  • Spyderbreath
  • Spyderbreath's Avatar
12 May 2025 19:05
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Actually, no. Spindle 'ON' shows 0v between COM and AI1.
  • Spyderbreath
12 May 2025 18:45
Replied by Spyderbreath on topic Moving from Axis to QtDragon?
Category: Qtvcp
Had a bit of a break and thought a minute and I think I figured this out. There is an entry [FILTER] in the .ini file and I added a line below that PROGRAM_EXTENSION = .nc,.ngc,.gcode G-Code and not only did that work, placing it first in the list makes it the default. Very nice. Thanks for that bit of info. Much appreciated.
  • jochen91
  • jochen91
12 May 2025 18:44
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
For the Z-180 after homing:
My startup procedure is: Starting the configuration and homing. After that the Z Axis is at -180. See screenshot attached.
For the different tool change position:
Toolchange from no tool to lathe tool:
X-Axis-Position: 250mm
X-Joint-Position: 623.2051mm
Toolchange No. 2 from lathe tool to endmill:
X-Axis-Position: 330mm
X-Joint-Position: 873.2051mm
The Y-Joint-Position is the same.
Spindle orient:
"Because this value changes instantly it would likely cause a following error in the b-axis drive " that was the missing bit of information.
  • PCW
  • PCW's Avatar
12 May 2025 18:28
Replied by PCW on topic hal functions
hal functions
Either pncconf or MesaCT can make working configurations for a 7I96S
(and MesaCT can make working configurations for the 7I95T AFAIK)
What actual issue do you have?
  • Murphy
  • Murphy
12 May 2025 18:17 - 12 May 2025 18:18
Measure the input voltage at the VFD it's probably at 10v constant ?
​​​​​​ Yes you can also hook up outputs for  FWD and REV.
  • Spyderbreath
12 May 2025 18:06
What does it do when you try adjust the speed? Is it a VFD you are using? What is the speed input to the vfd pwm or 0-10v analog. Have you the VFD wired correctly ?
OK, This is a Merckweir MK300 VFD that was installed from the factory. As par for the course with this machine, the unit is an old out of production version. All this that I am trying to do now is to salvage the purchase of this mill after taking a giga hose job and losing over $3k.
To answer your questions in order -
1. Nothing happens when I try to adjust the speed. Whether I issue an M3 S100 or M3 S15000, the speed is the same. VFD panel reports 3500 rpm, or at least I think it's RPM, anyway, no change.
2. Yes, VFD
3 The input is suppose to be 0-10v and if the translator on my phone is correct that is connected to the AI1 (0-10v analog signal input) on VFD
3. As far as I can tell.... There are only 3 wires, COM, AI1 for the 0-10v analog and X1 that connects to spindle out1 (spindle-cw)
  • Todd Zuercher
  • Todd Zuercher's Avatar
12 May 2025 18:05
Replied by Todd Zuercher on topic LinuxCNC Dual-Head Gantry Setup Assistance Request
I had posted some photos of the 8 spindle machine and the configuration file here, if is at all helpful. You can see there how I handled slaving the extra joints to the Z axis.
forum.linuxcnc.org/show-your-stuff/53675-8-spindle-gang-router
  • JT
  • JT's Avatar
12 May 2025 17:53
Replied by JT on topic keyboard shortcuts
keyboard shortcuts
Axis is a great GUI and very stable, the problem with Axis is it's super complicated to try and change the behaviour. Once you start to need a custom GUI this is where Flex GUI shines.
gnipsel.com/linuxcnc/flexgui/index.html
JT
  • Leuo_
  • Leuo_
12 May 2025 17:26
  • Murphy
  • Murphy
12 May 2025 17:05
  • theoneandonlyoreo
  • theoneandonlyoreo
12 May 2025 16:50
Replied by theoneandonlyoreo on topic keyboard shortcuts
keyboard shortcuts
I'm a n00b, straight from UGS, so I don't know if that will be an issue. I anticipate using the pendant during setup, so being on the "Manual Control" window might not be a problem.
What's a solution to the focus problem?
  • PCW
  • PCW's Avatar
12 May 2025 16:50
Which kernel version is best for real time?
Yes PCW, is the same Realtek with dkms driver for fix latency.
Maybe I'm asking the wrong question: is it really necessary to do the test with YouTube?
When you get an error, what does:
halcmd show param *.tmax
(typed in a terminal)
show?
  • theoneandonlyoreo
  • theoneandonlyoreo
12 May 2025 16:43
keyboard shortcuts
OK, I figured out a way to select from the GUI list of jog increments using a single keystroke.
There's more than meets the eye. You've got to pull in some GUI elements that are only apparent if you read through axis.py. It's not good enough to set the increment because the GUI will re-set it based on the dropdown.
import linuxcnc
import tkinter
import hal
def set_jog_inc_rc( event, index ):
global comp, jogincr_index_last
root_window.call( widgets.jogincr._w, "select", index )
jogincr = widgets.jogincr.get()
print( f"setting jog increment to {jogincr} inch " )
comp = float( jogincr.translate(str.maketrans("", "", string.ascii_letters)) ) # remove "in"
root_window.bind( "<e>", lambda event: set_jog_inc_rc( event, 5 ) )
root_window.bind( "<f>", lambda event: set_jog_inc_rc( event, 3 ) )
root_window.bind( "<g>", lambda event: set_jog_inc_rc( event, 1 ) )
  • Spyderbreath
12 May 2025 16:07 - 12 May 2025 16:34
Try deleting [spindle0]
setp scale-rpm.gain .02
put that in instead
At least that gets me to the next error - ./remora-ec500.hal:127: Pin 'remora.output.02' was already linked to signal 'spindle-cw'
line 127 is - net mist    remora.output.02     => iocontrol.0.coolant-mist
Edit: I figured out that the pin for the spindle was wrong, it should of been .00 not .02. Now I have the spindle turning on. First time I have seen the spindle run sense the day the machine shipped. No speed control and I am unsure how to fix that, but at least I am making progress. At this rate I might even see the mill actually working before fall.
Displaying 15046 - 15060 out of 17468 results.
Time to create page: 0.366 seconds
