  • Aciera
  • Aciera's Avatar
16 Nov 2024 14:54 - 16 Nov 2024 14:55
Replied by Aciera on topic Needing some video tutorials
Maybe these videos made by TheFeralEngineer help (There are multiple parts to each of these):
  • fabianpruitt
  • fabianpruitt
16 Nov 2024 13:36
Needing some video tutorials was created by fabianpruitt
Hi
I recently bought a cheap desktop CNC router as I couldn't afford a big one, and I need a decent video tutorial to show me how to setup the software and get Gcode as well as how to run jobs on the 3018 CNC machine via Linux.
Any one know of any videos that will get me up and running without going into the history of either Linux or the router?
Best regards
Fabian.
  • JT
  • JT's Avatar
16 Nov 2024 13:03
Replied by JT on topic Flex GUI 1.0.2 released
Category: Other User Interfaces
The current release is now 1.0.3 and all the tutorial videos are here .
Recently we have added examples of operations that use parameters set in the GUI similar to the old NGCGUI but better.
JT
  • Malteser01
  • Malteser01
16 Nov 2024 11:23
Replied by Malteser01 on topic Only one of the gantry joints move
Category: Basic Configuration
I was under the impression that kinstype=both only changes the behavior before homing. I will, however, try that later today.
  • Mecanix
  • Mecanix
16 Nov 2024 11:10
If I'd have to do it all over again I'd start with that incredibly simple yet super powerful starter kit. github.com/multigcs/rio-tangbob
So damn simple, and simplicity RULES. Not much can go wrong here.
  • Mecanix
  • Mecanix
16 Nov 2024 10:59
Hi, I'm not to familiar with the background of your issues (from a quick glance there's a hundred posts to decipher, it's overwhelming), but have you posted a concise and consolidated schematic, wiring installation and pictures of your entire set-up here or anywhere else?
Without that I highly doubt anyone (here at least) will be able to remotely assist. Although the noise issue you seem to be having has nothing to do with RIO let alone Linux CNC.
Ruling out RIO and Lcnc is easy, outputs can easily be probed while running a simple gcode program.
  • Gluca
  • Gluca
16 Nov 2024 10:16
Replied by Gluca on topic Remora rp2040 compile issues.
Hi all!
This issue was already known:
github.com/scottalford75/Remora-RP2040-W5500/issues/10
After: git clone github.com/scottalford75/Remora-RP2040-W5500
in pico_sdk_import.cmake, change GIT_TAG masteŗ to GIT_TAG 1.5.1 in lines 37 and 44
Than:
cd Remora-RP2040-W5500
mkdir build
cd build
export PICO_SDK_FETCH_FROM_GIT=TRUE
cmake -DPICO_BOARD=pico_w ..
cmake -DCMAKE_BUILD_TYPE=Debug . -DPICO_BOARD=pico
make clean
make
Now, the build process reaches its end with a functional firmware.
  • bruno84
  • bruno84
16 Nov 2024 09:07 - 16 Nov 2024 09:10
7i96s, 3 axis mill conversion, servo spindle, probe basic almost full function
Seems i have found a fix, for now. In my ham fisted attempt at merging a basic 3 axis Probe Basic configuration with a config containing a  step/dir driven servo for use as a spindle  I had left out the following... or at least a number of the following things
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
#addf pid.s.do-pid-calcs       servo-thread
addf spindle-pid.do-pid-calcs       servo-thread
setp [HMOT](CARD0).dpll.01.timer-us -50
setp [HMOT](CARD0).stepgen.timer-number 1
I have attached the quickly update HAL and will work on making it less of a mess and more readable before asking a couple more questions about the possibility of getting spindle orientation working. Have been working on the HAL tutorial and had halcmd up and running with the -kf parameter to show where all my signals are linking to, so will attempt to become more conversant in what is happening with the configuration i have chopped together Thanks
File Name: ProbeBasic...IXED.hal
File Size:15 KB
  • Grotius
  • Grotius's Avatar
16 Nov 2024 08:41
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
@Collins,
very nice, my only other bitch is that, encoder and position feedback are not interrupt driven but polled, this creates issues with positional accuracy at very high speeds and very high accuracy.
I don't really get the outcome of the problem. Is this related to a PID controller that's going wild using high speeds?
@Aleksam,
Yes, that's exactly how it should be.
You can setup multiple thread's attached to work with a certain memory region to create hal pins in.
Each thread can run on it's own assigned cpu.
Then when using a interpreter with multiple sub-interpreters, we can likely run this from userland.
Then the position command's of the interpreter's will be passed to a buffer to be executed by
motion components.
** Current status **
As the current status is testing real hardware with ethercat. No interpreter's are running yet.
Only a few realtime thread's are running over some hal pins, to test and verify all is working.
I realized that the original linuxcnc-ethercat source code is not able to parse the command: "$ ethercat xml" output.
This command gives a xml ethercat bus configuration or esi file output in the terminal.
You should expect that using this as configurator is the ultimate solution. This way could setup the hal pins automaticly for each slave.
As i am diving deeper into the etherlab's source code, we can ask for the slave list in c++ by scanning the network :
   // Scan network
        ec_slave_info_t slave_info;
        for (uint16_t slave_pos = 0;; slave_pos++) {
            if (ecrt_master_get_slave(master, slave_pos, &slave_info)) {
                break; // No more slaves
            printf("Slave %d: Name: %s, Vendor ID: 0x%08X, Product Code: 0x%08X\n",
                   slave_pos, slave_info.name, slave_info.vendor_id, slave_info.product_code);
Output:
Slave 0: Name: EK1100 EtherCAT Coupler (2A E-Bus), Vendor ID: 0x00000002, Product Code: 0x044C2C52
Slave 1: Name: EL2124 4K. Dig. Ausgang 5V, 20mA, Vendor ID: 0x00000002, Product Code: 0x084C3052
Slave 2: Name: EL2124 4K. Dig. Ausgang 5V, 20mA, Vendor ID: 0x00000002, Product Code: 0x084C3052
Slave 3: Name: EL2124 4K. Dig. Ausgang 5V, 20mA, Vendor ID: 0x00000002, Product Code: 0x084C3052
Slave 4: Name: EL1004 4K. Dig. Eingang 24V, 3ms, Vendor ID: 0x00000002, Product Code: 0x03EC3052
Slave 5: Name: EL2808 8K. Dig. Ausgang 24V, 0.5A, Vendor ID: 0x00000002, Product Code: 0x0AF83052
Slave 6: Name: EL2794 4K. Dig. Ausgang 24V AC/DC, 2A, kurzschlussfest, Vendor ID: 0x00000002, Product Code: 0x0AEA3052
Then there are more commands to use, to retrieve more info.
The idea is then to automaticly create the ethercat hal pin's  at runtime, conform the network scanning.
For example, this is a handmade setup file to setup the slave's, add hal pin's etc. It's a lot off work to do.
For new users this can be difficult task.
However it works fine and gives a complete overview how ethercat interact's with the outside world.
Will try to automate the ethercat configuration process for hal pins.
  • Dougal9887
  • Dougal9887
16 Nov 2024 06:34
Replied by Dougal9887 on topic Error when trying to open Gmoccapy confiuration.
Category: Gmoccapy
Does it follow that since any of the Gmoccapy sims open, that the problem does not lie with the kernel?
The problem, to the uninitiated, is what stepconf wizard produces.
  • dbtayl
  • dbtayl
16 Nov 2024 05:10 - 16 Nov 2024 15:17
Strange motion offsets in one direction on one axis
I'll try to make a better model tomorrow, but maybe the attached shows the gist of it better in cross section. The desired end result is a rectangular pocket. The result is as shown with the undercuts. The tops of both walls are in the right spots and of the correct thickness. The +Y wall is fine all the way down, the -Y wall is not. The end mill was a YG1 E5G98910 (3/8" diameter, 2-1/8" LBS, and 1/2" LOC, with a 0.345" shank, so it is possible for it to make some degree of undercut without rubbing). I'll see if I can measure how extreme the undercuts are tomorrow.
Cutting an internal pocket, climb cuts. The original material was a solid piece.
Possible multiple axes have errors, but I'm not seeing evidence of it. The one dimension in X I can measure is correct and shows no signs of misalignment between Z passes.
I agree this smells like a hardware issue- if so, it'll probably be a bear to track down. The motors are ClearPath servos, driven in quadrature mode. I believe the signals are 5V from the Mesa board, but would have to double check that. If there's some kind of encoder error, it's internal to the motor.
The cables are as provided from Teknic: motor -> cable -> soldered joint to circular connector -> connector -> soldered joint on other end of connector -> ferrule to 7i76E screw terminal. X and Y cables do run adjacent to one another (and power cables) for a few feet, and they're not shielded- though Teknic also sells 55' unshielded cables, so one might infer they don't believe it's important.
What's really hanging me up is that it seems to return to the correct place in +Y, despite apparently cutting incorrectly a variable amount in -Y.
Either way, I'll double check nothing is mechanically loose tomorrow (that would be the nicest answer) and put a scope on the Y axis signals while jogging X around, see what kind of cross-talk I get. I already got LinuxCNC 2.9.3 installed.
ETA: Mechanics appear fine- I can lean/pull on the Y axis and it'll move maybe 0.001", then springs back when I release it. Leadscrew retention nut appears tight.
Do let me know if things are still unclear.
  • bruno84
  • bruno84
16 Nov 2024 04:32
Hey guys. I wonder if someone could assist me in nutting a problem in my configuration. I know the layout of the config has more than one problem, and i plan to learn better how to fix this myself, however as long as i have the axis' dialled in and the servo spindle controlled through the software i am a-ok with not having spindle orientation and extras setup until I better understand the Hal configurations.
I have been running Probe Basic as a 3 axis stepper driven mill configuration, 3 homing switches for a year using the standard mill motor spindle and that has worked fine. I have just installed a Servo Motor to drive the spindle and now for some reason I am getting a joint following error when homing any axis.
I have had the servo spindle working in a test file, (both Axis and probe basic GUIs),but when combined together in the previously working Probe Basic config I have issues.
I have a feeling it might be something that is related to the post-gui file, as in an attempt to chase errors I was getting I have consolidated a not task that was conflicting, and I have reached to end of my limited knowledge.
I am working regularly to better understand the control flow within linuxcnc, but for now, if i was just able to get a minimal running configuration sorted I could at least use the machine whilst i gain that better knowledge.
Thanks very much,
Bruno
  • mBender
  • mBender
16 Nov 2024 04:19
I finally gave up. I have spend hours and hours trying to find out why my motor stall. I even contacted the manufacture of the drives and motors with no success. I replaced all wires,motors, drives, added ferrite cores,.... There is almost nothing I have not tested.
I am convinced it has nothing to do with the Rio software. But the tang vs parallel port makes the difference. The signal after the BOB comes out with less noise when I run it from the parallel port as when I have the tang connected. I don't know why and I don't know why my DM332T don't make an issue either way, but the Microkinetics does.
I will order a new drive, but that opens up a new can of worms and I may upgrade directly to servo drives...
  • Benb
  • Benb's Avatar
16 Nov 2024 02:38
Estop, external and internal with physical relay
Category: HAL
The attached control circuit will disable the spindle and servos of the machine if an Estop push button (PB) is pressed or change tool is requested. The arrangement is combination of both software and external hardwired circuit.
To stop any movement of the machine, the approach uses estop and reset pins of the halui component and redundant hardwired external circuit to disable any movement of the machine. The interface between the software and the hardwired circuit is done through digital I/O (2 or 3 inputs and two outputs).
Operation of this system is follows:
If an Estop PB is activated or tool change is requested machine will go into an Estop state.
  • If only Estop is activated, operator is required to press push button reset to enable spindle and servos
  • If tool change is requested, operator is required to change the tool, press tool changed PB (either hardwired or UI) and press reset PB to reset the estop and continue operation. (I know operators don’t like to press two buttons sequentially in certain order, but for their hands and fingers sake the extra mental challenge makes it worthwhile, I think!.
On the left side of the sheet is the electrical schematic. Showing use 5 relays. If you decide to use this circuit you need to determine the number of contacts normally open and normally closed before ordering the relays. The MCR contacts connection to servos and VFD are hardware dependent (if you need help with this part of the diagram ask)
On the right side is a postgui block diagram reflecting net listing of hal file see below.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
# Load realtime Components and their counts
loadrt and2         count= 2
loadrt flipflop     count= 1
loadrt or2          count= 1
# Add functions to threads
addf and2.0                   servo-thread
addf and2.1                   servo-thread
addf flipflop.0               servo-thread
addf or2.0                    servo-thread
# Connect Pins with Wires
#     signal/wire                 connected Pins
net estop.activate.sig     halui.estop.activate  and2.1.in1  flipflop.0.out
net estop.is-activated.sig halui.estop.is-activated  and2.0.in1  flipflop.0.reset  hm2-7i92.0.7i77.0.0.output-00
net estop.reset.sig        halui.estop.reset  and2.0.out
net external.reset         and2.0.in0  hm2-7i92.0.7i77.0.0.input-01
net external=estop         flipflop.0.set  hm2-7i92.0.7i77.0.0.input-00
net t.prepare.loop         iocontrol.0.tool-prepared  iocontrol.0.tool-prepare
net t.xch.done             hal_manualtoolchange.changed  iocontrol.0.tool-changed
net tool-changed           or2.0.in0
net tool-xch.request       hal_manualtoolchange.change  iocontrol.0.tool-change  hm2-7i92.0.7i77.0.0.output-01
net tool.changed           or2.0.out  and2.1.in0
net tool.changed.button    hal_manualtoolchange.change_button  and2.1.out
net tool.number            hal_manualtoolchange.number  iocontrol.0.tool-prep-number
net ui.tool.change.pb      or2.0.in1
  • HansU
  • HansU's Avatar
16 Nov 2024 00:14
Replied by HansU on topic Receiving GStat messages in GladeVCPs
Category: GladeVCP
Gcode properties are generated in Gremlin and then sent out using Gstat messages to whomever is connected in that GSTAT python instance context.
line change messages come from linuxcnc status, which is available in every GSTAT python instance.
So if your vcp has no gremlin then it gets no gcode properties message.
If I add a Gremlin object to the Glade file, then I get the G-code properties, nice. Thanks for that hint :)
I have a hunch that is why you get a 'file-changed' message on reload, but would have to test to confirm.
Chris
I am looking forward to your idea.. :)
Displaying 18016 - 18030 out of 24109 results.
Time to create page: 0.763 seconds
