  • PCW
  • PCW's Avatar
21 Jun 2025 22:25
Modbus connection issue mesa 7i76eu pktUART
The OP may need to update LinuxCNC to the latest 2.9.4 or 2.10
I'm not an expert in this as I usually use a built from source RIP installation
  • cakeslob
  • cakeslob
21 Jun 2025 22:24
Hey tux, Im getting the feeling of deja vu. Didnt we go over this a few years ago? Its been explained both times, that this is how LINUXCNC does the threading, not just remora. You are also not the only person doing threading with the EC500, Remora, or LinuxCNC. Are you sure you have the encoders setup correctly? Ive seen you mention several times you dont know how to set up the index. Maybe it would be helpful to post your ini/hal/config.txt?
You shouldnt take it personally if we dont understand the issue you are having. If you dont like the way we conduct our selves, you are free to fork the project. This way, you do not need to feel like you are at the mercy of the author. No one needs to throw a tantrum, you can point out the issue, and if it is not addressed in a way acceptable to you, make a fork, and correct the issue and move on with your day. We appreciate your input on the issue, but dont take it personally if the issue isnt addressed in the way you want.
But you appear to be unsatisfied with every single one of the remora projects, and every opensource cnc project in general. Maybe the Remora project needs to learn by example. Feel free to fork the projects and show us how it should be managed.
I look forward to testing out your new project thought. All the best, and I assume the documentation and instructions will clear and not misleading. I have faith you will retain interest for more than 1 month before moving on.
  • TheTinkeringMechanic1
21 Jun 2025 22:19
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
Category: Basic Configuration
I need to locate my thumb drive. I have a few pics for now.
21 Jun 2025 21:11
Replied by tommylight on topic Modbus connection issue mesa 7i76eu pktUART
man hm2_modbus
man mesambccc
You forgot "man"
  • aDm1N
  • aDm1N's Avatar
21 Jun 2025 20:47
Replied by aDm1N on topic Modbus T3D Servo Treiber
Category: Deutsch
Was hätte ich damit Gewonnen? Ich könnte ggf die Drehzahl regeln, in dem ich den Wert ändere, je dach Bearbeitung bei einer Drehmaschine (Planen) sind das viele Änderungen die Geschrieben werden müssen. Ich möchte aber ja den normalen modbus, der auch in der Anleitung beschrieben ist, damit ich auch sagen kann, das die Achse auf 60 grad Drehen soll.
  • Johnnysacalu
  • Johnnysacalu
21 Jun 2025 20:33 - 21 Jun 2025 20:34
Como conectar mesa 7i96s was created by Johnnysacalu
Category: Driver Boards
Hola tengo varias dudas.
mesa 7i96s, thcad 2, plasma stamos 125h cnc, linux cnc, qtplasmac.
El plasma tiene 2 pines que ivan al gatillo de la antorcha y otros 2 que son el arc volt.
Pa primera duda es si puedo usar los pinos del gatillo para encender antorcha ( por lo que e visto por el foro si con un rele de estado sólido ) lo medí i salen 10v mi duda es como tengo que cablearlo. ¿E visto estos reles podrían valer?
La segunda es que no me sale la configuración del thcad en pncconf pero e visto algunas personas que lo tienen.
Y tercera cual es la manera adecuada para la conexión a tierra tengo cables blindados.
Puedo mandar fotos de lo que tengo si es necesario
Gracias soy muy nuevo
  • clayton2ndtry
  • clayton2ndtry
21 Jun 2025 20:06 - 22 Jun 2025 19:38
crashing at startup was created by clayton2ndtry
crashing at startup
It has worked perfectly for years.  Suddenly, shortly after GUI appears:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.15
Machine configuration directory is '/home/clayton/linuxcnc/configs/by_machine.sherline.Sherline4Axis'
Machine configuration file is 'Sherline4Axis_inch.ini'
INIFILE=/home/clayton/linuxcnc/configs/by_machine.sherline.Sherline4Axis/Sherline4Axis_inch.ini
PARAMETER_FILE=stepper.var
TASK=milltask
HALUI=
DISPLAY=mini
Starting LinuxCNC...
Found file(REL): ./stepper_xyza.hal
Found file(REL): ./standard_pinout.hal
Starting DISPLAY program: mini
Can't issue MDI command when not homed
can't open none
task: 7606 cycles, min=0.000011, max=0.072272, avg=0.010010, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
unable to realloc 2147381251 bytes
/usr/bin/linuxcnc: line 864: 20362 Aborted                 $LINUXCNC_TCL_DIR/$EMCDISPLAY.tcl -ini "$INIFILE" $EMCDISPLAYARGS
20317
20359
Stopping realtime threads
Unloading hal components
Kernel message information:
981] R8188EU: INFO indicate disassoc
[2037195.674251] R8188EU: INFO assoc success
[2037216.650871] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037216.658495] R8188EU: INFO indicate disassoc
[2037217.965893] R8188EU: INFO assoc success
[2037237.673242] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037237.680495] R8188EU: INFO indicate disassoc
[2037238.959023] R8188EU: INFO assoc success
[2037259.286369] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037259.299382] R8188EU: INFO indicate disassoc
[2037261.051633] R8188EU: INFO assoc success
[2037281.514753] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037281.522003] R8188EU: INFO indicate disassoc
[2037282.863403] R8188EU: INFO assoc success
[2037303.118753] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037303.127513] R8188EU: INFO indicate disassoc
[2037304.465029] R8188EU: INFO assoc success
[2037324.211525] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037324.218762] R8188EU: INFO indicate disassoc
[2037325.569025] R8188EU: INFO assoc success
[2037481.453793] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037481.461051] R8188EU: INFO indicate disassoc
[2037482.747678] R8188EU: INFO assoc success
[2037486.599543] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037486.606793] R8188EU: INFO indicate disassoc
[2037488.285436] R8188EU: INFO assoc success
[2037488.839790] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037488.847055] R8188EU: INFO indicate disassoc
[2037490.341934] R8188EU: INFO assoc success
[2037492.672302] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037492.679552] R8188EU: INFO indicate disassoc
[2037494.049432] R8188EU: INFO assoc success
[2037495.823808] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037495.831053] R8188EU: INFO indicate disassoc
[2037497.609186] R8188EU: INFO assoc success
[2037499.408424] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037499.415684] R8188EU: INFO indicate disassoc
[2037503.440811] R8188EU: INFO assoc success
[2037505.352932] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037505.360185] R8188EU: INFO indicate disassoc
[2037507.226435] R8188EU: INFO assoc success
[2037508.301927] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037508.309192] R8188EU: INFO indicate disassoc
[2037509.773440] R8188EU: INFO assoc success
[2037510.785928] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037510.793179] R8188EU: INFO indicate disassoc
[2037512.167564] R8188EU: INFO assoc success
[2037513.764050] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037513.771306] R8188EU: INFO indicate disassoc
[2037515.106565] R8188EU: INFO assoc success
[2037515.870303] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037515.877554] R8188EU: INFO indicate disassoc
[2037518.764188] R8188EU: INFO assoc success
[2037520.350687] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037520.357942] R8188EU: INFO indicate disassoc
[2037522.103439] R8188EU: INFO assoc success
[2037525.624434] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037525.631683] R8188EU: INFO indicate disassoc
[2037526.975199] R8188EU: INFO assoc success
[2037530.658436] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037530.665814] R8188EU: INFO indicate disassoc
[2037532.113444] R8188EU: INFO assoc success
[2037532.914307] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037532.921557] R8188EU: INFO indicate disassoc
[2037534.277066] R8188EU: INFO assoc success
[2037535.566679] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037535.573936] R8188EU: INFO indicate disassoc
[2037536.894572] R8188EU: INFO assoc success
[2037538.068805] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037538.076058] R8188EU: INFO indicate disassoc
[2037539.371459] R8188EU: INFO assoc success
[2037539.929942] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037539.937307] R8188EU: INFO indicate disassoc
[2037541.410821] R8188EU: INFO assoc success
[2037542.533439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037542.540688] R8188EU: INFO indicate disassoc
[2037543.890824] R8188EU: INFO assoc success
[2037544.517684] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037544.524937] R8188EU: INFO indicate disassoc
[2037546.208949] R8188EU: INFO assoc success
[2037547.293806] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037547.301187] R8188EU: INFO indicate disassoc
[2037548.703079] R8188EU: INFO assoc success
[2037549.173685] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037549.180934] R8188EU: INFO indicate disassoc
[2037550.507466] R8188EU: INFO assoc success
[2037551.055944] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037551.063313] R8188EU: INFO indicate disassoc
[2037552.415572] R8188EU: INFO assoc success
[2037552.868439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037552.875812] R8188EU: INFO indicate disassoc
[2037554.309571] R8188EU: INFO assoc success
[2037555.707444] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037555.714688] R8188EU: INFO indicate disassoc
[2037557.003952] R8188EU: INFO assoc success
[2037557.490188] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037557.497444] R8188EU: INFO indicate disassoc
[2037559.107967] R8188EU: INFO assoc success
[2037559.816066] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037559.823312] R8188EU: INFO indicate disassoc
[2037561.288706] R8188EU: INFO assoc success
[2037562.202068] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037562.209318] R8188EU: INFO indicate disassoc
[2037564.134696] R8188EU: INFO assoc success
[2037564.734940] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037564.742574] R8188EU: INFO indicate disassoc
[2037566.021952] R8188EU: INFO assoc success
[2037566.655322] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037566.662567] R8188EU: INFO indicate disassoc
[2037567.963454] R8188EU: INFO assoc success
[2037568.614564] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037568.621823] R8188EU: INFO indicate disassoc
[2037569.887451] R8188EU: INFO assoc success
[2037570.505059] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037570.512320] R8188EU: INFO indicate disassoc
[2037572.419074] R8188EU: INFO assoc success
[2037573.150441] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037573.157813] R8188EU: INFO indicate disassoc
[2037574.501078] R8188EU: INFO assoc success
[2037575.078696] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037575.085950] R8188EU: INFO indicate disassoc
[2037576.341450] R8188EU: INFO assoc success
[2037576.829192] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037576.836446] R8188EU: INFO indicate disassoc
[2037578.192581] R8188EU: INFO assoc success
[2037579.057318] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037579.064571] R8188EU: INFO indicate disassoc
[2037580.352457] R8188EU: INFO assoc success
[2037580.861936] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037580.869187] R8188EU: INFO indicate disassoc
[2037585.340579] R8188EU: INFO assoc success
[2037588.294445] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037588.301691] R8188EU: INFO indicate disassoc
[2037589.671702] R8188EU: INFO assoc success
[2037592.154193] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037592.161573] R8188EU: INFO indicate disassoc
[2037595.170708] R8188EU: INFO assoc success
[2037599.313070] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037599.320324] R8188EU: INFO indicate disassoc
[2037600.917085] R8188EU: INFO assoc success
[2037602.118949] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037602.126201] R8188EU: INFO indicate disassoc
[2037603.483086] R8188EU: INFO assoc success
[2037604.889067] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037604.896319] R8188EU: INFO indicate disassoc
[2037606.257453] R8188EU: INFO assoc success
[2037607.880322] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037607.887578] R8188EU: INFO indicate disassoc
[2037609.230458] R8188EU: INFO assoc success
[2037610.300831] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037610.308076] R8188EU: INFO indicate disassoc
[2037611.631457] R8188EU: INFO assoc success
[2037612.325573] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037612.332827] R8188EU: INFO indicate disassoc
[2037613.635706] R8188EU: INFO assoc success
[2037614.746472] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037614.753835] R8188EU: INFO indicate disassoc
[2037616.561458] R8188EU: INFO assoc success
[2037617.295945] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037617.303192] R8188EU: INFO indicate disassoc
[2037618.631839] R8188EU: INFO assoc success
[2037619.391825] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037619.399078] R8188EU: INFO indicate disassoc
[2037622.935585] R8188EU: INFO assoc success
[2037625.192328] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037625.199582] R8188EU: INFO indicate disassoc
[2037626.617717] R8188EU: INFO assoc success
[2037627.346202] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037627.353449] R8188EU: INFO indicate disassoc
[2037632.633096] R8188EU: INFO assoc success
[2037634.023956] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037634.031597] R8188EU: INFO indicate disassoc
[2037635.320462] R8188EU: INFO assoc success
[2037637.154828] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037637.162085] R8188EU: INFO indicate disassoc
[2037638.491715] R8188EU: INFO assoc success
[2037640.046205] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037640.053459] R8188EU: INFO indicate disassoc
[2037641.633470] R8188EU: INFO assoc success
[2037643.708327] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037643.715582] R8188EU: INFO indicate disassoc
[2037645.057464] R8188EU: INFO assoc success
[2037646.447591] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037646.454843] R8188EU: INFO indicate disassoc
[2037653.684032] R8188EU: INFO indicate disassoc
[2037660.306717] R8188EU: INFO assoc success
[2037667.461461] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037667.468714] R8188EU: INFO indicate disassoc
[2037668.848851] R8188EU: INFO assoc success
[2037672.852214] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037672.859466] R8188EU: INFO indicate disassoc
[2037674.145595] R8188EU: INFO assoc success
[2037677.162838] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037677.170091] R8188EU: INFO indicate disassoc
[2037678.430095] R8188EU: INFO assoc success
[2037686.090851] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037686.098093] R8188EU: INFO indicate disassoc
[2037687.549234] R8188EU: INFO assoc success
[2037700.020963] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037700.028218] R8188EU: INFO indicate disassoc
[2037702.920480] R8188EU: INFO assoc success
[2037710.148594] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037710.155848] R8188EU: INFO indicate disassoc
[2037711.501854] R8188EU: INFO assoc success
[2037726.638225] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037726.645478] R8188EU: INFO indicate disassoc
[2037732.777367] R8188EU: INFO assoc success
[2037735.874602] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037735.881859] R8188EU: INFO indicate disassoc
[2037737.209492] R8188EU: INFO assoc success
[2037747.828729] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037747.843359] R8188EU: INFO indicate disassoc
[2037749.589613] R8188EU: INFO assoc success
[2037770.007236] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037770.014490] R8188EU: INFO indicate disassoc
[2037771.339995] R8188EU: INFO assoc success
[2037784.805745] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037784.812985] R8188EU: INFO indicate disassoc
[2037786.337257] R8188EU: INFO assoc success
[2037790.396490] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037790.403748] R8188EU: INFO indicate disassoc
[2037791.697254] R8188EU: INFO assoc success
[2037794.138614] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037794.145866] R8188EU: INFO indicate disassoc
[2037795.491625] R8188EU: INFO assoc success
[2037806.263371] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037806.270620] R8188EU: INFO indicate disassoc
[2037807.571125] R8188EU: INFO assoc success
[2037875.827257] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037875.834511] R8188EU: INFO indicate disassoc
[2037877.184266] R8188EU: INFO assoc success
[2037893.272514] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037893.279894] R8188EU: INFO indicate disassoc
[2037895.093400] R8188EU: INFO assoc success
[2037898.585390] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037898.593398] R8188EU: INFO indicate disassoc
[2037900.022901] R8188EU: INFO assoc success
[2037913.111271] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037913.118521] R8188EU: INFO indicate disassoc
[2037914.465527] R8188EU: INFO assoc success
[2037965.118907] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037965.126155] R8188EU: INFO indicate disassoc
[2037966.381916] R8188EU: INFO assoc success
[2037969.816779] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037969.824041] R8188EU: INFO indicate disassoc
[2037971.208162] R8188EU: INFO assoc success
[2037992.844669] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037992.851912] R8188EU: INFO indicate disassoc
[2037994.254419] R8188EU: INFO assoc success
[2038014.451664] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038014.458917] R8188EU: INFO indicate disassoc
[2038015.849298] R8188EU: INFO assoc success
[2038036.302673] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038036.309922] R8188EU: INFO indicate disassoc
[2038037.694677] R8188EU: INFO assoc success
[2038055.742295] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038055.749676] R8188EU: INFO indicate disassoc
[2038057.727438] R8188EU: INFO assoc success
[2038059.903943] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038059.911191] R8188EU: INFO indicate disassoc
[2038061.812939] R8188EU: INFO assoc success
[2038084.610178] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038084.617432] R8188EU: INFO indicate disassoc
[2038085.887321] R8188EU: INFO assoc success
[2038095.260557] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038095.267809] R8188EU: INFO indicate disassoc
[2038096.542185] R8188EU: INFO assoc success
[2038100.374060] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038100.381315] R8188EU: INFO indicate disassoc
[2038101.874072] R8188EU: INFO assoc success
[2038115.748435] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038115.755689] R8188EU: INFO indicate disassoc
[2038119.351700] R8188EU: INFO assoc success
[2038209.748458] R8188EU: INFO sta recv deauth reason code(7) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2038209.760712] R8188EU: INFO indicate disassoc
[2038211.112468] R8188EU: INFO assoc success
[2038231.669715] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038231.676971] R8188EU: INFO indicate disassoc
[2038233.018095] R8188EU: INFO assoc success
[2038313.378854] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038313.386104] R8188EU: INFO indicate disassoc
[2038314.646363] R8188EU: INFO assoc success
[2038316.769107] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038316.776365] R8188EU: INFO indicate disassoc
[2038318.706115] R8188EU: INFO assoc success
[2038319.577236] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038319.584484] R8188EU: INFO indicate disassoc
[2038320.885368] R8188EU: INFO assoc success
[2038325.595859] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038325.603111] R8188EU: INFO indicate disassoc
[2038327.031871] R8188EU: INFO assoc success
[2038333.775121] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038333.782368] R8188EU: INFO indicate disassoc
[2038335.244748] R8188EU: INFO assoc success
[2038337.228614] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038337.235870] R8188EU: INFO indicate disassoc
[2038338.515872] R8188EU: INFO assoc success
[2038341.324360] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038341.331616] R8188EU: INFO indicate disassoc
[2038343.002625] R8188EU: INFO assoc success
[2038358.403370] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038358.410618] R8188EU: INFO indicate disassoc
[2038359.713629] R8188EU: INFO assoc success
[2038364.458615] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038364.465870] R8188EU: INFO indicate disassoc
[2038365.739129] R8188EU: INFO assoc success
[2038374.598872] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038374.606121] R8188EU: INFO indicate disassoc
[2038376.064625] R8188EU: INFO assoc success
[2038393.322246] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038393.329502] R8188EU: INFO indicate disassoc
[2038394.615377] R8188EU: INFO assoc success
[2038401.888748] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038401.896003] R8188EU: INFO indicate disassoc
[2038403.213514] R8188EU: INFO assoc success
[2038415.776750] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038415.784005] R8188EU: INFO indicate disassoc
[2038419.284887] R8188EU: INFO assoc success
[2038425.926004] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038425.933264] R8188EU: INFO indicate disassoc
[2038427.386767] R8188EU: INFO assoc success
[2038436.161383] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038436.168635] R8188EU: INFO indicate disassoc
[2038443.392049] R8188EU: INFO indicate disassoc
[2038450.894017] R8188EU: INFO assoc success
[2038450.907005] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038450.914260] R8188EU: INFO indicate disassoc
[2038454.195395] R8188EU: INFO assoc success
[2038456.608765] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038456.616022] R8188EU: INFO indicate disassoc
[2038458.300903] R8188EU: INFO assoc success
[2038458.311515] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038458.319637] R8188EU: INFO indicate disassoc
[2038461.563396] R8188EU: INFO assoc success
[2038461.573886] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:39:c4:e6
[2038461.582269] R8188EU: INFO indicate disassoc
[2038463.202028] R8188EU: INFO assoc success
[2038463.216513] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038463.223774] R8188EU: INFO indicate disassoc
[2038471.597646] R8188EU: INFO assoc success
[2038471.609138] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038471.616521] R8188EU: INFO indicate disassoc
[2038473.648899] R8188EU: INFO assoc success
[2038473.662518] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038473.669767] R8188EU: INFO indicate disassoc
[2038475.001773] R8188EU: INFO assoc success
[2038475.014018] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038475.021266] R8188EU: INFO indicate disassoc
[2038477.212027] R8188EU: INFO assoc success
[2038477.227014] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038477.234268] R8188EU: INFO indicate disassoc
[2038479.769788] R8188EU: INFO assoc success
[2038479.774391] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038479.787895] R8188EU: INFO indicate disassoc
[2038481.935526] R8188EU: INFO assoc success
[2038481.946768] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038481.954394] R8188EU: INFO indicate disassoc
[2038483.889903] R8188EU: INFO assoc success
[2038483.900272] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038483.908894] R8188EU: INFO indicate disassoc
[2038491.688900] R8188EU: INFO assoc success
[2038499.912767] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038499.920532] R8188EU: INFO indicate disassoc
[2038501.222029] R8188EU: INFO assoc success
[2038502.232270] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038502.239526] R8188EU: INFO indicate disassoc
[2038503.573911] R8188EU: INFO assoc success
[2038506.395529] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038506.402776] R8188EU: INFO indicate disassoc
[2038507.659535] R8188EU: INFO assoc success
[2038508.785272] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038508.792526] R8188EU: INFO indicate disassoc
[2038510.236412] R8188EU: INFO assoc success
[2038516.550148] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038516.557528] R8188EU: INFO indicate disassoc
[2038518.322538] R8188EU: INFO assoc success
[2038534.150650] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038534.157907] R8188EU: INFO indicate disassoc
[2038536.003415] R8188EU: INFO assoc success
[2038562.148168] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038562.158689] R8188EU: INFO indicate disassoc
[2038563.683418] R8188EU: INFO assoc success
[2038566.493666] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038566.500920] R8188EU: INFO indicate disassoc
[2038567.800681] R8188EU: INFO assoc success
[2038583.332545] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038583.339924] R8188EU: INFO indicate disassoc
[2038590.564023] R8188EU: INFO indicate disassoc
[2038597.270054] R8188EU: INFO assoc success
[2038613.650796] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038613.658051] R8188EU: INFO indicate disassoc
[2038615.010303] R8188EU: INFO assoc success
[2038624.780794] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038624.791427] R8188EU: INFO indicate disassoc
[2038626.152808] R8188EU: INFO assoc success
[2038639.521802] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038639.529055] R8188EU: INFO indicate disassoc
[2038640.987184] R8188EU: INFO assoc success
[2038644.490307] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038644.497556] R8188EU: INFO indicate disassoc
[2038646.200691] R8188EU: INFO assoc success
[2038655.601430] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038655.611440] R8188EU: INFO indicate disassoc
[2038657.975447] R8188EU: INFO assoc success
[2038791.301591] R8188EU: INFO sta recv deauth reason code(2) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2038791.308840] R8188EU: INFO indicate disassoc
[2038792.641970] R8188EU: INFO assoc success
[2038813.385215] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038813.392469] R8188EU: INFO indicate disassoc
[2038821.304474] R8188EU: INFO assoc success
[2039176.300920] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039176.311430] R8188EU: INFO indicate disassoc
[2039182.652557] R8188EU: INFO assoc success
[2039199.013805] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039199.021055] R8188EU: INFO indicate disassoc
[2039200.288314] R8188EU: INFO assoc success
[2039234.459936] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039234.467188] R8188EU: INFO indicate disassoc
[2039235.991319] R8188EU: INFO assoc success
[2039239.304942] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039239.312190] R8188EU: INFO indicate disassoc
[2039240.644070] R8188EU: INFO assoc success
[2039241.133941] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039241.141189] R8188EU: INFO indicate disassoc
[2039242.475191] R8188EU: INFO assoc success
[2039244.690439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039244.697694] R8188EU: INFO indicate disassoc
[2039245.959943] R8188EU: INFO assoc success
[2039246.713815] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039246.721069] R8188EU: INFO indicate disassoc
[2039248.368948] R8188EU: INFO assoc success
[2039249.545189] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039249.552442] R8188EU: INFO indicate disassoc
[2039250.889077] R8188EU: INFO assoc success
[2039252.929571] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039252.936824] R8188EU: INFO indicate disassoc
[2039254.344829] R8188EU: INFO assoc success
[2039254.838065] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039254.845310] R8188EU: INFO indicate disassoc
[2039256.206823] R8188EU: INFO assoc success
[2039258.408324] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039258.415572] R8188EU: INFO indicate disassoc
[2039259.670697] R8188EU: INFO assoc success
[2039260.454820] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039260.462068] R8188EU: INFO indicate disassoc
[2039261.727324] R8188EU: INFO assoc success
[2039264.897439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039264.904693] R8188EU: INFO indicate disassoc
[2039268.088052] R8188EU: INFO indicate disassoc
[2039270.852041] R8188EU: INFO indicate disassoc
[2039272.175072] R8188EU: INFO assoc success
[2039272.184694] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2039272.193694] R8188EU: INFO indicate disassoc
[2039274.998828] R8188EU: INFO assoc success
[2039275.011565] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2039275.018820] R8188EU: INFO indicate disassoc
[2039282.821455] R8188EU: INFO assoc success
[2039289.014080] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039289.021327] R8188EU: INFO indicate disassoc
[2039290.305335] R8188EU: INFO assoc success
[2039291.231703] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039291.238950] R8188EU: INFO indicate disassoc
[2039292.548713] R8188EU: INFO assoc success
[2039293.040577] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039293.047827] R8188EU: INFO indicate disassoc
[2039294.391458] R8188EU: INFO assoc success
[2039295.050572] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039295.057826] R8188EU: INFO indicate disassoc
[2039297.362707] R8188EU: INFO assoc success
[2039297.949075] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039297.956330] R8188EU: INFO indicate disassoc
[2039299.297957] R8188EU: INFO assoc success
[2039300.057826] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039300.065078] R8188EU: INFO indicate disassoc
[2039301.365335] R8188EU: INFO assoc success
[2039303.190826] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039303.198078] R8188EU: INFO indicate disassoc
[2039304.550584] R8188EU: INFO assoc success
[2039305.137199] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039305.144454] R8188EU: INFO indicate disassoc
[2039306.467959] R8188EU: INFO assoc success
[2039307.389199] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039307.396454] R8188EU: INFO indicate disassoc
[2039308.738332] R8188EU: INFO assoc success
[2039310.334577] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039310.341838] R8188EU: INFO indicate disassoc
[2039311.684459] R8188EU: INFO assoc success
[2039313.379453] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039313.386712] R8188EU: INFO indicate disassoc
[2039314.677840] R8188EU: INFO assoc success
[2039315.720703] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039315.727953] R8188EU: INFO indicate disassoc
[2039317.036219] R8188EU: INFO assoc success
[2039318.601839] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039318.609081] R8188EU: INFO indicate disassoc
[2039319.902460] R8188EU: INFO assoc success
[2039321.614954] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039321.622215] R8188EU: INFO indicate disassoc
[2039322.989463] R8188EU: INFO assoc success
[2039323.805335] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039323.812584] R8188EU: INFO indicate disassoc
[2039325.169837] R8188EU: INFO assoc success
[2039326.475097] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039326.482333] R8188EU: INFO indicate disassoc
[2039328.697344] R8188EU: INFO assoc success
[2039331.716337] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039331.723587] R8188EU: INFO indicate disassoc
[2039333.415221] R8188EU: INFO assoc success
[2039335.817458] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039335.824710] R8188EU: INFO indicate disassoc
[2039338.989226] R8188EU: INFO assoc success
[2039341.074090] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039341.081590] R8188EU: INFO indicate disassoc
[2039342.420216] R8188EU: INFO assoc success
[2039345.187840] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039345.195095] R8188EU: INFO indicate disassoc
[2039348.669595] R8188EU: INFO assoc success
[2039350.150710] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039350.157964] R8188EU: INFO indicate disassoc
[2039351.839593] R8188EU: INFO assoc success
[2039355.219083] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039355.227715] R8188EU: INFO indicate disassoc
[2039356.564848] R8188EU: INFO assoc success
[2039358.249973] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039358.257218] R8188EU: INFO indicate disassoc
[2039359.513473] R8188EU: INFO assoc success
[2039359.992588] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039360.000216] R8188EU: INFO indicate disassoc
[2039361.343353] R8188EU: INFO assoc success
[2039362.645719] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039362.652966] R8188EU: INFO indicate disassoc
[2039363.917105] R8188EU: INFO assoc success
[2039365.199334] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039365.206587] R8188EU: INFO indicate disassoc
[2039369.754728] R8188EU: INFO assoc success
[2039370.612091] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039370.619336] R8188EU: INFO indicate disassoc
[2039374.300044] R8188EU: INFO indicate disassoc
[2039376.574103] R8188EU: INFO assoc success
[2039376.585090] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2039376.592968] R8188EU: INFO indicate disassoc
[2039384.412354] R8188EU: INFO assoc success
[2039385.807713] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039385.816225] R8188EU: INFO indicate disassoc
[2039387.173358] R8188EU: INFO assoc success
[2039388.271981] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039388.279226] R8188EU: INFO indicate disassoc
[2039389.619729] R8188EU: INFO assoc success
[2039390.113845] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039390.121100] R8188EU: INFO indicate disassoc
[2039391.444480] R8188EU: INFO assoc success
[2039392.290217] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039392.297469] R8188EU: INFO indicate disassoc
[2039393.620605] R8188EU: INFO assoc success
[2039395.565219] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039395.572469] R8188EU: INFO indicate disassoc
[2039396.899230] R8188EU: INFO assoc success
[2039397.653091] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039397.660344] R8188EU: INFO indicate disassoc
[2039402.297617] R8188EU: INFO assoc success
[2039406.076102] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039406.083355] R8188EU: INFO indicate disassoc
[2039407.340108] R8188EU: INFO assoc success
[2039408.047347] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039408.054612] R8188EU: INFO indicate disassoc
[2039409.412863] R8188EU: INFO assoc success
[2039411.073724] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039411.080973] R8188EU: INFO indicate disassoc
[2039412.388982] R8188EU: INFO assoc success
[2039413.148845] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039413.156096] R8188EU: INFO indicate disassoc
[2039414.500485] R8188EU: INFO assoc success
[2039416.331096] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039416.339605] R8188EU: INFO indicate disassoc
[2039418.292859] R8188EU: INFO assoc success
[2039421.426598] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039421.433849] R8188EU: INFO indicate disassoc
[2039422.696359] R8188EU: INFO assoc success
[2039423.718597] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039423.725852] R8188EU: INFO indicate disassoc
[2039425.061743] R8188EU: INFO assoc success
[2039426.664858] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039426.672108] R8188EU: INFO indicate disassoc
[2039430.982366] R8188EU: INFO assoc success
[2039431.608727] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039431.615982] R8188EU: INFO indicate disassoc
[2039432.933617] R8188EU: INFO assoc success
[2039433.943730] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039433.950983] R8188EU: INFO indicate disassoc
[2039435.290988] R8188EU: INFO assoc success
[2039436.355731] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039436.362975] R8188EU: INFO indicate disassoc
[2039437.648366] R8188EU: INFO assoc success
[2039438.684366] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039438.691609] R8188EU: INFO indicate disassoc
[2039440.009371] R8188EU: INFO assoc success
[2039440.776733] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039440.783984] R8188EU: INFO indicate disassoc
[2039443.508246] R8188EU: INFO assoc success
[2039444.234365] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039444.241616] R8188EU: INFO indicate disassoc
[2039445.549118] R8188EU: INFO assoc success
[2039446.083727] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039446.090983] R8188EU: INFO indicate disassoc
[2039447.367865] R8188EU: INFO assoc success
[2039448.470482] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039448.477731] R8188EU: INFO indicate disassoc
[2039449.753627] R8188EU: INFO assoc success
[2039450.384237] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039450.391482] R8188EU: INFO indicate disassoc
[2039451.678496] R8188EU: INFO assoc success
[2039452.150483] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039452.157737] R8188EU: INFO indicate disassoc
[2039453.414741] R8188EU: INFO assoc success
[2039454.074484] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039454.081738] R8188EU: INFO indicate disassoc
[2039455.371866] R8188EU: INFO assoc success
[2039455.956233] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039455.963482] R8188EU: INFO indicate disassoc
[2039459.334374] R8188EU: INFO assoc success
[2039460.304485] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039460.311862] R8188EU: INFO indicate disassoc
[2039461.608998] R8188EU: INFO assoc success
[2039462.173362] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039462.180614] R8188EU: INFO indicate disassoc
[2039469.412052] R8188EU: INFO indicate disassoc
[2039476.149124] R8188EU: INFO assoc success
[2039478.305116] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039478.312616] R8188EU: INFO indicate disassoc
[2039479.627248] R8188EU: INFO assoc success
[2039481.798862] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039481.806114] R8188EU: INFO indicate disassoc
[2039483.112372] R8188EU: INFO assoc success
[2039483.913992] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039483.925367] R8188EU: INFO indicate disassoc
[2039485.273124] R8188EU: INFO assoc success
[2039486.022611] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039486.029862] R8188EU: INFO indicate disassoc
[2039487.306497] R8188EU: INFO assoc success
[2039487.919736] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039487.926994] R8188EU: INFO indicate disassoc
[2039489.254006] R8188EU: INFO assoc success
[2039490.128743] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039490.135998] R8188EU: INFO indicate disassoc
[2039495.908129] R8188EU: INFO assoc success
[2039505.257596] R8188EU: INFO indicate disassoc
[2039506.381122] R8188EU: INFO indicate disassoc
[2039509.211757] R8188EU: INFO assoc success
[2039509.252744] R8188EU: INFO indicate disassoc
[2039515.268017] R8188EU: INFO indicate disassoc
[2039516.610756] R8188EU: INFO assoc success
[2039525.103638] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039525.110884] R8188EU: INFO indicate disassoc
[2039526.425632] R8188EU: INFO assoc success
[2039527.374628] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039527.381878] R8188EU: INFO indicate disassoc
[2039528.695640] R8188EU: INFO assoc success
[2039533.684876] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039533.692134] R8188EU: INFO indicate disassoc
[2039535.029134] R8188EU: INFO assoc success
[2039537.546129] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039537.553382] R8188EU: INFO indicate disassoc
[2039538.821760] R8188EU: INFO assoc success
[2039544.114252] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039544.121512] R8188EU: INFO indicate disassoc
[2039545.377391] R8188EU: INFO assoc success
[2039550.738255] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039550.745513] R8188EU: INFO indicate disassoc
[2039552.031265] R8188EU: INFO assoc success
[2039557.811389] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039557.818635] R8188EU: INFO indicate disassoc
[2039559.087890] R8188EU: INFO assoc success
[2039569.813385] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039569.820641] R8188EU: INFO indicate disassoc
[2039571.093891] R8188EU: INFO assoc success
[2039572.354511] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039572.361764] R8188EU: INFO indicate disassoc
[2039579.588021] R8188EU: INFO indicate disassoc
[2039586.242144] R8188EU: INFO assoc success
[2039587.281014] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039587.288262] R8188EU: INFO indicate disassoc
[2039588.909152] R8188EU: INFO assoc success
[2039601.026392] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039601.033650] R8188EU: INFO indicate disassoc
[2039602.824273] R8188EU: INFO assoc success
[2039617.649897] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039617.657149] R8188EU: INFO indicate disassoc
[2039619.006532] R8188EU: INFO assoc success
[2039626.451521] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039626.458782] R8188EU: INFO indicate disassoc
[2039627.792399] R8188EU: INFO assoc success
[2039641.812902] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039641.820155] R8188EU: INFO indicate disassoc
[2039643.170287] R8188EU: INFO assoc success
[2039667.181533] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039667.188785] R8188EU: INFO indicate disassoc
[2039668.451668] R8188EU: INFO assoc success
[2039672.469284] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039672.476544] R8188EU: INFO indicate disassoc
[2039673.788041] R8188EU: INFO assoc success
[2039675.526034] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039675.533287] R8188EU: INFO indicate disassoc
[2039676.958298] R8188EU: INFO assoc success
[2039693.337913] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039693.345166] R8188EU: INFO indicate disassoc
[2039694.668045] R8188EU: INFO assoc success
[2039709.180040] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039709.187296] R8188EU: INFO indicate disassoc
[2039710.646801] R8188EU: INFO assoc success
[2039811.290440] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039811.298939] R8188EU: INFO indicate disassoc
[2039813.050097] R8188EU: INFO assoc success
[2039813.600317] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039813.607561] R8188EU: INFO indicate disassoc
[2039815.187067] R8188EU: INFO assoc success
[2039830.422317] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039830.429826] R8188EU: INFO indicate disassoc
[2039832.677845] R8188EU: INFO assoc success
[2039851.821452] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039851.829951] R8188EU: INFO indicate disassoc
[2039853.082841] R8188EU: INFO assoc success
[2039853.608582] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039853.615830] R8188EU: INFO indicate disassoc
[2039854.932241] R8188EU: INFO assoc success
[2039873.280979] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039873.288329] R8188EU: INFO indicate disassoc
[2039874.596730] R8188EU: INFO assoc success
[2039890.120463] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039890.128969] R8188EU: INFO indicate disassoc
[2039892.408103] R8188EU: INFO assoc success
[2039908.347082] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039908.354337] R8188EU: INFO indicate disassoc
[2039909.705476] R8188EU: INFO assoc success
[2039931.070970] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039931.078219] R8188EU: INFO indicate disassoc
[2039932.541994] R8188EU: INFO assoc success
[2039952.382989] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039952.390225] R8188EU: INFO indicate disassoc
[2039953.749985] R8188EU: INFO assoc success
[2039970.605595] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039970.619478] R8188EU: INFO indicate disassoc
[2039972.076365] R8188EU: INFO assoc success
[2040056.214131] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2040056.222754] R8188EU: INFO indicate disassoc
[2040057.573753] R8188EU: INFO assoc success
[2040078.428629] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2040078.435880] R8188EU: INFO indicate disassoc
[2040079.996524] R8188EU: INFO assoc success
[2040099.632513] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2040099.639757] R8188EU: INFO indicate disassoc
[2040101.075886] R8188EU: INFO assoc success
[2040218.346797] R8188EU: INFO sta recv deauth reason code(7) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2040218.347772] R8188EU: INFO sta recv deauth reason code(7) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2040218.354031] R8188EU: INFO indicate disassoc
[2040227.154938] R8188EU: INFO assoc success
[2041218.593384] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041218.600630] R8188EU: INFO indicate disassoc
[2041220.027882] R8188EU: INFO assoc success
[2041234.619629] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041234.626890] R8188EU: INFO indicate disassoc
[2041236.082388] R8188EU: INFO assoc success
[2041256.436884] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041256.444142] R8188EU: INFO indicate disassoc
[2041257.798394] R8188EU: INFO assoc success
[2041278.442886] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041278.450143] R8188EU: INFO indicate disassoc
[2041279.704020] R8188EU: INFO assoc success
[2041300.373777] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041300.381018] R8188EU: INFO indicate disassoc
[2041301.820282] R8188EU: INFO assoc success
[2041322.284778] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041322.292030] R8188EU: INFO indicate disassoc
[2041323.640908] R8188EU: INFO assoc success
[2041343.885654] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2041343.892905] R8188EU: INFO indicate disassoc
[2041345.249287] R8188EU: INFO assoc success
[2041364.966284] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2041364.973539] R8188EU: INFO indicate disassoc
[2041366.247793] R8188EU: INFO assoc success
[2041386.790421] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041386.797674] R8188EU: INFO indicate disassoc
[2041388.347930] R8188EU: INFO assoc success
[2041407.986796] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041407.994041] R8188EU: INFO indicate disassoc
[2041409.367926] R8188EU: INFO assoc success
[2041429.587301] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2041429.594679] R8188EU: INFO indicate disassoc
[2041430.954431] R8188EU: INFO assoc success
[2041450.588054] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041450.595313] R8188EU: INFO indicate disassoc
[2041451.966189] R8188EU: INFO assoc success
[2041472.292811] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041472.300064] R8188EU: INFO indicate disassoc
[2041473.650065] R8188EU: INFO assoc success
[2043018.409152] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043018.416412] R8188EU: INFO indicate disassoc
[2043019.657666] R8188EU: INFO assoc success
[2043023.652036] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043023.659282] R8188EU: INFO indicate disassoc
[2043024.988913] R8188EU: INFO assoc success
[2043045.456034] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043045.463290] R8188EU: INFO indicate disassoc
[2043047.124292] R8188EU: INFO assoc success
[2043067.779798] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043067.787048] R8188EU: INFO indicate disassoc
[2043069.334922] R8188EU: INFO assoc success
[2043088.664548] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043088.671797] R8188EU: INFO indicate disassoc
[2043091.792021] R8188EU: INFO indicate disassoc
[2043094.560037] R8188EU: INFO indicate disassoc
[2043097.324039] R8188EU: INFO indicate disassoc
[2043100.088045] R8188EU: INFO indicate disassoc
[2043109.408032] R8188EU: INFO indicate disassoc
[2043112.172005] R8188EU: INFO indicate disassoc
[2043115.140041] R8188EU: INFO indicate disassoc
[2043117.904033] R8188EU: INFO indicate disassoc
[2043120.668033] R8188EU: INFO indicate disassoc
[2043128.538561] R8188EU: INFO assoc success
[2043134.974069] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043134.981308] R8188EU: INFO indicate disassoc
[2043136.320940] R8188EU: INFO assoc success
[2043137.405678] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043137.412939] R8188EU: INFO indicate disassoc
[2043138.772191] R8188EU: INFO assoc success
[2043142.407935] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043142.415184] R8188EU: INFO indicate disassoc
[2043143.689814] R8188EU: INFO assoc success
[2043170.780063] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043170.787315] R8188EU: INFO indicate disassoc
[2043172.190569] R8188EU: INFO assoc success
[2043186.025445] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043186.033071] R8188EU: INFO indicate disassoc
[2043187.317075] R8188EU: INFO assoc success
[2043192.389815] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043192.397071] R8188EU: INFO indicate disassoc
[2043194.064205] R8188EU: INFO assoc success
[2043208.155693] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043208.162953] R8188EU: INFO indicate disassoc
[2043209.633577] R8188EU: INFO assoc success
[2043226.999946] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043227.007207] R8188EU: INFO indicate disassoc
[2043228.479334] R8188EU: INFO assoc success
[2043242.257205] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043242.264456] R8188EU: INFO indicate disassoc
[2043243.731470] R8188EU: INFO assoc success
[2043248.702956] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043248.710207] R8188EU: INFO indicate disassoc
[2043249.977097] R8188EU: INFO assoc success
[2043268.161337] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043268.168587] R8188EU: INFO indicate disassoc
[2043269.415716] R8188EU: INFO assoc success
[2043283.399336] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043283.406596] R8188EU: INFO indicate disassoc
[2043284.773721] R8188EU: INFO assoc success
[2043297.968594] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043297.975846] R8188EU: INFO indicate disassoc
[2043299.330101] R8188EU: INFO assoc success
[2043314.855594] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043314.862847] R8188EU: INFO indicate disassoc
[2043316.339978] R8188EU: INFO assoc success
[2043336.671350] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043336.678605] R8188EU: INFO indicate disassoc
[2043338.047113] R8188EU: INFO assoc success
[2043358.379112] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043358.386483] R8188EU: INFO indicate disassoc
[2043359.728986] R8188EU: INFO assoc success
[2043380.406616] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043380.413862] R8188EU: INFO indicate disassoc
[2043381.772366] R8188EU: INFO assoc success
[2043402.430616] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043402.437860] R8188EU: INFO indicate disassoc
[2043403.766247] R8188EU: INFO assoc success
[2043424.022250] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043424.030121] R8188EU: INFO indicate disassoc
[2043425.492503] R8188EU: INFO assoc success
[2043449.712376] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043449.719759] R8188EU: INFO indicate disassoc
[2043451.282502] R8188EU: INFO assoc success
[2043471.015623] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043471.031389] R8188EU: INFO indicate disassoc
[2043472.579758] R8188EU: INFO assoc success
[2044818.416307] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2044818.423556] R8188EU: INFO indicate disassoc
[2044820.151943] R8188EU: INFO assoc success
[2044823.748430] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2044823.755682] R8188EU: INFO indicate disassoc
[2044825.083193] R8188EU: INFO assoc success
[2044845.524685] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2044845.531938] R8188EU: INFO indicate disassoc
[2044846.886572] R8188EU: INFO assoc success
[2045280.098155] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2045280.105410] R8188EU: INFO indicate disassoc
[2045281.368669] R8188EU: INFO assoc success
[2045282.730030] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2045282.737283] R8188EU: INFO indicate disassoc
[2045284.040788] R8188EU: INFO assoc success
[2045284.938782] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2045284.946043] R8188EU: INFO indicate disassoc
[2045286.331545] R8188EU: INFO assoc success
[2045346.206442] usb 8-6: USB disconnect, device number 9
[2045346.206703] R8188EU: INFO indicate disassoc
[2045372.136021] usb 8-4: new high-speed USB device number 10 using ehci_hcd
[2045372.268798] usb 8-4: New USB device found, idVendor=083a, idProduct=4505
[2045372.268802] usb 8-4: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2045372.268806] usb 8-4: Product: USB2.0 WLAN
[2045372.268809] usb 8-4: Manufacturer: SMC
[2045372.319910] cfg80211: Calling CRDA to update world regulatory domain
[2045372.390205] cfg80211: World regulatory domain updated:
[2045372.390208] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045372.390211] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045372.390213] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045372.390215] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045372.390217] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045372.390219] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045372.390221] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045372.390223] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045372.390225] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045372.460065] usb 8-4: reset high-speed USB device number 10 using ehci_hcd
[2045372.600981] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[2045372.601154] zd1211rw 8-4:1.0: phy0
[2045372.601341] usbcore: registered new interface driver zd1211rw
[2045372.660275] udevd[30670]: renamed network interface wlan0 to wlan1
[2045372.730553] zd1211rw 8-4:1.0: firmware version 4725
[2045372.770553] zd1211rw 8-4:1.0: zd1211b chip 083a:4505 v4810 high 00-13-f7 AL2230_RF pa0 g--NS
[2045372.772941] cfg80211: Calling CRDA for country: US
[2045372.776711] cfg80211: Regulatory domain changed to country: US
[2045372.776714] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045372.776716] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045372.776718] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045372.776721] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045372.776723] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045372.776725] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045372.776727] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045372.802071] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[2045390.152698] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045390.170944] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045390.372025] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2045390.378809] wlan1: authenticated
[2045390.388020] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045390.401694] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045390.402325] wlan1: associated
[2045390.402458] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[2045390.402510] cfg80211: Calling CRDA for country: US
[2045390.406159] cfg80211: Regulatory domain changed to country: US
[2045390.406162] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045390.406164] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045390.406166] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045390.406168] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045390.406171] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045390.406173] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045390.406176] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045395.525817] wlan1: deauthenticated from e8:d3:eb:2f:64:c6 (Reason: 15)
[2045395.535967] cfg80211: Calling CRDA to update world regulatory domain
[2045395.539772] cfg80211: World regulatory domain updated:
[2045395.539774] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045395.539777] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045395.539779] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045395.539781] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045395.539784] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045395.539786] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045395.539788] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045395.539790] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045395.539792] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045395.708437] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045395.717945] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045395.734559] wlan1: authenticated
[2045395.744054] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045395.775944] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045395.776576] wlan1: associated
[2045395.776729] cfg80211: Calling CRDA for country: US
[2045395.780368] cfg80211: Regulatory domain changed to country: US
[2045395.780371] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045395.780373] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045395.780376] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045395.780378] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045395.780380] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045395.780382] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045395.780384] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045400.924584] wlan1: deauthenticated from e8:d3:eb:39:c4:e6 (Reason: 15)
[2045400.934967] cfg80211: Calling CRDA to update world regulatory domain
[2045400.938755] cfg80211: World regulatory domain updated:
[2045400.938758] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045400.938760] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045400.938763] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045400.938765] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045400.938767] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045400.938769] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045400.938771] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045400.938773] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045400.938775] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045401.748579] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045401.766947] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045401.778200] wlan1: authenticated
[2045401.788040] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045401.815704] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045401.816323] wlan1: associated
[2045401.816451] cfg80211: Calling CRDA for country: US
[2045401.820164] cfg80211: Regulatory domain changed to country: US
[2045401.820167] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045401.820170] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045401.820172] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045401.820174] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045401.820176] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045401.820178] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045401.820186] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045406.940570] wlan1: deauthenticated from e8:d3:eb:2f:64:c6 (Reason: 15)
[2045406.950964] cfg80211: Calling CRDA to update world regulatory domain
[2045406.954887] cfg80211: World regulatory domain updated:
[2045406.954890] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045406.954892] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045406.954894] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045406.954897] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045406.954899] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045406.954901] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045406.954908] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045406.954910] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045406.954913] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045407.124401] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045407.133947] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045407.147066] wlan1: authenticated
[2045407.160028] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045407.176565] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045407.177196] wlan1: associated
[2045407.177345] cfg80211: Calling CRDA for country: US
[2045407.181113] cfg80211: Regulatory domain changed to country: US
[2045407.181115] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045407.181118] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045407.181125] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045407.181127] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045407.181130] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045407.181132] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045407.181134] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045412.294826] wlan1: deauthenticated from e8:d3:eb:39:c4:e6 (Reason: 15)
[2045412.304972] cfg80211: Calling CRDA to update world regulatory domain
[2045412.308647] cfg80211: World regulatory domain updated:
[2045412.308650] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045412.308652] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045412.308654] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045412.308656] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045412.308658] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045412.308661] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045412.308663] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045412.308665] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045412.308668] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045413.116392] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045413.134946] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045413.148069] wlan1: authenticated
[2045413.160042] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045413.178573] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045413.179365] wlan1: associated
[2045413.179476] cfg80211: Calling CRDA for country: US
[2045413.183059] cfg80211: Regulatory domain changed to country: US
[2045413.183062] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045413.183065] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045413.183067] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045413.183069] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045413.183071] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045413.183073] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045413.183075] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045415.002683] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2045415.018154] cfg80211: Calling CRDA to update world regulatory domain
[2045415.021804] cfg80211: World regulatory domain updated:
[2045415.021806] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045415.021809] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045415.021811] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045415.021813] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045415.021815] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045415.021817] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045415.021819] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045415.021821] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045415.021824] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045423.860348] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045423.878957] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045423.893446] wlan1: authenticated
[2045423.904055] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045423.919070] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045423.919878] wlan1: associated
[2045423.919982] cfg80211: Calling CRDA for country: US
[2045423.923603] cfg80211: Regulatory domain changed to country: US
[2045423.923606] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045423.923609] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045423.923611] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045423.923613] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045423.923615] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045423.923617] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045423.923620] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045456.789326] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045456.798959] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045456.817335] wlan1: authenticated
[2045456.828021] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045456.849953] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045456.850588] wlan1: associated
[2045908.175328] usb 8-4: USB disconnect, device number 10
[2045908.175627] wlan1: deauthenticating from e8:d3:eb:39:c4:e6 by local choice (reason=3)
[2045908.176056] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045908.176079] cfg80211: Calling CRDA to update world regulatory domain
[2045908.180116] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045908.184582] cfg80211: World regulatory domain updated:
[2045908.184585] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045908.184587] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045908.184589] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045908.184591] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045908.184594] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045908.184596] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045908.184598] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045908.184600] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045908.184603] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045926.164053] usb 8-4: new high-speed USB device number 11 using ehci_hcd
[2045926.296796] usb 8-4: New USB device found, idVendor=083a, idProduct=4505
[2045926.296805] usb 8-4: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2045926.296807] usb 8-4: Product: USB2.0 WLAN
[2045926.296809] usb 8-4: Manufacturer: SMC
[2045926.412023] usb 8-4: reset high-speed USB device number 11 using ehci_hcd
[2045926.544645] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[2045926.544816] zd1211rw 8-4:1.0: phy1
[2045926.560204] udevd[31029]: renamed network interface wlan0 to wlan1
[2045926.615678] zd1211rw 8-4:1.0: firmware version 4725
[2045926.655676] zd1211rw 8-4:1.0: zd1211b chip 083a:4505 v4810 high 00-13-f7 AL2230_RF pa0 g--NS
[2045926.658064] cfg80211: Calling CRDA for country: US
[2045926.661746] cfg80211: Regulatory domain changed to country: US
[2045926.661749] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045926.661751] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045926.661754] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045926.661756] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045926.661758] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045926.661760] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045926.661762] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045926.688269] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[2045928.152732] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045928.172056] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045928.283181] wlan1: authenticated
[2045928.296011] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045928.334813] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045928.335439] wlan1: associated
[2045928.335567] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[2045928.335618] cfg80211: Calling CRDA for country: US
[2045928.339472] cfg80211: Regulatory domain changed to country: US
[2045928.339475] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045928.339477] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045928.339479] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045928.339482] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045928.339484] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045928.339486] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045928.339488] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045949.257816] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045949.267074] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045949.347690] wlan1: authenticated
[2045949.360024] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045949.369065] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045949.369699] wlan1: associated
[2045974.371714] usb 8-4: USB disconnect, device number 11
[2045974.372015] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2045974.380067] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045974.380096] cfg80211: Calling CRDA to update world regulatory domain
[2045974.384084] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045974.388588] cfg80211: World regulatory domain updated:
[2045974.388591] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045974.388593] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045974.388596] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045974.388598] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045974.388600] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045974.388602] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045974.388604] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045974.388606] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045974.388608] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045980.108026] usb 8-4: new high-speed USB device number 12 using ehci_hcd
[2045980.240806] usb 8-4: New USB device found, idVendor=083a, idProduct=4505
[2045980.240809] usb 8-4: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2045980.240812] usb 8-4: Product: USB2.0 WLAN
[2045980.240814] usb 8-4: Manufacturer: SMC
[2045980.356035] usb 8-4: reset high-speed USB device number 12 using ehci_hcd
[2045980.488660] ieee80211 phy2: Selected rate control algorithm 'minstrel_ht'
[2045980.488858] zd1211rw 8-4:1.0: phy2
[2045980.504195] udevd[31234]: renamed network interface wlan0 to wlan1
[2045980.568683] zd1211rw 8-4:1.0: firmware version 4725
[2045980.608688] zd1211rw 8-4:1.0: zd1211b chip 083a:4505 v4810 high 00-13-f7 AL2230_RF pa0 g--NS
[2045980.611080] cfg80211: Calling CRDA for country: US
[2045980.614754] cfg80211: Regulatory domain changed to country: US
[2045980.614762] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045980.614764] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045980.614766] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045980.614769] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045980.614771] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045980.614773] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045980.614775] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045980.644190] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[2045982.104728] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045982.123077] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045982.207070] wlan1: authenticated
[2045982.220010] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045982.237328] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045982.237952] wlan1: associated
[2045982.238087] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[2045982.238138] cfg80211: Calling CRDA for country: US
[2045982.242047] cfg80211: Regulatory domain changed to country: US
[2045982.242050] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045982.242052] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045982.242054] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045982.242056] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045982.242058] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045982.242061] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045982.242063] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2046156.871602] udevd[3357]: starting version 175
[2046516.359316] RTAI[math]: unloaded.
[2046516.360451] SCHED releases registered named ALIEN PEDV$D
[2046516.364399] RTAI[malloc]: unloaded.
[2046516.464013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[2046516.465358] I-pipe: head domain RTAI unregistered.
[2046516.465390] RTAI[hal]: unmounted.
[2046522.239487] I-pipe: head domain RTAI registered.
[2046522.239491] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[2046522.239519] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[2046522.239522] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[2046522.239524] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[2046522.239527] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 18863000
[2046522.245156] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[2046522.245177] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[2046522.245181] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[2046522.245184] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[2046522.245186] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[2046522.250793] RTAI[math]: loaded.
[2046522.390899] config string '0x0378'
[2046561.294441] RTAI[math]: unloaded.
[2046561.295573] SCHED releases registered named ALIEN PEDV$D
[2046561.298290] RTAI[malloc]: unloaded.
[2046561.396012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[2046561.397370] I-pipe: head domain RTAI unregistered.
[2046561.397398] RTAI[hal]: unmounted.
[2046568.867886] I-pipe: head domain RTAI registered.
[2046568.867890] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[2046568.867913] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[2046568.867916] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[2046568.867918] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[2046568.867921] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 19077750
[2046568.873591] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[2046568.873612] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[2046568.873615] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[2046568.873618] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[2046568.873620] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[2046568.882958] RTAI[math]: loaded.
[2046569.027661] config string '0x0378'
[2111202.044479] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2111202.053602] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2111202.067229] wlan1: authenticated
[2111202.076018] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2111202.094998] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2111202.095592] wlan1: associated
[2111562.029170] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2111562.037684] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2111562.156427] wlan1: authenticated
[2111562.168027] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2111562.197807] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2111562.198549] wlan1: associated
[2114682.044502] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2114682.052360] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2114682.150622] wlan1: authenticated
[2114682.164060] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2114682.182496] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2114682.183130] wlan1: associated
[2114802.032519] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2114802.040283] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2114802.244014] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2114802.327659] wlan1: authenticated
[2114802.340043] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2114802.350025] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2114802.350655] wlan1: associated
[2203362.029874] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2203362.039129] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2203362.055504] wlan1: authenticated
[2203362.064035] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2203362.077126] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2203362.077924] wlan1: associated
[2203482.036390] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2203482.046140] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2203482.118772] wlan1: authenticated
[2203482.132024] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2203482.149406] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2203482.150033] wlan1: associated
[2204322.029968] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2204322.038357] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2204322.112593] wlan1: authenticated
[2204322.124044] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2204322.131851] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2204322.132660] wlan1: associated
[2204922.026227] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2204922.034479] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2204922.115098] wlan1: authenticated
[2204922.128017] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2204922.147349] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2204922.148095] wlan1: associated
[2243204.528026] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2243204.540138] cfg80211: Calling CRDA to update world regulatory domain
[2243204.544258] cfg80211: World regulatory domain updated:
[2243204.544261] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243204.544264] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2243204.544266] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243204.544268] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243204.544270] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243204.544272] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243204.544275] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2243204.544277] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243204.544279] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2243204.712567] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243204.722008] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243204.924023] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 2/3)
[2243205.128027] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 3/3)
[2243205.332045] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243206.144582] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243206.163010] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243206.364021] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243206.568052] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243206.772036] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243206.944397] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243206.954010] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243207.156055] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243207.360043] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243207.564034] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243208.380584] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243208.398897] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243208.600038] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243208.804018] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243209.008051] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243209.820375] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243209.840015] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243210.044029] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243210.248016] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243210.452018] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243210.628377] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243210.638008] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243210.840013] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243211.044009] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243211.248060] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243212.064437] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243212.082001] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243212.284052] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243212.488029] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243212.692040] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243212.872422] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243212.882002] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243213.084046] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243213.288013] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243213.492056] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243214.312441] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243214.331001] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243214.532057] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243214.736037] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243214.940044] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243220.832614] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243220.851022] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243221.019509] wlan1: authenticated
[2243221.032024] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2243221.236058] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2243221.440045] wlan1: associate with e8:d3:eb:2f:64:c6 (try 3/3)
[2243221.644033] wlan1: association with e8:d3:eb:2f:64:c6 timed out
[2243221.820517] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243221.850010] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243222.052023] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243222.256057] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243222.460042] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243223.276567] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243223.295011] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243223.496015] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243223.700037] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243223.904031] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243224.076373] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243224.085012] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243224.288056] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243224.492018] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243224.696011] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243225.512508] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243225.531024] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243225.732033] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243225.936018] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243226.140015] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243226.316370] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243226.326018] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243226.528028] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 2/3)
[2243226.732019] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 3/3)
[2243226.936008] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243227.752594] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243227.771017] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243227.972022] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243228.176036] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243228.380041] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243228.556455] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243228.566019] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243228.768046] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243228.854383] wlan1: authenticated
[2243228.868043] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2243228.876260] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2243228.876874] wlan1: associated
[2243228.877019] cfg80211: Calling CRDA for country: US
[2243228.880965] cfg80211: Regulatory domain changed to country: US
[2243228.880968] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243228.880970] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2243228.880972] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243228.880975] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243228.880977] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2243228.880979] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2243228.880981] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2243228.889640] wlan1: disassociated from e8:d3:eb:2f:64:c6 (Reason: 34)
[2243228.899035] cfg80211: Calling CRDA to update world regulatory domain
[2243228.899060] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2243228.902350] cfg80211: World regulatory domain updated:
[2243228.902352] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243228.902355] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2243228.902357] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243228.902359] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243228.902361] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243228.902363] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243228.902366] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2243228.902368] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243228.902370] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2243229.712523] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243229.730997] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243229.932027] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243230.136020] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243230.340045] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243230.516317] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243230.526021] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243230.728031] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243230.932036] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243231.136059] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243231.952416] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243231.971018] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243232.055628] wlan1: authenticated
[2243232.068020] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2243232.272051] wlan1: associate with e8:d3:eb:39:c4:e6 (try 2/3)
[2243232.476048] wlan1: associate with e8:d3:eb:39:c4:e6 (try 3/3)
[2243232.680012] wlan1: association with e8:d3:eb:39:c4:e6 timed out
[2243232.856407] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243232.866019] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243233.068054] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243233.272018] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243233.476041] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243234.292572] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243234.311020] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243234.512014] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243234.716032] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243234.920045] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243235.736694] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243235.755016] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243235.956052] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243236.160037] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243236.364026] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243236.540350] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243236.550011] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243236.562883] wlan1: authenticated
[2243236.576034] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2243236.780011] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2243236.984012] wlan1: associate with e8:d3:eb:2f:64:c6 (try 3/3)
[2243237.188040] wlan1: association with e8:d3:eb:2f:64:c6 timed out
[2243238.004544] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243238.021005] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243238.224039] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243238.428042] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243238.632016] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243238.808430] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243238.818016] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243239.020056] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243239.224056] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243239.428021] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243240.244350] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243240.263017] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243240.464023] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243240.668059] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243240.872026] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243241.048410] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243241.058021] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243241.260029] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243241.464031] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243241.668026] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243242.484445] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243242.503013] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243242.704044] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243242.908032] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243243.112046] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243243.932359] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243243.951028] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243244.152039] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243244.356032] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243244.560014] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243244.736465] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243244.766020] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243244.968051] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243245.172053] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243245.376012] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243666.728484] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243666.747113] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243666.753731] wlan1: authenticated
[2243666.764042] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2243666.781102] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2243666.781926] wlan1: associated
[2243666.782028] cfg80211: Calling CRDA for country: US
[2243666.785634] cfg80211: Regulatory domain changed to country: US
[2243666.785637] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243666.785639] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2243666.785642] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243666.785644] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243666.785646] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2243666.785648] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2243666.785650] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2276962.030140] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2276962.038535] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2276962.050767] wlan1: authenticated
[2276962.060010] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2276962.264035] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2276962.278521] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2276962.279442] wlan1: associated
[2277082.025929] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2277082.034555] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2277082.130057] wlan1: authenticated
[2277082.140032] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2277082.146672] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2277082.147349] wlan1: associated
[2283463.488046] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2283463.492113] cfg80211: Calling CRDA to update world regulatory domain
[2283463.495954] cfg80211: World regulatory domain updated:
[2283463.495957] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2283463.495959] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2283463.495961] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2283463.495970] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2283463.495972] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2283463.495974] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2283463.495976] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2283463.495979] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2283463.495981] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2283463.660426] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2283463.669975] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2283463.739725] wlan1: authenticated
[2283463.752058] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2283463.760728] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2283463.761351] wlan1: associated
[2283463.761500] cfg80211: Calling CRDA for country: US
[2283463.765042] cfg80211: Regulatory domain changed to country: US
[2283463.765045] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2283463.765047] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2283463.765049] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2283463.765051] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2283463.765053] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2283463.765056] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2283463.765058] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2292166.808039] hub 2-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[2292166.808045] usb 2-1: USB disconnect, device number 2
[2292167.056036] usb 2-1: new low-speed USB device number 4 using uhci_hcd
[2292167.233795] usb 2-1: New USB device found, idVendor=046d, idProduct=c31c
[2292167.233799] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2292167.233803] usb 2-1: Product: USB Keyboard
[2292167.233806] usb 2-1: Manufacturer: Logitech
[2292167.268286] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1:1.0/input/input8
[2292167.268402] generic-usb 0003:046D:C31C.0004: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1a.0-1/input0
[2292167.316857] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1:1.1/input/input9
[2292167.316980] generic-usb 0003:046D:C31C.0005: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1a.0-1/input1
[2292167.317036] hub 2-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[2292167.317039] usb 2-2: USB disconnect, device number 3
[2292167.564040] usb 2-2: new low-speed USB device number 5 using uhci_hcd
[2292167.739796] usb 2-2: New USB device found, idVendor=046d, idProduct=c00e
[2292167.739801] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2292167.739804] usb 2-2: Product: USB-PS/2 Optical Mouse
[2292167.739807] usb 2-2: Manufacturer: Logitech
[2292167.756223] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb2/2-2/2-2:1.0/input/input10
[2292167.756335] generic-usb 0003:046D:C00E.0006: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1a.0-2/input0
[2292177.616062] hub 2-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[2292177.616069] usb 2-2: USB disconnect, device number 5
[2292177.868024] usb 2-2: new low-speed USB device number 6 using uhci_hcd
[2292178.043801] usb 2-2: New USB device found, idVendor=046d, idProduct=c00e
[2292178.043806] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2292178.043809] usb 2-2: Product: USB-PS/2 Optical Mouse
[2292178.043812] usb 2-2: Manufacturer: Logitech
[2292178.060179] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb2/2-2/2-2:1.0/input/input11
[2292178.060300] generic-usb 0003:046D:C00E.0007: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1a.0-2/input0
[2292535.504059] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:2f:64:c6 after 500ms, disconnecting.
[2292535.516133] cfg80211: Calling CRDA to update world regulatory domain
[2292535.520167] cfg80211: World regulatory domain updated:
[2292535.520171] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2292535.520173] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2292535.520175] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2292535.520177] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2292535.520179] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2292535.520182] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2292535.520184] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2292535.520186] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2292535.520188] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2292536.316462] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2292536.334974] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2292536.421989] wlan1: authenticated
[2292536.432057] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2292536.441982] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2292536.442742] wlan1: associated
[2292536.442891] cfg80211: Calling CRDA for country: US
[2292536.446722] cfg80211: Regulatory domain changed to country: US
[2292536.446725] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2292536.446727] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2292536.446729] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2292536.446731] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2292536.446733] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2292536.446736] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2292536.446738] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2294362.025138] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2294362.033388] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2294362.113886] wlan1: authenticated
[2294362.124025] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2294362.134016] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2294362.134929] wlan1: associated
[2294482.024793] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2294482.033280] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2294482.120539] wlan1: authenticated
[2294482.132054] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2294482.142294] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2294482.143094] wlan1: associated
[2295442.025258] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2295442.033498] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2295442.120759] wlan1: authenticated
[2295442.132037] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2295442.147248] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2295442.148155] wlan1: associated
[2295562.024896] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2295562.033664] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2295562.106903] wlan1: authenticated
[2295562.120024] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2295562.130529] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2295562.131323] wlan1: associated
[2298126.504016] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2298126.516142] cfg80211: Calling CRDA to update world regulatory domain
[2298126.519741] cfg80211: World regulatory domain updated:
[2298126.519744] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298126.519746] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2298126.519749] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.519751] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.519753] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.519755] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.519757] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2298126.519760] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.519762] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2298126.688506] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2298126.698232] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2298126.783726] wlan1: authenticated
[2298126.796018] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2298126.807100] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2298126.807856] wlan1: associated
[2298126.808002] cfg80211: Calling CRDA for country: US
[2298126.811810] cfg80211: Regulatory domain changed to country: US
[2298126.811812] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298126.811815] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2298126.811817] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298126.811819] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298126.811821] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2298126.811823] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2298126.811825] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2298126.823720] wlan1: disassociated from e8:d3:eb:2f:64:c6 (Reason: 34)
[2298126.838282] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2298126.838826] cfg80211: Calling CRDA to update world regulatory domain
[2298126.842358] cfg80211: World regulatory domain updated:
[2298126.842361] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298126.842363] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2298126.842366] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.842368] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.842370] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.842372] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.842374] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2298126.842376] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.842378] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2298127.652513] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2298127.671233] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2298127.800727] wlan1: authenticated
[2298127.812034] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2298127.822984] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2298127.823480] wlan1: associated
[2298127.823635] cfg80211: Calling CRDA for country: US
[2298127.827434] cfg80211: Regulatory domain changed to country: US
[2298127.827437] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298127.827439] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2298127.827442] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298127.827444] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298127.827446] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2298127.827448] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2298127.827450] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2300375.492023] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2300375.496119] cfg80211: Calling CRDA to update world regulatory domain
[2300375.500114] cfg80211: World regulatory domain updated:
[2300375.500116] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2300375.500119] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2300375.500126] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2300375.500128] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2300375.500130] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2300375.500132] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2300375.500135] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2300375.500137] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2300375.500139] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2300375.668572] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2300375.697730] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2300375.711230] wlan1: authenticated
[2300375.724044] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2300375.749599] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2300375.750230] wlan1: associated
[2300375.750391] cfg80211: Calling CRDA for country: US
[2300375.754311] cfg80211: Regulatory domain changed to country: US
[2300375.754313] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2300375.754316] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2300375.754318] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2300375.754320] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2300375.754327] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2300375.754329] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2300375.754331] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2477025.492033] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:2f:64:c6 after 500ms, disconnecting.
[2477025.500139] cfg80211: Calling CRDA to update world regulatory domain
[2477025.504181] cfg80211: World regulatory domain updated:
[2477025.504184] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477025.504186] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2477025.504188] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477025.504196] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477025.504198] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477025.504200] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477025.504202] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2477025.504204] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477025.504206] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2477026.312456] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2477026.331087] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2477026.532009] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2477026.736018] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2477026.743074] wlan1: authenticated
[2477026.756033] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2477026.960030] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2477026.972458] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2477026.973080] wlan1: associated
[2477026.973250] cfg80211: Calling CRDA for country: US
[2477026.977150] cfg80211: Regulatory domain changed to country: US
[2477026.977152] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477026.977155] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2477026.977157] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477026.977159] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477026.977161] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2477026.977163] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2477026.977165] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2477030.488035] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:2f:64:c6 after 500ms, disconnecting.
[2477030.492166] cfg80211: Calling CRDA to update world regulatory domain
[2477030.495789] cfg80211: World regulatory domain updated:
[2477030.495792] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477030.495794] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2477030.495796] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477030.495818] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477030.495821] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477030.495823] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477030.495825] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2477030.495827] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477030.495829] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2477030.664501] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2477030.674081] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2477030.694699] wlan1: authenticated
[2477030.708044] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2477030.724964] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2477030.725566] wlan1: associated
[2477030.725718] cfg80211: Calling CRDA for country: US
[2477030.729670] cfg80211: Regulatory domain changed to country: US
[2477030.729673] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477030.729676] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2477030.729678] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477030.729680] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477030.729682] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2477030.729684] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2477030.729686] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[3340618.762095] RTAI[math]: unloaded.
[3340618.763300] SCHED releases registered named ALIEN PEDV$D
[3340618.766522] RTAI[malloc]: unloaded.
[3340618.864015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[3340618.865430] I-pipe: head domain RTAI unregistered.
[3340618.865462] RTAI[hal]: unmounted.
[3340619.885416] I-pipe: head domain RTAI registered.
[3340619.885420] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[3340619.885444] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[3340619.885447] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[3340619.885449] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[3340619.885452] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 20620750
[3340619.890832] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[3340619.890854] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[3340619.890857] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[3340619.890860] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[3340619.890862] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[3340619.894433] RTAI[math]: loaded.
[3340620.036236] config string '0x0378'
[3607191.444433] RTAI[math]: unloaded.
[3607191.445571] SCHED releases registered named ALIEN PEDV$D
[3607191.449526] RTAI[malloc]: unloaded.
[3607191.548017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[3607191.549457] I-pipe: head domain RTAI unregistered.
[3607191.549484] RTAI[hal]: unmounted.
[3607320.082119] I-pipe: head domain RTAI registered.
[3607320.082123] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[3607320.082145] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[3607320.082148] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[3607320.082151] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[3607320.082153] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 20743250
[3607320.089029] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[3607320.089059] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[3607320.089062] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[3607320.089065] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[3607320.089067] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[3607320.098444] RTAI[math]: loaded.
[3607320.140064] config string '0x0378'
[3934796.915873] RTAI[math]: unloaded.
[3934796.917014] SCHED releases registered named ALIEN PEDV$D
[3934796.920898] RTAI[malloc]: unloaded.
[3934797.020011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[3934797.021383] I-pipe: head domain RTAI unregistered.
[3934797.021411] RTAI[hal]: unmounted.
[3934805.583052] I-pipe: head domain RTAI registered.
[3934805.583056] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[3934805.583085] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[3934805.583088] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[3934805.583090] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[3934805.583093] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 18193500
[3934805.588909] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[3934805.588930] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[3934805.588933] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[3934805.588936] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[3934805.588938] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[3934805.595064] RTAI[math]: loaded.
[3934805.737646] config string '0x0378'
[4106504.834648] RTAI[math]: unloaded.
[4106504.835833] SCHED releases registered named ALIEN PEDV$D
[4106504.843438] RTAI[malloc]: unloaded.
[4106504.940013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4106504.941574] I-pipe: head domain RTAI unregistered.
[4106504.941605] RTAI[hal]: unmounted.
[4106514.290616] I-pipe: head domain RTAI registered.
[4106514.290620] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[4106514.290650] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[4106514.290652] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[4106514.290655] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[4106514.290657] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 15936000
[4106514.296464] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[4106514.296487] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[4106514.296490] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[4106514.296493] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[4106514.296495] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[4106514.300529] RTAI[math]: loaded.
[4106514.443270] config string '0x0378'
[4207596.220889] RTAI[math]: unloaded.
[4207596.222112] SCHED releases registered named ALIEN PEDV$D
[4207596.232358] RTAI[malloc]: unloaded.
[4207596.332013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4207596.333445] I-pipe: head domain RTAI unregistered.
[4207596.333472] RTAI[hal]: unmounted.
[4207613.565028] I-pipe: head domain RTAI registered.
[4207613.565033] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[4207613.565063] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[4207613.565065] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[4207613.565068] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[4207613.565070] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 20746250
[4207613.592805] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[4207613.592825] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[4207613.592829] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[4207613.592831] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[4207613.592833] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[4207613.602947] RTAI[math]: loaded.
[4207613.766267] config string '0x0378'
[4207650.424856] RTAI[math]: unloaded.
[4207650.425999] SCHED releases registered named ALIEN PEDV$D
[4207650.427956] RTAI[malloc]: unloaded.
[4207650.524014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4207650.525454] I-pipe: head domain RTAI unregistered.
[4207650.525482] RTAI[hal]: unmounted.
[4207673.837567] I-pipe: head domain RTAI registered.
[4207673.837571] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[4207673.837595] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[4207673.837598] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[4207673.837601] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[4207673.837603] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 64379500
[4207673.865463] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[4207673.865482] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[4207673.865486] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[4207673.865489] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[4207673.865491] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[4207673.871400] RTAI[math]: loaded.
[4207674.055558] config string '0x0378'
[4207753.585243] spurious APIC interrupt on CPU#1, should never happen.
[4207753.588077] RTAI[math]: unloaded.
[4207753.589387] SCHED releases registered named ALIEN PEDV$D
[4207753.598345] RTAI[malloc]: unloaded.
[4207753.696515] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4207753.698265] I-pipe: head domain RTAI unregistered.
[4207753.698292] RTAI[hal]: unmounted.
  • AdelRTP
  • AdelRTP
21 Jun 2025 19:21
Replied by AdelRTP on topic Modbus connection issue mesa 7i76eu pktUART
i have LINUXCNC - 2.9.4 the last version but where can i find man hm2_modbus, can you show me how to use hm2_modbus, mesambccc, give me examples please
I use mesambccc --help, it dos not exist
  • Hakan
  • Hakan
21 Jun 2025 18:48 - 21 Jun 2025 18:58
Replied by Hakan on topic EasyCAT Arduino shield
Category: EtherCAT
Yes it works! Awesome!
That -m flag made all the difference.
I took the XML file and generated an eeprom content with
siitool -m < esi.xml > eeprom.bin
wrote that to the eeprom with
ethercat sii_write -p 3 eeprom.bin
Made sure to reset the device and do a
ethercat rescan
And yes yes yes, it works. Thanks man. Will save me a lot of walking
between the workshop and the "office".
  • AdelRTP
  • AdelRTP
21 Jun 2025 18:42
  • endian
  • endian's Avatar
21 Jun 2025 18:27
Replied by endian on topic Experimental XML config generator
Category: EtherCAT
hi there...
This tool is basically my external memory device... I saved my experiences and knowledge to them because my brain has limits too ... Maybe you will try the TC3.. it is very powerfull enviroment with tons of usefull stuff
Have a try and let me know! :)
see U
  • PCW
  • PCW's Avatar
21 Jun 2025 18:03
hm2_modbus is an alternate modbus interface to Mesa FPGA cards with
PKTUART firmware. It supports additional features such as multiple devices
per interface, one time initialization code etc etc.
You need to have the latest LinuxCNC to have hm2_modbus
if
man hm2_modbus
Gives you a manual page, you have a late enough version of LinuxCNC
to use hm2_modbus.
hm2_modbus will work with your existing firmware.
  • ErrickW
  • ErrickW
21 Jun 2025 17:43
Replied by ErrickW on topic Lathe for Sale in Virginia
Category: User Exchange
FYI The lathe sold to a Company in North Carolina. We had it on our Auction site and it sold for $3K. Just another huge loss for our company. But when you are going belly-up it's just the way it is.
  • AdelRTP
  • AdelRTP
21 Jun 2025 16:58
I dont understand what is hm2_modbus new firmware ?
How to use it, what i should do ?
in mesa modbus i just find this
PktUART
MB2HAL
vfdmod
Classic Ladder
i want to use Classic ladder but i dont know how
Displaying 1126 - 1140 out of 25146 results.
Time to create page: 0.278 seconds
