  • mjones@welfab.ca
  • mjones@welfab.ca
23 Nov 2024 22:54
Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
Category: Basic Configuration
oh, thats good to know, I will try that in the morning when I am at the shop.
Thanks.
  • phillc54
  • phillc54's Avatar
23 Nov 2024 22:43
Replied by phillc54 on topic Translation files for QtPlasmaC
Category: Plasmac
I have only edited the file in LINGUIST, do I need to do this step from howto?
If any text changes are made to the GUI then run the following to create a GUI python file:
$ pyuic5 ../qtplasmac.ui > qtplasmac.py
No, you only need to do that if there are any changes to the original English version so the changes can be added to the translation.
What is the file that you attached, there doesn't seem to be any translations in it.
Can you post the .qm and .ts files as a zip file.
  • PCW
  • PCW's Avatar
23 Nov 2024 22:43
if (when linuxCNC is running) you run
halcmd show all  | grep 7i77
You can get all 7I77 sserial pins and parameters
  • Stanislavz
  • Stanislavz
23 Nov 2024 22:38 - 23 Nov 2024 22:39
Replied by Stanislavz on topic LinuxCNC on Linux Mint Debian Edition 6
Category: Installing LinuxCNC
But setup is kind of strange. For same pc on debian from iso list, i needed to nohz=off and nomideset to get 22-25 delay.and isolcpus=1. Here only the latest one. With two other system is slugish and result is worse. And i have lpt on pcie card. I can see it, but it does not show error if any other adress is beeing used. Normally xe000 is shown in lspci.
Also on i have left speed step on in bios. If turned of - cpus is at 800 mhz all the time. Strange..
  • mjones@welfab.ca
  • mjones@welfab.ca
23 Nov 2024 22:16
HaHa Don't I feel stupid. I guess that's how my day has gone. It didn't even occur to me that [] meant put in your own value
Now to look even more stupid. How many channels does the 7i77 have, and how do I know what is on each channel. Is it a channel per drive or just i.o on one, drives on another, encoders on another and so on. until earlier today I didn't know there was more than 2 and I didn't really know they were channels of the card I just thought that was the address of the whole card.
I have alot to learn.
  • PCW
  • PCW's Avatar
23 Nov 2024 21:48 - 23 Nov 2024 21:49
[card_ip_address] = Mesa FPGA card IP address, so likely 192.168.1.121 or 10.10.10.10
If you don't get analog output, (and there is some non zero aout value),
its likely appropriate analog enable is not true.
Note that the 7I77 has a common enable for analog  channels 0..4 and
separate enable for channel 5.
23 Nov 2024 21:39
Replied by tommylight on topic LinuxCNC on Linux Mint Debian Edition 6
Thank you, i will add this to the original post in case anyone needs it.
  • pdmore
  • pdmore
23 Nov 2024 21:33
etch servo configuration was created by pdmore
Hello, my name is Daniel and I am from Argentina, can someone help me modify the configuration for etch servo via parallel port? I want to do some tests of its operation. Currently I have the HAL configuration in 1.1 mode but my h-bridge works pwm up, pwm down, I think I have to change to 2.2 mode but I don't know what else I have to modify.
Configuration attached.
Excuse my English, I use a translator.
Thank you
Greetings
  • scotta
  • scotta's Avatar
23 Nov 2024 21:25
Yes, that's the latest RT1052 based board. It's supported by Remora.
  • langdons
  • langdons
23 Nov 2024 20:40
Installing LinuxCNC on Ubuntu 24.04 LTS is not possible.
It gives a broken dependencies error due to apt being super picky about which version of Python is installed.
  • mjones@welfab.ca
  • mjones@welfab.ca
23 Nov 2024 20:30
that mesaflash didn't work, just said [card_ip_address] was a bad command or something like that.
I think I might have a problem with the drive.
If I go to hal signals everything shows it works, but there is no output. I put a meter on the analog pins but I don't get any voltage. Im thinking there should be some voltage there when it is outputting.
  • ProG
  • ProG
23 Nov 2024 20:06
Replied by ProG on topic Weiler 160 CNC Retrofit
Category: Show Your Stuff
Hi Klopp,
great project.
I have exactly the same lathe and the problem that the siemens control has an defect since today. Is it possible that you can share more details (electrical scheme, configuration files for mesa cards, ...) from your project so that it is possible for me to do the same.
  • Stanislavz
  • Stanislavz
23 Nov 2024 20:01
it fit :)
used packages from this thread : forum.linuxcnc.org/9-installing-linuxcnc...ng-rtai-debs-for-2-9
needed to add python 3.11 manually.
  • Sziggy_NC
  • Sziggy_NC
23 Nov 2024 19:31
Replied by Sziggy_NC on topic 7i97t Spindle has 0v or 10v
Thank you for the formula. I was able to verify that the mesa card is performing correctly.
I tried adding 49 ohms of resistance with no change in behavior. (No combo of my resistors quite matched up to 47.)
I will double check the manual of the drive to see what parameters might need changing.
Thank you.
  • gekonko
  • gekonko's Avatar
23 Nov 2024 19:22
Replied by gekonko on topic Translation files for QtPlasmaC
Category: Plasmac
Hello,
I would like to create translation files for Slovak, but I have been unsuccessfull so far.
This is my progress so far:
- I have Installed linuxcnc from image
- deinstalled the linuxcnc and installed as run in place
- I have configuration running with mesa 7i96s
- i was able to generate QM and TS files, and create links to compiled .qm files
- i have tryied to copy qm files directly to  /qtplasmac_4x3/languages/ /qtplasmac_9x16/languages/
- my version is QtPlasmaC v2.10-008.054
File Name: qtplasmac_sk.txt
File Size:163 KB
LANG=sk_SK.UTF-8
LANGUAGE=
LC_CTYPE="sk_SK.UTF-8"
LC_NUMERIC="sk_SK.UTF-8"
LC_TIME="sk_SK.UTF-8"
LC_COLLATE="sk_SK.UTF-8"
LC_MONETARY="sk_SK.UTF-8"
LC_MESSAGES="sk_SK.UTF-8"
LC_PAPER="sk_SK.UTF-8"
LC_NAME="sk_SK.UTF-8"
LC_ADDRESS="sk_SK.UTF-8"
LC_TELEPHONE="sk_SK.UTF-8"
LC_MEASUREMENT="sk_SK.UTF-8"
LC_IDENTIFICATION="sk_SK.UTF-8"
LC_ALL=
Is there any obvious problem with my workflow?
thank you for help.
Displaying 17551 - 17565 out of 24060 results.
Time to create page: 0.673 seconds
