  • Lcvette
  • Lcvette's Avatar
09 Nov 2025 23:00
Replied by Lcvette on topic Probebasic tool length calculation
Category: QtPyVCP
Just remove any current tool length offset.
Kcjengr is correct.
  • PCW
  • PCW's Avatar
09 Nov 2025 22:06
Replied by PCW on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Category: Driver Boards
Does the machine not already have the interpolators built in?
IC Haus makes analog interpolators :
ichauschina.com/en/products/interpolator.htm?productid=2
  • tsaG
  • tsaG
09 Nov 2025 21:58
Replied by tsaG on topic Probebasic tool length calculation
Category: QtPyVCP
Hmm. Strange. Could you remind me on how to change this?
All I did was Start Linux CNC, Power the machine, home it, insert the tool (either via rack ATC or manual) and probe the length.
BTW: In which repo would I commit changes to? I saw that there are two Github repos, but ( I assume its yours) is rather old whereas the changes in kcjengr is only half a year old.
  • frayja2002
  • frayja2002
09 Nov 2025 21:39 - 13 Nov 2025 21:05
Replied by frayja2002 on topic USB pendant stops working after using macros
Category: Qtvcp
I have tried to setup one of the USB buttons to put it back into Man mode but the crash report keeps telling me I have used this before.
Line 65 of the report referring to line 26 of the USB hal.
Sorry. Ignore this post I found the problem.
I'll test some more soon as I get time.
Alex
Later....
Just to finish this off, I added this line to my USB buttons hal file & everything seems to work as expected.
# Go into Manual mode
net man_mode <= halui.mode.manual <= input.0.btn-base2
  • endian
  • endian's Avatar
09 Nov 2025 19:27
Replied by endian on topic scurve trajectory planner
Hello,
Is here any capable gentelman which understands Grotius repo with scurve trajectory planner and can help others with them?
thanks End
  • Masiwood123
  • Masiwood123's Avatar
09 Nov 2025 18:28
Replied by Masiwood123 on topic beta bulleri for retrofit?
Category: CNC Machines
  • andrax
  • andrax's Avatar
09 Nov 2025 18:06
Replied by andrax on topic Ethercat auto configurator.
Category: EtherCAT
I have the same problem.
First, it couldn't find common.h. Then I added the file from ethercat-master source.
Now I get the error
-- Generating done
CMake Generate step failed.  Build files cannot be regenerated correctly.
Now I'm wondering, is this the right way to go, or does this project have to be used?
skynet/realtime_app - Codeberg.org
  • zz912
  • zz912's Avatar
09 Nov 2025 17:18
Compile files in /linuxcnc/lib/ was created by zz912
Hello,
I use RIP installation.
If I debug files in the /linuxcnc/src folder, I just need to be in the /linuxcnc/src folder and type $ make. Then only what I edited is compiled.
If I debug files in the /linuxcnc/lib folder, I am in the /linuxcnc/src folder and type $ make, nothing happens.
I have to type $ make -B, but it takes a long time.
How should I debug the file:
/linuxcnc/lib/python/gladevcp/builtin-panels/gtk_little_probe/gtk_little_probe.py
  • deltafox24
  • deltafox24
09 Nov 2025 16:23
Replied by deltafox24 on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
When I load the tool, I see it rotating in the simulation, but all movement is drawn in only one plane. As I showed earlier
  • clayton2ndtry
  • clayton2ndtry
09 Nov 2025 16:19
wifi adapters was created by clayton2ndtry
wifi adapters
Because I am using an antique desktop (Dell Optiplex 960) and WiFi, I am stranded at linuxCNC 2.7.15.  I have struggled to get decent network speed.  Only some USB WiFi adapters work native to 2.7.15.  (Trying to install drivers for adapters with other chipsets was more effort than it was worth.)  The SMC EZ Connect works, but it is only 802.11g and because there is a range and refrigerator in line of WiFi to router, I was limited to about 16 Mbps.
I decided to take a walk on the wild side and bought a BrosTrend Linux USB WiFi Adapter AC1200 for Ubuntu Kali Mint Debian Kubuntu Mate Zorin PureOS Raspberry Pi Windows etc. Linux Compatible WiFi Adapter Wireless Dual Band 5GHz 867Mbps + 2.4GHz 300Mbps.  Once I followed the instructions at linux.brostrend.com/ I was able to install the drivers for what is apparently the AC1L family and now I get 240 Mbps. Customer support was necessary to figure out which driver family was required during driver installation.   Curiously, plugging the adapter into the front USB ports gave me many times the rate as rear USB ports.
  • Masiwood123
09 Nov 2025 15:19
I found encoder signals and attached z encoder linuxcnc reads nice with encoder scale -400, ballscrew is 5mm per revolution and encoders are 500 lines. now I have to connect the others and find a way to enable the drivers because they are all in the box, not each one individually.
09 Nov 2025 12:22
Replied by tommylight on topic Replacement for RPI5
Sorry, forgot the link, added on the first post.
  • axemas
  • axemas's Avatar
09 Nov 2025 12:09 - 10 Nov 2025 14:17
  • zoeper
  • zoeper
09 Nov 2025 11:54
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
I also have the wiring diagram and pinouts for the two ribbon cable connectors from the control to the electrical cabinet.
  • zoeper
  • zoeper
09 Nov 2025 11:46
This is the original sales brochure for the machine.
Displaying 7396 - 7410 out of 16716 results.
Time to create page: 0.478 seconds
