  • PCW
  • PCW's Avatar
14 Sep 2026 22:04 - 14 Sep 2026 22:10
7i97T + 7i74 + 7i84U – No Smart Serial Communication
Category: Driver Boards
Well naturally, no problem found...
pcw@pcw-HP-Compaq-Elite-8300-USDT:~/bitfiles$ md5sum 7i97t_7i74d.bin
4130ebee623115267327c166f8da9d39  7i97t_7i74d.bin
7I97T with that firmware finds 7I84Us on all (1..7) 7I74 channels
7I74 channel 0 (lower left if facing the jacks) is not used with this firmware
as port 0 channel 0 is on the 7I97T card.
This is with our normal DB25M-IDC26 cable (and 7I74 powered over cable)
For external power make sure you have both the 7I74 and 7I97T Jumpered correctly:
7I97T W22 DOWN
7I74 W1 DOWN
Also note the 7I74 channel 1 is the top/left jack
facing the jacks, they are numbered:
1  3  5  7
0  2  4  6
  • Cayenne
  • Cayenne
14 Sep 2026 20:55
Replied by Cayenne on topic Probe panel for Axis GUI
Category: AXIS
2.7.15
  • Cristy13
  • Cristy13
14 Sep 2026 20:20
  • PCW
  • PCW's Avatar
14 Sep 2026 19:42
  • PCW
  • PCW's Avatar
14 Sep 2026 19:24 - 14 Sep 2026 19:27
I would try:
config="sserial_port_0=00000000"
Might also be a DB25 cable issue, not all adapters are wired correctly for this use.
  • Cristy13
  • Cristy13
14 Sep 2026 18:58
Hi,I am retrofitting a CNC lathe with LinuxCNC and I have the following Mesa hardware:
  • 1x Mesa 7i97T
  • 1x Mesa 7i74
  • 4x Mesa 7i84U
  • IDC26 to DB25 adapter
  • DB25 male-male 1:1 cable between 7i97T P2 and 7i74
  • standard straight-through CAT5e cables between 7i74 and 7i84U
The problem is that none of the 7i84U boards are detected over Smart Serial.The 7i97T is reachable at:
192.168.1.121
I am using firmware:
7i97t_7i74d.bin
MD5:
I also verified the firmware in flash with:
mesaflash --device 7I97T --addr 192.168.1.121 --verify /home/cnc/7i97t_7i74d.bin
and I get:
Board FLASH memory verified successfully
mesaflash --device 7I97T --addr 192.168.1.121 --sserial
gives only:
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 8
SSLBP Baud Rate: 2500000
but no 7i84U devices are listed.I tested 7i84U boards on CH1 and CH2 of the 7i74 with the same result.On the 7i84U:
  • W3 = LEFT / operate mode / 2.5 Mbaud
  • VIN = about 28 V
  • VFIELD A = about 28 V
  • VFIELD B = about 28 V
  • CR2 ON
  • CR7 ON
  • CR5 red ON
  • CR6 green OFF / never blinks
On the 7i74:
  • CR1 is ON
  • I initially measured only about 4.5 V
  • I changed it to external regulated 5 V supply
  • now TB1 measures 5.08 V
  • the problem is still exactly the same
I checked the RJ45 cable and it is straight-through:
1-1, 2-2, 3-3, 4-4, 5-5, 6-6, 7-7, 8-8
I also tested the 7i97T P2 interface with W21 UP and P2 disconnected:
mesaflash --device 7I97T --addr 192.168.1.121 --rpo 0x1008
Result:
0001FFFF
So that test appears to pass.
readhmid
 also shows the expected Smart Serial signals:
RXData0/TXData0
 on the 7i97T and
RXData1...7 / TXData1...7
 for the 7i74 channels.I also tried loading HostMot2 manually:
halrun
loadrt hostmot2
loadrt hm2_eth board_ip=192.168.1.121 config="sserial_port_0=x0xxxxxx"
The 7i97T loads and registers normally, but the 7i84U is still not detected.Everything is new hardware.At this point I suspect either the 7i74 itself, the IDC26/DB25 path between P2 and the 7i74, or something I am missing in the Smart Serial configuration.Does anyone have a known-good 7i97T + 7i74 + 7i84U setup and can tell me what I should test next?In particular:
  • Is
     correct for a 7i84U connected to CH1 of the 7i74?
  • Is there a direct test for TX/RX on the 7i74 without an oscilloscope?
  • Are there any jumpers/settings on the 7i74 or 7i84U that I may have missed?
Thanks.
  • PCW
  • PCW's Avatar
14 Sep 2026 17:17
Replied by PCW on topic 7i76EU Availibility ?
Should be this week.
  • ihavenofish
  • ihavenofish
14 Sep 2026 16:31
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
beep boop...
  • Schaublin12
  • Schaublin12
14 Sep 2026 16:05 - 14 Sep 2026 16:11
Replied by Schaublin12 on topic EtherCAT Master Beckhoff slave not found
Category: Basic Configuration
I have tried lcec configgen xml
Now I have got a new xml file as attached, but LinuxCNC doesn't start.
  • tuxcnc
  • tuxcnc
14 Sep 2026 14:42
Replied by tuxcnc on topic Crash
Crash
Category: Plasmac
Typical of Python, the message is absolutely true and absolutely useless...
ValueError: invalid literal for int() with base 10: '' means that you are trying to use an empty string as an int variable, but it doesn't tell you where that empty string came from.
Of course, you can look for the cause for a long time and finally find that, for example, the disk is damaged...
I see that you have a very old Linux with Python 2.7 and instead of repairing this museum, you would be better off installing a new system on new hardware.
It may be easier, and it will definitely be better.
  • Jdog
  • Jdog
14 Sep 2026 12:14
Replied by Jdog on topic Crash
Crash
Category: Plasmac
Sorry about that. Ive attached pics here.
  • Marslukan
  • Marslukan
14 Sep 2026 11:12 - 14 Sep 2026 11:41
Replied by Marslukan on topic 7i98 and 5abobx3 firmware
Category: PnCConf Wizard
Спасибо большое. На плату залита прошивка с сайта mesa (7i98_5abobx3d.zip - bit and pin), хотя плата неоригинальная. Приложил файлы с фото платы и распиновкой: old - что сейчас пока установлено, new - как нужно. Свободные пины на P3 буду использовать по концевики,  HOME, Estop и переключатели.
  • my1987toyota
  • my1987toyota's Avatar
14 Sep 2026 10:07
Replied by my1987toyota on topic 7i76EU Availibility ?
I decided to wait for the next batch of boards to come out. Any estimation when they will be available?
14 Sep 2026 10:04
LinuxCNC + Mesa 7i92TF: motors barely move and ignore direction changes
-Use a DVM to check if the ground is properly connected.
-A quick test, make another config with PncConf, but invert all stepgen output pins.
Upload the config files here sop we can have a look, and some pictures of the wiring.
Displaying 886 - 900 out of 11519 results.
Time to create page: 0.406 seconds
