  • SwitchWitch
  • SwitchWitch
31 Jul 2025 11:48
Replied by SwitchWitch on topic Stepperonline A6 - How to properly Tune them?
Category: EtherCAT
You mean, that you didn`t tune your Servos at all?
In my world a Servo need to be tuned connected to the machine and the load it has to work with to work properly and performant.
  • andypugh
  • andypugh's Avatar
31 Jul 2025 11:30
Replied by andypugh on topic Touch off don`t work "file not open"
Category: AXIS
Why a user entry for a float value would be passed through all of that, I have no idea.
That part I can explain. Axis allows you to enter any valid G-code expression (apparently including parameters) in the numeric entry box.
I have used it for simple things like 1234.5 / 2 but it also allows functions like SIN / COS / PI (?) and from looking at the code I think you can probably use the numeric parameters in the .vars file.
So, in this case the error seems to be caused by not finding the PARAMETER_FILE.
OP: does that entry appear in your INI? And does the referenced file exist? (and who does it belong to?)
linuxcnc.org/docs/stable/html/config/ini...sub:ini:sec:rs274ngc
  • xlordofpainx
  • xlordofpainx
31 Jul 2025 11:16
Problem setting up with inputs on 7i96s. Potential Electrical cabinet problem
HAHA
Thank you!
I spent so much time on this, I had forgotten to hook that up. Still strange that the LEDs worked after connecting 4 switches. Anyhow. I can finish this now.
  • matthias
  • matthias
31 Jul 2025 10:57
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Category: Driver Boards
Nevermind, I have changed the JTAG programmer to USB Blaster and everything went fine.
My board responds to pings, but seems to drop 50% of the packets, is this normal?
  • unknown
  • unknown
31 Jul 2025 10:08
Replied by unknown on topic Wiring cables for closed loop stepper motors
Category: CNC Machines
I generally keep signal & power separate (I include the wires for the stepper coils power).
  • my1987toyota
  • my1987toyota's Avatar
31 Jul 2025 09:10
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
Even then unknown I don't expect things to get better with the next administrations.
  • unknown
  • unknown
31 Jul 2025 09:05
Replied by unknown on topic ARE YOU KIDDING ME YOUTUBE !!!
You can thank the UK gumbernment and my own pseudo socialist gumbernment. It's embarrassing to be an Aussie at the moment and we have 3 more years of the fools.
  • Gautham
  • Gautham
31 Jul 2025 07:04
Replied by Gautham on topic Connecting my 7i96s to the VFD
Unserstood, thank you
  • Gautham
  • Gautham
31 Jul 2025 06:12
Hi Everyone,
I am in the process of wiring up my first CNC machine and just spent the day finishing up the wiring from my closed-loop stepper motors to the drive, and was wondering if I had made a big blunder. Since the encoder needs 6 wires for EB-, EB+, EA-, EA+, VCC and GND and the stepper power needs 4 more for A+, A-, B+ and B-, I used a single 10-core shielded cable from the drive to the stepper. Is this ok, or will it cause problems, and should I have used a 4-core and a 6-core cables instead? I don't have much of an electrical background, so I am really unsure about this. Thanks for your help
Gautham
  • Gautham
  • Gautham
31 Jul 2025 06:03
Using a rotary encoder for Homing A-Axis on 7i96s
Hi Everyone
I am in the process of wiring up my first CNC 5-axis machine and I wanted to know if I can use this Rotary Encoder  to home the A-axis and if so how would I wire it up. From the research I have done, my understanding is that it can be done but it involves some editing of VHD files that I didn't really understand since I am new to LinuxCNC. Thanks for the help
Gautham
  • directandrew
  • directandrew
31 Jul 2025 02:54
Replied by directandrew on topic probe basic conversational macros missing?
Category: QtPyVCP
Thinking about this a little more, where is the documentation link to writing custom conversation macros? Basic ones,I can learn on or test.
I have a few conversation mill events in python, but just can't figure out how to try and load them. Looks like I need a gfx screen and then links to the macros. Which then produces some gcode?
Any help or videos would be awesome. I want to add a nice pocket and frame event.
AG
  • JetForMe
  • JetForMe's Avatar
31 Jul 2025 00:01
I seemed to have borked my GTK/Glade installation
Category: GladeVCP
What did you do to fix it?
I updated to GTK+ v3.x, and asked ChatGPT to help me update my lzpanel.ui file to the latest version. It was amazingly helpful in this regard, although I think there were a couple hiccups along the way.
  • ihavenofish
  • ihavenofish
30 Jul 2025 22:22
Replied by ihavenofish on topic Mini wannabe datron build
It's almost time to make V2....!!! (like for real)
Big enhancements in the work holding area. quick change 5 side vise indexing, and some other tricks. 430mm x 270mm/310mm travel And a 10 tool robodrill style tool changer.
  • DauntlessA
  • DauntlessA
30 Jul 2025 22:09
Possible to access a HAL OUT pin for jog count backlog
Category: HAL
For axis or joint jogging, there are HAL IN pins for jog-counts. For example, for axis jogging there is axis.L.jog-counts IN S32.
When movement is permitted (enable pin high, in manual mode, not at a soft limit etc) a change to the jog-counts pin will cause movement.
Since the jog is incremental, normally the value of the pin is increased incrementally by the control method (such as a jog wheel), not set to a specified value.
This means that there is potential for a backlog of incremental jog movements to be accumulated, if the rate at which the incremental logs are executed in one direction exceeds the rate at which the jog counts pin has changed.
This manifests as a continuous jog which ends once the backlog has been cleared.
My question is, is there currently any way of accessing the number of counts which make up this 'backlog'?
Or accessing an analogous value such as the DTG for the joint/axis if the backlog of jog counts is summed?
This data should exist in some form in the motion planner, so it should be possible to get it into a HAL OUT pin.
GStat does seem to have a get_jog_increments function, but since the other arguments reference GStat's internal jog parameters, so I think this just returns what was set by the set_jog_increments function.
In summary (as far as I know), there is an IN pin for jog counts, but no OUT pin which actually indicates how many counts are 'queued' in the motion planner.
Is it possible to make this into a HAL pin in a current installation?
Or what might be changed in the current motion planner to make this value a Stat/GStat attribute or HAL pin?
Thanks!
  • oneKone
  • oneKone
30 Jul 2025 22:03
Replied by oneKone on topic Ethercat CATIO-A setup
Category: EtherCAT
again, cheers once again for pointing me in the right direction.
unfortunately i'm still far to green to get a working hal snippet for pwm control, but chatGPT isn't... after a bit of back and forward this was the result:
setp lcec.0.0.PWM-OUT-0 98304000 #sets frequency to 1.5khz
loadrt scale count=1
loadrt conv_float_u32 count=1
addf scale.0 servo-thread
addf conv-float-u32.0 servo-thread
setp scale.0.gain 3.5
net gui-rpm spindle.0.speed-out => scale.0.in
net scaled-rpm scale.0.out => conv-float-u32.0.in
net rpm-u32 conv-float-u32.0.out => lcec.0.0.DUTY-OUT-0
i now have a working PWM out!
i did try outputting to analog out but there seems to be some problem with it, for example 20 000 rpm would output 3v, 10 000rpm would give 5v, 7500 rpm would output 2v. It's not the end of the world, but hopefully i can get it sussed at the very least for others that try this board.
once again,
cheers for the help to get a working PWM out!
Displaying 11566 - 11580 out of 17284 results.
Time to create page: 0.827 seconds
