Pncconf.My machine and PC software configuration are as follows:
1. Linear motor: HIWIN, LMSA22
2. Driver: Maga-Fabs, D1-36-S2-2-0-00 (refer to D1-User-Manual_CN2.pdf)
3. Optical scale: Renishaw, 20μm
4. Decoder: MicroE Veratus VX 0.5μm
5. Debian 12 + Linuxcnc2.9.8 + mesa 6i24 mesa 7i36
6. X-axis travel: 500mm, maximum speed: 50mm/sec (for testing purposes only, not for actual use)The generated INI and HAL files after configuration are attached. I'm not sure that it's correct?
  • rodw
  • rodw's Avatar
15 Jan 2026 02:48
if you expect a CNC machine to be able to be moved without using the CNC control to move it you are outside the normal paradigm.
You could try immediate homing without limit switches but I think that may restrict you motion to just one quadrant.
Try changing the jog scale when jogging in the gui.
There is something to be said for a good pendant
  • WobblyZ
  • WobblyZ
15 Jan 2026 02:14
Replied by WobblyZ on topic How to set current machine position manually?
From what I can see, touch off sets the part origin relative to the current position, but linuxCNC doesn't know what the real current position is because I moved it with the handwheels and not the jog function. So when I touch off, it thinks I'm still at home position and sets the part origin relative to home which causes the tool paths to be outside the machine limits.
Is there no way to set the current position relative to home directly? I can't use the jog function because my computer is too slow and the machine keeps moving long after I've let go of the mouse.
  • NWE
  • NWE's Avatar
15 Jan 2026 02:11
Replied by NWE on topic Press Brake controls
Looking to join a thread on this topic and collaborate. Is there any progress on a Brake Press UI and a repo or something where I can use/contribute.
I'd prefer not to use a glade UI due to deprecation if possible.
I'm working on a press brake retrofit and will also soon be needing a gui for it. I originally planned to do it in glade, but have been looking at FlexGUI and am open to the idea of using that or similar instead. What do you say, we start a thread and get it rolling?
Displaying 8446 - 8460 out of 12668 results.
Time to create page: 0.623 seconds
