  • NCPatrol
  • NCPatrol
25 Nov 2024 22:22
Replied by NCPatrol on topic Mesa
Mesa
Category: Driver Boards
Sounds easy. I don't know how to do any of that!
I don't think Pathpilot cares that it's a TH is the lights on the 7i92 indicate that it's trying to connect to the Tormach board when Pathpilot starts up - so it may just be steps 1 and 2.
  • smc.collins
  • smc.collins
25 Nov 2024 22:00 - 25 Nov 2024 22:01
Jones and shipley cylindrical grinder CNC conversion, grinding camshafts, cranks
I have a guy I know working on it. the rented solutions kinda suck. Most of the packages are aimed at very large scale operations. Mostly this will be used for protyping and R&D work on a small scale.
  • Thayloreing
  • Thayloreing
25 Nov 2024 21:45
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Sorry, I didn't understand the translation well, I don't speak English, in this case the remora doesn't support high pulse frequencies due to the limited hardware, does the ec 500 and ec300 have an input for high pulse frequency encoders? Or does it only allow you to make an extension module for the encoder? If so, what would this expansion module be like? Is there anything ready? and how would you add it? Sorry for the number of questions, I'm very interested in this project
  • PCW
  • PCW's Avatar
25 Nov 2024 21:41
Replied by PCW on topic Mesa
Mesa
There's probably a way to do this but is pretty hacky:
1. Write Tormach 1100 compatible firmware to the 7I92T
(should not be a big deal)
2. Disable the part of Tormachs startup script that updates the firmware
3. Change the 7I92t name to  7I92
(there's a utility to change Mesa Ethernet card names)
Now PathPilot will think you have a 7I92
  • NCPatrol
  • NCPatrol
25 Nov 2024 21:04
Mesa
I'm using a NUC so no PCI without a new build. Plus I've already purchased the 7i92th.....which may or may not matter if it won't be supported.
  • PCW
  • PCW's Avatar
25 Nov 2024 20:55
Mesa
Another possibility is a 6I25 (if you have a PCIE slot)
  • scotta
  • scotta's Avatar
25 Nov 2024 20:10
Hello all
I now have installed pyocd, but no luck with connecting. I guess it should show a target id here ?
xx@xxxxxx:~# pyocd list
# Probe/Board Unique ID Target
0 X893 ARM CMSIS-DAP 0001A0000000 n/a
Flashing fails then too:
xx@xxxxxx:~# pyocd flash /home/bf/Downloads/remora-rt1052-3.1.3.bin –-target mimxrt1050_quadspi
0000497 W Generic 'cortex_m' target type is selected by default; is this intentional? You will be able to debug most devices, but not program flash. To set the target type use the '--target' argument or 'target_override' option. Use 'pyocd list --targets' to see available targets types. [board]
0000674 I Loading /home/bf/Downloads/remora-rt1052-3.1.3.bin [load_cmd]
0000690 C No boot memory is defined for this device [__main__]
Anything wrong with the wiring ? I got 24v supplied to the remora board
schnellmued
The pyocd warning is hinting that the command line is not correct and it's defaulting the generic target type that cannot flash memory.
pyOCD/docs/target_support.md at main · pyocd/pyOCD
Is there a typo in the command line arguments?
  • NCPatrol
  • NCPatrol
25 Nov 2024 20:06
Mesa
I debated starting a new thread vs. bumping this 2 year old one, but this thread already covers what I'm looking for.
I have a Tormach PCNC with a missing control. I threw a new PC at it and installed Pathpilot. I read that a 7i92h was a direct swap...but then learned that it was also NLA so I ordered the 7i92TH that I assumed was direct replacement. I've since learned that that was a bad assumption.
Do you happen to know that status of Tormach supporting the "T" cards?
  • smc.collins
  • smc.collins
25 Nov 2024 20:00 - 25 Nov 2024 20:26
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
Category: Turning
I totally get the desire to stick with the existing tool changer. 1 thing you could make would be a gang holder, that would certainly give you more options.
  • scotta
  • scotta's Avatar
25 Nov 2024 19:59
Good morning guys, I bought my nvem v5 board to test with linuxcnc, I'm still waiting, I saw in the files that there is an encoder component to compile in linuxcnc to use in remora, this component was created to only accept the mpg encoder or is there a possibility of using the mpg input to connect an encoder to a spindle or the spindle shaft of a lathe, I don't know if it is possible to use just the mpg encoder input or there is a way to use other inputs if configured, could you give me more details of this part of the encoder on the nvem board? thank you in advance thank you very much
Hi, for the MPG the encoder counting is done in LinuxCNC using the normal inputs as the speed is low. The PRUencoder module is used for the hardware based encoder modules. The NVEM is limited on Inputs, but please check the EC500 configuration below with the NVEM configuration to identify which inputs are available for the QDC encoder module.
Remora-RT1052-cpp/LinuxCNC/ec500-rt1052-DMA-ENC.txt at main · scottalford75/Remora-RT1052-cpp
Remora-RT1052-cpp/LinuxCNC/nvem-rt1052.txt at main · scottalford75/Remora-RT1052-cpp
  • PCW
  • PCW's Avatar
25 Nov 2024 19:54
dynamic speed of spindle related to speed of x,y,xy axis speed via pwm
Sounds like maybe laser intensity setting?
Can you use motion-current-vel?
25 Nov 2024 19:46
Try searching for "adaptive feed", although a bit fuzzy on it, and not sure if you are looking for exactly that.
Is this for a lathe or mill?
I assume it is a mill since you mention XY but no Z.
25 Nov 2024 19:43
Replied by tommylight on topic Cant change from develop to stable
Category: QtPyVCP
Failing to build the kernel due to issues with the RealTek DKMS drivers:
Consult /var/lib/dkms/rtl8814au/4.3.21/
I would try removing the DKMS driver, install QtPyVCP then install the driver again.
  • COFHAL
  • COFHAL
25 Nov 2024 18:43
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
Here is an interesting discussion regarding IC AX58100 designed by Håkan BåstedtMetalMusings
github.com/MetalMusings/MyOwnEtherCATDev...uecomment-2474082363. With the kindly given instructions I have my board working and ready to run on LINUXCNC
  • schnellmued
  • schnellmued
25 Nov 2024 18:40
Replied by schnellmued on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello all
schnellmued
Displaying 17446 - 17460 out of 24059 results.
Time to create page: 3.921 seconds
