  • Hakan
  • Hakan
25 May 2025 09:14
Replied by Hakan on topic help with ethercat and omron drives
Category: EtherCAT
Use it?
Use the hal file from here as starting point to get the servos going.
github.com/dbraun1981/hal-cia402/tree/main/example
  • rodw
  • rodw's Avatar
25 May 2025 08:56
Replied by rodw on topic LinuxCNC S-Curve Accelerations
You have not solved anything. If you want to use cia402 devices and the component, you need to read all at the beginning of the servo thread and write all at the end of it.
My thought is you have blindly copied a config. This is not plug and play, you need to build a config to suite your devices.
  • rodw
  • rodw's Avatar
25 May 2025 08:47
Replied by rodw on topic Linuxcnc wood lathe insufficient torque
Thanks rodw, I had ordered a DM542 from Steppersonline and it arrived today. Even with the 24v and 270OZ stepper and DM542 set at 3A I now have plenty of torque. Problem solved. I guess the TB6600s weren't up to the task.
Great to hear. I really don't know why people ever recommend TB6600's. They have been known to be cr@p for years.
There is more on the table yet! Have a look at the green and red lines here showing the torque difference between 24v and 48v for a 3.2 amp nema 23 stepper
www.moonsindustries.com/p/nema-23-standa...0-000004611110011244
The temperature rise was a max of 60 deg C (40 deg in the graph) so still at a very safe level.
  • Aciera
  • Aciera's Avatar
25 May 2025 07:53
Replied by Aciera on topic versa-probe vs probe_screen_v2.9
Category: Gmoccapy
They are from the same author but 'versa-probe' has not seen any updates for a number of years.
If you are using 2.9 then you should probably use 'probe_screen_v2.9'
  • Aciera
  • Aciera's Avatar
25 May 2025 07:46
Duplomatic BSV N 160 Werkzeugwechsler / Turret
Category: Turning
seems that you are mixing underscore with hyphen in the hal
sauter_us. VS sauter-us
  • Miller Turner
  • Miller Turner
25 May 2025 07:00 - 25 May 2025 07:19
Replied by Miller Turner on topic Duplomatic BSV N 160 Werkzeugwechsler / Turret
Category: Turning
please forgive my stupidity.
after compiling I should have done the next step too I now see:
sudo halcompile --install --userspace sauter.comp
This seems to get me a bit further into debugging.
I get a Pin 'sauter_us_toolchange' does not exist error, which I don't understand yet.
as I did initiate it in the main hal file:
net tool-change iocontrol.0.tool-change => sauter_us_toolchange
Anyone has a clue of what I might be doing wrong?
  • Lcvette
  • Lcvette's Avatar
25 May 2025 06:24
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
here:
  • Lcvette
  • Lcvette's Avatar
25 May 2025 06:20
config tool setter
Category: QtPyVCP
i cannot replicate, i get the value stored in both the var and the ui even through multiple restarts it remains correct.
  • unknown
  • unknown
25 May 2025 04:53
Why does it seem like everyone here is Australian?
I blame things I can't say but also the things I can't say with their fascination with American culture.
If you can't laugh at yourself you're coward.
  • CORBETT
  • CORBETT's Avatar
25 May 2025 03:53
Replied by CORBETT on topic el5151 reseting counts
Category: EtherCAT
Okay, good deal.  Glad it's working for you.
  • CallumRD1
  • CallumRD1
25 May 2025 02:13
Replied by CallumRD1 on topic Keyboard shortcut rempaping
Category: Qtvcp
Thanks for the response. I am getting the line you asked about in the terminal. When I just tried using the space bar pause, it worked in all but one instance. I think you're right, it's a focus issue. In one instance, I had clicked the coolant button and then hit the space bar and the program failed to pause, but I was unable to replicate the behavior in the short session I had to test it this evening. I'll follow up if I'm able to reproduce the failure to pause.
But anyways, thanks for the help with this! I hadn't realized how much I use this feature until I didn't have it. When the tool is plunging rapidly, it's really nice being able to reflexively pause everything to check positions and the distance to go.
  • cmorley
  • cmorley
25 May 2025 00:44
Replied by cmorley on topic Keyboard shortcut rempaping
Category: Qtvcp
If you run linuxcnc from a terminal, do you see this text?
'Custom subclassed handler loaded for spacebar pause'
sometimes it's a focus problem, try pressing the 'G54' or 'ABS' button (after the program is started.). If that works I will look into why you need to do that.
  • PCW
  • PCW's Avatar
24 May 2025 23:36 - 24 May 2025 23:58
Replied by PCW on topic Threading Index Varies With Speed
I was able to reproduce this error with a simple test setup
with no mechanics and using g76. It also causes errors even
at a constant spindle speed, as the offset changes with thread
depth over the multiple threading passes which would cause
a  wider than expected cut.
To test this I setup a 7I96S with a stepgen spindle setup to
emulate a 8 count encoder with index (using the stepgen table mode)
I checked the offset by using the sum2 component to scale the spindle
rotations to the thread pitch and subtract the result. This offset
should be independent of spindle speed, X,Z motion constraints
and drive line distance to thread pass, but it is not.
Have you raised an issue on the LinuxCNC github page?
  • PCW
  • PCW's Avatar
24 May 2025 23:13 - 24 May 2025 23:14
AC Servo tuning - Joint 0 following error at high velocities
Category: Basic Configuration
I would check the encoder signals at the Mesa card
The way to check is disable the drives (I hope this can be done
in a way the encoders still work) and then measure the differential voltage
(from A to /A and B to /B ) with a voltmeter in all quadrature states.
(you can usually to this by wiggling the motor shaft a bit to get all 4 states)
The absolute value of the differential voltage should always be greater than 2V
(you should get a positive differential voltage in one state and a negative voltage in
the other state)
Another check is to enable quadrature error checking on the encoder and seeing if
you get errors, that is set
hm2_CARD.0.encoder.NN.quad-error-enable
 true in halshow
and monitor
(CARD is the mesa card name and NN is the encoder number)
  • CallumRD1
  • CallumRD1
24 May 2025 23:12
Category: Qtvcp
It doesn't seem to be working. Do I need to call that python file somewhere?
Displaying 14371 - 14385 out of 17458 results.
Time to create page: 0.408 seconds
