  • rocket6delta
  • rocket6delta
20 Jul 2025 20:27
Replied by rocket6delta on topic 7i76EU Hal and Ini File
Category: HAL
A better question I should ask is what kind of response or voltage should I see on the ENA pin when the jog is made? It's looks to be 24V and not changing.
  • rocket6delta
  • rocket6delta
20 Jul 2025 20:18
Category: HAL
i successfully updated to 2.9.4.  My pins are labeled as 7i76e now but i believe that is due to me picking 7i76 instead of 7i76e in pncconf.
However, I'm still not getting the motors to move.  It's changing the DRO and display in Axis.  I see voltage changes in Dir and Step pins but nothing changes.
Any ideas?
  • ZXT
  • ZXT
20 Jul 2025 20:05
Replied by ZXT on topic Touchscreen issues with debian12
Have anyone found a solution? I have the same problem with a Dell S2240T touchscreen, no double click or any clicks in QTdragonHD
  • ZXT
  • ZXT
20 Jul 2025 19:50
Replied by ZXT on topic Mesa Configuration Tool
Category: Configuration Tools
Managed to get info by making a test config in MesaCT and then look in I/O.hal
Input 16, TB5
hm2_7i95.0.inmux.00.input-16
  • dunnitagain
  • dunnitagain
20 Jul 2025 19:32 - 20 Jul 2025 21:53
Linuxcnc 2.4.5 with Ubuntu 10.04, Correct file path or structure ?
Can anyone direct me to the correct file path , or file structure within the system ? Machine will not move after a restart after , an .INI modification.Machine will run with another machines control. I have found a backup usb stick . But it has several files on it , Not sure what to delete and what to keep? I would like to reload the complete backup into the computer and try it. The hard drive is a cluttered mess , and I would like to clean it out. I will down load the files from the USB , if anyone can help! I will post some pictures also.
File Name: jetmill1.zip
File Size:18 KB
File Size:18 KB
File Size:18 KB
20 Jul 2025 19:17
Replied by tommylight on topic How to install kernel patch? (Moschip 9900)
Category: Installing LinuxCNC
Try this
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
You can boot from USB, and make a quick simple config and test with, all without installing it, then if it works better, install.
  • jor
  • jor's Avatar
20 Jul 2025 19:03
I just disabled a bunch of stuff in BIOS (another thread recommended) and latency is down to 15k, but all the same errors persist
  • Millimetergott
  • Millimetergott
20 Jul 2025 19:03
Ethercat Servo+Glas scale = clods loop was created by Millimetergott
Category: EtherCAT
Hello, I'm currently facing a small problem. I want to monitor my servos (Stepperonline A6 750w), which are operated via EtherCAT, using a closed loop. Currently, I only get feedback from the motor encoders, but I already have glass scales installed. Now I'm trying to link them so that the glass scales work together with the servos via PID (the scales are triggered by the Beckhoff EL5101).
Regards, Tom
  • jor
  • jor's Avatar
20 Jul 2025 18:05
OK I just looked into the latency test. It's almost 70k which i assume is bad... I tried changing to isolcpus=3 with no change.
I saw in another post someone said to use RTAI kernel but I cannot figure out how to install it. Computer is Dell Optiplex 9020 which people have recommended in several other forum posts.
Do you think RTAI is the right route? do i need to reinstall linuxcnc with a different image and then install the .deb file for rtai?
  • tcbmetalworks
  • tcbmetalworks
20 Jul 2025 17:58
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
Do you have any photos of your project or a build thread?
  • tcbmetalworks
  • tcbmetalworks
20 Jul 2025 17:35
This will be the second machine in the shop powered by linux. I'm getting close to having the 10x15 plasma table I've been building completed. Got all the motors/mechanical finished. The way the bar feeder works is it has 2 hydraulic clamps and one clamp is connected to a ball screw. Threw cycles of clamping unclamping and movement of the screw it carts the material forward.
Still unsure if I'm going to move forward with this saw project or not the saw is in pretty rough shape I'm bringing it home today or tommorow but I most likely will. I also bought a cnc lathe the same day a hyundai hit 20m for $1000 it's in nice shape but haven't been under power for 4 years and had some connection issues when we put it under power. So I definitely have my hands full here with projects. What do you guys think about gui how should I go about making one?
20 Jul 2025 17:34
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
I do not think any of mine are 44mm in height, should be more, but i will have to check that to be sure.
I will also check the exact model, if possible.
20 Jul 2025 17:32
Replied by tommylight on topic Mesa Auswahl für größeres Projekt
Category: Deutsch
www.welectron.com/
Ja, es gibt kein 7i95T zur zeit, aber in Portugal:
eusurplus.com/index.php?route=product/product&product_id=64
machts nich, deine liste ist OK.
die firmware fuhr 7i85 ist 7i92t_7i76_7i85d.bin
fuhr die 7i85S sollte 7i92t_7i76_7i85sd.bin sein.
Und denke ich sie brauchen kein remote hilfe, nur ein paar fragen und antworten, ein bissen lessen und das wars.
20 Jul 2025 17:19
Replied by tommylight on topic Automatic band saw marvel v10a
Seems pretty simple compared to what i had to deal with, namely a fully automated one with drilling on 3 sides included.
I would definitely use LinuxCNC, but i might be biased having done over 20 or 30 conversions! :)
  • PCW
  • PCW's Avatar
20 Jul 2025 17:02
PC latency is likely the cause of the issue , I doubt that it's driver related.
(especially it it ever worked)
Did you run a latency test?
Displaying 11986 - 12000 out of 17317 results.
Time to create page: 0.458 seconds
