  • andypugh
  • andypugh's Avatar
25 May 2025 16:07
Replied by andypugh on topic problems with Verser Probe Screen 2.9
Category: Basic Configuration
Which version of Linux, LinuxCNC and psng are you using?
I have done some work on psng to adapt it for Gtk3 / Python3 on Debian 12+
However, on my test machines, whilst it loads without errors, there are no graphics visible in the embedded tabs.
  • andypugh
  • andypugh's Avatar
25 May 2025 15:54
Replied by andypugh on topic Not able to get outputs on GPIO of Raspberry5
Category: Installing LinuxCNC
Have you run the "gpioinfo" command? That will list the available pins. If it doesn't work that may mean that you don't have gpiod installed.
Is your user account a member of the "dialout" group?
forums.raspberrypi.com/viewtopic.php?t=225274
  • AndyCNC
  • AndyCNC
25 May 2025 15:49
I'm a bit desperate. I want to replace my very old pc based linuxcnc with the actual version running on a raspberry pi 5.
I've been trying to get signals to the pin header for a day now.
First of all: Is there a tutorial for raspberry configuration? I found nothing except the general docu and then went from one error message to another.
What I did is:
1. Started Stepconf wizard
2. Replaced parallel port Pins with hal_gpioxxx, see attached hal file
File Name: AndyCNC.hal
File Size:3 KB
When I start this Setup following error occurs:
File Name: linuxcnc_report.txt
File Size:6 KB
This was my try to set the PINs:
halcmd: loadrt hal_gpio inputs=PIN3,PIN5,PIN7 outputs=PIN5,PIN6,PIN9,PIN10,PIN11,PIN17,PIN22,PIN27
Note: Using POSIX realtime
The GPIO line PIN3 can not be found
hal_gpio: rtapi_app_main: Operation not permitted (-1)
<stdin>:12: waitpid failed /usr/bin/rtapi_app hal_gpio
<stdin>:12: /usr/bin/rtapi_app exited without becoming ready
<stdin>:12: insmod for hal_gpio failed, returned -1
halcmd: Note: Using POSIX realtime
Would be nice if onyone could show my where I'm wrong.
Andy
  • andypugh
  • andypugh's Avatar
25 May 2025 15:48
Replied by andypugh on topic Threading Index Varies With Speed
It also causes errors even
at a constant spindle speed, as the offset changes with thread
depth over the multiple threading passes
Which LinuxCNC version? Not being able to cut threads would be a huge problem.
In your constant speed example, is there any possibility that what you are seeing is the "virtual compound angle" Q ?
  • andypugh
  • andypugh's Avatar
25 May 2025 15:35
Replied by andypugh on topic Retrofit SODICK A320D
Can _what_ be run on Linux?
Can you explain what you want to do?
25 May 2025 15:09
Replied by tommylight on topic help with ethercat and omron drives
Category: EtherCAT
Check and lower the P value in the ini.
  • ihavenofish
  • ihavenofish
25 May 2025 14:52
Replied by ihavenofish on topic help with ethercat and omron drives
Category: EtherCAT
Estop fixed, my mistake.
But as soon as i enable, the servos howl like mad, even though i had just tuned them perfectly. Hmmmmmm.
  • spumco
  • spumco
25 May 2025 14:30 - 25 May 2025 14:45
Replied by spumco on topic Threading Index Varies With Speed
Have you raised an issue on the LinuxCNC github page?
While I've raised a couple issues in the past, I am reluctant to directly engage on GH because I don't speak 'computer' fluently.  I can describe an issue in laymans terms, but as soon as any discussion moves towards code-type testing & solutions I'm lost.  My typical modus operandi is to prompt enough discussion on this forum that somone clever takes up the torch over on GH.
I'll raise one now, thanks for the reminder about it.
EDIT: github.com/LinuxCNC/linuxcnc/issues/3455
  • ihavenofish
  • ihavenofish
25 May 2025 13:07
Category: EtherCAT
I have no working config.
ill figure it out after lunch. :)
  • Hakan
  • Hakan
25 May 2025 12:40
Replied by Hakan on topic help with ethercat and omron drives
Category: EtherCAT
I just came from a fight with e-stop in a new config with qtdragon, and I didn't win. I'm quite sure I don't have the answers.
If you have a working config, one option is to replace the hal file in that one. Idea is that it overall worked before so it should overall work now.
Another way is to start with the simplest axis interface config from linuxcnc examples, replace the sim* hal files with the cia402.hal file.
  • Grotius
  • Grotius's Avatar
25 May 2025 11:57
Replied by Grotius on topic scurve trajectory planner
Hi Halas,
There is added a hal param for inertia wich can be set to from 0 up to 1 to run at programmed feed.
This results in less feed fluctiations at corners.
See the param section :  readme.
Also program execution time should be faster. As i reverted the acc max change.
  • ihavenofish
  • ihavenofish
25 May 2025 11:47
Category: EtherCAT
Hehe that was a joke. Although right now the machine is stuck on estop and I'm not sure why. I'm sure it will be something dumb. :)
  • JohnW
  • JohnW
25 May 2025 11:37
Replied by JohnW on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I'm new to this and was asking Chat GPT what the problems were with Lichuan drives. It says EtherCat Master stacks on Linux CNC expect drives to follow CiQ 402 correctly, but Lichuan drives lack full state machine compliance, and incorrectly transition from Ready to Switch ON to Operation Enabled, etc. Windows stacks are more tolerant of violations. So by plugging the drive in after they have done an illegal transition, Linux CNC stacks remain happy.
  • Miller Turner
  • Miller Turner
25 May 2025 10:41
Replied by Miller Turner on topic Duplomatic BSV N 160 Werkzeugwechsler / Turret
Category: Turning
Thanks for waking me up :)
It's even worse, not only - and _ got mixed up, it should have been:
net tool-change iocontrol.0.tool-change => sauter.0.toolchange
net tool-changed iocontrol.0.tool-changed => sauter.0.toolchanged
net tool-number iocontrol.0.tool-prep-number => sauter.0.newtoolnumber
Now Linuxcnc at least starts ok again. Let's see if I can get the turret move...
  • Beovoxo
  • Beovoxo
25 May 2025 09:47 - 25 May 2025 09:48
Replied by Beovoxo on topic Deckel FP4A Retrofit
Category: Milling Machines
Cabinet almost ready for sand blasting and paint.
Displaying 14356 - 14370 out of 17460 results.
Time to create page: 0.355 seconds
