  • Ferra
  • Ferra
04 Jan 2026 17:44
Quick sanity-check was created by Ferra
Quick sanity-check
Category: PnCConf Wizard
Hi everyone,
I’m configuring LinuxCNC with a Mesa 7i95T and I’d like to ask for a quick sanity-check of my .hal and .ini files, I'm new to the subject so just to make sure I didn’t do anything stupid before I move forward.Quick context: with the 7i95T there isn’t a full “wizard” configurator. I generated a base config with PnCconf, then had to manually edit a bunch of things (I/O mapping, firmware for PWM, encoder/MPG, etc.). The machine now works, but I’d really like a second pair of eyes on:
  • Mesa pin mapping ↔ LinuxCNC signals (inputs/outputs, enables, polarity)
  • thread setup / addf order (servo-thread, base-thread if used)
  • common HAL mistakes: duplicated nets, non-existing pins, unconnected signals, wrong inversions
  • INI mistakes: JOINT/AXIS settings, limits, SCALE, stepgen/encoder params, homing sequence, etc.
I’m attaching the following:
  • machine.ini
  • machine.hal
  • if needed, I can also post all the other HAL files like postgui.hal etc
If someone can spend a couple minutes to point out anything that looks wrong or risky, I’d really appreciate it.Thanks!
  • JT
  • JT's Avatar
04 Jan 2026 17:18
LinuxCNC 2.9.8 Image with Debian Trixie
Category: Installing LinuxCNC
Also note that there is no /etc/apt/sources.list.d/debian.sources in my Debian 13 after doing a full upgrade.
JT
  • Lcvette
  • Lcvette's Avatar
04 Jan 2026 16:14
Replied by Lcvette on topic Probe Error causes Jog lockout
Category: QtPyVCP
I am unable to reproduce the error on the sim because I needed to trigger the probe while it was going to home or the starting location to start probing. This would cause a G38.2 error then the lockout would start. I ran a debug and returned a [Error] from a specific routine. I should have grabbed a screenshot.. I noticed a difference in the sim subroutines folder vs the subroutines folder I got from the github. I replaced all the files and lockout is no longer accruing
If you by chance find the offending routine again, please let me know!
I assume the issue for the probe triggering while going to home or to the starting position was for tool setting?  or was this for a custom 3d touch probe subroutine you created?  I would like to try and find where the issue was coming from to make sure it gets corrected and doesn't re-appear in future edits.
Thanks!
Chris
  • Lcvette
  • Lcvette's Avatar
04 Jan 2026 16:05
Replied by Lcvette on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
nice! I think the more uniform future solution will be the suite of var file widgets i have been testing, but this will work for now and is similar to how i store, save and update var file parameters. its just a pain in the butt to have to custom code things in like that.
the new var widgets will handle all of the heavy lifting for saving, storing, loading, updating etc. so all you would need to do is drop the desired widget in your ui and assign it a variable number and it will just work as expected from that point forward. I also have made some changes so that the precision will not be lost when storing/loading between the var file and the qt interface where previously after a store/save occurred the values were getting truncated at the displayed decimal place formatting. the new widgets will have an option to check for high precision storage so that the full value untruncated is retained even with a truncated display. should make things more robust!
  • freylax
  • freylax
04 Jan 2026 15:43
Lieber Oliver,
ich benoetige noch einmal Deine Aufmerksamkeit. Mir will es nicht so recht gelingen eine vernuenftige Geschwindigkeit und Schritteweite einzustellen.
Ich habe Schrittmotoren welche im Fullstep Mode 60 Schritte fuer eine Umdrehung benoetigen. Eine Undrehung erzeugt einen Vorschub von 5 mm. Wenn ich eine maximale Geschwindigkeit von 5mm/sec einstellen moechte, welche Paramater sind fuer die Stepdir Konfiguration zu setzen? Ich dachte Scale bekommt einen Wert von 12 (60Steps/5mm) = 12 Steps/mm, und MaxVelocity 5(mm/s) - Aber so richtig will es nicht gelingen, der Motor flattert nur...
Ich danke Dir, liebe Gruesse,
Robert
  • tjtr33
  • tjtr33's Avatar
04 Jan 2026 15:15 - 24 Jan 2026 13:20
Sinker EDM machine based on diy pulse generator
EDM pulsae generation _is_ simple. thats true.
Some of the support circuits are not (like ionization detector)
But NB: I said 'pulse' , as in ONE pulse.
The EDM process has no use for repetitive oscilator function
( PWM is right out) .
I you use a repeating time sequence,
 you will not cut as fast as you can,
 you will not get a uniform crater ddpeth,
 you will get longer arcs after they begin
 you will get more arcs
 and you will have to accomodate
  by waiting langer than needed before rnext pulse.
Yes, fiexed on off will cut,
 jdut slower and with more nad discharges.
HOW TO MAKE ONE SPARKK:
The pulse generation sequence is:
 1) Detect when gap is ready for a pulse
  Tickler or Sensing Voltage:
  Apply a very weak yet high voltage difference across the gap.
   (say 100V with a 250mA supply)
  The potenttial will stay at 100V until...
   the tool gets close enough to the workpiece,
   so close that the dielectic breaks down and
   a tiny weak spark occurs.
  When the gap is small ecough,
   the gap voltage willnose dive
   markimg when the working pulse should begin.
   marking when the gap gfot IONIZED
 2) The genertor then makes ONE pulse:
  NOTE the sprak is triggered by the porcess not a timer.
  The current is connected
  and ontime is decremented till 0
 3) During OnTime current should be monitored.
  A scope will show the current rise to avalue and stay there till OffTime negins.
  The scope will ahow a very high frequency ringiing on the 'flat'
  If that ringing stops mid OnTime, you got and arc!
  ( we wre able to shut off a bad pulse within 4us, too slow!)
  Such a safety circuit is not discussed here,
  other than to say itrs a good idea.
  Turninf off the pulse is ghood,
  but you already arced! (ask Gemini how to predict arcs)
 4) Turn off the current:
  Turn it off as soonas you can.
  A sloping trailing edge is bad.
  square is good and hard to achieve
  Remove all inductance thgat uou can,
  Use ultrafast diode across gap.
  Sharp turn off gets better removal,
    ( the implosion is more explosive)
    a slow turn off gets more re-cast
     (material coolimg back onto wkpc)
  5) Take a break: Off Time
    Then a minimum delay time is waited out.
    ( The mfctrs say this value is usually enough
    time to let the gap recuperate. They say
    thius is a minumum, expect longer if you are not
    in a testing environment)
  6) Recuperation:
    GAP restoration:
    The gap _was- clean, then got chrged and dirtied.
    Q: whats all thata black smoke in the oil?
    A: The oil is a hydrocarbon
     that gets 'cracked' into hydrogen gas ( flammabvle)
     and carbon ( from oil, not from tool)
   When will the gap be ready again?
    The weak tickler voltage will rise to Uo
    ( say 100V) as soon as the gap is clear of debris.
    Waiting for a clear gap
     makes the same environment for the next spark.
    Your circuit _could_ refire as soon as the gao clesars
     or ( sort of debouncing) you could recheck a few times first.
    Dont refire when Uo is not high.
     That would avoid the necessary dielectic
     resistance and would cause pitting or arcing.
  8) repeat
    It's not on of on of on off
    It isd  Wait on of Wait on off Wait on rff
HTH TomP
  • Lcvette
  • Lcvette's Avatar
04 Jan 2026 15:11
Replied by Lcvette on topic Axis deflecting while jogging in G54
Category: QtPyVCP
were you reloading the table after saving it? this is what removes any previous offset that may be in cached memory even after storage location has changed i think.
  • JT
  • JT's Avatar
04 Jan 2026 15:04
Debian trixie uses the new deb822 format so sources.list is no longer used.
Instead  look in /etc/apt/sources.list.d/debian.sources for the sources in the new format
I added the mesact repository in debian 13 to synaptic package manager and it put it in sources.list... so it must still work.
JT
  • Lcvette
  • Lcvette's Avatar
04 Jan 2026 14:55
Category: QtPyVCP
ok great!
  • JT
  • JT's Avatar
04 Jan 2026 14:55
I would not use stable in the repositories because the os can change next time debian is released. Better to use trixie... to bad debian doesn't do something sensible like using numbers.
JT
  • dfarnainekl
  • dfarnainekl
04 Jan 2026 14:46
Replied by dfarnainekl on topic Spindle Encoder: Float Precision Issues
Category: HAL
Yes, the EL5151 provides integer counts, which get converted to float by the LinuxCNC EtherCAT driver.
So with the misconception of floats having only 32bit being resolved, everything makes sense now.
  • Tomatendose
  • Tomatendose
04 Jan 2026 14:30
Commission drive on AX5206) using TC3 to prep for linuxcnc-ethercat
Category: EtherCAT
Hello,
I am currently also in the process of setting up an AX5112 servo drive. Unfortunately, there does not seem to be any newer firmware available for my device that would allow me to use Drive Manager 2, so I have to stick with Drive Manager Classic.
My problem is that I cannot see the Drive Manager at all in the tabs of the drive/motor configuration. At the moment I am only supplying the drive with 24 V so that I can familiarize myself with it.
Does anyone have an idea what could be wrong here? I can hardly find any documentation on how to use Drive Manager Classic in TwinCAT 3. The Drive Manager Classic itself is installed via the package manager.
  • 5_Zylinder
  • 5_Zylinder
04 Jan 2026 13:14
Replied by 5_Zylinder on topic Mesa Configuration Tool
Category: Configuration Tools
A friend of mine helped me and adjusted the source.list accordingly. Now the Mesa Configuration Tool works.
  • tomaszeg
  • tomaszeg
04 Jan 2026 12:52 - 04 Jan 2026 16:11
Replied by tomaszeg on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I bought a cheap Ethercat servo from Aliexpress and trying to make it working Linuxcnc. The servo is PFDE ethercat 400W and it is almost the same like Lichuan A5 (I'm using Lichuan manual because original i got is only in Chinese language). Generaly servo is working with linuxcnc, but once per many times it is not going to OP mode. I started debugging and it turned out that it has DC sync problems. Usually after 5s timeout, syncronization is failing, but still it is going to OP mode and I can operate it from Linuxcnc.
Can anyone help me with this problem? Generally it is working, but I dont want situation that I have to start linuxcnc few times to make it working.
I have xml configuration file from seller, but they don't provide any application to program EEPROM, but when I'm checking slave version, it is the same that I got from seller. The dmesg output is:
[color=#000000][ 9372.332054] EtherCAT WARNING: Datagram 00000000b0d26d62 (master-fsm) was SKIPPED 1 time.
[color=#000000][ 9603.335415] EtherCAT: Requesting master 0...
[color=#000000][ 9603.335421] EtherCAT: Successfully requested master 0.
[color=#000000][ 9603.335511] EtherCAT 0: Domain0: Logical address 0x00000000, 26 byte, expected working counter 3.
[color=#000000][ 9603.335513] EtherCAT 0:   Datagram domain0-0-main: Logical offset 0x00000000, 26 byte, type LRW.
[color=#000000][ 9603.335534] EtherCAT 0: Master thread exited.
[color=#000000][ 9603.335537] EtherCAT 0: Starting EtherCAT-OP thread.
[color=#000000][ 9603.335572] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[color=#000000][ 9604.007324] EtherCAT ERROR 0-0: Failed to receive DC sync check datagram: Datagram queued.
[color=#000000][ 9604.333875] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[color=#000000][ 9604.733868] EtherCAT WARNING: Datagram 00000000b0d26d62 (master-fsm) was SKIPPED 1 time.
[color=#000000][ 9609.114230] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms.
[color=#000000][ 9609.119230] EtherCAT 0: Domain 0: Working counter changed to 3/3.
[color=#000000][ 9609.429835] EtherCAT 0: Slave states on main device: OP.
 [/color][/color][/color][/color][/color][/color][/color][/color][/color][/color][/color][/color][/color][/color]
  • unknown
  • unknown
04 Jan 2026 12:35
Replied by unknown on topic LinuxCNC 2.9.8 Image with Debian Trixie
Yeah the raspi-image thing was related to a config issue and the version of live-build being used.
Displaying 8866 - 8880 out of 12667 results.
Time to create page: 0.344 seconds
