  • djdelorie
  • djdelorie
04 Jul 2025 22:13
Replied by djdelorie on topic poor surface quality
I had similar problems with my servo system, and solved most of it by tuning the servos better. A loose servo control loop will look precise and accurate, until you put it under load. Can you rotate the servos by hand, at all, when they should be "holding"? If so, retune them.
  • scsmith1451
  • scsmith1451's Avatar
04 Jul 2025 22:09
MESA 7i76U inputs changing state without changes to config
Category: Basic Configuration
Yes, I now have the estop working as you specified and have verified that it stops the machine when the button is mashed (OPEN).
I'm on to getting my HY_VFD spindle hooked up.
Thanks to all who have helped on this issues.
  • Happppppppy
  • Happppppppy
04 Jul 2025 21:50
Argh, @meister thankyou, it works now. Took a bit of googling to figure out how to do that.
For other beginners, what I did in the terminal:
sudo ip addr add 192.168.10.1/24 dev eno1
sudo ip link set eno1 up
I also added the following to the "interfaces" file in /etc/network/
iface eno1 inet static
address 192.168.10.1
netmask 255.255.255.0
Change eno1 to your adaptor name
  • PCW
  • PCW's Avatar
04 Jul 2025 21:42
looking for advice on retrofitting hydrolic mill
Category: Driver Boards
If you are retaining the hydraulics, the question would be how are the hydraulic valves
that control position controlled and what is the position feedback method.
  • PCW
  • PCW's Avatar
04 Jul 2025 21:12
Troubles to get started with SD240 Retrofit
Category: Turning
Sounds like the jogging setup in the hal file is not quite right
can you post your hal file?
  • PCW
  • PCW's Avatar
04 Jul 2025 21:09
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
Honestly, I would just add a  leaded 620 Ohm pulldown
resistor on the back of the breakout card and not make
any further modifications.
  • PCW
  • PCW's Avatar
04 Jul 2025 20:57
Replied by PCW on topic Lo ejes dejaron de moverse
My guess is that there siginificant coupling of the plasma start transient into the step/dir wires
or perhaps a grounding issue.
If you use single ended connections, the step/dir wiring will be less susceptible to
damage from external RFI/EMI. Another option is to use shielded wiring for step/dir
(with the shield connected to GND only at the 7I96S end)
  • besriworld
  • besriworld
04 Jul 2025 20:57
Replied by besriworld on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
Control panel connections :
net matrix_r2c2 matrix_kb.0.key.r2c2 => halui.spindle.0.stop
net matrix_r2c1 matrix_kb.0.key.r2c1 => halui.spindle.0.forward
net matrix_r2c3 matrix_kb.0.key.r2c3 => halui.spindle.0.reverse
  • laurentl38
  • laurentl38
04 Jul 2025 20:25 - 04 Jul 2025 20:25
IO Questions around mixing IO between Ethercat and Pi 5?
Category: EtherCAT
Hello zmrdko,
I just found your great work with the easycat card.
I'm starting to play with it, and it works great for digital input and output. With 1 encoder, no problem.
However, with 2 or more encoders, it doesn't work... As soon as I change the "QUADENCS" value to greater than 1, I can no longer connect to the easycat card. I get an error with the "easynavigator" software.
Have you ever had this problem?
Do you have any leads?
Laurent
  • ALS
  • ALS
04 Jul 2025 20:02
Tool Change was created by ALS
Tool Change
Category: Configuration Tools
Hey guys...
I'm using Linux for the first time for a lathe with a turret with eight tools, each in its respective position, sending an individual signal for each position and a turret locked signal.
Working cycle:
"Control system sends signal of tool change -->Motor running with positive rotating -->Toothed disks is disengaged -->tool holder disk rotating-->tool holder disk locating-->Control system receives the signal of tool holder disk locating and sends the signal of delay time of motor reversal rotating Motor running with reversal rotating -->Toothed disks is locked-->Delay time of"
I need to know if there is any component in Linux that supports this cycle, or if someone has already done something similar so that I can use it as a basis to create the tool change cycle.
  • dubstar_04
  • dubstar_04's Avatar
04 Jul 2025 19:51
Replied by dubstar_04 on topic [Solved] Mesa 7i96 Spindle PWM
Amazing! Thank you!
I don't know the history of the board. Bought it cheap on eBay many years ago. It would be great if I can manage to use it, if not a 7I96S would probably suit my needs better.
Thanks again,
Dan
  • meister
  • meister
04 Jul 2025 19:47
  • PCW
  • PCW's Avatar
04 Jul 2025 19:44
Replied by PCW on topic [Solved] Mesa 7i96 Spindle PWM
File Name: 7i96s_2pwm...7-04.zip
File Size:248 KB
7I96 bitfile with 2 PWMGens
Looks like the 74ACT04 (U17) was damaged
  • Aciera
  • Aciera's Avatar
04 Jul 2025 19:20
Replied by Aciera on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
Probably. At least I could reproduce it this way.
The issue here is that using 'halui' in parallel to a gui is not really a very good idea at all. Many do it, myself included, to connect panel buttons. Gmoccapy is designed to use button rows aligned with the gui buttons but that is not always practical.
I wonder if it would make sense to have gmoccapy create its own dedicated pins like 'halui' so we would have more control over them.
  • whyme
  • whyme
04 Jul 2025 18:59 - 04 Jul 2025 20:19
Replied by whyme on topic Raspberry Pi 4 with Mesa 7c81
so a stiff pulldown to fight the pullup of the mesa card for the inputs?
I am using 7c81_5abobx2d firmware with BOB boards on P1 and P2.
Edit:
I did a little bit of digging.
- The relay pin P17 is IO7 of the Mesa ports, which is on the edge of the pull resistor array. I could desolder the array and put it back on shifted by one to remove the resistor of the pin.
- On the BOB there is a 10k pullup array on the relay pin. but the signal comes through a via in the middle of the pullup resistor and the 74HC... I could cut the trace between the via and the resistor to remove the pull up on the BOB
- solder in a pulldown resistor on the BOB (if for whatever reason the flat cable between the Mesa and BOB gets bad).
Displaying 12616 - 12630 out of 17374 results.
Time to create page: 0.396 seconds
