  • csurimilan
  • csurimilan
30 Apr 2025 19:59
How to change jog speed using joystick buttons (QtDragon + HAL)?
Category: HAL
im using a wireless xbox controller for PC. It is working fine
  • csurimilan
  • csurimilan
30 Apr 2025 19:57 - 30 Apr 2025 19:57
  • Jedi
  • Jedi
30 Apr 2025 19:42
Replied by Jedi on topic Losing some values after PB restart
Category: QtPyVCP
I will Check again.
and let you know. Is there a terminal command to see witch version is installed?
Best regards,
Ben
  • PCW
  • PCW's Avatar
30 Apr 2025 19:24
Replied by PCW on topic LinuxCNC S-Curve Accelerations
Indeed if you set acceleration to 200, the scurve max acceleration will be 400 at inflection point.
Exceeding your max acc off 240.
I get the same error even if all accelerations are set to 100 in the ini file
  • PabloSancez
  • PabloSancez
30 Apr 2025 19:06
Replied by PabloSancez on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Hi! This is a lathe with Lichuan Ethercat and mesa 7i96s servodrivers for controlling the spindle with a mesa digital potentiometer mesa processes three encoders, one spindle and two linear for each axis, and it seems to work fine. I was even able to thread the G76 cycle.
I use absolute encoders how do I set up the machine so that the position of the machine is automatically read from the drivers when the machine is turned on?
  • DarkPhoinix
  • DarkPhoinix
30 Apr 2025 18:52 - 30 Apr 2025 19:13
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
I don't understand if I have to add something about the hal file, I found this:
linuxcnc.org/docs/stable/html/man/man9/stepgen.9.html
stepgen.1.dirsetup
stepgen.1.dirhold
stepgen.1.steplen
stepgen.1.stepspace
I also found this but I don't know where to put the parameters, I know that this gui is only for the parallel port or am I wrong?
  • IB_CnC
  • IB_CnC
30 Apr 2025 18:19 - 30 Apr 2025 18:34
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
Found out why it delays when switching on.
The stepper driver (HBS57) is disabled by a 3.5V signal to the ENA+/- ports.
When you enable the driver by pulling the voltage signal (directly or via the pulse gen PCB), apparently it takes a bit of time for the driver to react.
This also happens when using a different 5V powersupply.
It does react instantly when you re-apply the 3.5V to the ENA+- ports, instantly stopping the motion.
If I can invert the ENA (Enabled) signal in the driver software, I can switch the opposite by relay to apply a voltage to enable the driver instead of disabling it. But I could get an issue stopping the driver in time if I do that.
I have to figure out how to connect to the driver, never done that before.
  • Muftijaja
  • Muftijaja
30 Apr 2025 17:55
motor-0-position error beim Abbremsen aus 4-7,5 m/min
Category: Deutsch
Chaka!
Today I tested the new i7 Tiny PC Lenovo m910q with previously shown pings and latency, and the machine seems to work fine. Ok, I just made an air milling over 10 minutes, but the whole code went through without motor-position errors. I tried full G0 with 7,5m/min and normal milling feeds with 3,5m/min, no errors anymore.
BTW- WLAN connection was active during the process, without activity, but former constellations had bad influence on ping and latency.
I hope, this is my final post regarding latency and pings. I learned a lot about settings.
Big Thank you to all of you for sharing your knowledge and for helpful comments!
Happy greetings, Hanno
  • COFHAL
  • COFHAL
30 Apr 2025 17:51
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
I see that I've updated the information related to the AX5800 card. Now I have some questions:
I see that I created some enable pins. I assume they are to enable the output of each of the step generators. In the XML file for LINUXCNC, these pins appear as BIT, but I don't know how to configure them correctly in the EEPROM generator file. Bit variables don't appear there. In that same file it appears
<pdoEntry idx="6001" subIdx="01" bitLen="32" halPin="Frequency" halType="float-ieee"/>
</pdo>
<pdo idx="1a01">
<pdoEntry idx="6001" subIdx="01" bitLen="8" halPin="DI1" halType="u32"/>
<pdoEntry idx="6001" subIdx="02" bitLen="8" halPin="DI2" halType="u32"/>
<pdoEntry idx="6001" subIdx="03" bitLen="8" halPin="DI3" halType="u32"/>
<pdoEntry idx="6001" subIdx="04" bitLen="8" halPin="DI4" halType="u32"/>
It's not clear to me what function those DI pins have and how they are programmed in the EEPROM generator.
  • grijalvap
  • grijalvap's Avatar
30 Apr 2025 17:50
Replied by grijalvap on topic Zero Pierce delay After pierce Only
Category: Plasmac
So basically if you select piercing only
1-Make  piercing.
2- Ask the operator to clean dross.
3 - Ask the operators to change consumables (if the case).
4 - Start cutting with 0 piercing delay.
  • Hakan
  • Hakan
30 Apr 2025 16:57 - 30 Apr 2025 16:57
Replied by Hakan on topic Zero Pierce delay After pierce Only
Category: Plasmac
I use a separate material config for piercing and switch to normal when cutting.
Going a bit further, one could have automatic shift to a piercing-only material config when doing piercing only.
And shift back afterwards.
  • Adam Maszynotwór
  • Adam Maszynotwór's Avatar
30 Apr 2025 16:42
Is there a bug in the carousel component or am I doing it wrong ATC Denford
I'm not good at typical programming languages. I'm best at G-code.
Here, G4 has to be because after reaching the pocket, the READY pin is active so the toolchange procedure runs without moving the engine
Yes, I know that ATC is not a priority, but I'm asking in advance (I'll eventually write ATC on CL .. I think that thanks to the knowledge I've gained from trying to start CAROUSEL, I'll manage, and if not, I'll treat it as an axis and use g-code)
This machine is a challenge because:
I've never used a tool magazine
I've never done anything on servos
I didn't have a Mesa card either
and here it will be all
GUI AXIS
  • DarkPhoinix
  • DarkPhoinix
30 Apr 2025 16:36 - 30 Apr 2025 16:53
STEPLEN = 150000
STEPSPACE = 150000
to
STEPLEN = 5000
STEPSPACE = 5000
or
STEPLEN = 10000
STEPSPACE = 10000
As you have it it is way to long so it limits the max velocity a lot and can cause joint errors, depending on the scale and velocity set in the ini file.
[AXIS_Y]
MAX_VELOCITY = 175
MAX_ACCELERATION = 2000.0
MIN_LIMIT = -5.0
MAX_LIMIT = 300.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -5.0
MAX_LIMIT = 300.0
#MAX_VELOCITY = 175
MAX_VELOCITY = 175
STEPGEN_MAXACCEL = 2200.0
SCALE = 160.0
FERROR = 1.0
MIN_FERROR = 0.5
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = 0
[STEPGEN]
#150000
DIRSETUP = 150000
DIRHOLD = 150000
STEPLEN = 5000
STEPSPACE = 5000
and
[AXIS_Y]
MAX_VELOCITY = 175
MIN_LIMIT = -5.0
MAX_LIMIT = 300.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -5.0
MAX_LIMIT = 300.0
#MAX_VELOCITY = 175
MAX_VELOCITY = 175
SCALE = 160.0
FERROR = 1.0
MIN_FERROR = 0.5
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = 0
#[STEPGEN] <
need this???
#150000
DIRSETUP = 150000
DIRHOLD = 150000
STEPLEN = 5000
STEPSPACE = 5000
same of the conf with:
#DIRSETUP = 150000
#DIRHOLD = 150000
#STEPLEN = 5000
#STEPSPACE = 5000
  • PCW
  • PCW's Avatar
30 Apr 2025 16:25
I will try this, note that this is a difference from LinuxCNCs standard TP where the
acceleration bound in the ini file is obeyed at all points.
(unless you have backlash compensation enabled)
30 Apr 2025 16:23
Replied by tommylight on topic [SOLVED]linuxcnc Latency test ambiguous results
STEPLEN = 150000
STEPSPACE = 150000
to
STEPLEN = 5000
STEPSPACE = 5000
or
STEPLEN = 10000
STEPSPACE = 10000
Displaying 15931 - 15945 out of 17460 results.
Time to create page: 0.366 seconds
