  • Dougal9887
  • Dougal9887
12 Nov 2024 21:09
Replied by Dougal9887 on topic Error when trying to open Gmoccapy confiuration.
Category: Gmoccapy
Yes. I chose parport/stepper config. That opened fine.
  • schnellmued
  • schnellmued
12 Nov 2024 21:00
Mesa 7i96s / Network no longer working was created by schnellmued
Category: Driver Boards
Hi all
I was happily using my 7i96s with LinuxCNC on my Mill. This week i powered on the machine and LinuxCNC was not able to connect. Ping 10.10.10.10 also got no response. So i picked a new 2m Lan Cable and connected the Laptop to the Mesa Card  (thought the cable from the cabinet might be damaged) - no Change :( I removed all connectors from the Mesa except the Power, still no change. I put the Mesa card on my bench, inspection did not show any damage. The Link Led is on, traffic led blinking from time to time. I did set the jumper W4/W5 down/down for 192.168.1.121 fallback ip (changed my laptop ip also ofc :D ), still no luck.
I did set the jumpers up/down for bootp and connected it to my router - it got stuck with red led on boot and no device did show in dhcp or the switch arp table.
The card was all the time inside a cabinet and there was no change to any electronics or firmware. I replaced the card with the one from my lathe - worked like a charm.
So the question: There is a firmware "7i96s_16m_fallback.bin", should i try to flash this on the card (the electronic guys at work have jtag equipment) ?
From the manual :  "Note that the card IP address is fixed at 192.168.1.121 when the IP select jumpers are in the UP,UP setting. If this fails, the 7I96Ss EEPROM must be re-programmed via the JTAG connector or (faster) JTAG FPGA load followed by Ethernet EEPROM update"
Anyone has done this before and could give me some hints please ? Thanks :)
schnellmued
12 Nov 2024 20:54
Replied by tommylight on topic Error when trying to open Gmoccapy confiuration.
Category: Gmoccapy
There is something terribly wrong there, buffer overflow detected, several segmentation faults, and multiple core dumps.
Try runing one of the included configs for parallel port from config picker, see if that works with Axis gui.
  • PCW
  • PCW's Avatar
12 Nov 2024 20:52
Spindeldrehzahl durch ändern der PWM Frequenz steuern
Category: Deutsch
Sollte das nicht sein:
pwmgen.0.pwm-freq ?
  • endian
  • endian's Avatar
12 Nov 2024 20:38 - 13 Nov 2024 14:16
Replied by endian on topic Ethercat, EL6751 and CANOpen
Category: EtherCAT
this is dry setup...You ve done them in tc build 4026.60 and I have 4024.59 and downloading yours... you do not use a legacy mapping but that else? why?tomorrow I check them live on my koppler and will exact customize mapping if it does not work... dmesg -v me with ethercat debug 1regards
  • Dougal9887
  • Dougal9887
12 Nov 2024 20:26 - 12 Nov 2024 20:29
Category: Gmoccapy
I am moving an existing working configuration to a new computer running Debian 12 and a newly downloaded version of LinuxCNC.
The Gmoccapy sims open fine, but I get an error attempting to open my configuration.
The message appears to reference Python, so I have attached copies of the .py files from the configuration Python folder and a copy of the report (linuxcnc.txt). I have also attached a copy of the .hal and.ini files in case they are relevant.
I wonder if perhaps there is a mismatch of the old Python files and the new LinuxCNC?
I would be most grateful if someone could please take a look as this is out of my depth!
Many thanks,
Dougal.
File Name: probe_screen.py
File Size:88 KB
File Name: remap.py
File Size:1 KB
File Name: stdglue.py
File Size:8 KB
File Name: toplevel.py
File Size:1 KB
File Name: starmill.hal
File Size:4 KB
File Name: starmill.ini
File Size:4 KB
File Name: linuxcnc.txt
File Size:14 KB
  • Aciera
  • Aciera's Avatar
12 Nov 2024 20:10
Category: Deutsch
Kannst du bitte mal deine hal und ini Dateien anhängen?
  • TripleM
  • TripleM
12 Nov 2024 20:06 - 14 Nov 2024 11:18
Category: Deutsch
ich habe einen ältern Gleichstrom Drehzahlregler der ein Rechtecksignal zur Drehzahlsteuerung benötigt.
Signal passt auch soweit und durch manuelles ändern des Parameters pwm_frquenzy kann ich die Drehzahl ändern.
Jetzt bekomm ich es nicht hin,  diesen Parameter mit der Spindeldrehzahl zu verbinden.
So habe ich es versucht:
net spindle-speed-cmd-rpm  => ...pwmgen.pwm_frequency
​​​​​​Jedoch kommt immer ein Fehler, dass der Pin nicht bekannt ist.
​​​​​​Wie kann ich das Problem angehen?
Danke
Viele Grüße
Manuel
  • JackRay
  • JackRay
12 Nov 2024 18:07
Replied by JackRay on topic Mesa 7i96s connected but inputs not working
thank you very much , I will go try that ASAP
  • mBender
  • mBender
12 Nov 2024 17:07
It's not that the motors stall during acceleration. The run for like 50mm normal. I try to make a video. And the weird thing is, it works with the parallel port. I can switch back and forth between the Tang and the parallel port.
  • Aciera
  • Aciera's Avatar
12 Nov 2024 16:58
Replied by Aciera on topic How to connect hal pins to custom GUI?
Category: Other User Interfaces
use the 'show Halconfiguration' tool to find the correct pin name (something like 'qtplasmac.somePin')
  • digiex_chris
  • digiex_chris
12 Nov 2024 16:53
is it maybe too high of an acceleration value? Even not connected to anything steppers need a slowish ramp up compared to servos.
  • PCW
  • PCW's Avatar
12 Nov 2024 16:11
Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
Category: Basic Configuration
Not sure what the easiest path is here but I see a couple options:
1. With pncconf, make a normal step/dir 7I76E configuration and a normal 7I77 configuration and merge them
2. Use pncconfs discover option
  • Sziggy_NC
  • Sziggy_NC
12 Nov 2024 16:10
Replied by Sziggy_NC on topic +-10v setup 7i97 & .ini
You are awesome! Thank you!
That was the final thing stopping me from continuing the retrofit.
After increasing the FERROR and MIN_FERROR in the ini I have tuned the X axis. I will get the Y and Z today.
Displaying 17926 - 17940 out of 24292 results.
Time to create page: 0.425 seconds
