  • ziggi
  • ziggi's Avatar
04 Jul 2025 18:46 - 04 Jul 2025 20:42
Troubles to get started with SD240 Retrofit
Category: Turning
Great, now the error is gone and LinuxCNC starts normally.
Unfortunately the Encoder handwheel does not move the selected axes. I can see it counting in Halshow, but the axis selected stays where it is.
I read in the documentation that the use of a MPG would reqire homing of the axis- my machine is not homed at the moment- but I thought the line
NO_FORCE_HOMING = 1
would let me use the MPG without homing- probably not, or is there any simple possibility to move the axes via MPG without homing them first?
The other thing I would like to get running is the spindle. I seached quite a bit, but did not really find out how to use the parameters. In diffeerent threads these are described differently.
The spindle is a Fanuc Servo which is capable to make 8000 rpm. Its connected to the correct Fanuc servo drive. The spindle itself only is allowed for 5000rpm. With the old control connected, I found that the max voltage the servo drive gets from the control is 7,6V+ at 5000rpm. So if I scale this to 10V it would give me 6570rpm.
As far as I know only pos voltage is used in the analog signal (0 to 7,6V) and the spindle is reversed by an additional signal to the drive unit. The 2500incr. encoder that I want to connect to the 7I33 is an additional encoder (TTL) driven by the spindle via toothed belt and is originally used with the old control for threadcutting (synch) only- the servo drive gets its info from an encoder inside the motor which I can not access.
So thats what I think currently the spindle params should be I wrote below. Is it correct- I guess not,but how is the calculation in this case done?
And how can I determine the output of min 0V to max 7V and no neg. voltage is used, if not this way.
MAX_OUTPUT = 5000
ENCODER_SCALE = 2500
OUTPUT_SCALE = 6570
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 7
Sigi
  • dubstar_04
  • dubstar_04's Avatar
04 Jul 2025 18:23
Replied by dubstar_04 on topic [Solved] Mesa 7i96 Spindle PWM
Category: Driver Boards
There is no output at all on TB2-2.
Is it possible to move the PWM to one of the other stepgens? eg. TB1-20/21?
Thanks,
Dan
  • Johnnysacalu
  • Johnnysacalu
04 Jul 2025 18:23
Replied by Johnnysacalu on topic Lo ejes dejaron de moverse
Los drivers están a unos 25/30cm de la placa
Creo que esta en modo diferencial pull+/pull- dir+/dir- si esto es a lo que te refieres
lo tengo todo conectado egual que esto solo tengo diferente un rele de estado solido para arc start y la maquina de plasma
  • steers
  • steers
04 Jul 2025 18:16
looking for advice on retrofitting hydrolic mill
hey all!im in the market for a decent mill that i want to retrofit with Mesa/linuxCnC. its a Knüth WF 5 NC, a hydrolic controlled mill with currently a Ljumo-PNC 63 controller. currently the mill isnt operational, but even with the full schematics we cant seem to figure out the current issue.i have done a retrofit before using mesa on a Vermano r170 which used some big servos, but i cant seem to find much info regarding retrofitting mesa hardware on a hydrolic controlled mill.is this even possible, and where can i find some more info on how to tackle this?best regards,steers
  • HansU
  • HansU's Avatar
04 Jul 2025 18:12
Replied by HansU on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
I start the program with an external button.
Well, yes but what hal pin do you use to start the program?
I presume 'halui.program.run'
Probably. At least I could reproduce it this way.
  • PCW
  • PCW's Avatar
04 Jul 2025 18:07 - 04 Jul 2025 18:14
Replied by PCW on topic [Solved] Mesa 7i96 Spindle PWM
Sounds like the output has been damaged...
You might check the step- output (TB2 pin 2)
(as a sanity check, STEP- should be at ~5V when STEP+ is 0)
  • dubstar_04
04 Jul 2025 17:15
With the output inverted the pwm output is 2.2v without the spindle running.
  • PCW
  • PCW's Avatar
04 Jul 2025 17:06
If you set the PWM to 0 and invert the PWM output
do you get ~5V?
to invert:
halcmd setp hm2_7i96.0.pwmgen.00.out0.invert_output true
  • dubstar_04
04 Jul 2025 16:53
Hi PCW,
Thank you for the quick response.
halcmd show all spin*
Loaded HAL Components:
ID      Type  Name                                            PID   State
Component Pins:
Owner   Type  Dir         Value  Name
    29  bit   IN          FALSE  spindle.0.amp-fault-in
    29  bit   IN           TRUE  spindle.0.at-speed <== spindle-at-speed
    29  bit   OUT         FALSE  spindle.0.brake ==> spindle-brake
    29  bit   OUT          TRUE  spindle.0.forward ==> spindle-cw
    29  bit   I/O         FALSE  spindle.0.index-enable <=> spindle-index-enable
    29  bit   IN          FALSE  spindle.0.inhibit
    29  bit   IN          FALSE  spindle.0.is-oriented
    29  bit   OUT         FALSE  spindle.0.locked
    29  bit   OUT          TRUE  spindle.0.on ==> spindle-enable
    29  bit   OUT         FALSE  spindle.0.orient
    29  float OUT             0  spindle.0.orient-angle
    29  s32   IN              0  spindle.0.orient-fault
    29  s32   OUT             0  spindle.0.orient-mode
    29  bit   OUT         FALSE  spindle.0.reverse ==> spindle-ccw
    29  float IN             -0  spindle.0.revs <== spindle-revs
    29  float OUT      29.16667  spindle.0.speed-cmd-rps
    29  float IN              0  spindle.0.speed-in <== spindle-vel-fb-rps
    29  float OUT          1750  spindle.0.speed-out ==> spindle-vel-cmd-rpm
    29  float OUT          1750  spindle.0.speed-out-abs ==> spindle-vel-cmd-rpm-abs
    29  float OUT      29.16667  spindle.0.speed-out-rps ==> spindle-vel-cmd-rps
    29  float OUT      29.16667  spindle.0.speed-out-rps-abs ==> spindle-vel-cmd-rps-abs
Pin Aliases:
 Alias                                            Original Name
Signals:
Type          Value  Name     (linked to)
bit            TRUE  spindle-at-speed
                         ==> gmoccapy.spindle_at_speed_led
                         ==> spindle.0.at-speed
bit           FALSE  spindle-brake
                         <== spindle.0.brake
bit           FALSE  spindle-ccw
                         <== spindle.0.reverse
bit            TRUE  spindle-cw
                         <== spindle.0.forward
bit            TRUE  spindle-enable
                         ==> hm2_7i96.0.pwmgen.00.enable
                         ==> hm2_7i96.0.ssr.00.out-05
                         ==> pid.s.enable
                         <== spindle.0.on
bit           FALSE  spindle-index-enable
                         <=> hm2_7i96.0.encoder.00.index-enable
                         ==> pid.s.index-enable
                         <=> spindle.0.index-enable
bit           FALSE  spindle-manual-ccw
                         ==> halui.spindle.0.reverse
bit           FALSE  spindle-manual-cw
                         ==> halui.spindle.0.forward
bit           FALSE  spindle-manual-stop
                         ==> halui.spindle.0.stop
float          1750  spindle-output
                         ==> hm2_7i96.0.pwmgen.00.value
                         <== pid.s.output
float            -0  spindle-revs
                         <== hm2_7i96.0.encoder.00.position
                         ==> spindle.0.revs
float          1750  spindle-vel-cmd-rpm
                         <== spindle.0.speed-out
float          1750  spindle-vel-cmd-rpm-abs
                         ==> pid.s.command
                         <== spindle.0.speed-out-abs
float      29.16667  spindle-vel-cmd-rps
                         <== spindle.0.speed-out-rps
float      29.16667  spindle-vel-cmd-rps-abs
                         <== spindle.0.speed-out-rps-abs
float             0  spindle-vel-fb-rpm
                         <== hm2_7i96.0.encoder.00.velocity-rpm
float             0  spindle-vel-fb-rpm-abs
                         ==> pid.s.feedback
float             0  spindle-vel-fb-rps
                         ==> spindle.0.speed-in
Parameters:
Parameter Aliases:
 Alias                                            Original Name
Exported Functions:
Owner   CodeAddr  Arg       FP   Users  Name
Realtime Threads:
     Period  FP     Name               (     Time, Max-Time )
Measuring the pwm pin output shows 1.1v at 50% speed and 2.2v at 100%, 0 volt when the spindle is off.
Thank you,
Dan
  • Sternfox
  • Sternfox
04 Jul 2025 16:38
poor surface quality was created by Sternfox
Hi Peeps,
Im pulling my hair out trying to debug a poor surface problem. I have a LinuxCNC retrofit Haas mini mill. Dimensional accuracy is within 5 microns, perfect. Backlash is around 3 microns.
The problem is the even faceting im getting, this is only on round or any move that needs the x and y axis working together. Straight lines in x and y are a nice and smooth surface finish. I have attached a few pics for reference.
the cutting strategy was adapive clearing with 0.5mm stock to leave cleaned up with a profile toolpath
The square was oriented with the points facing north, south, east and west, forcing them to be cut using both servo motors.
I'm using AC servo motors with 10.000 steps per rev. So 1 micron per pulse.
I'm running a 2 ms servo thread, probe basic on linuxcnc 2.9
for this cut I used 0.001 tolerance and tried smoothing on and off with no difference. I also used G64 p0.01 makes no difference
if you look at the images you can see the faceting lines, they all measure around 1.5mm between each line.
any thoughts?
  • PCW
  • PCW's Avatar
04 Jul 2025 16:16
When LinuxCNC is running and you have the spindle on and set to say 1/2 speed.
what does:
report?
Also, you can get an idea of PWM operation independent of any add-on cards
with just a voltmeter, as the voltmeter will read the average voltage which will
be proportional to the PWM duty cycle.
  • kworm
  • kworm
04 Jul 2025 16:09
Replied by kworm on topic Servo Driver Plasma Retrofit
Category: Plasmac
I contributed the support for the 7i95t in pncconf. I don't have any 7i97s to try but if there is a similar card already supported in pncconf I could add support for it...I'm just not sure if it supports analog servos though.
I also did some initial work to add qtplasmac support to mesact but there are some fairly major internal assumptions about encoder 0 going to drive 0, etc. and I didn't want to make backwards compatible breaking changes without hearing from JT.
  • SebastianM
  • SebastianM
04 Jul 2025 16:05
  • PCW
  • PCW's Avatar
04 Jul 2025 15:59
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
The 7C81 only has the option of all pullups and all pulldowns
on its I/O ports.
Simplest solution would probably be to add a stiff pulldown (say 620 ohms)
on the relay I/O pin. There is a firmware option for fixed parallel port type I/O
but currently its global (not per port), This firmware makes the parallel port
output pins default to outputs instead of inputs at startup or watchdog bite
What firmware are you using?
  • PCW
  • PCW's Avatar
04 Jul 2025 15:22
Replied by PCW on topic Servo Driver Plasma Retrofit
Category: Plasmac
I'm afraid ChatGPT will just be a time-sink here.
I suspect the easiest current path would be to make a pncconf  QTPlasmac/THCAD configuration
for a 7I95T (This requires updating to the very latest LinuxCNC master as 7I95T support was just added
about 1 week ago) This configuration will match as far as encoders, inputs, and outputs go (though will show
more inputs than the 7I97T has, so just don't use any inputs beyond input 15)
When creating the 7I95T configuration, setup step/dir axis.  and encoder feedback. This will create the
basic PID loop structure  required for changing over to the 7I97T PWM/analog axis configuration.
When this is done, you will have a step/dir configuration for a 7I95T and QTPlasmac/THCAD.
Next you will need to change the card name in the ini file to "7i97".
then the created hal file will need to be edited to change the PID feedback input from stepgen
position to encoder position and the PID output from stepgen velocity to PWM value.
There are also enables and some PWM setup needed. I can help with these when you get a basic
hal file setup.
You can use this example of basic 7I97/7I97T PWM hal file setup:
File Name: basic7i97_...7-04.zip
File Size:4 KB
Displaying 12631 - 12645 out of 17374 results.
Time to create page: 0.545 seconds
