  • jcbryant
  • jcbryant
25 Sep 2025 13:52
Going from Devian 10 to 12 has created problems
"As I said 2 cores may not be enough anymore"
Why does Microsoft come to mind here? Doubtless the folks at Debian would say that Bookworm is an improvement on Buster, but I'd question how a system that may require more advanced hardware to do exactly the same job can be called an "improvement". I'm quite happy with my little industrial PC. It's a perfect fit for my workshop environment (small, fanless) and experience has proved that it is quite capable of running Linux CNC. So to my mind the problem is not my PC but Bookworm, and if all else fails I'm going to simply revert to the Linux 2.8.2 Buster distribution and accept that my system will have to stand pat as the Debian world moves on. End of rant.
25 Sep 2025 12:57
Replied by tommylight on topic 5-Axis CNC Setup with LinuxCNC + Mesa Boards
1. yes
2. no
3. wire the power to Mesa, wire step and dir pins from Mesa to drives.
That part is very simple, so start with that and we will help with whatever comes next.
  • rodw
  • rodw's Avatar
  • rodw
  • rodw's Avatar
25 Sep 2025 11:36
Recommendations for a dual NIC SBC or mini-pc
Category: EtherCAT
there are a few Intel N100 PC's put there with multi Intel NIC included. Some also have rs485 with terminal input. I would go with that in preference to the Odroid to get away from the realtek card.
  • Hakan
  • Hakan
25 Sep 2025 11:35
Surely you can have that document as an attachment?
  • Ahmed.emara
  • Ahmed.emara
25 Sep 2025 11:08
Inquiry: Leadshine R3EC EtherCAT coupler + R3-0808-N digital I/O – XML
Category: EtherCAT
Hello everyone,I’m working on a LinuxCNC + EtherCAT setup and I’d like to ask if anyone has experience using the Leadshine R3EC EtherCAT coupler together with the R3-0808-N expansion module (8 digital inputs + 8 digital outputs).if so can please anyone share the XML configuration file with me ?
  • csreades
  • csreades
25 Sep 2025 11:00 - 25 Sep 2025 11:02
Replied by csreades on topic Recommendations for a dual NIC SBC or mini-pc
Category: EtherCAT
I have been testing LCNC on the pi with the nvme hat and PoE, until I realised that the integral RJ45 will be for the ethercat network and wont have PoE!! A bit of a misstep there. In a raspi environment the waveshare addon does complain about limited current availability and the shutdown of peripherals.
Less keen on the Rpi5 now because I realised it has integral wifi, my intention is for a product and adding wifi means I have to satify requirements of RED, so I even more so am interested in alternatives. The Odroid is looking more promising!
  • rodw
  • rodw's Avatar
25 Sep 2025 10:01
You should apt remove r8168 driver or it will take that one.
Best to check though, I might not remember this right.
No keep it. It is the correct driver for the R8111
Ref: packages.debian.org/trixie/r8168-dkms
Never remove the driver, always purge it as mentioned on that link
  • ozntyr
  • ozntyr
25 Sep 2025 09:04
Hi everyone,I’ve been working on a CNC project for a while and I’d like some advice before committing to hardware. Here’s my situation:
  • I originally built a 3-axis CNC router running on GRBL (ESP32) + a custom PCB. I used that setup for a long time and gained good experience with it.
  • Later, I decided to upgrade to 5-axis by adding A and C axes to the same GRBL-based system. While it functions, I quickly discovered a limitation: ESP32 GRBL doesn’t support TCP, so the machine can’t act as a proper 5-axis system.
  • Because of this, I started looking into LinuxCNC. At first I wanted to use my Raspberry Pi 5, but I read that the Pi version of LinuxCNC can’t really handle full 5-axis control.
  • I then tried installing LinuxCNC on an old laptop, but since it has no parallel port, I searched for hardware solutions that use Ethernet. That’s how I found Mesa boards.
From what I’ve gathered so far:
  • The 7i76 series supports 5 axes and spindle control, but its encoder inputs are only for the spindle, not for axes.
  • The 7i95 series seems more suitable because it supports encoder inputs for the axes as well. My thinking was that even though steppers usually work fine, it would be good to have encoder feedback to check for missed steps.
Where I’m at now:
  • When testing LinuxCNC setup, I couldn’t find any 7i95 options in PNCconf, which left me confused.
  • My current hardware: 2.2 Nm NEMA 23 steppers with DM556 drivers on all axes (6 motors total, since Y has dual rails).
  • I don’t have encoders yet, I was waiting to see which types are actually supported by the mesa boards.
  • As another option, I do have a couple of 400 W Delta B3 servos, but not enough to equip all axes. I’ve considered using them if steppers turn out too weak, but that would mean buying more servos.
  • My main goal with encoders is simply to check for missed steps on the steppers.
My questions to the community:
  1. Am I on the right track with the 7i95 + LinuxCNC setup for a 5-axis machine with encoder feedback?
  2. Would you recommend a different Mesa board or configuration for this?
  3. Are there any guides/resources for setting up a 4+ axis machine with Mesa boards and LinuxCNC?
Thanks in advance for any advice!Ozan T.
  • Hakan
  • Hakan
25 Sep 2025 08:53
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
After reading Note under the table, you can set "sync0Shift=700000" in ethercat.xml
  • Hakan
  • Hakan
25 Sep 2025 08:44
Category: EtherCAT
It's from the ethercat manual, I put a link there a post ago.
This is unique for this servo
You have a 1 ms cycle time in axis.ini. According to the manual you have it set to 2 ms. Change that with
ethercat download 0x60c2 1 1
and check the value again with ethercat upload.
The error comes from the drive, it thinks the config is wrong.
The only thing to do is to follow the manual.
One thing I can think of is that it doesn't like variable PDOS.
But there aren't any complains about that.
You can as a next step test to define the receive and transmit PDOS
as on page 9 and 10. Include all pdo entries even the ones you don't use.
  • Hakan
  • Hakan
25 Sep 2025 08:29
  • andypugh
  • andypugh's Avatar
25 Sep 2025 02:12
LCNC 2.9.5 - How to jog with a wireless xbox bt controller
Category: Basic Configuration
We should probably add that Wiki page to the main docs.
Sadly I have no solutions for the problem when the gamepad disconnects. I used to use a hard-wired one and the same problem existed.
It might be possible to fix it in the driver, but doing that isn't on my personal list of "must fix" items.
However, feel free to raise an issue so we don't forget about it.
github.com/LinuxCNC/linuxcnc/issues
  • andypugh
  • andypugh's Avatar
25 Sep 2025 02:12
  • bentiggin
  • bentiggin
25 Sep 2025 01:40
Replied by bentiggin on topic Hypertherm hsd130 interface
Category: Plasma & Laser
Here's the old interface to the d15 connector.
J3 goes to torch- which is the bottom right of the other pic.
4 on the bottom right of the break out is 1:10 divided arc.
5 on bottom right of break out is 1:25.
They were never wired up.
Displaying 9571 - 9585 out of 17018 results.
Time to create page: 0.381 seconds
