  • sin-do-re
  • sin-do-re
27 Jul 2025 15:08
7i97T and analogous + Siemens 611 was created by sin-do-re
Hey everyone
I have managed to completely interface with a Siemens 611, enabling it, clearing faults, reading encoder etc.
they move well when I apply voltage to the analog port.
its a huge tandem machine with two Y axis but I’ll be copying the signal as there’s no need for gantry skew correction.
I’m using a 7i97T but the analog part is not working as intended: no voltage comes out at all!
im using a 7i97T test config from the forums because there’s no PNCconf for 7i97T.
but, although the config runs, I have no analog output in any of the ports.
I assume it is configuration, because the config provided is using pwmgens and MAX_OUTPUT but no analog out or Min/Max.
does anyone have a working config for the 7i97t or 7i97?
thank you
best regards
  • AkkiSan
  • AkkiSan
27 Jul 2025 15:00
Replied by AkkiSan on topic Probe tripped during non-probe move deadlock
My apologies for spamming this forum with stupid questions,
but I was short on time, hehe.
Finally, success. I outsmarted the probe with the Great HAL:
setp                flipflop.0.set              FALSE
setp                flipflop.0.data             TRUE
net probepin        parport.0.pin-11-in-not  => flipflop.0.clk
net probereset      motion.digital-out-00    => flipflop.0.reset
net probefiltered   flipflop.0.out           => motion.probe-input  parport.0.pin-01-out
Then use M64/M64 P0 to keep the flipflop in reset during the retraction:
  G38.2 Z#8
  M64 P0    (reset probe flipflop HIGH)
  G0 Z#7
  M65 P0    (reset probe flipflop LOW)
Out probing,
AS
  • hitchhiker
  • hitchhiker
27 Jul 2025 14:42
Servo Spindle with velocity AND position mode for Toolchanger?
hi
i think here is it better instead of my retrofit thread.
the emco vmc100 has a carousel which is turned by the spindle.
i use the original spindle hardware.
i can tap threads and mill. there is a encoder on top of the spindledrive.
with m19 r p i can orient the spindle.
now i came to the point that orient not works for the toolchanger because 2 spindle rotation are 1 positionchange from slot to slot.
could someone help me to get it work in position and velocity mode?
to enable the spindle i have a relay. if the relay open the drive is disabled and i can turn the spindle by hand.
if its enable the spindle is blocked and the pid bring it back to position.
thanks i will upload my hal in a hour
  • tuxcnc
  • tuxcnc
27 Jul 2025 13:59 - 27 Jul 2025 17:59
SpindleETH was created by tuxcnc
SpindleETH
Category: Driver Boards
github.com/tuxcnc/SpindleETH
# SpindleETH
Intended for lathe spindle control by Ethernet.
No axes control.
# Hardware
This repository is for STM32F103C8 or STM32F103CB
# Tests
Tested on real machine with 2500 p/r encoder and ~1500 rpm.
Direct to PC's eth interface or thru switch (some switches may not work).
# Improvements
New index_enable philosofy.
The encoder's index signal (mostly named Z) is not transmitted to HAL component (it causes delays and threatens to lose a signal).
Controller sends raw counts and raw counts latched at every index pulse instead.
The component knows the index occured by comparing current and previous latched values.
# Adds
1. PWM output (1 kHz and 16 bit resolution)
2. Digital I/O
# Tools
Added encoder emulator for tests.
Important: Arduino can't turn off ESP32C3 watchdog and resets chips after every two seconds.
If it is problem for you, rewrite code for esp-idf or use other microprocessor.
# Other info
Read comments at the tops of source files.
  • kworm
  • kworm
27 Jul 2025 13:58
Replied by kworm on topic Servo Driver Plasma Retrofit
Category: Plasmac
Is it possible to use stall force tolerance for z axis home and detecting the sheet metal in qtplasmac?  I will add a floating head and a z home switch if its not possible.
I'm not sure that could be done using analog without writing a custom component, but I'm no expert on analog.   In my experience you want some kind of floating head so that if the metal tips up or something it will stop the machine plus you can use it to probe the work height.  I haven't tried it yet but you can also do ohmic sensing to detect the material + float as backup.
  • kworm
  • kworm
27 Jul 2025 13:55
Category: Plasmac
Hi kn612,
Were you able to get motion with your analog servos as well? PCW was kind enough to send me a 7i97t for testing as well. I will make a pull request to add it to 2.10/master when we confirm it.
  • PCW
  • PCW's Avatar
27 Jul 2025 13:01 - 27 Jul 2025 13:18
Mesa 7i96 mixed voltage field input wiring
Yes, if the input common is a + voltage, those are sourcing inputs.
( it's easy to get confused as sourcing inputs connect to a sinking drivers and vice versa )
  • hitchhiker
  • hitchhiker
27 Jul 2025 11:18
Replied by hitchhiker on topic ATC + TOOL_CHANGE_QUILL_UP
Category: G&M Codes
hi i am on the same point... could you share your solution please?
  • mBender
  • mBender
27 Jul 2025 11:03
Replied by mBender on topic SOLVED Fresh install and apt problem
This solved it.
sudo rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
  • epineh
  • epineh
27 Jul 2025 09:46
Just wondering if the MODBUS plugin will handle analog input modules, for things like feed/rapid/jog override? Modules like this one :
www.aliexpress.com/item/1005007137758623...3A#nav-specification
I am happy to purchase one for testing if it helps.
Cheers.
Russell.
  • beefy
  • beefy
27 Jul 2025 07:36
Reasons to DIY build a 3D printer was created by beefy
Category: Additive Manufacturing
OK, only just at the end of last week, I was given an Ender 3 original, my very first 3D printer.
Having seen how crap the mechanical design is (why didn't they just make it out of soft rubber) I wondered about DIY builds, but after chatting with the guy who gave me the printer he said just buy one. I do a search online and seems many say you don't save much money over a ready made one.
However, I look at the price of larger printers and they seem to cost a few thousand.
My studies over just this weekend have shown me that the dedicated 3D printing mainboards are freely available, not that expensive, and quite configurable.
Firmware such as Klipper / Marlin is free.
The slicing software is free.
So it seems it's just the price of the hardware/parts that is the main cost. And I know I would have a rigid and accurate build with good repeatability.
And if I can pick up an old used printer cheap I could use all the existing working parts on a quality built frame.
What's the experience of those who've built their own 3D printers. When it comes to a larger machine, say 450 cubic and up, do you find substantial cost savings or was it other reasons you went the DIY route.
  • oneKone
  • oneKone
27 Jul 2025 07:06
Ethercat CATIO-A setup was created by oneKone
Category: EtherCAT
Hi;
I've tried to setup an ethercat catio-a for pwm to control a vfd. Initially i followed this post: forum.linuxcnc.org/ethercat/52997-etherc...module-help?start=10 to get me started. In the cia402.hal i've added "net spindle-pwm => lcec.0.0.PWM-OUT-0" and "net spindle-duty =>  lcec.0.0.DUTY-OUT-0"
within linuxcnc/ halshow/ watch pins i can set the spindle duty and spindle frequency. The biggest problem is i'm not sure where to go from here for configuration to have a set frequency and pwm tied to spindle rpm. To me, is seems all of the spindle documents don't apply to (CIA402) ethercat io modules.
I should note that i'm a complete lcnc noob so there's more than likely something i've missed along the way. I'm hoping to get some help from someone that's successfully setup something like this in the past.
cheers
  • Aciera
  • Aciera's Avatar
27 Jul 2025 06:19
Replied by Aciera on topic problem with num_extrajoint
There is a folder with sim configs for extrajoints:
'configs/sim/axis/extrajoints/'
  • alexandrap
  • alexandrap
27 Jul 2025 05:26 - 27 Jul 2025 05:31
Replied by alexandrap on topic Mesa 7i96 mixed voltage field input wiring
1.)Hello,Is this connection of the 7i96 inputs identical / similar for the 7i95T?
2.)What is the connection diagram for MPG ENCODER INPUTS (7i95T)?
I have a problem - in the manual for the 7i95T (page 17) it says:
" MPG ENCODER INPUTS
Standard 7I95 firmware provides 4 quadrature MPG encoder inputs on isolated
inputs 0 through 7. Since the input threshold on isolated inputs is about 3V, its best to use
sinking inputs (with the input common terminal tied to +5V) with TTL output level MPGs."
Isn't that sourcing input?
Thanx
  • Willie
  • Willie
27 Jul 2025 04:23
Setting up a machine without a Z Axis
Category: Plasmac
I'm converting over an old Koike Oxy Fuel table that has a Burny controller on it to run on Qtplasmac. Swapped out all the electronics. Can move the axes around how I want and it'll run whatever shape I program. However a few issues in running into, probably just me overlooking ini file settings.
1. The torch won't activate at all when the program is running. The torch only works when I manually hit the "Torch Pulse" button.
2. I have a manually controlled Z Axis, no need for that auto height stuff on Oxy Fuel cause the height not being right is more forgiving. But the problem I run into is when I go to run a program without homing, it follows the path it should, but when I do home it goes to cut the shape and then the Z Axis starts moving on the screen and it throws the error "bottom limit reached while probing down". I feel like there's some simple solution that might fix both of these problems that I'm just not seeing.
3. Also a third random question while I'm here, I know I can set various pierce times for different materials but it's there a way to force the machine into always manually piercing, like a M1. But in the parameters/in, I that itll pause and make me hit like cycle start or something to do the pierce. Cause while I can let it run auto, pierce times are more finicky with oxy fuel and it can vary day to day and plate to plate.
Displaying 11716 - 11730 out of 17289 results.
Time to create page: 0.356 seconds
