  • Bennett
  • Bennett's Avatar
05 Aug 2024 14:45
Can a 'servo drive' be used to power a 3 phase AC spindle motor with encoder?
Category: Driver Boards
centroidcncforum.com/viewtopic.php?f=57&...1&hilit=fanuc#p88931
Wow, this is a neat implementation! Fairly simple and seems to work well. Gets me thinking about my solution. Going to take some cramming to fit it all in the space I have around the spindle but it just might work.
Some photos of the Hardinge Conquest spindle for those interested. This machine has an epoxy/granite base that you can see a little chunk broken off of in one of the photos. There is a gear-looking ring on the spindle that two separate pins can engage with (odd/even labels in documentation, maybe that stands for odd/even degrees based on their offset). Makes me think that a retractable worm drive could be fitted there in place of this system but that definitely seems more mechanically involved as it would have to be all custom. I wonder how Hardinge did their Conquests with full C axis..
It's hard to find anything clear on Fanuc stuff, but I think the spindle amp uses serial communication to/from the Fanuc control.  So while it may be possible...
Yes, very tricky to track down the Fanuc docs, mainly seems to be that they put a huge number of products in a single doc. I managed to track down the spindle amp documentation if anyone wants to see that. 400 pages or so, the forum wouldn't upload it so get in touch if you want me to send it over.
  • PCW
  • PCW's Avatar
05 Aug 2024 14:35 - 05 Aug 2024 14:36
Scaling power based on % of imposed velocity
It's a bit hard to tell because you don't have the line(s)
that caused the error in your hal file example.
  • PCW
  • PCW's Avatar
05 Aug 2024 14:28
We use 26LS32's a lot for a couple of reasons:
1. Their inputs are protected from up to +-25V
(the more expensive CMOS parts are typically protected to only +-14V or so)
2. Because they are TTL parts the outputs don't swing to 5V and if you add a 1K
pulldown, the outputs are OK for interfacing with most 3.3V chips.
3. They are much cheaper than  the CMOS equivalents.
The main disadvantage is higher power consumption
  • Muftijaja
  • Muftijaja
05 Aug 2024 14:20
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
so, I tried both adresses, with both settings in etc/network/interfaces I have no networks afterwards.
Hiernach geht die Verbindung gar nicht mehr:
    auto eno1
    iface eno1 inet static
    address 10.10.10.2  (same with 10.10.10.1)
    hardware-irq-coalesce-rx-usecs 0
  • sin-do-re
  • sin-do-re
05 Aug 2024 14:17 - 05 Aug 2024 14:21
Replied by sin-do-re on topic Scaling power based on % of imposed velocity
Hey. I've been trying this but no success entering the current velocity parameter into lincurve. i always get the same 2 types of errors, no matter how much i try to "juggle" the variable around. what can i do? ive been trying with motion.current-vel and qtplasmac.current-velocity  at first i tried directly, now im trying to pass it through a scale.2 first, but it gives me the same 2 errors.the errors are either that signal name motion.current-vel can’t be the same as a pin, and if I put a pin it says that motion.current-vel is already linked to such pin. Here is the Hal code:
################### added
# Load the necessary HAL components
loadrt scale count=3
loadrt lincurve count=1 personality=6
addf scale.0 servo-thread
addf scale.1 servo-thread
addf scale.2 servo-thread
addf lincurve.0 servo-thread
# Capture the spindle speed output from the G-code command
net spindle-speed => scale.1.in
# Scale the velocity before feeding it to lincurve
net qtplasmac.current-velocity => scale.2.in
setp scale.2.gain 1.0  # Adjust gain as needed
net scaled-velocity scale.2.out => lincurve.0.in
# Configure lincurve points for velocity to power scaling
setp lincurve.0.x-val-00 0.0  # Velocity percentage at 0%
setp lincurve.0.x-val-01 0.2  # Velocity percentage at 20%
setp lincurve.0.x-val-02 0.4  # Velocity percentage at 40%
setp lincurve.0.x-val-03 0.6  # Velocity percentage at 60%
setp lincurve.0.x-val-04 0.8  # Velocity percentage at 80%
setp lincurve.0.x-val-05 1.0  # Velocity percentage at 100%
setp lincurve.0.y-val-00 0.2  # Power scale at 20% for 0% velocity
setp lincurve.0.y-val-01 0.3  # Power scale at 30% for 20% velocity
setp lincurve.0.y-val-02 0.4  # Power scale at 40% for 40% velocity
setp lincurve.0.y-val-03 0.6  # Power scale at 60% for 60% velocity
setp lincurve.0.y-val-04 0.8  # Power scale at 80% for 80% velocity
setp lincurve.0.y-val-05 1.0  # Power scale at 100% for 100% velocity
# Scale the spindle speed by the lincurve output
net power-scale lincurve.0.out => scale.0.in
net adjusted-power scale.0.out => scale.1.gain
# Use scale to adjust the analog output voltage
net final-power scale.1.out => hm2_7i96s.0.pwmgen.00.value
  • onceloved
  • onceloved's Avatar
05 Aug 2024 14:09 - 05 Aug 2024 14:13
Replied by onceloved on topic EtherCAT i/o board for spindle, estop and mpg
Category: EtherCAT
The encoder input of this card is in the form of a counter. There is no AB phase input. I have studied it before and gave up. Now I use the rv901 fpga card with six encoder inputs and more than a dozen input and output
  • Muftijaja
  • Muftijaja
05 Aug 2024 14:02
Category: Deutsch
Ok, what adress to use - 10.10.10.2 or 10.10.10.1?
05 Aug 2024 13:57
Replied by tommylight on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
OK, add as PCW said for you Intel NIC, save and reboot, see if it works with Mesa, double check with ip a and ping.
  • Muftijaja
  • Muftijaja
05 Aug 2024 13:38
Category: Deutsch
/etc/network/interfaces has just
auto lo
iface lo inet loopback
everything else I did outcomment for the moment, but I need to have the better performance for the intel card
05 Aug 2024 13:29
Category: Deutsch
What do you have now in etc/network/interfaces ?
05 Aug 2024 13:27
Hardware needed to switch from mach 3 6 axis to linuxcnc 9 axis
No more Mach3! :)
You have to stop thinking about mach3 and how it does things, this is a whole new world with LinuxCNC.
BOB is a break out board used for parallel port to machine interfacing, cheap at ~10-15$ and it offers a bit of protection for the GPIO on the controller.
Up to a certain point, the SmoothStepper is similar to Mesa 7i96S, in that they both take commands from the machine controller or in this case the PC and send steps to motor drives, but it ends there as how they do the same thing differs a lot, mainly Mesa has usually 1ms response time (can be even faster) while smoothie will take quite a while to actually stop when commanded to stop due to buffering and ....
To put it simply, you can control happily an 16 ton machine with LinuxCNC for years on end 24/7/365, you can not do that with mach3...well you can but it ends up in tears and smoke and loss of will to live! :)
  • Muftijaja
  • Muftijaja
05 Aug 2024 13:07 - 05 Aug 2024 13:10
Category: Deutsch
So, my last actions today summarized:
I deleted all wired connections.
I triet to find out which connection goes to what hardware. Cable put out from the MESA card, eno1 is definitely the internal Intel card, ip a shows "no carrier" on eno1, so that is quite clear and how I want it. eno1 has had much better pings when I did the sudo ethtool -C eno1 rx-usecs 0.
Confusion about that resolved.
enp2s0 is the RLT8111 card. I want to get Internet over this connection.
this means, I have to do what?
Q: Further configuration only in the etc/network/interfaces? Not in the network manager? Seems to be quite more complex to do all settings just in the /interfaces file. (newbie in Linux)  I can't find the doc where either/or is defined.
Confusion exists further about this:
Mesa Card has 10.10.10.10, Intel 82579LM card has 10.10.10.2    What is 10.10.10.1?
Suggestion in this thread was:
"auto eno1
           address 10.10.10.2
   hardware-irq-coalesce-rx-usecs 0"
Suggestion in the google doc from PCW is:
"sudo geany /etc/network/interfaces
to append the following at the end of the file:
     auto enp2s0iface
          enp2s0 inet staticaddress 10.10.10.1
       Note, the last line is only required for Intel network cards."
Q: Besides the other connection enp2s0, what is the right configuration - 10.10.10.2 or .1 ?
Q: Do I need to have the loop in /interfaces to 127.0.0.1?
Thanks for any answers!
  • TucsonSean
  • TucsonSean
05 Aug 2024 12:32
Replied by TucsonSean on topic Probe panel for Axis GUI
Category: AXIS
Hello Gentlemen,
I have encountered an issue with my installation of EasyProbe. After installation, I have taken care of all errors and was able to start LinuxCNC and when I go to calibrate the probe, I get the following error: Named Parameter #<_ini[probe]vel_fast> not defined
I know that vel_fast was a variable copied directly from the installation instructions and placed into the ini file.  Any help pointing me in the right direction would be greatly appreciated.
-Sean
LinuxCNC ver: 2.8.4
  • meister
  • meister
05 Aug 2024 11:49
@all
how do you implement differential signals?
i wanted to try it now with the AM26LS32, there are also some from MAX but they are extremely expensive
  • papaathome
  • papaathome
05 Aug 2024 11:37
Replied by papaathome on topic Installing Linuxcnc on Debian Bookworm
Category: Installing LinuxCNC
I try to install the latest version of LinuxCNC on Debian Bookworm using the 'Debian 12 bookworm PREEMPT-MT ISO' from the web site. (LinuxCNC=2.9.3, linux image-rt. Build 2024-07-21 21:05:42, live build 20230502)
I have the ISO on an USB drive and can boot from it. Running live (amd64) is without any problems, I can run LinuxCNC and its test tools for latency testing.
Max jitter on servo thread/base thread is around 10000/20000. I should be able to use LinuxCNC on this machine (I think).
When I boot and select 'start installer' I run into problems.
During the boot, before entering the graphics screen I see lines like
moud: mounting /dev/sda on /media failed: Invalid argument
umout: can't unmount /media: Invalid argument.
Other devices that I see are /dev/sda1, /dev/sda2 and /dev/sda5 before the graphics screen removes is all and takes over the screen.
In the past I was able to install Debian 10 on this machine (still on it but can't use it at the moment), I don't think it is a hardware problem.
I tried several USB slots to see if it makes any difference, but all fails.
Does anybody have a suggestion how to fix this?
Kind regards
Displaying 24361 - 24375 out of 24521 results.
Time to create page: 0.545 seconds
