  • langdons
  • langdons
12 Jun 2025 15:44
Replied by langdons on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Perhaps configuring LinuxCNC to invert the fault input will work?
For some reason, powering the enable input on some drives disables the drive (Ask how I know).
  • langdons
  • langdons
12 Jun 2025 15:40
Replied by langdons on topic ERROR DE SEGUIMIENTO
Which version of Ubuntu?
  • vre
  • vre
12 Jun 2025 15:06
Replied by vre on topic Chinese Servo Drive Calibration XP200
Have you set up this drive ?
Performs well ?
  • CNC_Tux
  • CNC_Tux
12 Jun 2025 14:52
Replied by CNC_Tux on topic XHC-WHB04B-6 Bug
XHC-WHB04B-6 Bug
Category: HAL
Hello Rod,
Tank you so much for your answer.
yes of course, i know .... i am 2 versions behind.
If you has fixed in the new version 2.10 ... its possible to get the source code of the driver of the XHC-WHB04B-6 ?
I think this is for me faster like a complete new installation and new configuration of the Machine.
Thank you so much.
Best regards
Reinhard
  • juliankoenig87
  • juliankoenig87
12 Jun 2025 14:03
Connecting a tool setter and touch probe at the same time
Its way more easy. You can connect two hardware inputs to the probe-input without having to choose the specific one. As long as you do not disconnect for example the 3d probe and having a active probe signal by that.
In this case you can have a workaround and setting the input of the 3d probe to a ignored one while not having a specific tool in the machine. So for example 3d Probe is tool 1 and tool 1 is not in the machine -> disable the hw input of the 3d probe.
  • Edi_48
  • Edi_48
12 Jun 2025 12:33
Replied by Edi_48 on topic 7i96s Erweiterung
7i96s Erweiterung
Category: Deutsch
Hallo wie sehe ist die 7i84u eine Serielle Karte , ich habe aber an meiner 7i96s schon ein Serielles Handrad (Talla83 , Simples Handrad).
Wie kann ich die 7i84u mit Anschliesen ?
  • meister
  • meister
12 Jun 2025 11:57
  • epineh
  • epineh
12 Jun 2025 11:48
Oh wait a minute, so you can have more than one extra FPGA? Alright then looks like I need to order some more Tang's.
  • tar_san
  • tar_san
12 Jun 2025 11:14
cia402_homecomp , Are there any config sample?  (Lichuan LC10E + Simple XYZ)
Category: EtherCAT
Hi, everyone.
I have a trouble getting LinuxCNC work about homing  with Lichuan LC10E Servo drive.
My LinuxCNC System can move XYZ GCode with CSP Mode.
But I could not use homeing function.
I believe I should use cia402_homecomp.
I tried configurate my ini, hal, xml to use cia402_homecomp manually, using LC10E-driver's homing function,  but I failed to work it so far.
I hope, I can find any configuration about this library as a example.
Are there any LinuxCNC configuration files about it ?
Thanks.
  • zmrdko
  • zmrdko's Avatar
12 Jun 2025 11:11
IO Questions around mixing IO between Ethercat and Pi 5?
Category: EtherCAT
i am sorry, it was some time ago. I believe that you can customize PDOs as you need.
  • unknown
  • unknown
12 Jun 2025 10:22 - 12 Jun 2025 10:24
Replied by unknown on topic WiFi Problem on Raspberry Pi
A grounded steel enclosure is not the best place to be emitting radio signals from.
Nowadays just about any wifi dongle will work, but it will need an external antennae.
Should a good starting point for usable wifi adapters, anything that works with Debian Bookworm will work.
github.com/morrownr/USB-WiFi
If you need extra help I'm located in Sydney as well.
  • Soccer Kid
  • Soccer Kid's Avatar
12 Jun 2025 09:35
Replied by Soccer Kid on topic Base Thread Over 100k
Currently, this GPU is quite out of stock. In China, the price is approximately $40.
  • mgeiss
  • mgeiss
12 Jun 2025 08:43
Can somebody please explain dcconf and watchdog in XML?
Category: EtherCAT
Hi all,
I'm just starting out with EtherCAT, and I'm trying to configure my Servo drives. Looking at some example configs, I often see dcconf and/or watchdog tags with varying parameters.
Would somebody be so kind to explain in simple words what those lines do? Are they mandatory or just for optimization? Where do I find the correct parameters for my drives (Hiwin ED1 400W)?
A link to a good documentation of those tags would probably also be fine, I didn't find good info yet...
Cheers,
Matthias
  • electrosteam
  • electrosteam
12 Jun 2025 08:41 - 12 Jun 2025 08:44
Replied by electrosteam on topic WiFi Problem on Raspberry Pi
Steel, 400 x 600 x 190.
See attached (poor) photo showing RPi hanging in space:
Row 1: stepper drivers,
Row 2: RPi stacked on Mesa, I/O PSU,
Row 3: 12 Vdc relays, Mesa core PSU,
Row 4: Terminals,
Side: stepper sockets, hole for monitor+keyboard+mouse cables, GPO for monitor + RPi.
Terminals and cables as appropriate, much neater generally.
I have a virtually identical cubicle with some electrical equipment in it.
Stripping and testing should begin next week.
The RPi 4GB and L2.9.2 need to go back to their day job of cutting metal.
John.
  • tar_san
  • tar_san
12 Jun 2025 08:07
Replied by tar_san on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
(SOLVED)
I compared V1.04 and V1.11 EEPROM Files.
And tried to understand configuration files.
I found my cnc configurations were mixed for V1.04 and V1.11.
Lichuan sales person said, we should use V1.11 with LinuxCNC for some reason.
Now servo lock is working by pressing PowerOn button.
Displaying 1636 - 1650 out of 25069 results.
Time to create page: 0.211 seconds
