  • Spyderbreath
  • Spyderbreath's Avatar
01 May 2025 16:42
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Attis92 post=327432 userid=41888Yes, correct!
But I’m still having some issues with the config upload, which I’m currently investigating on the EC500 board.
If you're unable to change the config, you may need to erase the entire chip first:
sudo pyocd erase -c --target mimxrt1050_quadspi
Then flash the firmware again and upload the new config.
[code]sudo pyocd flash remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi
This worked for me, but it's definitely not an ideal solution.
[/code]
[code]OK, now for the most current question, just how were you able to determine you had trouble, was there an error at the point of issuing the flash command or did that seem to work and then you discovered the problem some other way? When I did this, it seemed to flash without error, or at least none were reported.
I have gotten past the point of running the upload script - python3 linuxcnc/configs/remora-rt1052-basic/upload_config.py configs/remora-rt1052-basic/nvem-rt1052.txt - and that reported back ...
[/code]
Valid JSON config file, uploading to board
Config file length (words) = 1701
Config file length (bytes) = 6804
Remainder = 0
Config file length with padding (bytes) = 6804
CRC-32 = 0x9fd7ecb
[code]Now I need to get a hal config into the mix if I am not mistaken as to my next steps. I have found this on github -
[/code]github.com/scottalford75/Remora-NVEM/tree/main/LinuxCNC - and now I am going to have to try and sort all that out with no real clue or set of directions. That is provided I did everything as I was suppose to and it all actually worked. I don't know how to test it other than try to get LinuxCNC configured and run it. At this point I will be happy just to see the Estop trip when the terminals are shorted on that input.
wish me luck
  • PasstScho
  • PasstScho
01 May 2025 16:35
mesa 7i73 4x8 keypad problems on KEY8 input
Category: Driver Boards
Hello,
I'm helping some friends to use a 7i73 connected to 7i96s for a CNC.
7i73 is using Firmware 14 (read from linuxcnc) with a custom adapter board to make it easier to connect a panel with switches and mpg. 7i73 is in 4x8 mode with analog in and no lcd (jumpers set accordingly & sserial=10000...).
The adapter board doesn't do much besides adapting from IDC Connectors to screw terminals.
In general the system works fine and the keypad also works with linuxcnc - buuuut all keys connected to KEY8(in) don't work. Other keypad-switches are working fine.
Cabling was done with 0,5mm² and it is quite a mess. My first guess was the big and long cables would have too much capacitance and the 10k pullups couldn't pull the line back up in time.
Bridging with a short cable made it work, so card and general set-up seems to be ok.
Replacing the 10k pullup resistors with 1k did NOT do the trick!
After some Scope measurements it actually looks like the KEY8 inputs will be measured far to soon after enabling e.g. the KEY4 output line. The outputs will be (open drain) low for ~30µs. In the scope the difference in the signals will be very little and only in the first few µs.
So the conclusion is that the KEY8 inputs will be sampled early after setting the row outputs. With my long cables and many connections it looks like this will make it unreliable to get the right switch input.
Shorter cabling is not really an option. And in case the signals are really sampled that early I'd rather like to somehow get that fixed in the firmware.
I counter-checked with another 7i73 board from another batch and did see the same result.
Attached pictures show the testing setup. Scope screenshots are from the video:
Scope cabling is not much better than the key cabling but it should still show the most important...
Yellow is KEY4 (open drain output with added pullup to see measurement moment without button pressed).
Blue is KEY8 input with pullup (not sure if original 10k or already changed to 1k).
The video is showing the difference of:
- a bad signal, "shorted" via switch that will not be seen in linuxcnc meter
- a "good" signal seen in linuxcnc meter, done by bridged signals on adapter board (very end of video)
Can anybody confirm this?
Could it be a problem in Firmware V14 that only KEY8 is sampled early?
What would be the solution for this problem?
Thanks for your help!
Alex
  • my1987toyota
  • my1987toyota's Avatar
01 May 2025 16:27 - 01 May 2025 16:39
Replied by my1987toyota on topic fresh install issue with 2.9.4
Category: Installing LinuxCNC
found the problem
I see it is talking about missing raspi-firmware.
to remove enter the terminal
then enter
sudo dpkg -P raspi-firmware
now the error is gone.
  • PCW
  • PCW's Avatar
01 May 2025 16:25
Replied by PCW on topic 7i84
7i84
The 7I84 needs VFIELDA VFIELDB and VIN
Suggested wiring is to power VFIELDA and VFIELDB and leave W1 in the default
left hand position, so VIN get powered via VFIELDB.
  • GDTH
  • GDTH's Avatar
01 May 2025 16:18
7i84 was created by GDTH
7i84
He,
I have a 7i84 connected to a 7i77. Lcnc can see the device but the red is always on and I am not able to control the outputs. Could it because I only have 24v connected to vin. Does the field a and b niet power?
  • my1987toyota
01 May 2025 16:05 - 01 May 2025 16:24
fresh install issue with 2.9.4 was created by my1987toyota
File Name: errorreport.txt
File Size:1 KB
So I decided to do a fresh install on the computers for my Mill and Lathe. The computers areDell Optiplex 9020 micros. I am installing Linuxcnc V2.9.4 ISO. After installing and then updatingI get an error message ofE: Subprocess /usr/bin/dpkg returned an error code (1)it also says there is an issue with initramfs-tools.all that said I am attaching a pic of the error message to help. I am sure I am missing something stupidI usually do. LOL
File Size:1 KB
  • PCW
  • PCW's Avatar
01 May 2025 14:32
[SOLVED]linuxcnc Latency test ambiguous results
Did you try pinning the Ethernet IRQ to the last processor?
This usually make a large difference in Network latency
  • Attis92
  • Attis92
01 May 2025 14:24
Yes, correct!
This worked for me, but it's definitely not an ideal solution...
  • Lcvette
  • Lcvette's Avatar
01 May 2025 13:22
Porbe basic lathe: Questions about the keyboard
Category: QtPyVCP
not sure i follow about the speeds thing? maybe your configuration settings for default jog speed? not sure about the keys things, been completely covered up with work and haven't had any time to dig into probe basic recently. maybe ask the linuxcnc devs if they could add a keyboard assignment to the configuration? for lathe? if its such an issue im sure more folks would want a global resolution that translates into any gui running the lathe option in the ini.
  • acourtjester
  • acourtjester
01 May 2025 13:18
Replied by acourtjester on topic Plasma center punching operation
Happy to help, just a small payback for all the help I have received in the past from this site and members.
  • Lcvette
  • Lcvette's Avatar
01 May 2025 13:17
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
did you get this resolved?
  • PCW
  • PCW's Avatar
01 May 2025 13:08
Replied by PCW on topic LinuxCNC S-Curve Accelerations
I did set the acceleration in the TRAJ section, it does affect the acceleration
but the scaling seems not to be correct. The Acceleration/Velocity bounds are important
since they are per joint physical limitations.
(sorry if I am getting out the sandpaper when construction is at the chainsaw stage)
It is great so see  a jerk limited profile working with LinuxCNC as it fixes the inevitable
following error at the start/end of motion due to the impossibility of having instant force
application in any real drive system.
  • Lcvette
  • Lcvette's Avatar
01 May 2025 13:05
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
yeah that delay is a bugger.. the drive should be enable constantly and just be looking for a direction voltage and step pulse stream. i would have the drive enabled anytime the the machine is on and not estopped. and have it sitting idle waiting for pulse command.
  • jjdege
  • jjdege's Avatar
01 May 2025 12:57 - 01 May 2025 20:22
cakeslob post=326968 userid=25269
Are all the drivers the same, or did you do your check all axis with the same drive
 jjdege post=326970 userid=32556
hi
the same driver for all axes.
I tried to unsolder the chip, without success
the board does not respond, for now I do not think I will buy another
thanks for the support
Hi guys
I couldn't resist and bought a new board, this time I opted for a 3-axis EC500,
it has LEDs that indicate the I/O status, I think it's more complete.
I tested it with Mach3 to make sure it was working well, given the previous ones,
and it worked on all three axes.
When loading the firmware, it got to 29% and timed out and everything froze,
the DAP wasn't receiving signals.
I reread page 115 of the thread that talks about how to unlock and after having
bridged BOOT_MO and 3V3 I managed to delete and write the new firmware!!
Now all 6 axes work.
Thanks again to Scott and to whoever made all this possible.
  • Lcvette
  • Lcvette's Avatar
01 May 2025 12:56
Replied by Lcvette on topic QtPyVCP designer plugin fails
Category: QtPyVCP
great!
Displaying 15871 - 15885 out of 17465 results.
Time to create page: 0.537 seconds
