  • electrosteam
  • electrosteam
11 May 2025 20:34
Replied by electrosteam on topic Gmoccapy Tool Change Dialog
Category: Gmoccapy
Thanks for that, I will review the documentation and try implementation later today.
11 May 2025 20:32
Replied by tommylight on topic New Config, issues with homing.
Category: Basic Configuration
Maybe i was not detailed enough, all configs have search and latch velocity positive for both, OR negative for both, plenty of those configs, only one has one joint where those two values are not the same direction.
To be more helpful, use Rod's advice and slow down everything to a crawl so you can actually see what is going on.
Before that, do absolutely make sure the motor direction is correct.
  • rodw
  • rodw's Avatar
11 May 2025 20:10
Replied by rodw on topic New Config, issues with homing.
Actually, the sign does matter because I have had machines where one side of the gantry does not home until the sign is flipped!
  • aeth
  • aeth
11 May 2025 20:04
Off-the-shelf CNC control box with LinuxCNC?
Category: Milling Machines
Thank you for your answer! I like to dream big sometimes :D Of course having this for sale as a bundle would be epic, but even if I just managed to make a github repo with the whole config + BOM + CAD model of the control cabinet, I think that'd still be really helpful, right? Also, is Raspberry Pi really so bad for this goal? What are the disadvantages? I thought it's a pretty nice option given that it's quite compact and rugged.
  • Murphy
  • Murphy
11 May 2025 20:02
Yes iv A and B hooked up to the PV which is working, counting fwd and back. Iv another encoder that came with the machine stock (emco encoder) that I'm using for the Z as it's 24v and hooked straight to an input pin. Yes iv the spindle speed in , in my Hal file same as yours.
  • machinedude
  • machinedude's Avatar
11 May 2025 20:00
Replied by machinedude on topic Black Friday Deal got me :)
Category: Plasma & Laser
i fixed everything so it all good information now.
  • rodw
  • rodw's Avatar
11 May 2025 19:56
Just checked some 15 of my old and new configs, luckily i found one where search is positive and latch is negative (on Z), all others are same direction.
I checked another config of mine and it was positive.
github.com/rodw-au/showstopper/blob/master/my_Plasma.ini#L260
I wonder if the sign matters? I don't have the machine anymore to check.
  • Krulli_Fräser
  • Krulli_Fräser
11 May 2025 19:55
Question on Servo analog output scaling was created by Krulli_Fräser
Hello all,
I have my milling machine running and following commands well. However, with a small endmill operating in tight quarters, I have some issues with the tool not following the toolpath exactly, I think there is some overtravel. I did the PID tuning months ago and was able to fine tune it after the machine is safely bolted down.
I rewatched some of RotarySMPs videos on the Schaublin conversion and he mentioned that the analog output voltage has to accurately reflect the speed resolution on the motor. Otherwise the initial voltage signal is not correct and the control has to compensate.
It just occured to me that I never adressed that. I have Linuxcnc configured to limit my travel speed to 5000 mm/min. However, the maximum speed the machine could run from the factory is triple that at 15000mm/min.
So this means the Servos only ever run at up to 1/3 of their full speed.
The way I understand it, when I command a rapid move, the Mesacard wants to give it the full 10V, leading to a really rapid move on the motor, way to fast for what linuxcnc anticipated, and that will cause some issues.
Can I change this in my Hal oder Ini files? I think there is a line with maximum output??
I can´t easily change the parameters in my drives, so I prefer changing this in the config.
11 May 2025 19:52
Replied by tommylight on topic Black Friday Deal got me :)
No worries at all, it has just become increasingly bad info all over the web, so at least here trying to keep info correct.
11 May 2025 19:49
  • machinedude
11 May 2025 19:48
2000N i should have just let you convert it :) sorry i was going off of memory and should have added the extra 0 thanks for the catch on that.
  • rodw
  • rodw's Avatar
11 May 2025 19:48
Replied by rodw on topic Esab Ultrarex UXD-P2000 Upgrade Project
Excellent to see stuff moving!
The torch voltage seems low but that is just a calibration issue.
Is there a reason why you are not using the qtplasmac config?
linuxcnc.org/docs/stable/html/plasma/qtplasmac.html
Or did this project start so long ago it didn't exist?
  • CallumRD1
  • CallumRD1
11 May 2025 19:38
Replied by CallumRD1 on topic G-code file loading at G53 instead of G54
Category: Qtvcp
Thank you so much! I figured it out with your comment.
It turns out that for whatever reason, when I set up my .ini file, I had commented out the .var file. I just uncommented it and now everything appears to be working normally. The offsets table is updating as I expect when changing work offset locations.
The littlest issues can be so frustrating when you don't know where to look, yet so easy to fix once you realize how the system works. Thank you again!
  • 3dtech_ks
  • 3dtech_ks
11 May 2025 19:31
Esp32 wroom + w5500 to run linuxcnc was created by 3dtech_ks
Category: Driver Boards
Hi , im new to linuxcnc i have been looking to run linuxcnc via ethernet with w5500 and esp 32 can someone please help , linuxcnc will not toggle e stop
Displaying 15106 - 15120 out of 17467 results.
Time to create page: 0.344 seconds
