  • nwallace
  • nwallace
12 Nov 2025 19:23
Replied by nwallace on topic How to disable buttons in Probe Basic
Category: QtPyVCP
A reinstall unfortunately does not solve the issue. I am also not sure that this is a new problem. It looks like the running version is probe-basic_0.5.3-216. We never tried using the probing part of the interface until a few days ago. After the probing routine completes, the ui stays in the busy state indefinitely if I had it set to update the WCO. If it is only set to measure, it works fine. I can find no significant differences between the old and the updated probing routines. Also, probing with my own custom routines works fine. It is only when I click a probing routine on the probing tab with it set to update the WCO that it locks up. If I comment out the G10 line, the ui does not stay locked. I have tried running linuxcnc from the terminal to see if there is any debug output but no luck there either.
I figured that support from the people who make it for what appears to be a bug in a version from 2023 would be a long shot. It is from before installing from apt was even an option. There are also a few modifications I no longer have to do because they have become features. I have not connected the new version to the machine to test if probing behaves the same way yet. Wanted to make sure I could get everything to behave the way we have trained people. I have a little mini pc set aside to for that once I get a copy of the config modified for our machine.
Appreciate that it can be tiresome to see the same stuff repeatedly. Everyone is at a different point in their journey of learning.
  • Jensner
  • Jensner
12 Nov 2025 19:18
Nach Neuinstallation upgrade auf Kernel-Release 6.3.0-rt11-linuxcnc
Category: Deutsch
OK, installation is done.
At the moment the latency test looks like this:
The only thing is that i allways get the same depending-problems, so i can not upgrade the kernel.
Can someone help me here..
Thanks a lot
Jens
12 Nov 2025 18:37
Is there any LinuxCNC expereinced user from Warsaw (Poland)
I would venture a guess at some 20 members here being from Poland, so there is always a chance.
Also Proma is from Poland and Tomaszh is here often, lately with new capacitive sensors, and they also do THC and some controllers, see Proma Elektronika (yes, with K )
Now, what exactly do you need help with?
  • Hakan
  • Hakan
12 Nov 2025 18:36
I can guarantee you that there are many users in Poland with that equipment.
But if they are here and see this request is another thing.
  • PCW
  • PCW's Avatar
12 Nov 2025 18:16
connecting 7i96s to 2-wire RS485 using Pktuart
Category: Driver Boards
This is described on page 11 of the 7I96S manual
basically:
RX-/TX- connect to RS-485 "A"
RX+/TX+ connect to RS-485 "B"
W7 right
  • cajbr
  • cajbr
12 Nov 2025 17:58
I have a 7i96s rev E that I'm trying to connect to a WJ200 VFD. The VFD  uses a 2-wire RS485 interface with pins labeled SN and SP.
How should I connect this to the 7i96s i/o pins?  What position should W7 be in?
Thanks,
BR
  • Lcvette
  • Lcvette's Avatar
12 Nov 2025 17:49
Replied by Lcvette on topic Probebasic tool length calculation
Category: QtPyVCP
ok i think i found a bug dealing with pocket in the tool table causing some odd behavior. let me dig into it some and see what is happening.
  • zz912
  • zz912's Avatar
12 Nov 2025 17:33
Replied by zz912 on topic Compile files in /linuxcnc/lib/
Hi Andy,
Sorry for the confusion.
Python files in /linuxcnc/lib/ may not be processed by the "make" command.
Python files in /linuxcnc/src/ may be processed by the "make" command.
I've tested it now.
You were right.
  • kmeld
  • kmeld
12 Nov 2025 17:27
I am wondering if there may be someone experienced with linuxCNC and MESA board based controllers from Warsaw (Poland) (or near Warsaw).
Cris.
  • zoeper
  • zoeper
12 Nov 2025 17:25
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
Thank you Tommylight, I gave up on my previous efforts and installed Mint as you suggested. Upgrading now. Hope this one is less hairy than my last attempt.
Will let you know when it's up and running.
  • bevins
  • bevins's Avatar
12 Nov 2025 17:19
Replied by bevins on topic 7i92 cnc motion controller from aliexpress?
It is cheaper to get the real ones from Mesa.
  • Hakan
  • Hakan
12 Nov 2025 17:17
  • Hakan
  • Hakan
12 Nov 2025 17:14
Ethercat - assinged the same pdos to multiple Slave-Signals?
Category: EtherCAT
From what I can see, the lcec EL1014 driver expects PDOs at 0x6000, 0x6010, 0x6020 and 0x6030. Two of your units have that.
Three of your units have PDOs at 0x3101:1, 0x3101:2, 0x3101:3 and 0x3101:4.
Maybe there is a reason for that? Different versions? I don't know the products very well.
You can use the generic driver for the 0x3101 units.  And for the other units as well.
Run "lcec_configgen -typedb=false" and hopefully you should get the "generic" driver for all devices in the output.
  • Lcvette
  • Lcvette's Avatar
12 Nov 2025 17:11
Category: QtPyVCP
ah are you using the tool setter page to set the spindle zero with the probe spindle zero button?
Displaying 7276 - 7290 out of 16717 results.
Time to create page: 0.541 seconds
