  • cnbbom
  • cnbbom
18 Jan 2026 12:42
Replied by cnbbom on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
I have a PC that does not skip a beat at 15000 but it's power supply failed (workstation=expensive), most mine do 50000-100000, and i have some bad laptops that are in daily use for over 10 years with base period set at 300000.
Unfortunately, I had to leave the motors vibrating a bit because 7000 mm/min is necessary for me, and I use the SFU1605 in the X and Y directions. Seeing that my PC wasn't helping with this, I fixed the microstepping at 800.
But I'll still try to upgrade this PC until it's closer to these recommendations.
  • 2tinker
  • 2tinker
18 Jan 2026 10:49
Replied by 2tinker on topic How do I lubricate correctly?
Category: Milling Machines
Interesting, thank you very much.
  • unknown
  • unknown
18 Jan 2026 09:41
Replied by unknown on topic Raspberry with LinuxCNC direct interface
If using the RPi Trixie image you will need to update Linuxcnc to 2.9.8.
This will be the situation until late March\early April.
  • ruediger123
  • ruediger123
18 Jan 2026 09:39
Replied by ruediger123 on topic G-Code Schleifen
G-Code Schleifen
Category: Deutsch
Danke
  • unknown
  • unknown
18 Jan 2026 09:39
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
Well aware of how Italians dramatic and exaggerated in their statements, all you have to do is listen to Rossi et al and his comments regarding Marc.
The 7i73 will allow a reasonable HMI with just one cable as well. A 7i90 with SmartSerial firmware works in the same way.
  • rodw
  • rodw's Avatar
18 Jan 2026 09:34
Once you have hardware, submit the PR, Look at the S curve motion. It was pushed to Master branch with bugs in it so it could be tested more widely. Money is made by original thought. You just need one good idea and you might be surprised.
This would be good where a PC like an Odroid H4 was embedded in the HMI enclosure itself
  • bobwolf
  • bobwolf
18 Jan 2026 09:25
So many great comments!
I'm a little unconvinced how changing to USB would have an affect on the "wiring nightmare or EMI issues".
I'm Italian. Italians are all dramatic and exaggerated in their statements.
But to get serious: I imagined installing the system near the operator panel, so that all the controls are wired nearby; thus, keeping the wiring and connections clean and organized. Only the USB cable runs from the panel to the PC.
NWE writes
Last year I was thinking that this type of I/O via USB connection should be developed, but did not find time to start on it.
Over the past few months, I've had a lot of free time, and at first it was just a test to see if it worked... and gradually, things took shape, and I saw that there was a viable solution. I started with bit-banging from the Mesa board to control the shift registers... but I wasn't satisfied with the solution.
To reply to rodw:
1. The project started as a personal challenge, and the ones you see in the videos are the boards with "sins of youth" that I had built after the breadboard phase. I'm planning on making some basic kits with the correct versions. For now, I have some old boards.
2. It would be a dream.  But I'd like the project to be further tested by others as well.
3 See point 2. Then I'll get organized, and if it's accepted, they'll include it in some update of the new version.
4 If you compare me to Mesa, you'll make me blush... I'm a hobbyist, they're professionals.
ciao
Roberto
  • jimmyrig
  • jimmyrig
18 Jan 2026 05:29
Replied by jimmyrig on topic Servo Driven tool changer - How to set up
I'm working on a gantry style one currently....though might build a carousel so it's quicker/doesn't eat space.
Rough process is you remap the m6 code, example here github.com/LinuxCNC/linuxcnc/tree/master...emap/rack-toolchange
  • PCW
  • PCW's Avatar
18 Jan 2026 02:32
First Analog Build - 7i97 - Anilam - Issue enabling machine
Category: Basic Configuration
You MUST set the 7I97 PWMgens offset mode to true or runaways are guaranteed.
  • PCW
  • PCW's Avatar
18 Jan 2026 02:28
Replied by PCW on topic need firmware for mesa 7i76eu+7i85+pwm
The current firmware puts the PWMgen on P1 pin 1
If you want the PWM  on a 7I85 RS-422 output, that would
require different firmware.
18 Jan 2026 02:17
Those are two separate issues, first is always (granted wiring is OK) hal/settings issue, the second is a limit switch triggered or inverted issue.
For the first, some checks:
-disconnect one of the analog output wires from mesa, power on the machine and enable shortly = the motor should very slowly turn. Be aware that if wiring is not OK the machine might run away at full speed
-reconnect the wires
-use a DVM set in beep or resistance mode and check between analog ground on the drive and machine ground = there should not be low resistance, usually. machine should be powered off.
-use the DVM and measure the analog output voltage on Mesa or on the drive while LinuxCNC is disabled but the machine is powered on and LinuxCNC is running = there should be no voltage
-use the calibration screen to invert the output, or encoder, but NEVER both, test by enabling the machine
-if you still get joint errors, lover the P value to 10 or 5 or 2 and test.
  • NWE
  • NWE's Avatar
18 Jan 2026 02:09
Replied by NWE on topic Stepper Motor Shaft Failure
If the inside radius of the step is too small, that produces a weak point in the shaft. Frequently, when a shaft has to be reduced, tapering or rounding the step in the shaft largely prevents that weak point.
Think of the sharp inside corner of the step as being the starting point of a fracture beginning to form. That is where it will break.
18 Jan 2026 02:04
Replied by tommylight on topic Stepper Motor Shaft Failure
Can anyone confirm that this is a recognized risk with this arrangement ?
With a reduced shaft ?
I can not confirm, but i read a lot of Creality CR-30 3D printers have a failed motor shaft from factory, not reduced but long, and i do have a CR-30 that is still OK. The belt on those is 10mm wide and tight like a drum, literally.
The reason might also be the reduction on a lathe can leave grooves that might initiate the break due to tension and vibrations, so it seem plausible.
Best way to avoid this would be, granted the shaft is long enough, to make a bearing holder at the end of the shaft.
18 Jan 2026 01:56
Replied by tommylight on topic New and Working RTAI debs for 2.9
Well, with a value of 46872, Linux CNC runs at maximum speed, but if I change it to 50000 I get an error message.
Try 100000 , and also since you say it works better with 46872 try 93744.
This will limit your max velocity in half, use the "Max velocity" slider on screen to limit the speed till you do not get joint errors.
Notice the motor sound, should be much smoother.
I'd also like to ask a question: on a normal machine that is acceptable for running Linux CNC, what are the minimum and maximum acceptable values ​​for BASE_PERIOD?
There is no such thing, it all depends on what your PC can do safely, and from that set the drive microstepping to achieve the desired machine velocity/speed, if possible, as with low microstepping motors vibrate a lot.
Displaying 4066 - 4080 out of 17075 results.
Time to create page: 0.591 seconds
