  • jschulze
  • jschulze
30 Jul 2025 02:33
Replied by jschulze on topic Unwinding Rotary Axis for Homing
Here's the file for the head assembly. It's a fusion archive, so hopefully it included all the components properly. If you want a different format just let me know.
drive.google.com/file/d/1jZTfEVjwmL9wT5n...b-K/view?usp=sharing
  • cakeslob
  • cakeslob
29 Jul 2025 22:48
Replied by cakeslob on topic Probe panel for Axis GUI
Category: AXIS
instructions for that are in the readme
  • PCW
  • PCW's Avatar
29 Jul 2025 22:07 - 29 Jul 2025 23:08
Replied by PCW on topic Mesa 7i96S MPG encoder on P1
Category: Driver Boards
Not sure what the issue is, it works for me:
Built a 7I96S bitfile, flashed to 7I96S and ran it with LinuxCNC
( This is on Mint 20.3 = Ubuntu 20.04, Efinity 25.1 patched with the July 24,2025 patch )
  • GuiHue
  • GuiHue's Avatar
29 Jul 2025 20:50
Replied by GuiHue on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
i've got the AX5106 and A5203 up and running. db1981 helped al lot regarding the homing and pos_mode issues.
The project itself is still work in progress, but the main features are working. See attached files. These are the relevant snippets from *.hal: [..]
Hi deedee: Are the referenced ax5206.xml and ax5203.xml in the ethercat-config.xml the files attached or are they different ones?
  • atrex77
  • atrex77's Avatar
29 Jul 2025 19:21 - 29 Jul 2025 19:25
W5100S-EVB-PICO stepgenerator and encoder driver
started a proper configurator tool in python, early version, if you want to try it clone the test repository.
early sample, most of the functions are not working yet, you can move the components by grab it, make connections by click the pin and click to another pin, and delete the connections using the list in the right side and the "Del conn" button.
git clone -b test https://github.com/atrex66/stepper-ninja.git
sudo apt install python3-pygame
cd stepper-ninja/configurations/configurator
python3 configurator.py
  • PCW
  • PCW's Avatar
29 Jul 2025 18:24
I'll try with 2025.1 today
Did you apply the 2025.1 patch?
  • roland100
  • roland100
29 Jul 2025 18:11
Replied by roland100 on topic Mesa 7i96S MPG encoder on P1
I tried efinity 2025.1.When I try to open the project seveni96s.xml i get the error:
The previous synthesis run has failed. To avoid potential problems or unreliable data, please run it again.
I click O then I get the message:
The family or device maybe invalid. Click OK to proceed with default family and device. Click Cancel to close project and abort.
Then I click OK the next message:
Encounter internal error. Please get help from support team
What does this all mean ? Do I have to choose a family or device first ?
I`m working on xubuntu 24.04
Do you have any suggestions ?
  • COFHAL
  • COFHAL
29 Jul 2025 17:23
Replied by COFHAL on topic Probe panel for Axis GUI
Category: AXIS
When I press any of the keys X0 YO ZO X this error Unknow command M: M130 appears. What could be the cause?
  • PCW
  • PCW's Avatar
29 Jul 2025 13:21
Replied by PCW on topic Connecting my 7i96s to the VFD
They all connect to the VFD COM pin
(Spindle-,Out4b,Out5B --> VFD COM)
  • GuiHue
  • GuiHue's Avatar
29 Jul 2025 12:41
Commission drive on AX5206) using TC3 to prep for linuxcnc-ethercat
Category: EtherCAT
In a rather unfortunate and quite embarrassing turn of events: The actual gearbox section was missing from that drive without anyone noticing. Turns just fine now;).
  • epineh
  • epineh
29 Jul 2025 11:22
Yep cool, I am thinking of things like feedrate override, jog speed, rapid override etc nothing "realtime". We have noticed Modbus is slow with general IO, horses for courses I guess.
I've had more electronic parts turn up today so I plan to get busy on the weekend and start testing Riosub over the next few weeks. I've got 4 and 6 axis closed loop controller boards ready to test, both with dual Modbus connections and shift register out, so I can trial multiple combinations... will keep you posted.
Cheers,
Russell.
  • sk_linuxcnc
  • sk_linuxcnc
29 Jul 2025 08:32
Help : Layman configuration for Raspberry Pi 5, Linuxcnc 2.9. and Mesa 7i96
you are right, it was quite simple indeed.
i opened the file interfaces file with
$ sudo open /etc/network/interfaces
commented out every line under #wireless
(managed to save the file this time since i was with sudo previlages.. unlike previously where i opened the file manually through the file manager)
$ sudo reboot
now wifi shows up under network manager gui, and it can be turned on and off easy.
thank you!
  • TripleM
  • TripleM
29 Jul 2025 07:24
Replied by TripleM on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
hello,
in the nc files you have set the actual x and z positions as starting point after you do a tool change (M6).
In my case it moves to the tool changing position and than the startingpoint is wrong.
I adapted it for myself, but I just wanted to ask if there was a specific reason why the order was chosen that way.
I'm also interested in why the cycle isn't used for thread cutting.
  • Hakan
  • Hakan
29 Jul 2025 06:59
Replied by Hakan on topic Ethercat CATIO-A setup
Category: EtherCAT
Yes one often need some type conversion.
Maybe conv_float_u32? linuxcnc.org/docs/html/hal/components.html
Displaying 11611 - 11625 out of 17286 results.
Time to create page: 0.364 seconds
