  • rodw
  • rodw's Avatar
31 Jan 2026 06:25
How to update QtDragon_HD to latest version?
Category: Qtvcp
you have it. Best to build from source. then  Just do a git pull and make again  for the absolute latest I did a video recently on my @MrRodW youube channel
  • NWE
  • NWE's Avatar
31 Jan 2026 05:32
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
This is similar to how many industrial robotic cells are structured, where a dedicated motion controller handles paths, and a PLC controls the cell logic and operator interaction.
So the question is not whether LinuxCNC can do everything, but how others have structured a clean responsibility boundary between a real PLC and LinuxCNC in production machines.
Any practical examples along those lines would be appreciated.
I think of this: LinuxCNC has capability to be operated by the user, entirely using keyboard+mouse+monitor, at opposite extreme it can have external I/O wired to physical buttons, switches and dials for operator control without any keyboard+mouse+monitor if you wish.
I'm thinking wire connections from your PLC I/O to LinuxCNC I/O to "drive by wire"? Cycle start, Feed hold, etc. maybe also jogging, whatever you need can be brought out on a wire and connected to your PLC.
The Fanuc 6-axis robot bag palletizer I've been reprogramming lately is connected to an Allen Bradley PLC via ethernet/IP. I have never heard the words "LinuxCNC" and "ethernet/IP" in the same sentence, but I've been meaning to explore the possibilities. I have about $1500 usd worth of new Beckhoff ethernet/IP remote I/O hardware on the shelf for nearly a year now, that I plan to connect with LinuxCNC. My big hurdle has been my nil experience with ethernet/IP. Now on this Fanuc I got an idea what ethernet/IP configuration looks like...
  • NWE
  • NWE's Avatar
31 Jan 2026 05:05
Admittedly, the Click PLCs are fairly 'low-end', so higher-end PLC's likely have more sophisticated onboard motion control features.
I've always had good results with AutomationDirect's Click PLC's. But I've been disappointed with the reliability of their Productivity 2000 and also their BRX models. Maybe it was just bad luck. I've finally retrofitted most of my higher end AutomationDirect PLC's but those Clicks sure don't seem to make much trouble. Still I don't care for ladder logic.
The very first project I sold containing a Productivity 2000 quit about a week after it was out the door. I tried reprogramming it, also tried updating its firmware, no go. I was able to read out some error logs. Automation tech support told me it is bricked, and that they have been having that trouble with that one firmware version. I have to return it for warranty. They gave me a choice of sending back the bricked plc then after they have it back, they send me a replacement. Or I can buy a new plc and they refund me when they get the broken one back. So I bought the new one and got the refund later because the customer was in a hurry. This was a $1200 USD PLC about 7yr. ago. (CPU + base + PSU + motion I/O) Even the base was bricked, that contained a CPLD on its motherboard.
  • NWE
  • NWE's Avatar
31 Jan 2026 04:34 - 31 Jan 2026 05:34
Just to be clear, in your setup you are using Beckhoff EtherCAT I/O as remote I/O, but without a Beckhoff PLC runtime (e.g. TwinCAT PLC), correct?
Yes, I'm using Beckhoff I/O strictly as remote I/O, all my logic exists in the pc running LinuxCNC
31 Jan 2026 03:14 - 31 Jan 2026 03:39
First conversion, Axiom CNC Router with RichAuto controls
Category: Show Your Stuff
Sorry i had no time to watch this, will do very soon.
Thank you.
OK, watched it, left a comment, nicely done and very detailed.
31 Jan 2026 03:12
Replied by tommylight on topic Remote - Camera - Touch - MPG
Category: Other User Interfaces
Magnificent or wunderbar in German, danke schon.
For context this is using a touchscreen to move the machine and watch the video from a camera, as MPG with vision.
Anyone have a better tittle, feel free to chime in, i feel this tittle does not do it justice.
Thank you.
31 Jan 2026 03:09
How to connect any pulse/dir drive to EtherCAT network - a new hardware coming
Savaal teshekyr (if i recall correctly, been 30 years since i learned that).
One small complaint, turn the camera on it's side, it is hard to watch vertical video on a ultra wide monitor! :)
31 Jan 2026 03:06
  • rodw
  • rodw's Avatar
31 Jan 2026 01:15
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
I've totally rewritten it anyway. I was able to move the state machine into a seperate procedure which has substantially streamlined the code. Now I just have to get it to compile
A lot of that does not need to be in the component because you are setting the pin externally. But we may need to scale or otherwise calculate data for them in which case they need to pass through the component. Get the basics first....
write all becomes something like
FUNCTION(writeall) {
    // Restart sequence on rising edge of enable
    if (enable && !data.prev_enable) data.control.raw = 0x0000;
    data.prev_enable = enable;
    if (enable) {
        int drive_ready = runCiA402StateMachine(&__comp_inst);
        if (drive_ready) {
            if (homing) {
                opmode_out = 6; // Homing Mode
                // Bit 4 starts homing; check for errors before commanding
                if (!data.status.bits.op_error) data.control.bits.op_specific = 1;
            } else {
                opmode_out = (s8)default_opmode;
                data.control.bits.op_specific = 0; // Clear Bit 4
                // Normal Motion
                drive_target_position = (s32)(target_position * pos_scale);
                drive_target_velocity = (s32)(target_velocity * vel_scale);
    } else {
        data.control.raw = 0x0006; // Shutdown / Disable Voltage
    controlword_out = data.control.raw;
homing feedback is in the read command
30 Jan 2026 23:47
Replied by tommylight on topic Custom PC build for my brothers company and more
And here is the short video of the build process of that same PC above:
30 Jan 2026 23:22
OMRON Yaskawa controllers, what I/O board would you choose
Category: Driver Boards
Sorry PCW, i keep advising boards that are usually in stock.
For this use case, Mesa 7i95T should also be considered as it is a step/dir board with encoders for all axis/joins, for if you ever want to also include LinuxCNC in the loop.
  • Marcos DC
  • Marcos DC's Avatar
30 Jan 2026 23:11
Thanks for the replies — I think it may help to clarify one architectural point.
We are not evaluating a PLC + LinuxCNC setup because LinuxCNC lacks sequencing, ladder logic, or HMI capabilities.
The decision is driven by industrial architecture requirements.
In our case, the PLC is not intended to replace motion control.
The process is trajectory/raster-based (laser cleaning and spray overlap), where motion quality, lookahead, and path execution are critical — this is why LinuxCNC remains responsible for motion.
The PLC acts as the machine controller:
• machine state and sequencing
• safety and interlocks
• operator workflow and recipes
• maintaining a safe and known state independently of the PC
  • aDm1N
  • aDm1N's Avatar
30 Jan 2026 22:55 - 30 Jan 2026 22:58
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
The current state focuses on contour machining and the related LinuxCNC cycles.Contour (CONTOUR) is defined purely as geometry (lines, chamfers, radii, inner/outer).
Different operations can then be derived from this geometry, independent of their order in the workflow.Currently implemented:
  • Drilling using LinuxCNC cycles G81–G84 (including G82 with dwell, G83/G73 peck drilling, G84 tapping)
    • cycle-specific parameters are shown dynamically
    • internal correct switching to
      G17
      , followed by
      G80
      and back to
      G18
  • Roughing of contours
    • use of G71/G72 if the contour is monotonic
    • automatic fallback to move-based machining for non-suitable contours
  • Finishing of the same contour as a separate step
All operations reference the same contour geometry but are processed as logically separate steps.G-code generation (current logic):
  • Before every tool change, the machine always moves to a defined G53 tool change position
  • Definition of an explicit safe area (
    X_safe
    Z_safe
    ) derived from stock geometry and retract planes
  • After each cutting step:
    • retract in X first
    • then retract in Z (no combined retract moves)
  • Approach from the safe area may be diagonal
  • Coolant (
    M7/M8/M9
    ) is set explicitly per operation
  • Comments are sanitized (no nested parentheses)
The preview is directly based on the geometry:
  • true arcs for radii
  • separate visualization of contour, stock, toolpaths, retract planes, and safety limits
  • visual highlighting when machining or safety limits are exceeded
A reworked README describes the current feature set, safety logic, and G-code strategies in detail.
Screenshots will follow in the next few days.
The current state will also be published on GitHub in the coming days.Additionally, a test file (
Test.ngc
) is attached, reflecting the current state of the generated G-code.
  • RNZ
  • RNZ
30 Jan 2026 22:33
  • RNZ
  • RNZ
30 Jan 2026 22:23
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
I haven't been on the Forum for ages but today I noticed that someone asked if I could post my RPi 5 ethernet settings on this thread.
I think they have been posted a few pages back by someone else, nevertheless the following wider context may be helpful.
As an aside, my RPi 5 and Mesa setup has worked perfectly since the ethernet issue (below) was fixed.
The following is copied from another thread.
I ran my RPi 5 and 7i96s overnight and completed 40 million pings with zero errors.
sudo chrt 99 ping -i .001 10.10.10.10 -c 40000000
At the same time in the background, I ran Latency Histogram and two Glxgears. I have attached photos in case anybody is interested in seeing the results.
I’m not sure what to make of the maximum ping time of just over 10 ms.
It seems that "hardware-irq-coalesce-rx-usecs 0" has fixed the issues I was having (aside from the 10 ms issue) at least on RPi 5 * GB with LinuxCNC 2.9.2.
What is this "coalesce" thing?
Interrupt coalesce settings ( access.redhat.com/documentation/en-us/re...ing_networking/index )
"By using interrupt coalescing, the system collects network packets and generates a single interrupt for multiple packets. This increases the amount of data sent to the kernel with one hardware interrupt, which reduces the interrupt load, and maximizes the throughput."
My /etc/network/interfaces looks like this:
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 10.10.10.11
Displaying 3136 - 3150 out of 17261 results.
Time to create page: 0.278 seconds
