  • ihavenofish
  • ihavenofish
09 Jan 2026 01:30
Replied by ihavenofish on topic LinuxCNC S-Curve Accelerations
These are in inches.
So my understanding would be:
So 20 IPS max Velocity
200 Max accel (~1/2g) so 1/10 second to maxvel with no jerk limit (old TP)
2000 Max jerk  so 1/10 second to full accel
Which (jerk=2000) actually sounds a bit low
I was doing some math to create paths (not real time) a little while back and on my machine with 0.5G (5000mm/s/s) a jerk of like 50000mm/s/s/s was the starting point of usefulness, and 500000 would probably be where I end up. So your 10:1 seems a logical place to start.
BUT, it shouldn't matter. Jerk should never create a following error, it should be mathematically precise, even if its comically low for real life machines.
  • PCW
  • PCW's Avatar
09 Jan 2026 00:57
Replied by PCW on topic LinuxCNC S-Curve Accelerations
Those ini values do not cause an issue with the old TP (0)
I'll check your suggestions in a bit...
  • PCW
  • PCW's Avatar
09 Jan 2026 00:54
  • grandixximo
  • grandixximo's Avatar
09 Jan 2026 00:49
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Thank you Peter for looking at this.
I see a few issues with your ini.txt
16 float IN 1e+99 ini.traj_default_acceleration
16 float IN 0 ini.traj_default_jerk
16 float IN 1 ini.traj_default_velocity
16 float IN 1e+99 ini.traj_max_acceleration
16 float IN 0 ini.traj_max_jerk
16 float IN 1e+99 ini.traj_max_velocity
these settings seems a bit waky, if you want to have jerk control you need
and
ini.traj_max_jerk
to be more than 0
and the 1e+99 max acc and velocity, is this something people actually run with? is it something is supported without f-error on TP0 aka old TP?
  • andypugh
  • andypugh's Avatar
09 Jan 2026 00:46
Replied by andypugh on topic LinuxCNC S-Curve Accelerations
Is a jerk of 2000 reasonable? What units is your config?
  • soehlrich
  • soehlrich
09 Jan 2026 00:02 - 09 Jan 2026 01:55
Replied by soehlrich on topic Qtdragon_hd Zero button not zeroing
Hi, Apologies, did some more testing. If I start at ABS of Zero then Job axis 5mm at a time slowly (ie 100mm/min) every 3rd or 4th jog the counter will increment by .001 ie instead of reading 15.000 it will read 15.001, then if I keep joging it will then stay with the .001 until 35 then it will read 35.002.After some more testing here are my job results (jogging at 30mm/min and incr of 5mm)starts at ABS 0 G54=00->5->10->15->20->25.001->20->25.001->20->25.001->20->25.001->30.001...all .001 till 70.002jogging -ve from 70.002->65.001 ...all .001 til 25.000 .. all the way back to 0.000Feels like some sort of rounding / fp / devision error creaping inI have attached a HALShow screen - after joggin in cnrements of 5mm the first count was correct at 6400, then after a few it added an extra count then another at 30mm so now shows 30.001 as it must be rounding upHope this helps
  • HansU
  • HansU's Avatar
08 Jan 2026 21:54 - 09 Jan 2026 07:57
Linuxcnc 2.9.x and Glade GTK3 display issue
Category: Gmoccapy
Works for me as well with the change Aciera suggested.
  • TripleM
  • TripleM
08 Jan 2026 21:20 - 08 Jan 2026 21:20
Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
Category: Driver Boards
We seem to have strayed from the topic...
I tried again today and simply tried other serial channels. When I was at SSerial 5 (7i85 TB1, pin 17-24), my 7i84 was found. So it seems that either there is something wrong with the DB25 - ID24 connection cable (I measured it pin by pin) or with the 7i85 itself. I'm not sure how to check that yet...
 But back to the topic. The bit files work.
Thank you very much for your help.
  • PCW
  • PCW's Avatar
08 Jan 2026 21:05 - 08 Jan 2026 23:50
Just a quick test and I got large following errors:
ini setting are:
File Name: ini.txt
File Size:5 KB
  • PCW
  • PCW's Avatar
08 Jan 2026 21:00
Replied by PCW on topic 7i92tm_7i76u
7i92tm_7i76u
Category: PnCConf Wizard
The 7I76u uses normal 7i92t_7i76 firmware so 7i92t_7i76x1pd.bin
Then select  7i92-internal Data and 7i76x2 with one 7i76:
The stepgens are selected from the P2 tab:
  • PCW
  • PCW's Avatar
08 Jan 2026 20:50
Replied by PCW on topic 7i92M + 7i76 add PWM+PktUART
That's possible, I'll take a look when I get a chance
08 Jan 2026 19:45
Replied by tommylight on topic No configuration pages for Y2 Axis
Is -3 correct for a dual Y axes configuration?
Yes it is, tandem joints must have negative value for homing sequence.
  • amanker
  • amanker
08 Jan 2026 18:43
I was using remora on BTT Octopus pro board. Few days back I had to remove the board for some reason. Now it's not working. Nothing has changed. I tried erasing and reflashing remora by stm32 programmer. Tried changing spi cable from board to rpi4. I can see remora firmware is working on board. I added blink module to verify remora, it's working. I can see via UART console that remora ha loaded correctly and comes to idle state.
But on LinuxCNC side machine don't comes out of estop. No configuration changed. Tried new trixie image but can't compile remora due to incomplete pointer error. Don't know what's going wrong?
  • lorenzing
  • lorenzing
08 Jan 2026 15:51 - 08 Jan 2026 15:55
Replied by lorenzing on topic Ethercat Motion Problem
Category: EtherCAT
Hi all,
thanks to Hakan, I’m now able to control all the motors without any issues.
However, could someone help me with this error shown by the code dmesg command:  dmesg.txt
Could this error cause problems during machine operation?
Many thanks, Lorenzo
  • PHILCOAST
  • PHILCOAST's Avatar
08 Jan 2026 15:43
Replied by PHILCOAST on topic RPi CM5 on Mesa Ethernet 7i95
Thanks for the test image.It solved the issue on CM5-7i95 detected and linuxcnc running with hm2_eth and working I/O.Much appreciated.
Displaying 4471 - 4485 out of 17022 results.
Time to create page: 1.066 seconds
