  • foxlabs
  • foxlabs
23 May 2025 01:40 - 23 May 2025 01:41
GMOCCAPY 3.4.9 LCD7" can not display the whole GUI
Category: Gmoccapy
Hello Aciera, Thank you for your replay , The orignal GMOCCAPY  I used on RPI4 is OK, but on RPI5 is not OK
  • kubes
  • kubes
23 May 2025 01:35
Setting started modification Probe Basic
Category: QtPyVCP
I am new to LinuxCNC and  ProbeBasic, but not to Linux or Python.
I want to modify the "Status" tab to be similar to what  anfänger did in the thread forum.linuxcnc.org/qtpyvcp/39734-show-your-screens#177730 (see below).   I also want to change so the "Main" tab is the default on start-up
Is there a getting-started guide or notes?  I reviewed the ProbeBasic docs kcjengr.github.io/probe_basic.
Thanks!!!
  • mjoconr
  • mjoconr
23 May 2025 00:50
Smart Serial Comms Error - Since upgrade to 2.9.4
I upgraded via backports to 6.12.22+bpo-rt-amd64, still get a 5ms max delay.
I ran it a few times
rtt min/avg/max/mdev = 0.053/0.116/5.600/0.269 ms
rtt min/avg/max/mdev = 0.054/0.099/4.908/0.216 ms
rtt min/avg/max/mdev = 0.054/0.106/4.672/0.241 ms
I've not had a warning since I ran the IRQ script.
We will see once I start actually cutting
  • ihavenofish
  • ihavenofish
23 May 2025 00:11 - 23 May 2025 00:12
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
ooh, nice. you think you can help me config my ethercat setup. i have different drives, but im stuck at the "how do i even make ethercat work" part. :)
i looked through your files a bit, but of course they dont start cause i got no mesa card in mine.
  • PCW
  • PCW's Avatar
22 May 2025 22:46 - 22 May 2025 22:47
Replied by PCW on topic Need Help Setting Up a 2nd Spindle
# net machine-is-on => hm2_7i92.0.stepgen.07.enable
AFAICS, nothing sets hm2_7i92.0.stepgen.07.enable true so it can never run.
try removing the comment (#) :
  • richcolvin
  • richcolvin's Avatar
22 May 2025 22:41
Replied by richcolvin on topic Need Help Setting Up a 2nd Spindle
The attempts to run the spindle are by using:
M3 S10 $0 <=== that works
M3 S10 $1 <=== does not work
  • richcolvin
22 May 2025 22:39
Need Help Setting Up a 2nd Spindle was created by richcolvin
I am trying to configure LinuxCNC for use on a rose engine with 2 spindles + 6 other axes.
Everything works for Spindle0 & the other 6 axes of movement (X, Y, Z, B, U, & V), however I cannot get Spindle1 to work. Any ideas would be greatly welcomed!
I've copied the key items I believe are needed below.  The complete versions of the HAL and INI files are attached.  (The include files for the spindles had to be renamed to be .ini for attaching them, but they are actually .inc.)
hal fileloadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=0 num_pwmgens=0 num_stepgens=8"
loadrt pid names=pid.x,pid.y,pid.z,pid.b,pid.u,pid.v,pid.s0,pid.s1
(other sections are also configured for SPINDLE 1, and are setup fundamentally the same as they are for SPINDLE 0)
 ini file[TRAJ]
SPINDLES = 2
# [JOINT_7]
# SPINDLE = 0
# TYPE = ANGULAR
[SPINDLE_0]
(this works as expected, so I've not added the details here)
[JOINT_6]
SPINDLE = 1
TYPE = ANGULAR
[SPINDLE_1]
(the rest is setup just as with SPINDLE_0)
 Side Note: Please don't refer me to RoseKins.  I tried that and it will not meet our needs.
22 May 2025 22:18
Replied by tommylight on topic Smart Serial Comms Error - Since upgrade to 2.9.4
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60401ms
rtt min/avg/max/mdev = 0.056/0.084/7.709/0.139 ms
That is not good, at all.
If the PC has a RealTek network card, you will find a lot of replies here to install the DKMS drivers for it, i would skip that and try a new RT kernel, something like 6.11 or above.
  • Doc_emmet
  • Doc_emmet
22 May 2025 22:01
Replied by Doc_emmet on topic Read the S-Command in the HAL
Category: HAL
Thanks, it works
  • spumco
  • spumco
22 May 2025 21:46
Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
At a later stage, I plan to add an additional 1kW servo motor, which will operate in torque mode to act as a dynamic load on the main 7kW motor. This will increase the system's rigidity. Currently, I'm using the encoder from the main motor
That sounds interesting.  How are you planning to couple the secondary motor to the spindle?
  • PCW
  • PCW's Avatar
22 May 2025 21:39 - 22 May 2025 21:39
Issue getting XYYZ gantry to home (using 7i92t with 7i76u)
Category: Basic Configuration
Are you sure the proximity switches are deactivated (red in halshow) when not at home position?
If these were inverted, the "home" move might actually be LinuxCNC backing off what it thinks is
a closed switch.
  • mjoconr
  • mjoconr
22 May 2025 21:37
Kept looking last night and ran the IRQ script found else where on this forum.
This seemed to improve things, I left LCNC running all night with glxgears and other things running and did not get the messages again.
Ping result
cnc@minimill:~$ sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
The issue maybe be fixed I'll see how we go actually using it today.
22 May 2025 21:27
1. make sure both Y spin in the correct direction
2. what sensing distance do the proximity switches have? 1 and 2mm should be avoided. And switches are not mounted correctly, they should be sideways to prevent crashing into stuff.
For 1:
make a normal 3 axis test config, test one Y with a short jog, change drive inputs and test second Y with a short jog.
This can be done on software but more complicated to explain.
22 May 2025 21:16
  • PCW
  • PCW's Avatar
22 May 2025 21:08
Replied by PCW on topic How to Control a PWM Gripper
Category: G&M Codes
www.linuxcnc.org/docs/html/gcode/m-code.html#mcode:m68
See the note about the hal pin.
Looks like meister was using different numbers for different positions
some likely being fully open and some fully closed
Displaying 14491 - 14505 out of 17470 results.
Time to create page: 0.419 seconds
