  • PCW
  • PCW's Avatar
12 Apr 2025 00:11
Replied by PCW on topic 7i92 firmware issue
7i92 firmware issue
Category: Driver Boards
12 hex characters (this is from an initialization script so the
last three characters (the $1) are supplied on the command line
that is:
./setmac 00123456789A
etc
Note that "00601B" is Mesas range
  • unknown
  • unknown
12 Apr 2025 00:02
Replied by unknown on topic 7i92 firmware issue
7i92 firmware issue
Wow thanks Pete, was just thinking about how to do this. I really think I owe you a few beers.
Another question, if I may.
[/code]./setmac 00601B168$1/[code]
What's the format for the MAC ?
  • Lcvette
  • Lcvette's Avatar
11 Apr 2025 23:34
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
Post your var file
  • Hakan
  • Hakan
11 Apr 2025 23:06
Replied by Hakan on topic ETHERCAT WAIT SYNC
ETHERCAT WAIT SYNC
Category: EtherCAT
Is it the same if you just install the ready apt package with ethercat instead of building ethercat master yourself?
  • andypugh
  • andypugh's Avatar
11 Apr 2025 22:56
  • PCW
  • PCW's Avatar
11 Apr 2025 22:45
  • sin-do-re
  • sin-do-re
11 Apr 2025 22:43
EtherCAT + 7i96s for encoder input and analog output
Category: EtherCAT
Hello
I have managed to get a few motors running with etherCAT, but I still need a simple I/O system with analog out and encoder input, to use a mesa THCAD.
How is it feasible? Do I need a dual Ethernet card?
The PCs I’m using have a single Ethernet port, so to run both mesa and ethercat I will need another Ethernet system, to have different NICs, right?
thank you.
  • Grotius
  • Grotius's Avatar
11 Apr 2025 22:25 - 11 Apr 2025 22:26
Replied by Grotius on topic ETHERCAT WAIT SYNC
ETHERCAT WAIT SYNC
Category: EtherCAT
The corbett install uses systemctl to start & stop the ethercat bus.
In debian 12 & 13 i use /etc/init.d/ethercat start.
At what time is your ethercat bus started, at pc boot time?
  • Grotius
  • Grotius's Avatar
11 Apr 2025 22:12
Replied by Grotius on topic Running an external program from a HAL pin
Category: HAL
@Pcw,
Yes, that should work.
Script below works.
$ halcmd -s show pin halui.estop.is-activated
prints:
halui bit   OUT FALSE halui.estop.is-activated
Then get the FALSE or TRUE in a script:
Warning: Spoiler!
  • PCW
  • PCW's Avatar
11 Apr 2025 21:51 - 11 Apr 2025 21:58
Category: HAL
Another possibility would be a script with halcmd  in a loop,
watching the desired pin/signal  (halcmd -s show pin spindle.0.on | grep TRUE)
(this could also turn off the spindle if LinuxCNC was not running)
  • Grotius
  • Grotius's Avatar
11 Apr 2025 21:50
Connecting TURCK B20 Gateway through EtherLab EtherCat
Category: EtherCAT
Here is a example project how to read & write to ethercat-master from any device.
I called the project twincat, because it is able to get and send info to the bus system.
The  ethercat-master source is slightly updated, It can print out more info as normal.
And the source had a nasty bug related to c code configuration wich i found.
This bug is still not resolved in etherlab master. I did tell them the bug, but i did not do a push request.
I think with this project you will be able to figur out how to use the TURCK device.
The project can print all details of the TURCK device. And you can send any data you want to the TURCK device.
1 bit send . Or 8bit, 16bit, and you can add more types if you need.
  • pgf
  • pgf
11 Apr 2025 21:39 - 11 Apr 2025 21:46
Category: HAL
I run Home Assistant (open source, no cloud involved) which does a good job of managing the devices. It's not the interface to zigbee that's the issue -- it's the interface to HAL. :-)
Is the NML channel documented somewhere?   [ Edit:  Never mind, I found it.   No, I won't be going there...  ]
  • andypugh
  • andypugh's Avatar
11 Apr 2025 21:34
Replied by andypugh on topic Strange behaviour of custom component
Okay I got it... But how to customize them to not hard code them
In this case the answer is simple, just move the two variables above the ;; separator and create them as parameters. Then you will end up with independent static variables for each instance of the component.
So:
enum MODESWAP{WRITEMODE, WAITVELOMODE, INITIAL, WORKING, WAITINGFORENABLE, HOMING};
enum MODESWAP modeSwap;
enum HOMESTATE{HOMETRIGGER, HOMECONFIRM, HOMESEEKING};
enum HOMESTATE homeState;
becomes
param out unsigned modeSwap;
param out unsigned homeState;
You _may_ still be able to use the enum, that would be something I would experiment with to find out. If not you could create the state names as macros to preserve readability. (but you can always use something like:
switch(modeSwap){
   case 1: // Waiting
   case 10: // Exploding
  • Grotius
  • Grotius's Avatar
11 Apr 2025 21:27 - 11 Apr 2025 21:29
Category: HAL
Maybe we can use the zigbee-api
Then we make a tiny connection to the nml channel, as a client.
Then the zigbee can follow the emergency status. on - off.
Displaying 17011 - 17025 out of 17466 results.
Time to create page: 0.414 seconds
